Removed unused wake header file from Tegra board files
bug 980993
Change-Id: I61d919a2dc5b98caaca612b990fd1a7d06e76ae2
Signed-off-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-on: http://git-master/r/103622
Reviewed-by: Simone Willett <swillett@nvidia.com>
Gpio direction setting and freeing functions will do the needful now.
Bug 984440
Change-Id: I598cfbda4ac1d8fe7a61fe070abc92c5179807e9
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/104493
GVS: Gerrit_Virtual_Submit
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Enabling the sh532u driver feature to not register itself
if it does not identify the sh532u device during probe.
This is for the case where the platform does not populate
the device.
Bug 929133
Change-Id: Ic5ac7fa0ae4c05e4978fe7aebc3fc630ef1c2fd3
Signed-off-by: Erik Lilliebjerg <elilliebjerg@nvidia.com>
Reviewed-on: http://git-master/r/92340
Specify correct device names for ventana and cardhu speaker
and digital mic regulators.
Bug 956562
Signed-off-by: Preetham Chandru <pchandru@nvidia.com>
Change-Id: Iaa357b3da52dc9f593558b7f7e0ffda10ce8d938
Reviewed-on: http://git-master/r/91531
Reviewed-by: Kiran Adduri <kadduri@nvidia.com>
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-by: Allen Martin <amartin@nvidia.com>
Bug 925547
Change-Id: I81f87cef3a9767d9bd60b72e33a23620392ab5fc
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-on: http://git-master/r/89736
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Opt into the tps6586x registering the pm_power_off handler instead of
doing it ourselves.
Change-Id: I8363a3b4f5626bb45b2118559c3ab67e247e3172
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-on: http://git-master/r/83599
Bug 925547
Change-Id: Id4aaec9a847034ff16022123993433c9ce4754c3
Reviewed-on: http://git-master/r/76997
bug 871544
VDD_DDR_RX is a reference voltage used by the DDR/LPDDR IO cells.
If this supply is turned off and memory accesses are taking place
then the values read from the Memory may be corrupted.
(cherry picked from commit Id01d051ce02ed1d30484c42297624483f6561314)
Reviewed-on: http://git-master/r/50764
Change-Id: Ib4832f3a856b01411f626d5870ab2fc440eccdd1
Signed-off-by: Artiste Hsu <chhsu@nvidia.com>
Reviewed-on: http://git-master/r/72797
(cherry picked from commit c3e189bdefae5d4568b4a67fa48bb1c7b880c22a)
Reviewed-on: http://git-master/r/73958
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
Bug 865305
Change-Id: I4dc602d84e9a0037b8078ccacee59d78caa5dc2a
Reviewed-on: http://git-master/r/66118
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Rebase-Id: R6504de46ef65a4b5bb154d668a8e21d01fc438a5
Bug 882012
Bug 866726
Bug 896181
Bug 894789
Bug 861828
Bug 852480
Bug 872156
Change-Id: Ib87ca49d2b5c7e865571d79a37a5739e92d2cdf6
Reviewed-on: http://git-master/r/66055
Reviewed-by: Erik Lilliebjerg <elilliebjerg@nvidia.com>
Tested-by: Erik Lilliebjerg <elilliebjerg@nvidia.com>
Rebase-Id: Ra9d5d0c801460e62d74066e415f6a9459feb8967
Bug 862504
Change-Id: Iabae1c9528d5ffa2904a509f9e4010fc547be959
Reviewed-on: http://git-master/r/52943
Tested-by: Jin Qian <jqian@nvidia.com>
Reviewed-by: Jin Qian <jqian@nvidia.com>
Reviewed-by: Wen Yi <wyi@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Rebase-Id: R924a9542bcff40393bada5db36806abfda0e7165
Specify device names for ventana and cardhu speaker and digital mic
regulators. Also use same regulator name for ventana and cardhu
speaker supply.
Bug 872652
Change-Id: I5a254eee2037c86e208818f34cdff24aee0edad9
Signed-off-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-on: http://git-master/r/55668
Rebase-Id: R81411e5e595ec1d9e700d08410a9d3e49f24cbee
-Separate ac detection from battery driver
Bug 877456
Change-Id: I411ca707c58422075bdb27105bafc86a8de4e63e
Reviewed-on: http://git-master/r/54636
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Rebase-Id: R34bd7290f4c20c55bba8730b48fabe3fe0f566e1
http://nvbugs/876057
Change-Id: I54b6c584305d14fe198a6272b40bd1018050f4e9
Reviewed-on: http://git-master/r/52137
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Rebase-Id: Rf5a199586bdbbea2ba0a609c53b4d935a3eb1952
Change-Id: I156af0bdd8b37cb23aec214c3e158027252e27e1
Signed-off-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-on: http://git-master/r/51157
Rebase-Id: R795bf03590a76b6c494afd37603ed951dc2cd082
Currently Ventena reference design is using the wrong LC values in tps6586x,
we need reduce the slew rate of SMx in order to prevent voltage undershoot.
BUG 815933
Original-Change-Id: Ib44bd9a61769ef6c2af14174347181ce7426a5b3
Reviewed-on: http://git-master/r/40265
Rebase-Id: Rfe48ec428553eed008c70244d4872a9a1bd3e36c
Added the board level suspend/resume and call the console
suspend from board level suspend/resume.
bug 820536
Original-Change-Id: I246265241246dc0682870571c927bd23023e5aca
Reviewed-on: http://git-master/r/41448
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-by: Narendra Damahe <ndamahe@nvidia.com>
Rebase-Id: Re1f3dd4f75ee05456899d9a67f74ae84f9572654
Rebase-Id: Rcd2e8847135818a4a08515767cb6e050a6acd08e
Rebase-Id: Rc1fbe4548e4482dab61877b36a6a7921a8602b57
disabling ldo4 kills power to the board completely.
there is no way to power on the board again, other
than reinserting the power plug.
Reviewed-on: http://git-master/r/#change,34692
(cherry picked from commit a556670031234ea910561b4a0de75a5741f6b1b6)
Original-Change-Id: Id248811727cc7ca8f5ef2640f9a1d81a0217de05
Reviewed-on: http://git-master/r/35195
Rebase-Id: R8a2543048e33e74a83e9d9b58c43d7792d657bcc
camera needs LDO6 to be 1.8v always. the same was
done in the camera init code but was causing issues
because of recent changes in the regulator core.
fixing this issue by setting LDO6 to 1.8v at
during regulator init.
Bug 832292
Original-Change-Id: I185d83f5f31640d30c2c04acc28ccbb04f9f0557
Reviewed-on: http://git-master/r/34473
Reviewed-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-by: Abhinav Sinha <absinha@nvidia.com>
Rebase-Id: R32a9fd66a379b201edc689d80f926cc1ef3b2f4e
Ventana has external 20pF cap on RTC XTAL, set PMU
internal cap to minimum value.
Bug 798832, Tested on Ventana/wake via Alarm Clock
Original-Change-Id: I67495f7daddbb226c3b9c652d037fa05766b8276
Reviewed-on: http://git-master/r/22403
Rebase-Id: R0a764a3b15ee0fc84b333e2b0eb86fd5cfdcbd61
Original-Change-Id: Ifb9469d85096eedc0d872b8aac086facfdf7c843
Reviewed-on: http://git-master/r/24084
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Tested-by: Daniel Willemsen <dwillemsen@nvidia.com>
Reviewed-by: Jonathan Mayo <jmayo@nvidia.com>
Rebase-Id: R45875775e68c3280b234dae237aeb17f943701fa
vmmc regulator is used to power down the emmc
Bug 783535
Original-Change-Id: I104c87e25a91a9263e05af143906be0bc321da0e
Reviewed-on: http://git-master/r/23309
Rebase-Id: R05406c43662a27186857833fa52305ac62f9e5c0
Original-Change-Id: I77b3df9125208e687af02d321c1e3ff9b5c041ca
Reviewed-on: http://git-master/r/23057
Reviewed-by: Xin Xie <xxie@nvidia.com>
Tested-by: Xin Xie <xxie@nvidia.com>
Rebase-Id: Rc47774650bc007e8878110502a1c84375eae2925
Linux kernel has a standard way to handle this, which is to
call regulator_has_full_constraints(), which will make the
regulator core at late_init time disable any regulators that
don't have a reference count and are enabled in hardware.
Original-Change-Id: Ibd6d87be7ef0bf0218ab948806ddb1e7beffb251
Reviewed-on: http://git-master/r/21108
Rebase-Id: Rde87c3c4afa99f5d1df12204c3ce98b6e956874d
Enabling power down when device suspends for USB1 and USB3.
Also added the platform data structure which is used
when USB suspends.
Bug 770041
Original-Change-Id: I8bbe3ee90451a4a193c832bd384558747fe25036
Reviewed-on: http://git-master/r/20030
Rebase-Id: R4e63ff13e831b3a278b4f195e0ff67097f87630b
Original-Change-Id: Ic8e7d6bc016ceb0e9f96ee1639c925a83e0f1bce
Reviewed-on: http://git-master/r/17989
Rebase-Id: R353ca8c41a758d474d588b2c65fb1910401083f8
remove PC7 from the wake up sources list
bug 781489
Original-Change-Id: I92e2580192c1766fc913185d9f4e04aadf6e0993
Reviewed-on: http://git-master/r/16494
Rebase-Id: R1a55f9e3b6b125d9b203bba83f75fc0bc88e6afb
if we expose these regulators for the sdhc framework, then the regulators
are disabled when the sdhc framework suspends thus cutting off power to the
sd/mmc cards as well. for now the sdhc host driver does not have logic
to re-enumerate the sd/mmc cards, due to which these cards are not
re-detected by the system.
bug 779343
Original-Change-Id: If7681af0ea4bb5b1e0481267bff934690c1788f7
Reviewed-on: http://git-master/r/16525
Rebase-Id: R532985ade2de14c908b588524dc505eb23ca6470
Should save ~12mW at init.
bug 773330
Original-Change-Id: Icd2bec9ff8dae1d1c13e9ebb7af589332c71a624
Reviewed-on: http://git-master/r/14216
Rebase-Id: Rc6ba869bc92daa622f4911266a2915b93ae9e305
based off Ic3aa58f7794c24042fafe0b5d3915875bda7447a
Original-Change-Id: Ied7c9b739a8bcfe6bc1917363e4e8557244b2bb6
Reviewed-on: http://git-master/r/15122
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Rebase-Id: R47f8619b460445b48a765081acaf1dad88cf59c1
vdd_lvds supply is not directly derived from pmu in ventana and hence correction
Original-Change-Id: Idf925ec9b6ff6aeeddfd590f3bd8ff42147727bb
Reviewed-on: http://git-master/r/14138
Tested-by: Narendra Damahe <ndamahe@nvidia.com>
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Rebase-Id: R38c9d56298a154495646a590808cd5e60cdd10f4
Bug 745149
Original-Change-Id: I1907f9e3da8389b4fc51cd6270a4e66105d30978
Reviewed-on: http://git-master/r/13835
Rebase-Id: R48e14e6b8b8d0b502ac75097a55d30af86bab42b
Original-Change-Id: I645b5f64f3b8148cb054f5da4890e5ee940a96e6
Reviewed-on: http://git-master/r/13754
Rebase-Id: R97808e7489e1269d98ed8fcaf0919bd544797c09
Bug 749251
Original-Change-Id: I95db2d0327f4425de40e64b4ea70c0c76f908ab9
Reviewed-on: http://git-master/r/12465
Rebase-Id: R93eae47b9e270c19d4cc1adf164330ceb114b0c5
Making default suspend mode as LP0 and adding platform data
for LP0.
For non-A03 ventana systems making LP1 as default suspend mode.
Original-Change-Id: If9d6c3c1b2a421bb257baa282183c74b0a03ab98
Reviewed-on: http://git-master/r/12079
Rebase-Id: R2efdc05bd47ec7671c33d4bf225f469a6ba5e5db
vdd_aon (vdd_rtc) supply powers the RTC domain. It is required that vdd_aon
should follow vdd_core which is changed by dvfs. This supply enables dvfs to
effectively manage vdd_aon, vdd_core and vdd_cpu.
Original-Change-Id: I54e06d38ae1cd8ed96923cb3b3ffb4370f7db848
Reviewed-on: http://git-master/r/12282
Tested-by: Nitin Kumbhar <nkumbhar@nvidia.com>
Rebase-Id: R8835002cd07968d5bee2afb0b485c9647398451d
-board-ventana-pinmux.c: change following pin groups
to TEGRA_PUPD_NORMAL and TEGRA_TRI_NORMAL
TEGRA_PINGROUP_CSUS,
TEGRA_PINGROUP_DTE and
TEGRA_PINGROUP_GPV
-board-ventana-power.c: tegra_camera is connected to
regulator LDO6 (vcsi) and it should be max 1800mv
-board-ventana.c: add platform device tegra_camera
Original-Change-Id: Ie83a9a34d72ba584673634dccf72c6cc0f25c74c
Reviewed-on: http://git-master/r/11336
Rebase-Id: R92b15f626cb274d3a7b0d5bf8a49afbfc85f8a7e
pda-power is only needed on pdas and phones.
Change-Id: I46a668cc0ee3f4b23c63de48251591cf4a8f99e8
Change-Id: If5e07b2eb62805a00426799184989fa290318f4a
Signed-off-by: Gary King <gking@nvidia.com>
configure the PMC interrupt polarity low, and register IRQ
numbers with the TPS6586X core and RTC
Change-Id: Iba08704bd1355ed00af3d9132118ce095c5118fe
Change-Id: I1c851ab4982764b7f72d968d665d0c898fae25aa
update the suspend platform data for ventana to match recent changes
Change-Id: I142123027453ee34f80c094fb7cf1fcb464e889d
add support for system suspend to ventana; currently LP1 (DRAM in
self-refresh, CPU power-gated, core power active) is used.
Change-Id: Idb223a7da94c3b87ea61e0eef1de77206c4171e4
register I2C controllers, regulator consumers and the panjit
touchscreen platform_device
Change-Id: Ife13c0d86084f26c734dea2c358f8c4fd3e27a8e
