Since there is no PMC available in tegra2
we will not be able to get any remote wakeup events. Hence do not
power of the phy during usb suspend.
Bug 1166740
Change-Id: I882066a283af2e574b111da3472eb3f8f8a9d6eb
Signed-off-by: Preetham Chandru R <pchandru@nvidia.com>
Reviewed-on: http://git-master/r/160593
Reviewed-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
GVS: Gerrit_Virtual_Submit
Enable device tree support for ventana by adding board
compatible table.
Bug 1001225
Change-Id: I3f20c1a7966aff1a8a5fbfc1a7ccf2790419be70
Signed-off-by: Nitin Kumbhar <nkumbhar@nvidia.com>
Reviewed-on: http://git-master/r/110203
Reviewed-by: Simone Willett <swillett@nvidia.com>
The gpio mode of pin is configured when setting
direction and hence this call is no more required.
Change-Id: I870c361cfcfff949620c0518afb324faeb5879d3
Reviewed-on: http://git-master/r/119609
Add configurability support for i2s parameters accross all board.
ARM: tegra: board: add i2s params
files.
Signed-off-by: Ankit Gupta <ankitgupta@nvidia.com>
Change-Id: If58788b5126280b7e1dc8c66e9c96d0e71229b5e
Reviewed-on: http://git-master/r/111476
(cherry-picked from commit cac52867b0a0cad3b3c5bf46f08b0b94d0be2e02)
ARM: tegra: include: add configurability support for i2s params.
Add several variables for i2s configuration in platform data
structure.
Change-Id: Iea3930f308954471f170513234c2c02a8559ef98
Reviewed-on: http://git-master/r/111473
(cherry picked from commit 35e749770f6046fc82860f1152db2f5f579b9508)
Reviewed-on: http://git-master/r/118071
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-by: Scott Peterson <speterson@nvidia.com>
rfkill-gpio driver is available in linux delivery as a generic rfkill driver.
use rfkill-gpio driver to perform bluetooth RFKILL gpio activities, instead of
bcm4329 rfkill driver.
Bug 993990
Signed-off-by: Nagarjuna Kristam <nkristam@nvidia.com>
Change-Id: I654b93f099431029177913605d15ad921df07833
Reviewed-on: http://git-master/r/108499
Removed unused wake header file from Tegra board files
bug 980993
Change-Id: I61d919a2dc5b98caaca612b990fd1a7d06e76ae2
Signed-off-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-on: http://git-master/r/103622
Gpio direction setting and freeing functions will do the needful now.
Bug 984440
Change-Id: I598cfbda4ac1d8fe7a61fe070abc92c5179807e9
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/104493
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Modify USB structures of platform data. Based on the new
platform data structures modifying the initialization in
board files.
Bug 887361
Change-Id: Ie6347a078c9a596a4debe21a353e127ddde35220
Signed-off-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-on: http://git-master/r/103597
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Bug 949759
Reduce DDC freq. The original freq is 100KHz, but some edid communication
at this rate on some monitors like acer H243HX may fail
Change-Id: Ib087025a35ff085b4bf618b70100fe6670c3eaec
Signed-off-by: Hao Tang <htang@nvidia.com>
Reviewed-on: http://git-master/r/88261
Opt into the tps6586x registering the pm_power_off handler instead of
doing it ourselves.
Change-Id: I8363a3b4f5626bb45b2118559c3ab67e247e3172
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-on: http://git-master/r/83599
Reviewed-on: http://git-master/r/75209
Change-Id: I4c90973c808bb9f21a01d6d30fd1bfe915728439
Signed-off-by: Joshua Cha <joshuac@nvidia.com>
Reviewed-on: http://git-master/r/77747
remove CONFIG_USB_HOTPLUG and add default_enable into tegra_ehci_platform_data
We can't use different def_config because whistler & ventana source code
is merged in same tree.
BUG 923705
Change-Id: I3dfdf237d80865831264f02104c89c8088101905
Reviewed-on: http://git-master/r/74574
Signed-off-by: Kurt Yi <kyi@nvidia.com>
Reviewed-on: http://git-master/r/75888
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
-move sensors defines to board header file.
-add defines for pca954x i2c mux instead of using direct i2c
bus number.
-cleanup board-ventana.h.
Bug 925547
Change-Id: I76a42b66f3a3fa0adbc8c06b2edb9fd006c7ae44
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-on: http://git-master/r/75689
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Added 1MB extra memory for the first FB device, required for double buffering.
Bug 898400
Change-Id: I92245fdb2e7a1d71888fc0831f052017608b975a
Signed-off-by: Shashank Sharma (shashanks@nvidia.com)
Signed-off-by: Jong Kim <jongk@nvidia.com>
Reviewed-on: http://git-master/r/69838
Reviewed-on: http://git-master/r/70946
Tested-by: Shashank Sharma <shashanks@nvidia.com>
Reviewed-by: Allen Martin <amartin@nvidia.com>
Updated i2c platform data to add i2c arb lost recovery funtion
and corresponding gpio numbers to i2c pins
This is cherry pick of change http://git-master/r/#change,47290
Change-Id: I4098a512625c16598b8596d0e46d285ca9b92d2b
Signed-off-by: Shridhar Rasal <srasal@nvidia.com>
Reviewed-on: http://git-master/r/69717
Reviewed-by: Vandana Salve <vsalve@nvidia.com>
Reviewed-by: Alok Chauhan <alokc@nvidia.com>
Modifies the bluesleep and rfkill platform driver registration to be more concise
and mirror the style of other similar code.
Change-Id: If5100248d0fe9cf00c1b78acbc72e3f45d173fa9
Signed-off-by: Matt Wagner <mwagner@nvidia.com>
Reviewed-on: http://git-master/r/64601
Rebase-Id: R0ec1bc987d0286bfdff3a5db5ccd142050a38872
Change-Id: I9d08c86aa406fd8b5c41f374ad4168f3685409f4
Reviewed-on: http://git-master/r/66280
Rebase-Id: Rceacdad26018405ebf53cf3b48dcd7b52f319d5b
correctly configuring the GPIOs used by bluesleep driver.
Bug 791669, 773186
Original-Change-Id: If81c3dbf2e2e36f00033ff8a93bd693050d9d057
Reviewed-on: http://git-master/r/20526
Reviewed-by: Anantha Idapalapati <aidapalapati@nvidia.com>
Tested-by: Anantha Idapalapati <aidapalapati@nvidia.com>
Reviewed-by: Rakesh Kumar <krakesh@nvidia.com>
Rebase-Id: R5242bd9fc0660bac5376705b4212da69b574f8fb
Based on CONFIG_BT_BLUESLEEP configuration variable, a bluesleep device
will be created and used to actively manage the BT device power.
Bug 791669, 773186
(cherry picked from commit 011a705248274804c80c12af5366693e6662829b)
Reviewed-on: http://git-master/r/6851
Original-Change-Id: If5275ecfc920a038ec96928ea7f7f739f5051e33
(cherry picked from commit ae1bf987d38b15d6688cd2152ee4b4624211c113)
Reviewed-on: http://git-master/r/19868
Rebase-Id: R5e8a80983a7d22f608176224ca4d8295b96fa931
arch/arm/mach-tegra/Kconfig
arch/arm/mach-tegra/board-ventana.c
drivers/misc/Kconfig
drivers/video/tegra/dc/hdmi.c
OTG host register/unregister functions were duplicated identically
across all board files, making the code difficult to maintain (and
actually some boards did not get all some code fixes leading to the same
bug being met again and again). This patch moves this common code into
tegra-otg.c.
Bug 884315
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
Change-Id: I99b118664f0481f6c5470411b43f36609e0feb52
Reviewed-on: http://git-master/r/61763
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
Rebase-Id: R0f6060514c017946cc9ae2ba2f04a1c134d14d9b
Enable i2s2 and bluetooth dit device for ventana and whistler platforms.
Also add i2s2 clock in clock table. It is needed to support BT SCO
playback/record on Tegra20.
Bug 872652
Signed-off-by: Sumit Bhattacharya <sumitb@nvidia.com>
Change-Id: I61f1f26cb502570ec5348137bbe0ac62e6c1f9e6
Reviewed-on: http://git-master/r/61504
Rebase-Id: R424e4d712a1dd5f3647d2183c94138ef38e2ba4a
These initcalls weren't ensuring that they're actually running on the
board they care about, which breaks on a multi-board kernel.
Change-Id: Ifd8a3e523c2523b68ec4d7e30c2b87969b939931
Reviewed-on: http://git-master/r/60010
Rebase-Id: R2a4547ecd3b25da494799af15e42df89700b9fde
Hotplug on usb is supported when hotplug flag is set in platform data
Bug 869745
(cherry picked from commit I57ba0b18a2d4232b2df2074c91aff97c6e639e7d)
Reviewed-on: http://git-master/r/54588
Change-Id: I24e5ddf49cead14d3eebe30da0f92402015c95c7
Reviewed-on: http://git-master/r/57725
Tested-by: Artiste Hsu <chhsu@nvidia.com>
Rebase-Id: Rdf4296a0b0e04733832b8b60b347a3da9cc67413
On cardhu and ventana WM8903 GPIO1 is used for digital mic lrclk
output and GPIO2 is used for digital mic data input. Pass corresponding
WM8903 gpio configuration through platform data to enable cardhu and
ventana digital mic support.
Bug 872652
Change-Id: I410265f1b4f9a8c5e43e5437ed6bac4122709178
Reviewed-on: http://git-master/r/55654
Rebase-Id: Rb47b7afe17013d4a0d5d73a15ba19c12dab0efbf
-Separate ac detection from battery driver
Bug 877456
Change-Id: I411ca707c58422075bdb27105bafc86a8de4e63e
Reviewed-on: http://git-master/r/54636
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Rebase-Id: R34bd7290f4c20c55bba8730b48fabe3fe0f566e1
On Ventana, Keys are handled through the GPIO driver. So CONFIG_KEYBOARD_TEGRA
should not be defined
On LDK, kernel defconfig of Harmony is shared with Ventana(to move towards
SingleBinary for multiple tegra boards). Since on Harmony we have
to support the matrix keyboard through KBC, we have enabled the KBC driver by
defining CONFIG_KEYBOARD_TEGRA which reflects in Ventana also.
This situation leads to an spurious interrupt from KBC as soon as system
enters into the LP0 state.
To avoid the early exit from LP0, we are removing the KBC device registration
on board_ventana.c
Bug 869778
Reviewed-on: http://git-master/r/52049
(cherry picked from commit 68f4c9bbf9b533fd44215d26b3d0acf11865a819)
Change-Id: I8fe42bbe5d5bd41dd1737bca9af9e35611443f40
Reviewed-on: http://git-master/r/54422
Rebase-Id: Ra71aa54f1b8d7f8d30ca45c36e2b8d130969b62e
Modified the usb registration order, otg is the first to be registered.
Bug 835678
Reviewed-on: http://git-master/r/39505
(cherry picked from commit 4f43316f3cbe55dc75e67002bfff37dcbba4178e)
Change-Id: I8b39b280995fc3185569746bfdbd328fa2282975
Reviewed-on: http://git-master/r/54893
Tested-by: Rakesh Bodla <rbodla@nvidia.com>
Rebase-Id: R5e668cb4f262058fb910c284aa1ab029eb1cd4cd
Enabling the XCVR setup for USB using USB calibration
fuses.
Bug 867817
Reviewed-on: http://git-master/r/51575
(cherry picked from commit 5c9d3b4c06bd22e1d6aae31c0fbe67fc5f7e1902)
Change-Id: If74435b8d9db7eb7a60d5c27f6b6e23cae890fb6
Reviewed-on: http://git-master/r/54652
Rebase-Id: R640f690ad3a38c20888c34009bda495fbb5ba755
Change-Id: I5e66e920d2132a9bcc101f14026a6b686b59a002
Reviewed-on: http://git-master/r/54052
Rebase-Id: Rdbf71e85a3242a95c74b64976ce41593b9835fe0
Bug 872652
Change-Id: I7b948b820434721511c008f644b69d93c23865e1
Reviewed-on: http://git-master/r/53094
Tested-by: Sumit Bhattacharya <sumitb@nvidia.com>
Rebase-Id: R3fb55fe060065d76fb18010ad249e6ee0f96a944
Change-Id: I156af0bdd8b37cb23aec214c3e158027252e27e1
Signed-off-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-on: http://git-master/r/51157
Rebase-Id: R795bf03590a76b6c494afd37603ed951dc2cd082
Bug 868608
Bug 862023
Change-Id: I0f902098fc9cabd9d8c4962cf73c758df99a3199
Reviewed-on: http://git-master/r/49459
Rebase-Id: Rea8335719e3f20cdb645d22c19da3d61d52d4eaf
Added the board level suspend/resume and call the console
suspend from board level suspend/resume.
bug 820536
Original-Change-Id: I246265241246dc0682870571c927bd23023e5aca
Reviewed-on: http://git-master/r/41448
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-by: Narendra Damahe <ndamahe@nvidia.com>
Rebase-Id: Re1f3dd4f75ee05456899d9a67f74ae84f9572654
Adding board specific suspend and resume call apis through platform
data.
Added call of these function at appropriate stage of suspend/resume.
Added mechanism to select the uart debug channel base address through
variable so that board file can directly change this.
bug 820536
bug 832273
Original-Change-Id: Ia9ff3b8a8d2faa1071a8ff634960e6a6c8a43d40
Reviewed-on: http://git-master/r/34494
Rebase-Id: R6d7bfb3f8f9152779f5138cbcd1b7a9e9a9545df
set usb2 phy type to TEGRA_USB_PHY_TYPE_LINK_ULPI
bug 845612
(cherry picked from commit 85a08621c371254cc786afae9def58adad63fe63)
(reviewed on http://git-master/r/39603)
Original-Change-Id: I5ac253652d7a1f19b1c2cf4b031324e0b2cdd64e
Reviewed-on: http://git-master/r/40350
Tested-by: Ken Chang <kenc@nvidia.com>
Reviewed-by: ChihJen Hsu <chhsu@nvidia.com>
Rebase-Id: Rf33bdc08ba3d0278e94b866509b61efe69e5ae05
- The issue is due to the corruption of bootloader fb during kernel
initialization. This change reserves the bootloader fb and then
frees it until bootloader fb is copied to fb for Cardhu, Ventana,
Whistler, Enterprise and Aruba.
- Change color depth of Cardhu and Harmony to 32-bit.
Bug 828271
Bug 832016
Original-Change-Id: I05ef5930ee68dcbd672a5cb59b4568a2c88a2e55
Reviewed-on: http://git-master/r/34966
Rebase-Id: Rb3c9280ea4643ccee661d37d24fb540319470bf7
Using the debug port device structure to enabling/configuring the
uart debug console port.
Removing the duplicate local definition of the uart console.
Original-Change-Id: Icbf954e0d02dcc4891169b3c701c72f35f8f29e3
Reviewed-on: http://git-master/r/35711
Rebase-Id: R74bd3a179a7ef7327397805f21389f08ac3bceb1
connect wakeup_key method to KEY_POWER (TEGRA_WAKE_GPIO_PV2)
Change-Id: I13b8f503399989bb06e97343711ed9e7348839ac
Reviewed-on: http://git-master/r/47364
Tested-by: Cho-Che Cheng <jacheng@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Chih-Lung Huang <lhuang@nvidia.com>
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Rebase-Id: Rffb10919b9cfa49c975f37d12646a34aeee44375
Rebase-Id: Rcd2e8847135818a4a08515767cb6e050a6acd08e
Rebase-Id: Rf7adaaf2eaa1a12e8686e2518a2a2ccfb56df5c9
Rebase-Id: Rc1fbe4548e4482dab61877b36a6a7921a8602b57
Revise some default settings for utimp phy
Bug 815848
Reviewed-on: http://git-master/r/30257
(cherry picked from commit 5f2b525a73dd48435975ef72937d1b8627e1c917)
Change-Id: I403746d85a3ef32d05bec5867b407f41e1f614e4
Reviewed-on: http://git-master/r/30568
Rebase-Id: R604781894e13c3c82b8e6dec0b20bc24f78ea080
Set the platform data for the USB1 host mode to NULL during the unregister.
After freeing up the platform data pointer.
Bug 820333
(cherry picked from commit 3d416101e629b50c9060e3daed7ab1281a465de5)
Original-Change-Id: I432a7315ed3a2ff3c1d8d961f6f1e981451b22fe
Reviewed-on: http://git-master/r/34459
Reviewed-by: Suresh Mangipudi <smangipudi@nvidia.com>
Tested-by: Suresh Mangipudi <smangipudi@nvidia.com>
Reviewed-by: Hanumanth Venkateswa Moganty <vmoganty@nvidia.com>
Rebase-Id: R5275958f08715d65d117bf5c687898498f8b166b
Per the 8.4.1 section of HDMI spec version 1.4a, 100KHz is the maximum
clock rate of DDC i2c bus.
Bug 820552
Original-Change-Id: I7990309c4f3485c9c356623468cfabe25d733604
Signed-off-by: Haley Teng <hteng@nvidia.com>
Reviewed-on: http://git-master/r/29966
Rebase-Id: Rb653b99d7f392767c04e910077c132e2f52b867d
Original-Change-Id: I1cc3005f179fbb4de44c991c026b73ef1cbd9897
Rebase-Id: R8da265e6645f80c2d7f0211d999b71a241ba0fbc
Using proper usb phy types instead of hard coded usb instance.
Bug 800301
Original-Change-Id: I24a66ce062b937a947ac6cb34e829d6b42ecf0b4
Reviewed-on: http://git-master/r/24371
Reviewed-by: Niket Sirsi <nsirsi@nvidia.com>
Tested-by: Niket Sirsi <nsirsi@nvidia.com>
Original-Change-Id: I5a4bd4d25ec8d4d4335f17d0794c4440a470a099
Rebase-Id: Re744ad52caf6c5814295a6712b7e17022e31d5e5
Set proper phy type for each of the USB host instances.
Original-Change-Id: Ic02e2bdddf77c9118c312d2d9aeb607721e7769b
Reviewed-on: http://git-master/r/19568
Original-Change-Id: Ida37a16bdb214dc3263dc653013aa71db86fd161
Rebase-Id: R65125c99bd3d92914d0083882bf5bd4d757fd9ab
Assign 0xFC as i2c slave address for all new i2c slaves
BUG 788286
Reviewed-on: http://git-master/r/25101
(cherry picked from commit 32390e01c72732272c933883d0921a80d369c82f)
Original-Change-Id: Id1d19c7b03ff5ce6b4150f2a84ce2885e8edb44c
Reviewed-on: http://git-master/r/25224
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Rebase-Id: Re3223392d37740e802da731d722c4525cc6cc90a
enable debug_uart port as highspeed(ttyHS*) or lowspeed(ttyS*)
according to kernel parameter debug_uartport.
Bug 778978
Original-Change-Id: Icb56357f62ad8375933fb0fe5032b42a59346d79
Reviewed-on: http://git-master/r/24519
Tested-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Rebase-Id: Rfc20ac1e2328ef462ca145a630939376a710930f
