Repeat key events reported to android causes keys (e.g power key) to be
treated differently. Disable EV_REP on android platforms for now.
BUG 918758
Change-Id: I62a7c495303a906ef72738465ce5101d244e725d
Signed-off-by: Nitin Kumbhar <nkumbhar@nvidia.com>
Reviewed-on: http://git-master/r/72953
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Configuring the kbc pins such that the row/column is configured
in their respective GPIO number.
bug 804531
Reviewed-on: http://git-master/r/64033
(cherry picked from commit ec1c562461090170ce9515147954185c9a5bda44)
Change-Id: I5242bee91e767151022071022f195f0f1ca7bea2
Change-Id: I3cb02c81b88db4284337177355caaea77ef48e12
Reviewed-on: http://git-master/r/65134
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: R2867df551e1c8d81fe4a7cd0034aeed9439f1e09
Set pin configuration information for required rows and columns.
Enable only required ROW and COL gpio.
bug 889620
Change-Id: I4965fc8db89ccc79c12e4295b9afdef635e6c909
Reviewed-on: http://git-master/r/59155
Reviewed-by: Shridhar Rasal <srasal@nvidia.com>
Tested-by: Shridhar Rasal <srasal@nvidia.com>
Rebase-Id: Rd658f960ea9f0b4e79bc99b0c4f159f030f65320
Change-Id: Idf9ada9551fcee0216b6b7966f2bbbe3eaf06810
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-on: http://git-master/r/51859
Rebase-Id: Rcd2d406d3520b8f8e0e5598e66ba5576e8aeff20
Add support for matrix Keypad in whistler
Change-Id: I5132f8e3ec7b4353f0cf525b7fceecc721ac014b
Signed-off-by: Puneet Saxena <puneets@nvidia.com>
Reviewed-on: http://git-master/r/51259
Tested-by: Sachin Nikam <snikam@nvidia.com>
Rebase-Id: R34806f304acb565419c4e3301fadd324f7210c81
The key-matrix is updated for the case scroll-wheel is not enabled.
Bug 847651
Original-Change-Id: I12e1ac66b7692733e8947aa2a57eaa2fa5b8a66f
Reviewed-on: http://git-master/r/39553
(cherry picked from commit 25b2522711cd1e0186ff6bc46a0bb91b2abe5226)
Reviewed-on: http://git-master/r/39945
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Rebase-Id: Refd0a693749b6091b184aca891233ae91eafd5cb
BUG 780067
Map row 2, column 1 to KEY_MENU
Original-Change-Id: I120ea7714111e129c3ec330c70592cc292dbba7a
Reviewed-on: http://git-master/r/21737
Reviewed-by: Wen Yi <wyi@nvidia.com>
Tested-by: Wen Yi <wyi@nvidia.com>
Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
Rebase-Id: Re62e357067a84bd6c974ca0c33365cbb78bfac1c
Following are changes:
- Fixes stylistic, indenting and coding style issue.
- Added option for scan timeout.
- Fixes code to have only required number of key codes from board.
- Remove the keycodes from driver and only based on board table.
- Fixes the kbc platform data to provide better option for configuration.
- Modified board files to build properly.
Original-Change-Id: I5e6b9f26ecf8db0769aabac9574cfb6d48c1f061
Reviewed-on: http://git-master/r/16254
Tested-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Rebase-Id: R3c23e26a5a9faa1ae3889fea08426cf0aae6f190
See bug 773201.
Previous implementation defined all possible pins as KBC pins, which
caused some conflicts. New implementation uses only Row0/1/2 and Col0/1
as KBC.
Original-Change-Id: I0d599c3fe9c076ea930ee8e9ae682be865b54361
Reviewed-on: http://git-master/r/14217
Tested-by: Victor Ryabukhin <vryabukhin@nvidia.com>
Rebase-Id: R2f3fcdac1d6d0696a5c84112e5c2d54ec88ec36b
Adding functional keymap for whistler.
Original-Change-Id: I43208d8f901933b368c1c034f56cf0680613312a
Reviewed-on: http://git-master/r/13777
Rebase-Id: R08ed261467ceee3bb8a841a154123406c21ff29d
