Add irq to max8907c mfd driver to be used with RTC and battery charger
Change-Id: I55afc2269dbc2fc872f4aa2f79751896d1c77705
Reviewed-on: http://git-master/r/16616
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
LDO5 regulator has consumers VCORE_MMC, AVDD_LCD1 and
VDDIO_1WIRE.
SDHCI gets this regulator by name "vmmc" and disables in
suspend and enables on resume.
Though it happens equal number of times after resume UI is not seen.
Till proper fix is identified removing the consumer supply entry
for LDO5 after which device resumes with UI properly.
Bug 780047
Change-Id: Ia95906861ad5fa030546f5d723615c74932c97be
Reviewed-on: http://git-master/r/17197
Tested-by: Sachin Nikam <snikam@nvidia.com>
Reviewed-by: Rakesh Kumar <krakesh@nvidia.com>
Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
Bug 780047
Change-Id: Ideec82c535d9fbad869cce89375828342da91dbb
Reviewed-on: http://git-master/r/16058
For Max8907b SD1 and SD2 regulator min and max voltages are same.
min = 637500mV and max = 1425000mV.
Change-Id: I11ace93220df1a8f57ba2f08aff7b25f2f37a9e2
Reviewed-on: http://git-master/r/14796
Regestering and intializing tegra_camera and ov5650.
Configuring pinmix for VI.
Change-Id: I7672f5a1e4ef87cc115183395b144a82bb52f9e8
Reviewed-on: http://git-master/r/14773
mmc driver expects regulator name as "vmmc"
Change-Id: Ic3aa58f7794c24042fafe0b5d3915875bda7447a
Reviewed-on: http://git-master/r/14728
Adding names of the regulator supply for max8907c
Change-Id: I7e56937bc7b223f062b9573776435a479cccb203
Reviewed-on: http://git-master/r/14378
Change-Id: I03149a2ca8d7fd1724a450612ac37c750167d7cd
Reviewed-on: http://git-master/r/11699
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Tested-by: Thomas Cherry <tcherry@nvidia.com>
Reviewed-by: Jinyoung Park <jinyoungp@nvidia.com>
Change-Id: I6fce3852aa1e5063c45caa72c53d6f095db969b7
Reviewed-on: http://git-master/r/11640
