Protected shared bus update with bus lock - common for all shared bus
users (update procedure was already covered by individual shared users
locks, but it did not prevent concurrent access to shared rates list).
Change-Id: Ia0e6886265aff1f624802e0415fe8cecb887b507
Reviewed-on: http://git-master/r/39918
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
clk_disable_locked should not be called when
clk_enable_locked is failed.
Change-Id: I2524ec0198f62de2487723676ca7657d15757eda
Reviewed-on: http://git-master/r/38273
Giving read-write permission for user only for sysfs attributes.
Group and other will have only read permission.
-clock: syncevents
Bug 828100
Change-Id: I14affc209e954a58de055e291093e31dc1dbfe16
Reviewed-on: http://git-master/r/39364
Reviewed-by: Niket Sirsi <nsirsi@nvidia.com>
Tested-by: Niket Sirsi <nsirsi@nvidia.com>
This change provides a centralized location for powergating modules.
It would take care of switching on/off clocks while un-powergating/
powergating modules respectively.
Bug: 814267
Change-Id: Ic80dc517f634c29085c8e089bdaa32c6fd742710
Reviewed-on: http://git-master/r/31776
Change-Id: Icb1a5028d575155427f1fd7fa5b3ee2a145934f4
Reviewed-on: http://git-master/r/38421
Tested-by: Aleksandr Frid <afrid@nvidia.com>
Tested-by: Gerrit_Virtual_Submit
Reviewed-by: Wen Yi <wyi@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Narendra Damahe <ndamahe@nvidia.com>
Change-Id: I55f52ab038764079811c68b3bb3738a9de17d7bf
Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com>
Reviewed-on: http://git-master/r/31530
- tegra_mc_stats: enable and quantum
- susend: mode
- clock: rate, parent, state
File System Permission CTS expects this to pass.
Bug 840409
Change-Id: I3335b27124be38f0f5ea4cc415fef6532e574680
Signed-off-by: Sachin Nikam <snikam@nvidia.com>
Reviewed-on: http://git-master/r/36867
Change-Id: I97434334a4214180a365d9709a331405da135669
Reviewed-on: http://git-master/r/36202
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
On Tegra3 clocks of major h/w engines - 2D/EPP/3D/MPE/VDE/SE - are
sourced from PLLC through integer dividers. Low resolution of these
dividers does not allow to set scaling frequency levels matching
intermediate voltage steps within core voltage range. Only changing
the source frequency can achieve it. However, re-locking common PLL
while engines are running requires synchronization of engines clock
control, and complex operations including switching to backup sources
during PLL stabilization time.
This commit introduces a new virtual clock "cbus" to support clocks
synchronization and PLLC re-locking procedures. The dvfs table for
cbus clock is constructed from frequency steps close to maximum rates
for each characterized core voltage level. Engine clocks exposed to
the drivers are no longer physical module clocks, but shared cbus
users. Setting the rate for such clock specifies the clock floor.
The final cbus rate is determined as maximum floor setting for all
enabled engines, and rounded up along the cbus dvfs ladder. Actual
engine clock rate is set equal to the cbus clock rate. Hence, engines
will be running close to maximum frequency for minimum voltage that
satisfies all floor requests.
Special case: Host1x. This clock will be always configured at 1/2 of
cbus clock rate, and its shared user floor request is ignored by cbus
target frequency calculations.
Added cbus dvfs tables and updated VDE engine dvfs data.
Change-Id: Ic02ea08227f920dc4f47b2389c311a23cea472f6
Reviewed-on: http://git-master/r/36199
smp_processor_id() only makes sense if the code can not move to a
different CPU. The tegra clock code runs with IRQs enabled and
preemption on, so it can move to a different CPU.
Bug 827687
Change-Id: I8b3077c71966e535cc6ca2a2ec63eca0d7119777
Reviewed-on: http://git-master/r/35239
Reviewed-by: Peter De Schrijver <pdeschrijver@nvidia.com>
Tested-by: Peter De Schrijver <pdeschrijver@nvidia.com>
When clock configuration (source mux, divider value) changes, the new
control register setting does not take effect if clock is disabled.
Later, when the clock is enabled it would run for several cycles on
the old configuration before switching to the new one. This h/w
behavior creates two problems:
- since dvfs takes into account only new (enabled) rate, the module
can be over-clocked during initial phase of the clock switch
- since parent clock refcount is updated when the mux register was
written, the parent clock maybe disabled by the time of actual switch
and h/w would not be able to complete switch at all
To avoid described problems clock is now always enabled while setting
the new rate/parent (and disabled afterwards to keep refcount intact).
Change-Id: I9bda56a2a98c9f3678715da1e1b8fe78874fb71e
Reviewed-on: http://git-master/r/31640
Reviewed-by: Jin Qian <jqian@nvidia.com>
For different Tegra3 process corners/skus/revisions/boards set nominal
voltages for CPU and core rails as well as adjust maximum clock rates
as follows.
- VDD_CORE rail nominal voltage: default value is indexed by speedo_id
of the chip (speedo_id is determined by chip sku and revision). Minimum
of the default and board specific electrical design voltage is rounded
down against core dvfs voltage ladder. The result is set as nominal
core voltage (edp voltage API is not implemented, yet).
- VDD_CPU rail nominal voltage: default value is indexed by speedo_id
of the chip. If too high, it is lowered to core nominal voltage so that
core_on_cpu dependency is resolved at nominal core level. The result is
compared with voltage required to reach CPU maximum rate as specified
in the dvfs table for the particular process corner. Again, the minimal
level is selected, and finally set as CPU nominal voltage.
After nominal voltages are determined, maximum rate for each dvfs clock
is adjusted accordingly, so that it does not exceed the rate specified
in the respective DVFS table at nominal level.
Change-Id: Ia6c1c5c853f98ab185f42bf1cfd7a1d7d54d10c3
Reviewed-on: http://git-master/r/30928
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
Tested-by: Diwakar Tundlam <dtundlam@nvidia.com>
Change-Id: If6ae23251aa615a678c8edb76d3c1e6463d86f2e
Change-Id: I50ffa54eacaf5b3973fcd6cb94eee56e46ec81bf
Reviewed-on: http://git-master/r/30384
During dvfs initialization, change propagation of sleeping attribute
from "current_parent-to-child" to "possible_parent-to-child". This would
guarantee that any non-sleeping clock has only non-sleeping parents, and
it is no longer required for sleeping clock to be a sole parent of all
its children.
Change-Id: I11110f6cb9c538c1e71bf00195c3f49dd09ea1f7
Reviewed-on: http://git-master/r/29706
Change-Id: Iff900aa5b69329696bcd250c824e0a191f6f6299
Reviewed-on: http://git-master/r/29705
Made sure Tegra3 LP CPU mode maximum rate, and G CPU mode minimum rate
are clipped to the entries in cpufreq scaling table.
Change-Id: I4c82b65be3a8680edbb501041a7158d1a7fbbd07
Reviewed-on: http://git-master/r/29703
On Tegra3 CPU power is supplied by different rails in G-mode (VDD_CPU)
and LP mode (VDD_CORE) - updated dvfs dependencies respectively.
Original-Change-Id: Ifae8ae501b227a44e46ce1577bcd532e2e778322
Reviewed-on: http://git-master/r/25200
Change-Id: I96e6cb7e3dcdf8514714d2900d8f947b6438c95f
Original-Change-Id: I361e00ef84ce4ca9a9c6d7340de2d095fc67a208
Reviewed-on: http://git-master/r/25180
Reviewed-by: Jonathan Mayo <jmayo@nvidia.com>
Change-Id: If382fc3b5d2ca678df8a9319a06bae967fc3c658
Added second level virtualization (on top of virtual cpu rate control)
to support different Tegra3 CPU power modes: low power (LP) mode and
geared performance (G) mode. Virtual cpu complex (cpu_cmplx) clock is
defined as a child with two parents: virtual cpu_lp and virtual cpu_g
clocks for the respective modes. Mode switch sequence was integrated
into cpu_cmplx set parent implementation. (Before this commit mode
switch was triggered outside the clock framework, which created cpu
clock/mode synchronization problems).
Each mode clock is derived from its own super clock mux (cclk_lp and
cclk_g) to statically match Tegra3 h/w layout. (Before this commit the
code had to dynamically synchronize CPU mode and active mux selection).
This change also allowed to support PLLX output divider for low power
mode as fixed 1:2 divider with bypass control embedded into cclk_lp
parent section.
Updated auto and sysfs CPU mode switch calls to use new clock framework,
and removed clock manipulation from the low level mode switch
implementation.
Original-Change-Id: Ibc3cc495b2ff29e2d3417eff2bfd45535cbd015b
Reviewed-on: http://git-master/r/24734
Tested-by: Jin Qian <jqian@nvidia.com>
Change-Id: I23ae80edbf14fb22727a6fc317cd9e5baf8bd6be
Change-Id: I2ffeaf6f8dfeb279b40ca6f69f6c9157401a746a
Using pll_p clk source for all sdmmc instances.
Disabling clocks left over by the bootloader.
Original-Change-Id: I245347b016618c39a4ceb2323f659b09261eaf7d
Reviewed-on: http://git-master/r/17847
Tested-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Change-Id: I0790f6f67c944a9ca42be9d6b9398d8093b4beef
Do not switch off sdmmc4 clock. Also, removed ddr
mode temporarily from linux mmc driver.
Programming tap_delays and internal clock.
Original-Change-Id: I830bf5e94ccd47e154c5ef9909e8bff1ff7754c0
Reviewed-on: http://git-master/r/17070
Tested-by: Scott Williams <scwilliams@nvidia.com>
Change-Id: Ic1cff8dd85229fe903206f1dc9a967d600ba88c1
Pre-set clock rate when changing parent to avoid parent over-clocking
during clock initialization from common/board specific tables. Drivers
however, may still hit over-clocking error.
Original-Change-Id: Ib101d85e90ab4c1194ac98680c930eebd8c56b76
Reviewed-on: http://git-master/r/16877
Change-Id: I307e7eb507d885c381087812d262d56338aab861
Fail clk_set_parent() interface if switching the clock parent will set
the rate above maximum limit.
Original-Change-Id: I47c0798dafe5f8f497dcacfcd23f6957244cdb0a
Reviewed-on: http://git-master/r/16876
Change-Id: Ie5fef027411096a465ae5aa84fe84a08a769a613
Original-Change-Id: I7d7f4f49cc1e41707032467197d53967d3ecaf06
Reviewed-on: http://git-master/r/16659
Change-Id: I9e04b2833ef12466664cf6f6c2666d440600db08
Original-Change-Id: I2a16c36c8ee414a1f046eda2f3bdb9c1d71caf8b
Reviewed-on: http://git-master/r/16657
Change-Id: Icc4b526f44697bd788d83434f6e9a62de005b09c
Re-factored extended clock operations to enumerate configuration
parameters.
Original-Change-Id: I6c1e5f07803a8e6da0ebd6690892f50bb59efcd5
Reviewed-on: http://git-master/r/15144
Change-Id: I25147998969b385905bad5eb3ceb2dbb89c0d93a
Some peripheral clock source registers have extra bits with setting
specific for the respective controller. Added mechanism to manipulate
these bits from the clock code with proper locking. Implemented NAND,
VI and DTV extended configurations.
Original-Change-Id: Ic8a1887923f0b98f9b1fac06dcf4f90084b017c0
Reviewed-on: http://git-master/r/15059
Change-Id: Ic3416be8683c90043376d6675269fc23e440f61d
arch/arm/configs/tegra_defconfig
arch/arm/configs/tegra_whistler_android_defconfig
arch/arm/mach-tegra/Kconfig
arch/arm/mach-tegra/Makefile
arch/arm/mach-tegra/board-ventana.c
arch/arm/mach-tegra/board-ventana.h
arch/arm/mach-tegra/board-whistler-power.c
arch/arm/mach-tegra/board-whistler.c
arch/arm/mach-tegra/clock.c
arch/arm/mach-tegra/clock.h
arch/arm/mach-tegra/common.c
arch/arm/mach-tegra/cpu-tegra.c
arch/arm/mach-tegra/dma.c
arch/arm/mach-tegra/fuse.c
arch/arm/mach-tegra/headsmp.S
arch/arm/mach-tegra/include/mach/iomap.h
arch/arm/mach-tegra/irq.c
arch/arm/mach-tegra/spi_tegra_slave.c
arch/arm/mach-tegra/tegra2_clocks.c
arch/arm/mach-tegra/tegra2_dvfs.c
arch/arm/tools/mach-types
drivers/crypto/tegra-aes.c
drivers/rtc/rtc-tegra.c
drivers/video/tegra/host/dev.c
drivers/video/tegra/host/nvhost_acm.c
drivers/video/tegra/host/nvhost_channel.c
drivers/video/tegra/host/nvhost_intr.c
sound/soc/tegra/tegra_i2s.c
sound/soc/tegra/tegra_pcm.c
Original-Change-Id: If13d61cce097ee90892132e775c5ac805a1f91e0
Reviewed-on: http://git-master/r/14922
Change-Id: Id331a2ef77522766e5b7f86131c6c981b37ba4c8
Original-Change-Id: Ifde476a05bd01cdce8c3f4802b268a193a832a1b
Reviewed-on: http://git-master/r/14584
Change-Id: I41204d17c5d8092b1a24b3138efe12cfbd16d7e7
Bug 764354
Original-Change-Id: I8a390eb4dae87dceacb97461f23d13554868b046
Reviewed-on: http://git-master/r/12228
Change-Id: I8e6b8303898796419fb5a759cd16edff9aeac081
Adjust max rates for CPU and several SKU-dependent core clocks
(system bus, AVP, VDE, 3D) to match chip SKU ID. Added max_rate
node to debugfs.
Change-Id: Ifd72d45a303b3d8b5ae5f327693bb97c8510031d
Reviewed-on: http://git-master/r/16077
drivers/net/wireless/bcm4329/Makefile
Change-Id: I31ce81e09c6f18d6966a5cffebc533453bce02d8
Implemented debugfs clock write mechanism (disabled by default).
Expanded and fixed debugfs clock nodes to properly read clock
parent and rate.
Change-Id: I9f20994d0829634e09f4bccd6fce6c7c8b5bf844
Reviewed-on: http://git-master/r/15315
Tested-by: Amit Kamath <akamath@nvidia.com>
When picking clock divider values, the clock framework picks
the closest frequency that is lower than the requested
frequency. If the value from a clock divider rounds down,
and then the new rounded down frequency is requested, it
will get rounded down again, resulting in a frequency two
steps lower than the original requested frequency.
Fix the problem by rounding up when calculating the frequency
coming out of a clock divider, so if that frequency is
requested again, the same divider value will be picked.
Change-Id: Ieaf74448f67d91aeb7ba08226e48c092d8afaa2b
Signed-off-by: Colin Cross <ccross@android.com>
The SDMMC controllers have extra bits in the clock source
register that adjust the delay between the clock and data
to compenstate for delays on the PCB. The values need to
be set from the clock code so the clock can be locked
during the read-modify-write on the clock source register.
Change-Id: Id25b7cc01fa4ec48478b60aefdf5e59bb040fbf2
Call the clock's round_rate op, if it exists, before setting
dvfs rate. Ensures dvfs is set to the rate the clock will
be at after the later call to set_rate.
Change-Id: I4c8e85991238492adc3c37aed57c7269f3b41a2c
The previous version of dvfs handled requirements between two
different voltage rails by using two sets of dvfs tables, one
for each rail. That method fails for vdd_aon, which must be
within 170 mV of vdd_core.
Instead, have each dvfs clock only set the voltage rail that
it directly depends on, and add a relationship system to the
voltage rails. When the voltage changes on one rail, it calls
update on all the rails that depend on it. The dependent rails
compare the new voltage of the original rail to their own
voltage, and update their own voltage as necessary.
Change-Id: I17b30a61c7c0c01e44702ab486238789abd47330
This reverts commit f58886c359db3c5056fea2d1a41d297f19e9f585.
Change-Id: Ie88d8f79db9bf958fc3b9f261d74d031785161d0
Change-Id: I9e3a3cc8c6c4424d7f7ded22d886d51f715ec5d5
Get rid of dvfs_lock, replacing it with the cansleep flag on clocks.
Clocks with the cansleep flag set will lock a mutex before calling
into dvfs.
Also does the regulator api calls during late init, after the
regulators have been probed.
Change-Id: I5b8bd249bd4f3ae495f2076f1e6d2bfb38737f29
Give each clock its own lock, and remove all lock traversals from
parent to child clocks to prevent AB-BA deadlocks.
Change-Id: I0afb7d1bca956439b1a4f17bbc6748aaec706b49
Change-Id: I732f9428096d057e08092120c6f8c2890230a242
New and improved dvfs:
Registered dynamically during init
Exports dvfs functions to control clocks that are not visible to
the clock subsystem
Supports multiple regulators per clock
Fix dvfs on disabled clocks
Adds /d/clock/dvfs to show current voltage requirements
Change-Id: I93794a7761dccc702566e8850bb79f344ff787a2
Change-Id: Iaa5377dd1d8bf32e90deb668053c10588642fa03
Change-Id: I136713c2a2ff9fec9fc629ae8f91709e49016618
Change-Id: I6651ab59b738787ec94f358d5789d950c3d1a563
Change-Id: Ic707eb111856eb9bdb165776d011c35d04502a9a
- Add drivers to clock lookup table
- Add new pll_m entries
- Support I2C U16 divider
- Fix rate reporting on 32.768kHz clock
- Call propagate rate only if set_rate succeeds
- Add support for audio_sync clock
- Add 24MHz to PLLA frequency list
- Correct i2s1/2/spdifout mux
- Add suspend support
- Fix enable/disable parent clocks in set_parent
- Add max_rate parameter to all clocks
- DVFS support
- Add virtual cpu clock with dvfs
- Support clk_round_rate
- Fix requesting very high periph frequencies
- Add quirks for PLLU:
PLLU is slightly different from the rest of the PLLs. The
lock enable bit is at bit 22 instead of 18 in the MISC
register, and the post divider field is a single bit with
reversed values from other PLLs.
- Simplify recalculating clock rates
- Fix UART divider flags
- Remove unused clock ops
v2: fixes from Russell King:
- include linux/io.h instead of asm/io.h
- fix whitespace in Kconfig
- Use spin_lock_init to initialize lock
- Return -ENOSYS instead of BUG for unimplemented clock ops
- Use proper return values in tegra2 clock ops
additional changes:
- Rename some clocks to match dev_ids
- add rate propagation
- add debugfs entries
- add support for clock listed in clk_lookup under multiple dev_ids
v3:
- Replace per-clock locking with global clock lock
- Autodetect clock state on init
- Let clock dividers pick next lower possible frequency
- Add support for clock init tables
- Minor bug fixes
- Fix checkpatch issues
