Warnings removed are related to unused variables/labels,
structure/argument type mismatch, copyright update, function return
type mismatch and wrong C coding style.
Bug 949219
Change-Id: Ib748d12d5ab3cfc35118be28c29983081cca6cbb
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/103770
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
An api (del_timer_sync), which can sleep, should not be used in
hardirq context. This gives warnings for potential deadlock. Use
non-sleeping api to cancel the work instead. In this case, if the
work is already running, it would unthrottle mc error prints.
BUG 889717
Change-Id: I4c0205766d82a45a04d1c0125bb8ed5927757456
Reviewed-on: http://git-master/r/59604
Tested-by: Nitin Kumbhar <nkumbhar@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-by: Prajakta Gudadhe <pgudadhe@nvidia.com>
Rebase-Id: R713c536217d0169f395ffb199ec2a97b274b9914
It's current spot, in tegra_early_init, was too early. It was being
called before we could allocate memory.
Rebase-Id: Rff026504107e75b33dccf714c5219d78c0d1dac9
Adding MC_DECERR interrupt handler ported from Froyo.
This addition will not gracefully terminate a failing DMA transfer.
The handler does noting but simply reporting the error status with prink,
and the clinet software will likely hang forever waiting for a non-
completing DMA transfer. But it is still useful for debugging.
Reviewed-on: http://git-master/r/16289
(cherry picked from commit 4c66e8b978f054b332c21a97a53d89f588d24889)
Original-Change-Id: I7b19c70d8cbb62be9ab3f955bf19c707c1e5045d
Reviewed-on: http://git-master/r/16590
Tested-by: Hiro Sugawara <hsugawara@nvidia.com>
Tested-by: Scott Williams <scwilliams@nvidia.com>
Original-Change-Id: Ibdcfe63d56d22e39d8c5398ff50eb663bd0d82f3
Rebase-Id: R5a24a2ae2ab4585c3d48c76761beef815a665649
