Tegra internal temperature sensor addresses defined
Bug 661228
Original-Change-Id: I061ac9e7da3115d1e832e645582353f93378d291
Reviewed-on: http://git-master/r/36119
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Tested-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-by: Narendra Damahe <ndamahe@nvidia.com>
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
Rebase-Id: R62de8521a55164f582eb2b0f8ad5a83bbc02876c
Change-Id: I119fdbbc2440f8a7e64e2f3b5cec2ae4b182ee36
Signed-off-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-on: http://git-master/r/47592
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Rebase-Id: R891ed7225b634dc01aaf3f13dbe79fc1eae1c27c
Also, remove "audio" platform device; it won't be used with the ALSA
driver.
Rebase-Id: Rcbe1845a8d41292dfa82d61ff662d2f233b20af2
tegra3 has a hardware block which can be used
for encryption/decryption and hashing. add an
entry in the common location so that all the
boards using tegra3 can leverage it.
Bug 835859
Original-Change-Id: I5f3b031f5648fb04f85caa7c42b69b7482c96a7b
Reviewed-on: http://git-master/r/35635
Reviewed-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
Rebase-Id: R7cbf0a98df1bc006a575a4e6728008522bc27788
Adding device entry for the uart port as a debug console.
The device struture will be used in board files to invoke the
debug console driver.
bug 832273
Original-Change-Id: I61c1dbdd946d5c371d7a9b23517119048a7487cb
Reviewed-on: http://git-master/r/34445
Tested-by: Jay Agarwal <jagarwal@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Rebase-Id: R28de1684d8f7fce67c09d909f7bda51259128c0b
Change SOC conditionals to make them more forward-looking.
Original-Change-Id: Ib60db4e690c2f396afdec962616d735548b5a8a9
Reviewed-on: http://git-master/r/32706
Reviewed-by: Niket Sirsi <nsirsi@nvidia.com>
Tested-by: Niket Sirsi <nsirsi@nvidia.com>
Rebase-Id: R77c675a1995116098b58f1f775bc7c3cc8722998
Adding device details for the tegra based kbc driver.
Bug 827020
Original-Change-Id: I47b150fc97f97ce91c1de569aec067ad2e5f0660
Reviewed-on: http://git-master/r/31725
Reviewed-by: Alok Chauhan <alokc@nvidia.com>
Tested-by: Alok Chauhan <alokc@nvidia.com>
Rebase-Id: Ra1a6e6dc6477cf1deae0b84dc3911b8ccfd9bbb8
Original-Change-Id: I2ffeaf6f8dfeb279b40ca6f69f6c9157401a746a
Rebase-Id: Rd8ebde470ad475b826857413018a2da8e1fdea25
Adding device details for the spi slave driver. Also adding clock
details for these drivers.
Original-Change-Id: I38a34c289e296152339dd23858dc19bfb95db354
Reviewed-on: http://git-master/r/22411
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
Reviewed-by: Hanumanth Venkateswa Moganty <vmoganty@nvidia.com>
Original-Change-Id: Id60caffa97965ac424083353388a0e6dfd963779
Rebase-Id: R442b1ac8bacbd15325abf7d8dc96699f75cd5fda
Adding device entries for SPI5 and SPI6 for TEGRA3 ARCH.
Original-Change-Id: Ie9d6a1e0cb9488bf07327c403edb78626137688b
Reviewed-on: http://git-master/r/20309
Reviewed-by: Ramachandrudu Kandhala <rkandhala@nvidia.com>
Original-Change-Id: I7706a2b32177aaa4b4ca53d4f089cb3218f51ba3
Rebase-Id: Ra0f5901afa740929c904d681f89582d04ff230c1
Original-Change-Id: I18c63f1c69e155ddc1cec1718af9684d861815b7
Reviewed-on: http://git-master/r/15863
Tested-by: Yen Lin <yelin@nvidia.com>
Reviewed-by: Rhyland Klein <rklein@nvidia.com>
Reviewed-on: http://git-master/r/16485
Original-Change-Id: I6afa5a097b4fc7d6c45614107118458da0d9d888
Rebase-Id: R18ae88707c208faafc26de033e9f34a7466fa608
audio device is enabled in the device file
Original-Change-Id: Id19526c0be5d77c25e81cb1e75648288174fadd0
Reviewed-on: http://git-master/r/15910
Reviewed-by: Scott Peterson <speterson@nvidia.com>
Reviewed-by: Vinod Gopalakrishnakurup <vinodg@nvidia.com>
Tested-by: Vinod Gopalakrishnakurup <vinodg@nvidia.com>
Original-Change-Id: I3eaf368150a62df38683f79c10180078a57052c3
Rebase-Id: R865e609be363dfa234d06ff4a90914df1d491499
Bug 764354
Original-Change-Id: I8a390eb4dae87dceacb97461f23d13554868b046
Reviewed-on: http://git-master/r/12228
Tested-by: Scott Williams <scwilliams@nvidia.com>
Original-Change-Id: I8e6b8303898796419fb5a759cd16edff9aeac081
Rebase-Id: R2866240384c6c24f46bd7ef54bc3dc9140d9e96b
This reverts commit b1b863de1b1a83f8f9edd8e8e6172d3aa55f3f60.
arch/arm/mach-tegra/tegra2_clocks.c
Original-Change-Id: I29c3479fb34ec22472f449ea8c8744643e25b219
Rebase-Id: R495b37a5f80b161558bce9e31ab13eae53f19cc3
- spi slave device added.
- clock entry added for spi slave device.
bug 785523
Original-Change-Id: I6d3daeb3e7f4171f2dc4f9ec1fe255f19ea48928
Reviewed-on: http://git-master/r/23554
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: R7adc06e45ba28d84b92182e65b30ed8f3ec50847
Change-Id: Id13075009d785e784ae6bd0feb9b29f3fa7184df
Use resources to pass data to tegra_hsuart to set
mapbase, irq.
Signed-off-by: Jaikumar Ganesh <jaikumar@google.com>
Change-Id: I8229873e1a450b75d31e6ea4ec64647b88d16844
Signed-off-by: Dima Zavin <dima@android.com>
Change-Id: If447711b095ec7025f3bbe232e22444839054927
Change-Id: I4c694d3c9f8a15975591ba5b61625da410991efd
Signed-off-by: Gary King <gking@nvidia.com>
Signed-off-by: Iliyan Malchev <malchev@google.com>
Change-Id: Icdc0de036566220f337a21d5b1bae0e81057f115
Change-Id: I8d861fd9f7748f29879315cd6f0800cec6a84f9e
Change-Id: I8098fa38ebef8636a6eeb1179e679201445e5237
Change-Id: Id748aa37a3c2234a2a618b09dfa963a4b4ac572c
update harmony and ventana to use the common UDC definition, rather
than using the current duplicated definitions
Change-Id: I2e3aca674ab35305a0c516bd22e044382280d05e
This adds w1 as a device for mach-tegra boards, fixes wrong
OWR I/O base, and changes OWR clock name.
Change-Id: Idffbdbd05f383ce8e423ee301e197e230db4f2f9
Signed-off-by: Andrei Warkentin <andreiw@motorola.com>
For I2S, DAS, PCM devices
Add a common location to register resources for used on-chip devices
that are commonly configured on boards. Devices will be added to this file
as more drivers are added that can make use of them.
This is based on work contributed by several people, most of it from
Colin Cross and Erik Gilling.
Acked-by: Colin Cross <ccross@android.com>
