path: root/arch/arm/mach-tegra/fuse.c
2013-03-19ARM: tegra: add speedo-based process id for Tegra114Danny Huang
Add speedo-based process identification for Tegra114. Based on the work by: Alex Frid <afrid@nvidia.com> Signed-off-by: Danny Huang <dahuang@nvidia.com> [swarren: added include of bug.h] Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-01-28ARM: tegra: add function to read chipidPrashant Gaikwad
Add function to read chip id from APB MISC registers. This function will also get called from clock driver to flush write operations on apb bus. Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-11-15ARM: tegra: Tegra30 speedo-based process identificationDanny Huang
This patch adds speedo-based process identification support for Tegra30. Signed-off-by: Danny Huang <dahuang@nvidia.com> [swarren s/Tegra3/Tegra30/ in log print, s/T30/Tegra30/ in commit description] Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-11-15ARM: tegra: Add speedo-based process identificationDanny Huang
Detect CPU and core process ID by checking speedo corner tables. This can provide a more accurate process ID. Signed-off-by: Danny Huang <dahuang@nvidia.com> [swarren s/Tegra2/Tegra20/ in log print] Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-11-15ARM: tegra: flexible spare fuse read functionDanny Huang
Change the spare fuse base from a definition to a variable. It provides flexibilty to read spare fuse on different chip. Signed-off-by: Danny Huang <dahuang@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-11-05ARM: tegra: move iomap.h to mach-tegraStephen Warren
Nothing outside mach-tegra uses this file, so there's no need for it to be in <mach/>. Since uncompress.h and debug-macro.S remain in include/mach, they need to include "../../iomap.h" becaue of this change. uncompress.h will soon be deleted in later multi-platform/single-zImage patches. debug-macro.S will need to continue to include this header using an explicit relative path, to avoid duplicating the physical->virtual address mapping that iomap.h dictates. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-09-06ARM: tegra: use IO_ADDRESS for getting virtual addressLaxman Dewangan
Use macro IO_ADDRESS for getting virtual address of corresponding physical address to make the consistency with rest of Tegra code-base. This macro calls the IO_TO_VIRT() which is defined in arch/arm/mach-tegra/include/mach/iomap.h Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-03-28Merge tag 'soc2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "ARM: More SoC support updates" from Olof Johansson: "This branch contains a handful of updates of SoC base code that had dependencies on other external trees that have now been merged: * Support for the new EXYNOS5250 SoC from Samsung * SMP and power domain support for Tegra3 from NVIDIA * ux500 updates for exporting SoC information through sysfs" Fix up trivial merge conflicts as per Olof. * tag 'soc2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (30 commits) ARM: mach-shmobile: ap4evb: Reserve DMA memory for the frame buffer ARM: EXYNOS: Fix compilation error with mach-exynos4-dt board ARM: dts: add initial dts file for EXYNOS5250, SMDK5250 ARM: EXYNOS: add support device tree enabled board file for EXYNOS5 ARM: EXYNOS: add support ARCH_EXYNOS5 for EXYNOS5 SoCs ARM: EXYNOS: add support get_core_count() for EXYNOS5250 ARM: EXYNOS: support EINT for EXYNOS4 and EXYNOS5 ARM: EXYNOS: add interrupt definitions for EXYNOS5250 ARM: EXYNOS: add support for EXYNOS5250 SoC ARM: EXYNOS: add support uart for EXYNOS4 and EXYNOS5 ARM: EXYNOS: add initial setup-i2c0 for EXYNOS5 ARM: EXYNOS: add clock part for EXYNOS5250 SoC ARM: EXYNOS: use exynos_init_uarts() instead of exynos4_init_uarts() ARM: EXYNOS: to declare static for mach-exynos/common.c ARM: EXYNOS: Add clkdev lookup entry for lcd clock ARM: dt: Explicitly configure all serial ports on Tegra Cardhu ARM: tegra: support for secondary cores on Tegra30 ARM: tegra: support for Tegra30 CPU powerdomains ARM: tegra: add support for Tegra30 powerdomains ARM: tegra: export tegra_powergate_is_powered() ...
2012-03-27Merge tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "ARM: driver specific updates" from Arnd Bergmann: "These are all specific to some driver. They are typically the platform side of a change in the drivers directory, such as adding a new driver or extending the interface to the platform. In cases where there is no maintainer for the driver, or the maintainer prefers to have the platform changes in the same branch as the driver changes, the patches to the drivers are included as well. A much smaller set of driver updates that depend on other branches getting merged first will be sent later. The new export of tegra_chip_uid conflicts with other changes in fuse.c. In rtc-sa1100.c, the global removal of IRQF_DISABLED conflicts with the cleanup of the interrupt handling of that driver. Signed-off-by: Arnd Bergmann <arnd@arndb.de>" Fixed up aforementioned trivial conflicts. * tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (94 commits) ARM: SAMSUNG: change the name from s3c-sdhci to exynos4-sdhci mmc: sdhci-s3c: add platform data for the second capability ARM: SAMSUNG: support the second capability for samsung-soc ARM: EXYNOS: add support DMA for EXYNOS4X12 SoC ARM: EXYNOS: Add apb_pclk clkdev entry for mdma1 ARM: EXYNOS: Enable MDMA driver regulator: Remove bq24022 regulator driver rtc: sa1100: add OF support pxa: magician/hx4700: Convert to gpio-regulator from bq24022 ARM: OMAP3+: SmartReflex: fix error handling ARM: OMAP3+: SmartReflex: fix the use of debugfs_create_* API ARM: OMAP3+: SmartReflex: micro-optimization for sanity check ARM: OMAP3+: SmartReflex: misc cleanups ARM: OMAP3+: SmartReflex: move late_initcall() closer to its argument ARM: OMAP3+: SmartReflex: add missing platform_set_drvdata() ARM: OMAP3+: hwmod: add SmartReflex IRQs ARM: OMAP3+: SmartReflex: clear ERRCONFIG_VPBOUNDINTST only on a need ARM: OMAP3+: SmartReflex: Fix status masking in ERRCONFIG register ARM: OMAP3+: SmartReflex: Add a shutdown hook ARM: OMAP3+: SmartReflex Class3: disable errorgen before disable VP ... Conflicts: arch/arm/mach-tegra/Makefile arch/arm/mach-tegra/fuse.c drivers/rtc/rtc-sa1100.c
2012-02-26ARM: tegra: export Tegra chipidPeter De Schrijver
The powergating and reset handling code needs to differentiate between Tegra variants. Therefore we export the chipid here. Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-02-26ARM: tegra: cleanup use of chipid registerPeter De Schrijver
The chipid register contains information about the Tegra variant and revision. We want differentiate between Tegra variants for powergating and secondary core bringup. This patch cleans up the reading and decoding of this register. In subsequent patches the variant will exported as a global variable. Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-02-06ARM: tegra: fuse: add bct strapping readingOlof Johansson
This is used by the memory setup code to pick the right memory timing table, if needed. Signed-off-by: Olof Johansson <olof@lixom.net>
2012-02-06ARM: tegra: fuse: add functions to access chip revisionOlof Johansson
Add function to get chip revision, and print it out at boot time. Restructure the fuse access to just use cached variables instead of always reading the fuses, and export those variables directly instead of using accessor functions. Add a SKU ID table of currently known values. Based on code originally by Colin Cross <ccross@android.com>. Changes since v1: * Add A01 minor rev support * Don't decode for A03p on anything but T2x Signed-off-by: Olof Johansson <olof@lixom.net> Acked-by: Stephen Warren <swarren@nvidia.com>
2012-02-06ARM: tegra: fuse: use apbio dma for register accessOlof Johansson
Use the apbio dma functions for accessing the fuse registers. Signed-off-by: Olof Johansson <olof@lixom.net>
2012-01-13arm: tegra: export tegra_chip_uidHenning Heinold
The crypto driver will need this api to use it in the RNG calculations. In order to build the crypto driver as a module, tegra_chip_uid has to be exported. Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Henning Heinold <heinold@inf.fu-berlin.de> Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-10-21[ARM] tegra: Add support for reading fusesColin Cross
The Tegra SOC contains fuses to identify the CPU type and bin, and a unique id. The CPU info is required to determine the correct voltages for each cpu and core frequency. Signed-off-by: Colin Cross <ccross@android.com>
