path: root/arch/arm/mach-tegra/include/mach/arb_sema.h
2011-11-30crypto: tegra-aes: dual core supportSanjay Singh Rawat
* add bsea engine support for encryption and decryption * add arbitration semaphore id for bsea Bug 803932 Original change: http://git-master/r/#change,29672 (cherry picked from commit 0008cdb0f38d0cd0c074671fc067c4321f340b06) Original-Change-Id: I59fcaab29c47a8b42e7470b30486851cfe90848f Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com> Reviewed-on: http://git-master/r/30190 Tested-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Rebase-Id: Rb63b593aa4fe4b4d4f3607ac9471ae7e7372407a
2011-11-30ARM: tegra: hardware arbitration semaphore supportVarun Wadekar
add apis to use the hardware arbitration semaphores in order to share hardware modules between kernel drivers and AVP firmware (e.g., the BSEA (audio bitstream) engine and AES block) Change-Id: I500ef0797223bc702151ad14e0e2156f50644a2a Signed-off-by: Varun Wadekar <vwadekar@nvidia.com>
