-Added support for setting a pin io state to INPUT/OUTPUT.
-Exported tegra_pinmux _get_pingroup/_set_io to make them
available to loadable kernel modules.
Bug 845065
Change-Id: I7d9500f590b804d1d222dfd7e42d1dbfc6686611
Signed-off-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Reviewed-on: http://git-master/r/71975
Replace the hand-crafted pinmux mux selector enumerators and
name table with generator macros to avoid mismatches between
them.
Change-Id: I2e56bf89a4b29f33af00d0e4d2617ee13c554997
Signed-off-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-on: http://git-master/r/70088
Reviewed-by: Mark Stadler <mastadler@nvidia.com>
Reviewed-by: Allen Martin <amartin@nvidia.com>
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Setting the slewrise and slewfall rates properly.
Bug 811303
Reviewed-on: http://git-master/r/52367
(cherry picked from commit 337b90b5a359c4f320f58f5026fa511dca5d8031)
Change-Id: I518b4dcdad8ac338cf03d4fb6c634b0747a82836
Reviewed-on: http://git-master/r/62326
(cherry picked from commit 7a04424fb0b8c1f36f28c99f73a313cd192360e9)
Reviewed-on: http://git-master/r/63813
Tested-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Rebase-Id: Racfd777be42f83018a9e295e1c7048ebb02f7f9e
Create mapping from gpio to pingroup and set gpio to
normal or tristate
Bug 866633
Reviewed-on: http://git-master/r/56557
(cherry picked from commit 321ded98d41170b9e32d60177c6808492ccdf115)
Change-Id: I3d1b979717f1c6b208af3df0a7dfe603e5272d21
Reviewed-on: http://git-master/r/61120
Tested-by: Bandi Krishna Chaitanya <bandik@nvidia.com>
Rebase-Id: R5991c2cbc11aa35345fde7f08c0bfeb306e85e1e
Change-Id: I156af0bdd8b37cb23aec214c3e158027252e27e1
Reviewed-on: http://git-master/r/51157
Rebase-Id: R795bf03590a76b6c494afd37603ed951dc2cd082
In T30, different pad ctrl group registers have
different pull up and pull down drive strength field
offsets and maximum values. Modified drive_strength
structure to be able to pass the offsets and masks of
each group to ensure that drive strengths are properly
configured.
Bug 870369
Original-Change-Id: Ib1872417542236c95c3b41a1ad860ef8418f5704
Reviewed-on: http://git-master/r/49872
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: R4889bbb8bc0e5fef57d98bc68cd0116a9be3fdbd
Change-Id: I69f9b9f74a98ef31f496478e48896dc51044a72e
Reviewed-on: http://git-master/r/49273
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Rebase-Id: Rf384c1b08e441df3a7aeb4bba86a78da1663a7d2
configuring sdmmc drive strengths as suggested
by HW team based on Characterization results
Bug 799568
Original-Change-Id: Id30505659aefb9c63a24f8baa8296a62723710b4
Reviewed-on: http://git-master/r/46949
Tested-by: Naveen Kumar Arepalli <naveenk@nvidia.com>
Rebase-Id: R4d0b228317fd12c185b735ed248818f5217d9ed4
Setting maximum driver strength of DAP2 in all tegra3
based system by default.
bug 820361
Original-Change-Id: I2f992f4779e7babe76a5dc7a679bee53b3369c9a
Reviewed-on: http://git-master/r/44497
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Rebase-Id: R03343987d0b060291c323558f5eaf96b63cd2321
For Linux 2.6.39, CONFIG_PM_SLEEP is the proper kernel configuration
parameter to use on Tegra for power management, and not CONFIG_PM.
CONFIG_PM does not have the required dependency on CONFIG_SUSPEND
necessary to pull in the CPU suspend/resume functionality used by
Tegra.
Also fixes compilation errors when CONFIG_PM and by implication
CONFIG_PM_SLEEP are not configured.
Change-Id: I8bb380ae7c6b22759bfbc223febc28f585111aad
Reviewed-on: http://git-master/r/40458
Tested-by: Daniel Willemsen <dwillemsen@nvidia.com>
Rebase-Id: R61d656cd67439aa9f466c381845d7a4685fc8648
Change SOC conditionals to make them more forward-looking.
Original-Change-Id: Ib60db4e690c2f396afdec962616d735548b5a8a9
Reviewed-on: http://git-master/r/32706
Reviewed-by: Niket Sirsi <nsirsi@nvidia.com>
Tested-by: Niket Sirsi <nsirsi@nvidia.com>
Rebase-Id: R77c675a1995116098b58f1f775bc7c3cc8722998
On tegra3 TRM, some of the pin mux option for a given
pin group is not recommended and so not exposed in the
TRM reference table.
Updating the pinmux table accordingly. The non-recommended
pin option is set as TEGRA_MUX_INVALID.
bug 817099
Original-Change-Id: I572ee84912fe065a73e59d4f9ba0ce01223ead85
Reviewed-on: http://git-master/r/29626
Rebase-Id: R88ad8a84c4516c8692b9266d6c073f20e35b420e
Supporting the LOCK, OpenDrain (OD), IO_RESET configuration on pinmux register
through pinmux apis.
Original-Change-Id: I2459723c5fbcadd925331696c9469f64d2ba3b20
Reviewed-on: http://git-master/r/17532
Reviewed-by: Venkata Nageswara Penumarty <vpenumarty@nvidia.com>
Tested-by: Venkata Nageswara Penumarty <vpenumarty@nvidia.com>
Original-Change-Id: Ibd06c9a650ffbacf51530514e58bd52d1f60b4f2
Rebase-Id: R8e593a0b1e27db641d2e0c7b57a2946d97819f25
Bug 764354
Original-Change-Id: I8a390eb4dae87dceacb97461f23d13554868b046
Reviewed-on: http://git-master/r/12228
Tested-by: Scott Williams <scwilliams@nvidia.com>
Original-Change-Id: I8e6b8303898796419fb5a759cd16edff9aeac081
Rebase-Id: R2866240384c6c24f46bd7ef54bc3dc9140d9e96b
For getting actual rate, add mux clock inputs to cdev1 and cdev2.
Change-Id: Ic42eb97a51bceb5249ca29938ac00f8add9ef032
Signed-off-by: Jin Park <jinyoungp@nvidia.com>
Reviewed-on: http://git-master/r/23187
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
Rebase-Id: Rae9706a85a80f4cd8cf724c6d0adf97694138f70
Signed-off-by: Colin Cross <ccross@android.com>
Change-Id: I3228600e93f819821b13b0955961fc1cbfb826a8
- the reset values for some pin groups in the tegra pin mux can result in
functional errors due to conflicting with actively-configured pin groups
muxing from the same controller. this change adds a known safe, non-
conflicting mux for every pin group, which can be used on platforms
where the pin group is not routed to any peripheral
- also add each pin group's I/O voltage rail, to enable platform code to
map from the pin groups used by each interface to the regulators used
for dynamic voltage control
- add routines to individually configure the tristate, pin mux and pull-
ups for a pingroup_config array, so that it is possible to program
individual values at run-time without modifying other values.
this allows driver power-management code to reprogram individual
interfaces into lower power states during idle / suspend, or to
reprogram the pin mux to support multiple physical busses per
internal controller (e.g., sharing a single I2C or SPI controller
across multiple pin groups)
- move chip-specific data like pingroups and drive-pingroups
out of the common code and into chip-specific code
- fix debug output for group with no pullups
- add a TEGRA_MUX_SAFE function. Setting a pingroup to TEGRA_MUX_SAFE
will automatically select a mux setting that is guaranteed not to
conflict with any of the hardware blocks.
Signed-off-by: Gary King <gking@nvidia.com>
v2: fixes from Russell King
- include linux/io.h instead of asm/io.h
v3:
- Add drive strength controls
- Replace typedef enums with plain enums
Signed-off-by: Erik Gilling <konkers@android.com>
