In order to find a viable resolution we not only parse VESA mode,
we also parse CEA (multimedia) modes and our own small modedb (for
specific touch screens).
Use new modedb based framebuffer settings by defining default_mode
in the display controllers platform data. Also impelmented the
fallback logic to this default_mode in case no kernel cmd line
parameter was set.
Allow to specify framebufffer videomode using kernel command line
parameters. NVIDIAs binary X driver later on picks up those settings
and start X with current mode settings, if no EDID data are available.
Several file names and paths showed copy/paste or otherwise issues.
Android R14 userspace seems to have issues with timestamp support:
[ 14.764337] host1x host1x: SurfaceFlinger: syncpoint id 8 (disp0_a) stuck waiting 3, timeout=2147483447
[ 14.773845] host1x host1x: id 8 (disp0_a) min 2 max 4
[ 14.779163] host1x host1x: id 9 (disp1_a) min 2 max 4
[ 14.784316] host1x host1x: id 18 (2d_0) min 21 max 25
[ 14.789586] host1x host1x: id 20 (disp0_b) min 2 max 4
[ 14.794889] host1x host1x: id 21 (disp1_b) min 2 max 4
[ 14.800241] host1x host1x: id 22 (3d) min 77 max 95
[ 14.805217] host1x host1x: id 24 (disp0_c) min 2 max 4
[ 14.810573] host1x host1x: id 25 (disp1_c) min 2 max 4
[ 14.815873] host1x host1x: id 26 (vblank0) min 800 max 0
[ 14.821264] host1x host1x: id 27 (vblank1) min 684 max 0
[ 14.826810] host1x host1x: waitbase id 3 val 77
Therefore conditionally revert it in that case for now.
See e4e2e776a3d4bf1adf37fc061cfdfb92281f3ace.
arch/arm/mach-tegra/tegra3_usb_phy.c
arch/arm/mach-tegra/usb_phy.c
drivers/usb/gadget/tegra_udc.c
drivers/usb/otg/Makefile
drivers/video/tegra/fb.c
sound/soc/tegra/tegra_pcm.c
Clean-up the definition of the tegra_gpio enable/disable so that
it compares to the l4t r16 rel.
Change-Id: Ia8584ada1e2a728d2784d6d57c72ed4b0ee01cf1
Signed-off-by: Matt Pedro <mapedro@nvidia.com>
Reviewed-on: http://git-master/r/140648
Fix up the definition of the tegra_gpio enable/disable.
Change-Id: Id71242690efa3e5994a4b70089826f2b87997ece
Reviewed-on: http://git-master/r/140036
Fix the missing tegra_gpio enable/disable function defitintions.
Change-Id: I82ed085bd67486d5e9c383a8c26243e2c1edf670
Reviewed-on: http://git-master/r/140026
Merge with latest NVIDIA L4T R16.
Only real conflict concerning inverted VBUS gpio support.
Add wait for vsync support for one-shot panels. The code supports extension
of this feature to other panels.
Bug 1033411.
Change-Id: Ie4d6cb45e5de81083458169ccdfa33230235ed72
Signed-off-by: Rakesh Iyer <riyer@nvidia.com>
Reviewed-on: http://git-master/r/128927
Reviewed-by: Mrutyunjay Sawant <msawant@nvidia.com>
Tested-by: Mrutyunjay Sawant <msawant@nvidia.com>
Add functionality to enable changing of latency
allowance settings. This is used for memory
tables that may have different tick lengths.
Bug 955082
Change-Id: I3055a062846cfdeb992931e691cf687ffb05725c
Signed-off-by: Ray Poudrier <rapoudrier@nvidia.com>
Reviewed-on: http://git-master/r/124979
GVS: Gerrit_Virtual_Submit
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
bug 1021221
Change-Id: Ifbe007de5bdeafaa15a0b3f2a138086045eba160
Signed-off-by: Raghavendra VK <rvk@nvidia.com>
Reviewed-on: http://git-master/r/118179
(cherry picked from commit 74be8d4e7210d7bcea0d55565a7cbb06d6cc960e)
Reviewed-on: http://git-master/r/121087
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-by: Robert Morell <rmorell@nvidia.com>
The direction apis and irq_set_wake() support the
configuration of pins in gpio mode and hence it
is not require to export the apis for gpio_enable()/
gpio_disable().
Hiding these api.
Change-Id: I5493e4f270df85da21afb6500ac841f4fa4b522a
Reviewed-on: http://git-master/r/119616
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Due to issues with rcu notifiers on secureos, modifying dc flip
notifications to use a simple callback instead.
Bug 1028850
Change-Id: Iebf2a6d64d7316e3df2b88444201f9f9a29698c5
Signed-off-by: Ilan Aelion <iaelion@nvidia.com>
Reviewed-on: http://git-master/r/123103
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-by: Nitin Kumbhar <nkumbhar@nvidia.com>
This is necessary to support future tegra SOC's.
Change-Id: I2f6ce328e30a6895dce16d82c4097291339155cd
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/123146
Reviewed-by: Mark Stadler <mastadler@nvidia.com>
hsic_unregister is being called multiple times
during two step enumeration process of xmm.
In failure cases when enumeration does not
complete properly, kernel panic is seen because
of extra unregister-ehci device.
Bug 1016593
Change-Id: Ibaeb20ed0dab0e906741fdfad78f7d89a3672f60
Signed-off-by: Vinayak Pane <vpane@nvidia.com>
Reviewed-on: http://git-master/r/116626
Reviewed-by: Simone Willett <swillett@nvidia.com>
E1853 is T30 based Automotive platform.
Changes done:
1. New board specific files added
2. Added new machine number for E1853
3. Added pinmux configuration for E1853
Bug 966833
Bug 1018258
Signed-off-by: Ashwin Joshi <asjoshi@nvidia.com>
Change-Id: Ibf1093f59e10a0a5cfa42a177c21c0db01983196
Reviewed-on: http://git-master/r/118000
Tested-by: Ashwin Joshi <asjoshi@nvidia.com>
Reviewed-by: Sandeep Trasi <strasi@nvidia.com>
(cherry picked from commit ad9dd1b3242f23c0f46eaf92ab49f495c06f330f)
Reviewed-on: http://git-master/r/119580
Creates a miscdev at /dev/tegra-throughput which gl will use to set a
target frame rate. In addition it receives notifications from dc on
flip events. On each notification the percentage ratio of the actual
frame time to the target frame time is calculated. In subsequent
changes this ratio will be reported to other modules as a throughput
hint.
Bug 991589
Change-Id: Ieaa2b2755b63d2d071de31e3ef819d4c3b51a956
Reviewed-on: http://git-master/r/116865
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
Add configurability support for i2s parameters accross all board.
ARM: tegra: board: add i2s params
files.
Signed-off-by: Ankit Gupta <ankitgupta@nvidia.com>
Change-Id: If58788b5126280b7e1dc8c66e9c96d0e71229b5e
Reviewed-on: http://git-master/r/111476
(cherry-picked from commit cac52867b0a0cad3b3c5bf46f08b0b94d0be2e02)
ARM: tegra: include: add configurability support for i2s params.
Add several variables for i2s configuration in platform data
structure.
Change-Id: Iea3930f308954471f170513234c2c02a8559ef98
Reviewed-on: http://git-master/r/111473
(cherry picked from commit 35e749770f6046fc82860f1152db2f5f579b9508)
Reviewed-on: http://git-master/r/118071
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-by: Scott Peterson <speterson@nvidia.com>
The one shot thread will clock gate the modules periodically. This will ensure
relevant paths in dc driver have an active dc clock and dsi host.
Bug 1013172
Change-Id: Ibb505e35044f31405c06cb9fa0d6fdf78aafd4a6
Reviewed-on: http://git-master/r/117137
Reviewed-by: Animesh Kishore <ankishore@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
This is a WAR solution that allows for the turning on
SD DPD feature.
The original issue is that enabling SD DPD immediately after device comes
out of LP0 causes ULPI disconnect. The root cause of that is
not known.
The WAR is to delay the enabling of SD DPD for 100ms after
device comes out of LP0.
Bug 929628
Change-Id: I3c5e35ace422e5441535c2c0fe18545b53bbddc4
Signed-off-by: Wen Yi <wyi@nvidia.com>
(cherry picked from commit bffb7b917d52a3523af80db21322ec7ba5fd33f9)
Reviewed-on: http://git-master/r/113392
Update function prototype along with:
commit 6cbf4c7465b7b70936cb422b509da0ad0829c306
ARM: tegra: iovmm: Allow alloc_client to take struct device
Change-Id: I11d173429413ab268f6ab789d90f321e3d33de2c
Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com>
Reviewed-on: http://git-master/r/115391
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Replace IOVMM backend functions with the standard IOMMU API
ones. Instead of modifying the actual C-files in drivers, MACROs in
iovmm.h does the all work.
Change-Id: I27dc893555ca1495588852261e3ba1e3e5619764
Reviewed-on: http://git-master/r/114460
Allow tegra_iovmm_alloc_client() to take struct device * instead of
const char *name w/ __tegra_iovmm_alloc_client(). This is necessary to
support IOVMM and IOMMU simultaneously.
Change-Id: I18df5001bfe0ece8f9f15b636eb11def9f228dfb
Reviewed-on: http://git-master/r/114215
Replace TEGRA_{SMMU,GART}_{BASE,SIZE} with TEGRA_IOMMU_{BASE,SIZE} to
deal with SMMU/GART in unified manner.
This is necessary for DMA mapping API to pass the appropriate IOMMU
address for SMMU and GART in the same code in nvmap.
[Hiroshi Doyu: Squash nvmap parts into "nvmap: API conversion" patch.]
Change-Id: I75429dd56554f880f144c375d2c20e8e8948ceee
Signed-off-by: Vandana Salve <vsalve@nvidia.com>
Reviewed-on: http://git-master/r/114212
Earlier implementation only allowed single wake source
for a particular irq in wake table. Changed implementation
to support multiple wake sources ==> single irq mapping.
bug 980993
Change-Id: Iacb00487531129ef19c53128824aba802e80350e
Signed-off-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-on: http://git-master/r/103140
Add IO and device support for tegra 3 cec block
bug 894195
Change-Id: Icc68b2f900002cf14f48609d4676e7b3e091e948
Signed-off-by: Ankit Pashiney <apashiney@nvidia.com>
Reviewed-on: http://git-master/r/105517
- Gpio freeing function does disabling job.
- If backlight pin is an sfio, we have to claim the gpio. So that we can use
the gpio api's to configure it as sfio.
bug 984440
bug 858120
Change-Id: I583bf4a486d2d9a6d9b78ee459b1962379eafd3b
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/109564
Added skin prediction algorithm.
bug 1007726
Change-Id: Ia76f73cb818aa02e608e1fc69ab4d8277a5825eb
Signed-off-by: Joshua Primero <jprimero@nvidia.com>
Reviewed-on: http://git-master/r/104814
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Implemented an object based balanced throttling in preparation
for multiple balanced throttling objects.
bug 1007726
Change-Id: Ib58fafaf696af0ae58e78bd9fd417d3a822d0571
Reviewed-on: http://git-master/r/105238
Send specified DC frames to 720p panel during power up/down sequencing.
Bug 997484.
Change-Id: I3927e98322ec93f68cabf635c71485b64750d7f9
Reviewed-on: http://git-master/r/109917
(cherry picked from commit e1d10bc056031fbc2f68101978d76317c44fc7af)
Reviewed-on: http://git-master/r/111944
Bug 995950
Signed-off-by: Sang-Hun Lee <sanlee@nvidia.com>
Reviewed-on: http://git-master/r/110190
(cherry picked from commit cbfc31fb126cd651157125d1785135eced6587dd)
Change-Id: I44eb889235db82b0efda238b87be5612425afb9d
Reviewed-on: http://git-master/r/110978
We support 3 different aggressiveness levels of disabling DSI runtime.
The larger the aggressive level is, the higher DSI power we can save.
Bug 936337
Change-Id: Idadcb49b364e29ddd0a05dde1c6d3dfda6cd493e
Signed-off-by: Kevin Huang <kevinh@nvidia.com>
Reviewed-on: http://git-master/r/106361
1. Add sysfs file so the fild can load/unload host controller before
modem power cycle.
2. Move modem boot irq to modem PM driver.
3. Add short autosuspend to optimize power consumption if the wake
source of system resume is not modem.
4. Avoid LP0 abort if remote wakeup happens during L0/L2 -> L3
transition.
5. Fix deadlock in pm_notifier function.
Bug 975990
Signed-off-by: Steve Lin <stlin@nvidia.com>
Reviewed-on: http://git-master/r/109079
(cherry picked from commit 0b60aade303a022ff3335b4a238ba2dbae4da4b5)
Change-Id: I9bcac40e2f93f95c702b42a2eb5e4e9aa7a9d721
Reviewed-on: http://git-master/r/103981
Reviewed-by: Uday Raval <uraval@nvidia.com>
Tested-by: Steve Lin <stlin@nvidia.com>
Reviewed-by: Steve Lin <stlin@nvidia.com>
Part of panel settings need to be done before/after pixel clock
is disabled. Add support for these actions to meet panel
spec.
bug 976081
Signed-off-by: Ken Chang <kenc@nvidia.com>
Reviewed-on: http://git-master/r/102542
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
(cherry picked from commit dcecdc64d4d0fd4d9f69df52c9d200dfbf1dd7fc)
Change-Id: Ibfede68d67a4815156f73c2d1cdca90f3f771755
Reviewed-on: http://git-master/r/110296
Bug 990586
Change-Id: I63da2bd0aaae86070718e0d769b8c9555db18547
Reviewed-on: http://git-master/r/107714
Bug 936337
Bug 899053
Change-Id: I2b3d8cfc8a00881338c1e17d03f2844d15ba7d3e
Reviewed-on: http://git-master/r/106313
The function tegra_dc_host_trigger() is no longer used, removing it.
Change-Id: I929450bdf0224779910e8569bc8d1b3edb93f12d
Signed-off-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-on: http://git-master/r/106075
sdio supports 1.8 volts, setting 1.8 volts for
cardhu, kai, ventana, whistler
Bug 979504
Change-Id: I8f03b01e0792ac0e6abe74ce898934e65762fb85
Signed-off-by: naveen kumar arepalli <naveenk@nvidia.com>
Reviewed-on: http://git-master/r/104712
Added code to select i2s vs tdm mode.
Added tdm-pcm-audio device defination.
Changed the pcm driver to use tdm-pcm-audio device.
Added fields to pass the pcm driver name to ASoC.
Added P1852_TDM config to KConfig and Linux defconfig
Bug 948478
Change-Id: I82fa03ab947cc615089e0a3107fb53901a1c00cd
Signed-off-by: Bob Johnston <bjohnston@nvidia.com>
Reviewed-on: http://git-master/r/105383
Warnings removed are related to unused variables/labels,
structure/argument type mismatch, copyright update, function return
type mismatch and wrong C coding style.
Bug 949219
Change-Id: Ib748d12d5ab3cfc35118be28c29983081cca6cbb
Reviewed-on: http://git-master/r/103770
Refactored the phy interface to scale multiple usb
phy hardware versions and for ease of maintenance.
Bug 887361
Change-Id: I08ea9e728f760ca123af7777d3ffabbd71a1aa99
Signed-off-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-on: http://git-master/r/103598
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Detect the stride size used by the bootloader.
If DC is not enabled, fallback to a default stride size.
Bug 973111
Change-Id: If04647ddf04a44987cd841062ff30e03fa4d6a02
Reviewed-on: http://git-master/r/104031
Set default videomode during the dc probe. This patch enables
HDMI during the probe only and fixes following issues:
1. Until Xinit there was no display on HDMI.
2. Framebuffer console on HDMI needs it to be enabled well before
Xinit.
To avoide un-necessary powering on HDMI,Check HPD and enable HDMI
only if it's present.
Bug: 930136
Bug: 977705
Change-Id: Ifb71328e5df0ccbb5751669db71fd24719fe3738
Signed-off-by: Shashank Sharma <shashanks@nvidia.com>
Reviewed-on: http://git-master/r/100656
(cherry picked from commit dfd813141283891e397d73958aabad38eddfe350)
Reviewed-on: http://git-master/r/103630
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Added TDM mode params to be passed from platform to the machine driver
Bug 948478
Change-Id: I909db0ceebde002fcebcf7635cebe98c6a74142d
Signed-off-by: Nitin Pai <npai@nvidia.com>
Reviewed-on: http://git-master/r/103594
All throttling must go through the Linux thermal sysfs
framework now.
Change-Id: Ia871e0b06e548d5d82211a65979bea52a6c28fb0
Reviewed-on: http://git-master/r/103183
It is moved to kernel/include.
Bug 854182
Change-Id: I3fb729c88e29a9f213656fbf20810c10dfd9d7a6
Reviewed-on: http://git-master/r/102727
Reviewed-by: Bo Yan <byan@nvidia.com>
