There was no code to clear interrupt registers for AVP. First run
of AVP was OK because those registers start from reset value.
But because those registers were not cleared, when the second
time AVP was started, some interrupts were enabled too early.
That caused interrupts coming before handlers were ready.
This change also removes the workaroud for the bug.
bug 827353
bug 826234
Change-Id: I51546400f0bace67dfcdb23f667c051c060d3983
Reviewed-on: http://git-master/r/33083
Reviewed-by: Niket Sirsi <nsirsi@nvidia.com>
Tested-by: Niket Sirsi <nsirsi@nvidia.com>
Change SOC conditionals to make them more forward-looking.
Change-Id: Ib60db4e690c2f396afdec962616d735548b5a8a9
Reviewed-on: http://git-master/r/32706
Extend the wait interface to relay the actual resultant waited
point back.
Change-Id: Idbaa96b186390a2383ef2cc99aefb950648a2d19
Reviewed-on: http://git-master/r/23033
Dynamic Voltage & Frequency Scaling (DVFS) is not possible on
FPGA platforms. Completely remove the DVFS code from the image
on FPGA platforms to reduce the image size.
Change-Id: I4f1a8587f01e775000f48fbca7c85d75acee9c74
Reviewed-on: http://git-master/r/32466
Change-Id: Ia36ea70b054262772df39650b5fdc7419be2bfcf
Reviewed-on: http://git-master/r/32802
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
Tested-by: Diwakar Tundlam <dtundlam@nvidia.com>
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Adding the support in function gpio_to_irq() such that the external
gpio peripheral driver can provide the gpio to irq number through
their gpio implementation.
Change-Id: Ibab369df435af79ce09d71e491a8ee851f2228ba
Reviewed-on: http://git-master/r/32563
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
bug 622025
Change-Id: Ic01ad6e93a26b332e016fcef6dbc928918c25745
Reviewed-on: http://git-master/r/29952
Tested-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
arch/arm/mach-tegra/include/mach/dc.h
drivers/video/tegra/dc/dc.c
Change-Id: I88eb56972632ec9c87c6ac81c14c0cadb689415c
Change-Id: I80fdbf17c2e3a77be3ea63350191c8eab235ed94
Change-Id: I82497fc756552740836eaa2f608fecaea409cfeb
Signed-off-by: Michael I. Gold <gold@nvidia.com>
Change-Id: Ied3851e0cb801f607499493f1e552f42daa97e6b
Signed-off-by: Ari Hirvonen <ahirvonen@nvidia.com>
Support for power management in dsi kernel driver
Bug 793857
Change-Id: If2ac183c830974d33b9aeeb615178cf554136bbf
Reviewed-on: http://git-master/r/31541
Reviewed-by: Animesh Kishore <ankishore@nvidia.com>
Tested-by: Animesh Kishore <ankishore@nvidia.com>
Reviewed-by: Narendra Damahe <ndamahe@nvidia.com>
Add support for usb hotplug, this change will add the following:
vbus is left enabled.
Bug 796158
Bug 801533
Change-Id: I282da0a37ab4311d9d9c61f75e03228bfb15698e
Reviewed-on: http://git-master/r/30041
Reviewed-by: Suresh Mangipudi <smangipudi@nvidia.com>
Tested-by: Suresh Mangipudi <smangipudi@nvidia.com>
Tegra cpu-freq driver will now recognize edp zones
and cap the max cpu freq for that zone. The temperature
monitoring driver will be giving inputs to cpu-freq
on the current temperature which would be interpreted
by the cpu-freq driver appropriately.
Change-Id: I918eb31771aa7e1e1a5f25438edded727de6eb8c
Reviewed-on: http://git-master/r/31339
Audio manager common interfaces are defined to be called from
SOC code. Audio manager will make the decision which all modules to
be controlled based on use case connection.
Correction added to the speaker amp and i2c gpio is provided for
controlling the speaker amplification. Removed the speakersetting call.
Change-Id: Id2c7f953fc78f66bee2e1d4773e03548de0ba5b4
Reviewed-on: http://git-master/r/30891
Reviewed-by: Vinod Gopalakrishnakurup <vinodg@nvidia.com>
Tested-by: Vinod Gopalakrishnakurup <vinodg@nvidia.com>
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Adding a build time CONFIG option to enable forcing of conversion
of non-IRAM CarveOut memory allocation requests to IOVM requests.
Default is "y" to force the conversion.
Each forced conversion is reported to console.
Allocation alignments larger than page size for IOVM are enabled.
Single page CarveOut allocations are converted to system memory.
CarveOut memory reservation has been removed for aruba, cardhu,
and enterprise.
Change-Id: I3a598431d15b92ce853b3bec97be4b583d021264
Reviewed-on: http://git-master/r/29849
Changed the values of packet sequence registers for DSI burst video mode.
Change-Id: I70188ed3c8fff094862a89377457751fd0d4382c
Reviewed-on: http://git-master/r/31080
Reviewed-by: Kevin Huang <kevinh@nvidia.com>
Tested-by: Kevin Huang <kevinh@nvidia.com>
Exposed the baseband i2s port for cardhu.
Added separate audio init function.
Change-Id: I9ff38f101c5540ad6e2365ed93a8c88373164ea3
Reviewed-on: http://git-master/r/30087
Reviewed-by: Scott Peterson <speterson@nvidia.com>
Creates /d/tracing/events/nvhost. Logs channel opens, closes,
writes and flushes. For writes, logs number, size and address
of cmdbufs and number of relocs.
Change-Id: I5bdadcb40c31e3f057eb8c4579b95e235d860e39
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/29770
Reviewed-by: Andrew Howe <ahowe@nvidia.com>
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
arch/arm/mach-tegra/usb_phy.c
drivers/usb/gadget/fsl_tegra_udc.c
drivers/usb/host/ehci-tegra.c
Change-Id: I62d72b8b96d4039bd0d253583c415ae714fb2693
* add bsea engine support for encryption and decryption
* add arbitration semaphore id for bsea
Bug 803932
Original change: http://git-master/r/#change,29672
(cherry picked from commit 0008cdb0f38d0cd0c074671fc067c4321f340b06)
Change-Id: I59fcaab29c47a8b42e7470b30486851cfe90848f
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/30190
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
Switching off and switching on the power rails during
suspend and resume. Passing the power rail name, maxV
and minV through platform data.
Bug 793796
Change-Id: I6c80c1a23c9681043d11ffdd210dc6d2146bdd2e
Reviewed-on: http://git-master/r/29660
Reviewed-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Tested-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Modified cardhu board config for ehci2 to use HSIC.
Need to turn on 6416 IO expander gpio for VDDIO_HSIC. Otherwise,
VDDIO_HSIC would be 0 Volts.
Fix HSIC register differences between T20 / T30.
Change-Id: I03079d4691981c8bc5fa220720aa55de507e6f04
Reviewed-on: http://git-master/r/29428
added support for audio BT sco usecase. For BT sco, i2s is
programmed in pcm mode.
Change-Id: Iffcfb707cd2c025b78b82e70ba35f89d47a21263
Reviewed-on: http://git-master/r/30042
Reviewed-by: Ravindra Lokhande <rlokhande@nvidia.com>
Tested-by: Ravindra Lokhande <rlokhande@nvidia.com>
bug 820773
Fix the audio issue resulted from code merge.
Change-Id: I37999fabec7de077eac337db33eb2b01939349fc
Reviewed-on: http://git-master/r/29684
On tegra3 TRM, some of the pin mux option for a given
pin group is not recommended and so not exposed in the
TRM reference table.
Updating the pinmux table accordingly. The non-recommended
pin option is set as TEGRA_MUX_INVALID.
bug 817099
Change-Id: I572ee84912fe065a73e59d4f9ba0ce01223ead85
Reviewed-on: http://git-master/r/29626
By changing the dma allocation API to take the client name, it is easy
to track who is allocated the DMA channels when we run out of the
DMA channels.
Original-Change-Id: I016011cfd74089fed0da1bc0f121800017ce124a
Reviewed-on: http://git-master/r/28031
Change-Id: I048bcb87f95ee6d8ad2fdce993a1758dc5071666
bug 793875
bug 818490
Merge spdif soc code from dev_hc.
Add clock and power mode calls to spdif
Fix the system suspend/resume issue caused by audio modules.
Original-Change-Id: Ie6d9c1e52596fa744dff893fd7340c1fa2f0f058
Reviewed-on: http://git-master/r/28520
Change-Id: I367a048727b5fbe1a8db70a140b6ed1d752cd3a5
Added board level tuning parameter to specify minimum LP2 residency
time (previous policy allows down to zero residency targets limited
only by LP2 exit latency).
Original-Change-Id: I4ae7d458fba78f35a40f138cf9489bf938715b22
Reviewed-on: http://git-master/r/28162
Change-Id: I38e798ca6d242d136ea2353d90cc961de14f25b6
Fix slot control and lrck programming.
Original-Change-Id: Ib6fcb4bdb909b41db892cabdd901dcf3384fa7d6
Reviewed-on: http://git-master/r/28190
Change-Id: I1f5108367ea6e0a9714831761b0f5ad1a63e2450
Fix "initialization from incompatible pointer type" warnings due to
a mixure of void and non-void functions used as initializers for
arrays of type tegra_phy_fp[]. All functions of type tegra_phy_fp
now uniformly return a status.
Original-Change-Id: I2fa80d329817ab6dffd789a34fc5dc3baca7dbff
Reviewed-on: http://git-master/r/28088
Tested-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Szming Lin <stlin@nvidia.com>
Reviewed-by: Rakesh Bodla <rbodla@nvidia.com>
Change-Id: I5515a933c850b4e51315a3791cab6e0b81bc8444
Add calls to support clocking and power to dam module.
Corrected and cleaned up the dam code.
bug 804696
Original-Change-Id: Icfff431504ce66bd781c99476e34a34a7ccfcd72
Reviewed-on: http://git-master/r/27817
Change-Id: Ifd2b20a65cae89ae90e32a4170ec540157dc4c43
added suspend/resume calls to audioswitch and i2s code
is using those calls.
Original-Change-Id: I475f43b67feeab61f1a3fd84f446ba5c4e126f87
Reviewed-on: http://git-master/r/27697
Change-Id: Ie01d6d20c24902a42461bcdb42d9bef57c7cc63b
Rearrange the i2s clock code so that it will be handled properly
using the audio_manager code.
Mclk code is moved to audio_manager from soc.
bug 804696
Original-Change-Id: Icf9e823154cf3b5a63426944c4864a413df82213
Reviewed-on: http://git-master/r/27255
Change-Id: I8acd9c5d5389b3d4ca574bd62a392c56fdfa35b7
Using proper usb phy types instead of hard coded usb instance.
Bug 800301
Original-Change-Id: I24a66ce062b937a947ac6cb34e829d6b42ecf0b4
Reviewed-on: http://git-master/r/24371
Change-Id: I5a4bd4d25ec8d4d4335f17d0794c4440a470a099
Original-Change-Id: I158d2be97c795313e7e74ce9fb4ec0bdc7d95496
Reviewed-on: http://git-master/r/27559
Reviewed-by: Hiro Sugawara <hsugawara@nvidia.com>
Reviewed-by: Jin Qian <jqian@nvidia.com>
Reviewed-by: Kaz Fukuoka <kfukuoka@nvidia.com>
Change-Id: I0ff198daa548ed2837f7fb1794013bf0adf7e5a1
add new dc out callback hotplug_init and postsuspend to handle board
specific configuration of power and gpios for detecting hotplug.
bug 812083 bug 811523
Original-Change-Id: Ia7937cc9461465502cabbd2a5efaee0093bccfe0
Reviewed-on: http://git-master/r/27570
Reviewed-by: Jonathan Mayo <jmayo@nvidia.com>
Tested-by: Jonathan Mayo <jmayo@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Change-Id: Iab0fbe0e493ad3818416454ba7a2dda679f68dfb
Change-Id: Ibf2914683b617ef036c7c9abc89ed9407a2d2a07
Original-Change-Id: Ie4b29d1119bc2f640891525ab781c8de1bf64ddf
Reviewed-on: http://git-master/r/23215
Tested-by: Jin Qian <jqian@nvidia.com>
Change-Id: Idc616485ecdb9e7c39728409d91a511e1de79e05
Change-Id: I8f344d368a501c7bb3c0eba6cecabd7c48a6c9a2
Tegra3 A01 continues to use the high address range.
Tegra3 A02 (and after) uses the bottom 1GB.
The new AHB register bit access has no effect to Tegra3 A01.
Original-Change-Id: I90cedbb22d9aae4307908750ebeb03bef639945c
Reviewed-on: http://git-master/r/23379
Tested-by: Hiro Sugawara <hsugawara@nvidia.com>
Change-Id: I33253f8ae32c416a9d19694e87380dbae94c2f68
Making the regulator power supply names independent of platform.
Now, power supply names should be given through board specific
files.
Bug 807534
Original-Change-Id: If83a23df91de9efd7d06733a7a306e57f3c89315
Reviewed-on: http://git-master/r/25058
Tested-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-by: Hanumanth Venkateswa Moganty <vmoganty@nvidia.com>
Reviewed-by: Allen R Martin <amartin@nvidia.com>
Change-Id: If7c7600e49b9d1f4c1bcd5d1e6eba098df39cb0b
Change-Id: Icb70299bafebbec75614dccbc09833dc5681b402
Change-Id: Idc283042ec10cf1b38ca073df138125b03568e2d
Big 804696
Added the dynamic apbif channel allocation to be used among
various controller. Support added to more apbif function calls
Original-Change-Id: I5420751037eebb07e4c9a3be339ce5c72174d1be
Reviewed-on: http://git-master/r/24774
Change-Id: If38be7a842ed7684978a8853106dcadf04e6520d
After kernel merge usb is broken. This is due to
improper merge of usb files. Fixed all the merge
issues.
Bug 807534
Original-Change-Id: Id9f6ae0022a84bcc7b4e39965a469ae8947faa83
Reviewed-on: http://git-master/r/24806
Change-Id: Ib5f76a2660f8d761eac08721c7d147b8cc11c2bf
Rename timer.c to timer-t2.c for consistency with other
chip-specific implementations.
Bug 790458
Bug 790448
Bug 738259
Original-Change-Id: I7e0fceb716590cd92b64ba00c0bebe659e9beb21
Reviewed-on: http://git-master/r/22885
Change-Id: I322324c2177d57657a63e9428f8e49d5df2b828e
The EVP reset vector for the CPU must be written one and only once
per cold/warm boot session. Enable Tegra3 hardware enforcement of this.
Bug 786290
Original-Change-Id: I4231e0c85db2a1e8fce92f6a72d3d8a57cc0be64
Reviewed-on: http://git-master/r/22863
Change-Id: I4797d5b17387fb9ca23f8aebb61bea1aecd05cfd
Change back to the backwards compatible null kickoff method
(having a separate ioctl).
Original-Change-Id: Ifb6e706ac9e068c5bc8d834fe61f797f14c5889f
Reviewed-on: http://git-master/r/24159
Change-Id: Ifde9ee33e072ec502fcd855ffc8d92d312946a00
