Tegra wake source interrupts are only enabled before suspend
bug 904746
Change-Id: Ie9722199b4541f2bac77e47d0c8c7e65d5d8b54d
Signed-off-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-on: http://git-master/r/115655
Earlier implementation only allowed single wake source
for a particular irq in wake table. Changed implementation
to support multiple wake sources ==> single irq mapping.
bug 980993
Change-Id: Iacb00487531129ef19c53128824aba802e80350e
Reviewed-on: http://git-master/r/103140
Move Tegra GIC initialization to be with the other GIC functions.
Change-Id: I9b23757d135f3a9062f21fccb816c745ce8add43
Signed-off-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-on: http://git-master/r/78829
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-by: Mark Stadler <mastadler@nvidia.com>
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
It is possible for GPIO interrupt to occur when registering handler
since set_irq_chained_handler enables GPIO interrupt. Thus
all relevant variables are required to be initialized
before calling set_irq_chained_handler.
Also add initialization of interrupt status register.
Bug 884569
Reviewed-on: http://git-master/r/58218
(cherry picked from commit e03fe4cc1bf06fa6c32c0520e2ba31f009f9301d)
Change-Id: Ic76f95215b61d6e091ae1cfa11522f8af9c3eecd
Reviewed-on: http://git-master/r/60475
Reviewed-by: Daehyoung Ko <dko@nvidia.com>
Tested-by: Daehyoung Ko <dko@nvidia.com>
Rebase-Id: R5340918dccc1a8b1d95c5b629cc985f44d45fb67
There was no code to clear interrupt registers for AVP. First run
of AVP was OK because those registers start from reset value.
But because those registers were not cleared, when the second
time AVP was started, some interrupts were enabled too early.
That caused interrupts coming before handlers were ready.
This change also removes the workaroud for the bug.
bug 827353
bug 826234
Original-Change-Id: I51546400f0bace67dfcdb23f667c051c060d3983
Reviewed-on: http://git-master/r/33083
Reviewed-by: Niket Sirsi <nsirsi@nvidia.com>
Tested-by: Niket Sirsi <nsirsi@nvidia.com>
Rebase-Id: Rb45b8d54afeda71d35c011120fc0e748929ad74e
For Linux 2.6.39, CONFIG_PM_SLEEP is the proper kernel configuration
parameter to use on Tegra for power management, and not CONFIG_PM.
CONFIG_PM does not have the required dependency on CONFIG_SUSPEND
necessary to pull in the CPU suspend/resume functionality used by
Tegra.
Also fixes compilation errors when CONFIG_PM and by implication
CONFIG_PM_SLEEP are not configured.
Change-Id: I8bb380ae7c6b22759bfbc223febc28f585111aad
Reviewed-on: http://git-master/r/40458
Tested-by: Daniel Willemsen <dwillemsen@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Rebase-Id: R61d656cd67439aa9f466c381845d7a4685fc8648
Original-Change-Id: I2ffeaf6f8dfeb279b40ca6f69f6c9157401a746a
Rebase-Id: Rd8ebde470ad475b826857413018a2da8e1fdea25
Bug 764354
Original-Change-Id: I8a390eb4dae87dceacb97461f23d13554868b046
Reviewed-on: http://git-master/r/12228
Tested-by: Scott Williams <scwilliams@nvidia.com>
Original-Change-Id: I8e6b8303898796419fb5a759cd16edff9aeac081
Rebase-Id: R2866240384c6c24f46bd7ef54bc3dc9140d9e96b
Add LP0 wake irq handling in pm-irq.c, called from irq.c and
gpio.c.
Use IRQCHIP_MASK_ON_SUSPEND for LP1 wake irq handling, when
the legacy irq controller stays powered.
Determine valid suspend modes based on requested wake sources.
Signed-off-by: Colin Cross <ccross@android.com>
Change-Id: I547bd8290c0921163054d49f43141379e8f9f493
Implement irq_eoi to allow the GIC irq chip flow controller to
be changed to fasteoi.
Now that irq.c is just an interface layer between the gic
and legacy_irq.c, move the contents of legacy_irq.c into
irq.c.
Tegra PM irq support is being improved, remove it for now
until the rest of the platform gets PM support.
Replace the ugly hack that inserts legacy irq controller calls
into the irq call paths by reading and replacing the gic irq
chip with the new gic arch extensions.
Use irq_set_chip_and_handler() instead. Converted with coccinelle.
Convert to the new function names. Automated with coccinelle.
A future patch will export gic_mask_irq and gic_unmask_irq.
Rename the pointers in arch/arm/mach-tegra/irq.c to avoid
a compile error.
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca>
Provide gic_init() which initializes the GIC distributor and current
CPU's GIC interface for the boot (or single) CPU.
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
Tested-by: Abhijeet Dharmapurikar <adharmap@codeaurora.org>
mirror IRQ enable and disable operations on the legacy PPI system
interrupt controller, since the legacy controller is responsible
for responding to wakeup interrupts when the CPU is in LP2 idle mode
save the irq controller state on suspend and restore on resume
Signed-off-by: Gary King <gking@nvidia.com>
v2: fixes from Russell King
- include linux/io.h instead of asm/io.h and mach/io.h
Signed-off-by: Erik Gilling <konkers@android.com>
