Move the device structures to the driver source code files. Register
all nvhost_device's in one loop which is called from board file.
host1x driver code is moved to live under host1x, too. This causes
a need to add host to include path of tegradc and nvavp.
Bug 982965
Change-Id: If99cf9d1ef6bc24663ee8294c19370429ed04ca7
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/104076
Reviewed-by: Simone Willett <swillett@nvidia.com>
- Adding flag to treat warning as error.
- Handling warnings of unused variable, structures and functions,
wrong return type, wrong type comparision.
Bug 949219
Change-Id: I9d02387ce1073c4e46f69d01669285aa3754f1d9
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/104968
Removed unused wake header file from Tegra board files
bug 980993
Change-Id: I61d919a2dc5b98caaca612b990fd1a7d06e76ae2
Signed-off-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-on: http://git-master/r/103622
Modify USB structures of platform data. Based on the new
platform data structures modifying the initialization in
board files.
Bug 887361
Change-Id: Ie6347a078c9a596a4debe21a353e127ddde35220
Signed-off-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-on: http://git-master/r/103597
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Use nvmap.h include file from kernel/include instead of mach-tegra/include.
Bug 854182
Change-Id: Ic82b35d6c2e1c49461575a7bbbfd28ee43921466
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/102723
GVS: Gerrit_Virtual_Submit
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
CSUS clock can't be driven from any clk other than clk_m. So
updating its parent to clk_m.
Removing pll_m's entry as it's already enabled and running at
666 MHz which is our requirement.
Removing tegra_init_suspend() as it's not needed on p852.
Bug 938667.
Bug 949584.
Change-Id: Id62401de11d213d4e0b87b52fe30e2b37372bbea
Signed-off-by: Vishal Singh <vissingh@nvidia.com>
Reviewed-on: http://git-master/r/94237
Reviewed-by: Manoj Chourasia <mchourasia@nvidia.com>
Reviewed-by: Sandeep Trasi <strasi@nvidia.com>
Changing the values of registers timing0 and timing1 of NOR flash
to those specified in the NOR POR.
Bug 914158.
Change-Id: Ie65fadbeda7329b22786841f46dd2583043a8381
Reviewed-on: http://git-master/r/#change,72828
Reviewed-on: http://git-master/r/91737
Tested-by: Vishal Singh <vissingh@nvidia.com>
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
- the suspend order of devices is governed by the order
in which devices are registered
- this commit ensures that nvhost master is registered before
any of the graphics devices
- previously this was done in rootfs_init call which is
later than arch_init calls of board-xxx-panel.c
- this caused tegra-dc device to be registered *before* nvhost
master device. as a result it was suspended *later* than nvhost
master device. this is a clear violation of dependency rule
for nvhost. this caused suspend-resume to fail for L4T
- this worked on android as it has CONFIG early suspend enabled
while it failed for L4T which doesn't have CONFIG early suspend
enabled
Bug 947617
Change-Id: I6cd405f3ba23d004e7659140019f5130e6c25159
Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Reviewed-on: http://git-master/r/87756
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
- tegra_grhost is a platform device that represents host1x
- nvhost has device host1x which represents the same hardware
- merge these two device structs
- as the new struct is a nvhost_device, platform_driver
is also converted into a nvhost_driver
- register nvhost device before other graphics devices.
this ensures that nvhost_probe() is called as soon as
nvhost_driver is registered with the core.
- this also ensures that nvmap is probed first, followed
by nvhost, followed by tegra-dc and nvavp (if they
are enabled).
Change-Id: Ic420a6516a9cb20d6f481692a4db10fa6053dd90
Reviewed-on: http://git-master/r/82631
Opt into the tps6586x registering the pm_power_off handler instead of
doing it ourselves.
Change-Id: Ia722505aa3ee6eba8dd5ebe7769d784045d76ec4
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-on: http://git-master/r/83604
Get timing register value from platform data
instead of timing structure.
Fix NOR device registration using tegra_nor_device.
Signed-off-by: Manoj Chourasia <mchouraia@nvidia.com>
Reviewed-on: http://git-master/r/56889
(cherry picked from commit f77e726ec89d09ba3174a395d9f98c1b02a83c58)
Change-Id: Ie5ea216a770c998dd2ce578f206f83bcbd248fd2
Reviewed-on: http://git-master/r/67710
Tested-by: Manoj Chourasia <mchourasia@nvidia.com>
This patch adds initial support for p852 platform
bug 872849
Signed-off-by: Manoj Chourasia<mchourasia@nvidia.com>
Reviewed-on: http://git-master/r/46397
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
(cherry picked from commit 7c3e671d05fcabdac4e73adf8f3f297924d44498)
Change-Id: I098489f5ef672ab1462edc0a188dc107f1291435
Reviewed-on: http://git-master/r/56897
Rebase-Id: R7bfc6620b98515249ead457cf9dde9d2f267de64
