This reverts commit 06c880a6086183173c361b4a9d4f8047c6a39769.
This CL is reverted as it causes write perf regression with lmbench(bw_mem)
benchmark.
Bug 1026077
Change-Id: I7ff9ffbfe74e2083aa43cab75b694b1c61987bc3
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/125097
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
This reverts commit b25193d5c3e2c59169c127d23b59123136cfefa7.
benchmark.
Bug 1026077
Change-Id: I9858c88a6e846d2c3629f14c7cc62a7feb4f4528
Reviewed-on: http://git-master/r/125096
On Tegra3 make sure cpu rate is within G-mode range before LP to G
mode switch triggered by secondary cpu boot directly from LP mode.
Bug 988544
Change-Id: I0d86fbf0727a6bbf6069159e7c532947a9d0af73
Signed-off-by: Alex Frid <afrid@nvidia.com>
Reviewed-on: http://git-master/r/115930
Reviewed-by: Peter Boonstoppel <pboonstoppel@nvidia.com>
Reviewed-by: Greg Lo <glo@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Bug 947861
Change-Id: I1ac97b5de5e7e79a418b3c38c70df4976616cdf3
Reviewed-on: http://git-master/r/100457
Enable speculative line fill in SCU.
Bug 947861
Change-Id: I2db7515c47715160a4e559931e178b41c01a1744
Reviewed-on: http://git-master/r/91834
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
cherry-picked from adf08ef4030598a6bf9036f45584be8acc008fea
Bug 862504
Change-Id: I79460aa4abdccc4f2ca17867197bb12668d59dea
Reviewed-on: http://git-master/r/52420
Tested-by: Jin Qian <jqian@nvidia.com>
Rebase-Id: Rffc2d7314a61f04274e0db116c5a1cb7004dc77d
Change-Id: I156af0bdd8b37cb23aec214c3e158027252e27e1
Signed-off-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-on: http://git-master/r/51157
Rebase-Id: R795bf03590a76b6c494afd37603ed951dc2cd082
Change-Id: I07c389092132e52e2bdd3deab22c10f8e1e6035c
Reviewed-on: http://git-master/r/48798
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Rebase-Id: R1e0c9acc87c81f9d0dc394c09d6a7b8b94c48d3f
Use the value calibrated by master cpu.
Bug 843553
Original-Change-Id: I88939f37050873e0633782f6a927ffaf9b8d776d
Reviewed-on: http://git-master/r/47988
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: R6520764a88346d5ab4a180810636b04ce474f4d7
This change provides a centralized location for powergating modules.
It would take care of switching on/off clocks while un-powergating/
powergating modules respectively.
Bug: 814267
Original-Change-Id: Ic80dc517f634c29085c8e089bdaa32c6fd742710
Reviewed-on: http://git-master/r/31776
Reviewed-by: Niket Sirsi <nsirsi@nvidia.com>
Tested-by: Niket Sirsi <nsirsi@nvidia.com>
Rebase-Id: Rc0aac0edd4e693c15d22d998c882fceeeb85765d
For CONFIG_SMP systems that report only a single CPU available,
platform_smp_prepare_cpus() will never get called. Make sure that
tegra_all_cpus_booted is properly set in this case.
Change-Id: I6bf30be02c0b692f0578eb9a19062bcb562c1892
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Rebase-Id: Rb800c15e27cff51a091e8e704610ed72572b4b6e
- For CONFIG_SMP kernels on systems that only report one CPU available,
there is never a call to platform_smp_prepare_cpus() which means
the reset handler would not get initialized. Invoke the reset handler
initialization from smp_init_cpus() if there is only one CPU.
- For non-CONFIG_SMP kernels, the call to initialize the reset handler
got accidentally dropped in the port to Linux 2.6.39. Invoke the
reset handler initiazation from tegra_init_early() in this case.
Change-Id: I782faf84c89d4285aac26bfccb829f27878029de
Rebase-Id: R9b35221571885a1620e0d7e19880b05a18c97233
Add support for forced Tegra3 LP2 low power mode on the boot processor
(CPU 0) via the cluster control interface when all others are offline.
Switching to the LP CPU mode is also enabled with this change.
LP2 in idle and LP2 mode on the secondary processors is not yet
supported.
Change-Id: Icb898729f093be5e006c413f701532dd45228687
Rebase-Id: Rd5d8c2b0addfd6853033670b992ae082e4a0d9c8
- Add a single unified handler for all CPU resets that is copied to
IRAM.
- Add state information to direct the flow of execution through the
reset handler based on the reason a CPU was reset.
- Write the EVP CPU reset vector only once per cold/warm boot session.
- Prevent modification of the EVP CPU reset vector in Tegra3.
Bug 786290
Bug 790458
Change-Id: Ica6707f3514986ee914e73a2d9766a4e06ce2d29
DW: Split into logical changes
Rebase-Id: R7b9859a83717e76c3c083bdde724bd5fef9ce089
Change-Id: Id45f6be8336370bf011484bea0a90e7e9f49f026
Rebase-Id: R06af455b61cb70a1a7dc18b38ad3f816d4ccba63
Change-Id: I07ffcffafcf47fd7539b22d4829712e041293bf3
Rebase-Id: R34a7800e24254d54b499411652d59421be703619
Rebase-Id: Ra4550b3ee066c825b3484bac1e928fe8c086e0c4
Change SOC conditionals to make them more forward-looking.
Original-Change-Id: Ib60db4e690c2f396afdec962616d735548b5a8a9
Reviewed-on: http://git-master/r/32706
Rebase-Id: R77c675a1995116098b58f1f775bc7c3cc8722998
Check the CPU is ever booted before entering into
powerup status confirmation loop.
BUG 824307
Original-Change-Id: I474d0536b00e84967a240037d2ed984a889dd2e0
Reviewed-on: http://git-master/r/30679
Reviewed-by: Venkata Jagadish <vjagadish@nvidia.com>
Tested-by: Venkata Jagadish <vjagadish@nvidia.com>
Rebase-Id: R2346bcc108f59eae21cc98a311b95dc702c0a57e
Added second level virtualization (on top of virtual cpu rate control)
to support different Tegra3 CPU power modes: low power (LP) mode and
geared performance (G) mode. Virtual cpu complex (cpu_cmplx) clock is
defined as a child with two parents: virtual cpu_lp and virtual cpu_g
clocks for the respective modes. Mode switch sequence was integrated
into cpu_cmplx set parent implementation. (Before this commit mode
switch was triggered outside the clock framework, which created cpu
clock/mode synchronization problems).
Each mode clock is derived from its own super clock mux (cclk_lp and
cclk_g) to statically match Tegra3 h/w layout. (Before this commit the
code had to dynamically synchronize CPU mode and active mux selection).
This change also allowed to support PLLX output divider for low power
mode as fixed 1:2 divider with bypass control embedded into cclk_lp
parent section.
Updated auto and sysfs CPU mode switch calls to use new clock framework,
and removed clock manipulation from the low level mode switch
implementation.
Original-Change-Id: Ibc3cc495b2ff29e2d3417eff2bfd45535cbd015b
Reviewed-on: http://git-master/r/24734
Tested-by: Aleksandr Frid <afrid@nvidia.com>
Original-Change-Id: I23ae80edbf14fb22727a6fc317cd9e5baf8bd6be
Rebase-Id: Rdcd4a2165ebd92bf4caa35d68ca81d19a3789351
- Wait for power up status confirmation after secondary CPU was
un-gated by flow controller (instead of directly UN-gating CPU
again if the 1st status check failed).
- Enable CPU clock only after power up is confirmed.
- Insert propagation delays before and after removing clamps.
Original-Change-Id: I81cd1479bdb49163eeb9a369fc165cede49eb71a
Reviewed-on: http://git-master/r/19372
Original-Change-Id: I061738a5c5f46299cccfcb264d9b5bd838694305
Rebase-Id: R8f3d1364c016aaf4d9856add97612dc7ac77aa6e
Forbid cluster switch to G cluster if the G cluster doesn't exist.
Bug 791057
Original-Change-Id: I215de2581edf5fb3c1feaa00d1c6e0b52b15dc23
Reviewed-on: http://git-master/r/19302
Tested-by: Scott Williams <scwilliams@nvidia.com>
Original-Change-Id: Id0a7e5ad62df4d1638518fe00715aac60e4efea9
Rebase-Id: Re39a0fedb7bb0e2518cfd56d46c6565d4a6c2ef4
Original-Change-Id: I162c061f8a1851394d6390bc1234910cdf0972b3
Reviewed-on: http://git-master/r/15269
Original-Change-Id: I0dc20ab81db7456c0faf3a81984f2821e7d565ae
Rebase-Id: R880097280de4f9691f689ab8ab25f08020e98e23
Original-Change-Id: I5464b01ebb454b7fdc6fd316ba31de110a642063
Reviewed-on: http://git-master/r/14167
Reviewed-by: Jin Qian <jqian@nvidia.com>
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Original-Change-Id: I201cdb6dc4e78f762266cb96e48689d4d4f963f6
Rebase-Id: Rb3ac2fff9435330ec65c5541d369b743c9cb898f
Bug 764354
Original-Change-Id: I8a390eb4dae87dceacb97461f23d13554868b046
Reviewed-on: http://git-master/r/12228
Original-Change-Id: I8e6b8303898796419fb5a759cd16edff9aeac081
Rebase-Id: R2866240384c6c24f46bd7ef54bc3dc9140d9e96b
The synchronization between cpus is handled in the generic ARM
code, no need to do it in boot_secondary
Change-Id: I2c490823d962c88e177e267c2a46278976925a38
Signed-off-by: Colin Cross <ccross@android.com>
commit a06f916b7a9b57447ceb875eb0a89f1a66b31bca upstream.
Rather than clipping the number of CPUs using the compile-time NR_CPUS
constant, use the runtime nr_cpu_ids value instead. This allows the
nr_cpus command line option to work as expected.
Reported-by: Mark Salter <msalter@redhat.com>
ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc
* 'next/devel' of ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (128 commits)
ARM: S5P64X0: External Interrupt Support
ARM: EXYNOS4: Enable MFC on Samsung NURI
ARM: EXYNOS4: Enable MFC on universal_c210
ARM: S5PV210: Enable MFC on Goni
ARM: S5P: Add support for MFC device
ARM: EXYNOS4: Add support FIMD on SMDKC210
ARM: EXYNOS4: Add platform device and helper functions for FIMD
ARM: EXYNOS4: Add resource definition for FIMD
ARM: EXYNOS4: Change devname for FIMD clkdev
ARM: SAMSUNG: Add IRQ_I2S0 definition
ARM: SAMSUNG: Add platform device for idma
ARM: EXYNOS4: Add more registers to be saved and restored for PM
ARM: EXYNOS4: Add more register addresses of CMU
ARM: EXYNOS4: Add platform device for dwmci driver
ARM: EXYNOS4: configure rtc-s3c on NURI
ARM: EXYNOS4: configure MAX8903 secondary charger on NURI
ARM: EXYNOS4: configure ADC on NURI
ARM: EXYNOS4: configure MAX17042 fuel gauge on NURI
ARM: EXYNOS4: configure regulators and PMIC(MAX8997) on NURI
ARM: EXYNOS4: Increase NR_IRQS for devices with more IRQs
Fix up tons of silly conflicts:
- arch/arm/mach-davinci/include/mach/psc.h
- arch/arm/mach-exynos4/Kconfig
- arch/arm/mach-exynos4/mach-smdkc210.c
- arch/arm/mach-exynos4/pm.c
- arch/arm/mach-imx/mm-imx1.c
- arch/arm/mach-imx/mm-imx21.c
- arch/arm/mach-imx/mm-imx25.c
- arch/arm/mach-imx/mm-imx27.c
- arch/arm/mach-imx/mm-imx31.c
- arch/arm/mach-imx/mm-imx35.c
- arch/arm/mach-mx5/mm.c
- arch/arm/mach-s5pv210/mach-goni.c
- arch/arm/mm/Kconfig
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc
* 'next/cross-platform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc:
ARM: Consolidate the clkdev header files
ARM: set vga memory base at run-time
ARM: convert PCI defines to variables
ARM: pci: make pcibios_assign_all_busses use pci_has_flag
ARM: remove unnecessary mach/hardware.h includes
pci: move microblaze and powerpc pci flag functions into asm-generic
powerpc: rename ppc_pci_*_flags to pci_*_flags
Fix up conflicts in arch/microblaze/include/asm/pci-bridge.h
cpu_set() is marked as obsolete cpumask function and we plan to
remove it in future.
This patch replace it with modern cpumask function.
Cc: Colin Cross <ccross@android.com>
Cc: Erik Gilling <konkers@android.com>
Cc: Olof Johansson <olof@lixom.net>
Cc: linux-tegra@vger.kernel.org
Remove some includes of mach/hardware.h which are not needed. hardware.h
will be removed completely for tegra and cns3xxx in follow on patch.
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
If an ARM system has multiple cpus in the same socket and the
kernel is booted with maxcpus=1, secondary cpus are possible but
not present due to how platform_smp_prepare_cpus() is called.
Since most typical ARM processors don't actually support physical
hotplug, initialize the present map to be equal to the possible
map in generic ARM SMP code. Also, always call
platform_smp_prepare_cpus() as long as max_cpus is non-zero (0
means no SMP) to allow platform code to do any SMP setup.
After applying this patch it's possible to boot an ARM system
with maxcpus=1 on the command line and then hotplug in secondary
cpus via sysfs. This is more in line with how x86 does things.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: David Brown <davidb@codeaurora.org>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Cc: Linus Walleij <linus.walleij@stericsson.com>
Rather than having each platform class provide a mach/smp.h header for
smp_cross_call(), arrange for them to register the function with the
core ARM SMP code instead.
arch/arm/Kconfig
arch/arm/common/Makefile
arch/arm/kernel/Makefile
arch/arm/kernel/smp.c
All platforms call trace_hardirqs_off() in their secondary startup code,
so move this into the core SMP code - it doesn't need to be in the
per-platform code.
There is a certain amount of smp_prepare_cpus() which doesn't belong
in the platform support code - that is, code which is invariant to the
SMP implementation. Move this code into arch/arm/kernel/smp.c, and
add a platform_ prefix to the original function.
Milo is an old boot loader, which is no longer relevant for these
platforms. References to it are misleading. Move the code out
of poke_milo(), and remove references to milo in comments.
scu_get_core_count() never returns zero cores, so we don't need to
check and correct if ncores is zero.
Tegra was missing the check against NR_CPUS, leading to a potential
bitfield overflow if this becomes the case.
We don't need to re-pass the base address for the CPU interfaces to the
GIC for secondary CPUs, as it will never be different from the boot CPU
- and even if it was, we'd overwrite the boot CPU's base address.
Get rid of this argument, and rename to gic_secondary_init().
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
Tested-by: Abhijeet Dharmapurikar <adharmap@codeaurora.org>
Signed-off-by: Erik Gilling <konkers@android.com>
