path: root/arch/arm/mach-tegra/pm-t2.c
2012-01-04arm: tegra: power: io dpd APIs definedBitan Biswas
Defined IO deep power down(DPD) APIs for tegra drivers - tegra_io_dpd_get - returns dpd handle tegra_io_dpd_enable - enable driver dpd tegra_io_dpd_disable - disables driver dpd bug 919993 Change-Id: I45976b41dca0e3e9266ace86393ef4db8b20c97b Signed-off-by: Bitan Biswas <bbiswas@nvidia.com> Reviewed-on: http://git-master/r/72737 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com>
2011-12-08tegra: treewide: Remove unused gpio-names.h includesDan Willemsen
Most places shouldn't be using these macros, they should get the gpio information from the board files. Either way, all of these instances were unused. Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com> Change-Id: Ifb76704dccb24e5e6eab4c06c79bc8e97802c6d3 Reviewed-on: http://git-master/r/68481 Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com> Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
2011-11-30ARM: tegra: Update copyrightsScott Williams
Change-Id: I156af0bdd8b37cb23aec214c3e158027252e27e1 Signed-off-by: Scott Williams <scwilliams@nvidia.com> Reviewed-on: http://git-master/r/51157 Rebase-Id: R795bf03590a76b6c494afd37603ed951dc2cd082
2011-11-30ARM: tegra: Finish suspend.h -> pm.h renameScott Williams
Change-Id: Iad4b8a7c73ebe4b23a24b5986807358d481aac55 Signed-off-by: Scott Williams <scwilliams@nvidia.com> DW: Split into logical changes Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com> Rebase-Id: Rb796a9ffc20dd4fbf9c463bc9cf3c175f4b03f88
2011-11-30PARTIAL arm: tegra3: Add CPU idle supportScott Williams
Original-Change-Id: I5464b01ebb454b7fdc6fd316ba31de110a642063 Reviewed-on: http://git-master/r/14167 Tested-by: Scott Williams <scwilliams@nvidia.com> Reviewed-by: Jin Qian <jqian@nvidia.com> Tested-by: Jin Qian <jqian@nvidia.com> Reviewed-by: Krishna Reddy <vdumpa@nvidia.com> Reviewed-by: Aleksandr Frid <afrid@nvidia.com> Reviewed-by: Scott Williams <scwilliams@nvidia.com> Original-Change-Id: I201cdb6dc4e78f762266cb96e48689d4d4f963f6 Rebase-Id: Rb3ac2fff9435330ec65c5541d369b743c9cb898f
2011-11-30ARM: tegra: Add suspend supportColin Cross
Tegra supports three low power modes that involve powering down the CPU. LP2 powers down both CPU cores and the GICs, but leaves the core peripherals, including the memory controller and the legacy interrupt controller, enabled. The legacy interrupt controller is used as the wakeup source, and any interrupt can wake the device. LP2 can be used in idle. LP1 is the same as LP2, but in addition turns off the memory controller and puts the DDR memory in self-refresh. Any interrupt can wake the device. LP1 could be used in idle if no peripherals are doing DMA. LP0 turns off everything in the SoC except the RTC and a power management controller, both of which run off a 32 kHz clock. The power management controller has 32 wake sources, all other interrupts can not be used to wake from LP0. These low power modes power-gate the main CPU complex, requiring a full processor state save and restore from a reset vector. Platform-specific data (power good times, PMU capabilities, etc.) must be specified when registering the suspend operations to ensure that platform power sequencing restrictions are maintained. In both LP0 and LP1, SDRAM is placed into self-refresh. in order to safely perform this transition, the final shutdown procedure responsible for * turning off the MMU and L1 data cache * putting memory into self-refresh * setting the DDR pads to the lowest power state * and turning off PLLs is copied into IRAM (at the address TEGRA_IRAM_BASE + SZ_4K) at the start of the suspend process. In LP1 mode (like LP2), the CPU is reset and executes the code specified at the EVP reset vector. Since SDRAM is in self-refresh, this code must also be located in IRAM, and it must re-enable DRAM before restoring the full context. In this implementation, it enables the CPU on PLLP, enables PLLC and PLLM, restores the SCLK burst policy, and jumps to the LP2 reset vector to restore the rest of the system (MMU, PLLX, coresite, etc.). The LP2 reset vector is expected to be found in PMC_SCRATCH1, and is initialized during system-bootup. In LP0 mode, the core voltage domain is also shutoff. As a result, all of the volatile state in the core voltage domain (e.g., pinmux registers, clock registers, etc.) must be saved to memory so that it can be restored after the system resumes. A limited set of wakeups are available from LP0, and the correct levels for the wakeups must be programmed into the PMC wakepad configuration register prior to system shutdown. On resume, the system resets into the boot ROM, and the boot ROM restores SDRAM and other system state using values saved during kernel initialization in the PMC scratch registers. Resuming from LP0 requires the boot ROM to supply a signed recovery codeblob to the kernel; the kernel expects that the length and address of this blob is supplied with the lp0_vec= command line argument; if not present, suspend- to-LP0 will be disabled For simplicity, the outer cache is shutdown for both LP0 and LP1; it is possible to optimize the LP1 routine to bypass outer cache shutdown and restart. Includes fixes from: Scott Williams <scwilliams@nvidia.com> Aleksandr Frid <afrid@nvidia.com> Vik Kasivajhula <tkasivajhula@nvidia.com> Bharat Nihalani <Kbnihalani@nvidia.com> James Wylder <james.wylder@motorola.com> Allen Martin <amartin@nvidia.com> Change-Id: I9e4e61c2fbb8c7bb5a29b1832ea38e7ea0524c52 Original-author: Gary King <gking@nvidia.com> Signed-off-by: Gary King <gking@nvidia.com> Signed-off-by: Colin Cross <ccross@android.com>
