When doing LP to G transition, it had a power up latency on VDD_CPU
rail. To reduce the latency, CPU_LP can trun on the VDD_CPU rail
before the LP to G transition.
Bug 930985
Change-Id: I087e185ea5aa90f309b8cafba9bc4bb7d3fc950c
Signed-off-by: Joseph Lo <josephl@nvidia.com>
Reviewed-on: http://git-master/r/93141
Reviewed-by: Antti Miettinen <amiettinen@nvidia.com>
Tested-by: Antti Miettinen <amiettinen@nvidia.com>
GVS: Gerrit_Virtual_Submit
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
When doing LP2 on last standing CPU, we currently pass
"mode | flag" to a few functions as argument, with the
assumption that "mode" will be confined to lower 22 bits
in PMC_CTRL register and "flags" will occupy higher 10
bits. If "flags" grows downward or "mode" grows upward,
without this explicit knowledge, LP2 will break on the
last standing CPU. Therefore we need to decouple them.
Currently only "flags" part is being used when passed to
other subroutines, so use "flags" only.
Change-Id: I299c998145d81c17760bda8a0b56311fed553958
Signed-off-by: Bo Yan <byan@nvidia.com>
Reviewed-on: http://git-master/r/100358
Reviewed-by: Simone Willett <swillett@nvidia.com>
A new trace event is added for tracing cpu suspend start and end
Change-Id: I2506e3aed0692c44fb4325e9d381cea53228b0c3
Signed-off-by: Sivaram Nair <sivaramn@nvidia.com>
Reviewed-on: http://git-master/r/101748
For update of PMC_CTRL register delay is not required.
Replacing pmc_32kwritel by writel to improve cluster switch time.
bug 954247
Change-Id: Ic39c6fafd606321d549cf26e4cfe662f462b9bdc
Signed-off-by: Shridhar Rasal <srasal@nvidia.com>
Reviewed-on: http://git-master/r/97229
This reverts commit e6d0e0ceec7cd1a7b8085eb31d2e70bc4d15684f.
Bug 967887
Change-Id: I60927a93ebdf6ba4da14311f8ffcc1edf4f56391
Signed-off-by: Sang-Hun Lee <sanlee@nvidia.com>
Reviewed-on: http://git-master/r/96788
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
This reverts commit f31ca2d9e0580b58dc51fde31fc8ace190dd253b.
Bug 967887
Change-Id: I3fe975f7a6939cace5e208947bcb82e09008c0ac
Reviewed-on: http://git-master/r/96787
Simple trace points for measuring cluster switch latencies.
Bug 958262
Change-Id: Ia1e5e13131d5e55aaa0a44e9e8b5196539df54e7
Signed-off-by: Antti P Miettinen <amiettinen@nvidia.com>
Reviewed-on: http://git-master/r/93841
The current kernel methodology expects that tegra_cpu_suspend
is actually the last function in the entire suspend sequence.
In order to achieve this, the code needs to be remodelled a
bit so that we actually execute native cpu_suspend at the end
of the suspend sequence. This allows us to leverage all the
cpu_suspend code developed by ARM in the upstream kernels.
Bug 934368
Change-Id: I94172d7adaa54c10043c479a57b270925d85a16b
Reviewed-on: http://git-master/r/84481
Bug 934368
Change-Id: Ic9d75cbb0c324b1858b2e476e33dd4f96349bce3
Reviewed-on: http://git-master/r/86351
- current code does not turn off pll-a/p in LP1
irrespective of voice call status
- add a new flag to indicate voice call on-going
- use PMC_SCRATCH37 to hold this flag
- if it is set, do not turn-off pll-a/p during LP1
- save-restore PMC_SCRATCH37 if it was used to hold the
voice call on-going flag
- fix few misc formatting issues in tegra3_cpu_clk32k
Bug 924817
Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Reviewed-on: http://git-master/r/85768
(cherry picked from commit 7853981c987ae329620bb54d869016cb74a6c054)
Change-Id: Id5348d2eb44a4bacaf00f6d17edceedaef819e29
Reviewed-on: http://git-master/r/94395
Tested-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Change the minimal rate of sclk to 12 MHz and set the lowest
frequency of sbus to be 40 MHz when display is on.
bug 939415
Original change http://git-master/r/#change,76959
Change-Id: I81cda6a95494764721c1be5b4001c476f3aed6ab
Signed-off-by: Amit Kamath <akamath@nvidia.com>
Reviewed-on: http://git-master/r/93850
Completely removed PLLP restoration from CPU complex resume on
Tegra2 platforms (too late: PLLP is restored from AVP warm boot
code)
Bug 952200
Bug 931285
Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Reviewed-on: http://git-master/r/92523
(cherry picked from commit 066dc172010f1a5ea5a375e1cbdcf162ab206d63)
Change-Id: I1a31793db8ee1fda5a947d69890e3118f0d3cdab
Reviewed-on: http://git-master/r/93562
Reviewed-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Tested-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Set CPU rate floor to 100MHz when the system is awake (after boot,
or on late resume). Remove the floor when the system enters early
suspend.
Bug 922351
Change-Id: Ibaca50791a5b04b4b4165ceac5018d4cfd7c1bcf
Signed-off-by: Alex Frid <afrid@nvidia.com>
Reviewed-on: http://git-master/r/89587
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Boost CPU frequency in tegra platform resume finish phase, just
before driver resume. Boost level is specified by platform suspend
data (ignored if 0).
Bug 946301
(cherry picked from commit eaedf228861e4456454ca13f0958ed97e799fc59)
Change-Id: Ica0cff28f9651e38787ec98f54563d95d876d79e
Reviewed-on: http://git-master/r/89353
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Bug 941380
Signed-off-by: Ray Poudrier <rapoudrier@nvidia.com>
Reviewed-on: http://git-master/r/87095
(cherry picked from commit 72b72afb18f852ee0b352b0644bf30b4afeaa055)
Change-Id: I7e10b6180044a6fb58b2fee835991812c193d9b1
Reviewed-on: http://git-master/r/89564
Reviewed-by: Raymond Poudrier <rapoudrier@nvidia.com>
Tested-by: Raymond Poudrier <rapoudrier@nvidia.com>
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
There is no need to flush the complete L2 upon LP2
entry but it is necessary to clean the page table
entries needed by LP2 code sequence that has L2 off
and MMU on.
Bug 931316
Change-Id: Ice353f16d35ee24d4387e7b9b135f205c4d0ba32
Reviewed-on: http://git-master/r/86293
Disable selection of LP2 suspend mode from sysfs and
if LP2 mode set from board file change mode to LP0
Bug 928456
Change-Id: I1603153e23688ff1048289c4e04f7c7337f480af
Reviewed-on: http://git-master/r/86580
PMC SCRATCH register 0 holds value across warmboot.
Storing values in bit31:30 for recovery and fastboot.
This requires change in bootloader as well to parse these arguments.
Bug 863014
Change-Id: I1d4b752dbc6dd7b065e9d0cc87df189e7caeb201
Signed-off-by: Gaurav Sarode <gsarode@nvidia.com>
Reviewed-on: http://git-master/r/86140
Commit cb0428145196ed7a75861c78d28f46b6bc8d2320 implemented LP0
state entry with fast CPU and system bus clocks only for Tegra3,
but changed power timers rate calculation in the common Tegra2
and Tegra3 path. Fixing it now.
(cherry picked from commit 9e66d6adf6ab1fe06eee63baf0f1f684715d1ae2)
Change-Id: Iac276f048fed4edbee318cadddb862e45ba851c6
Reviewed-on: http://git-master/r/86550
Tested-by: Aleksandr Frid <afrid@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Do not change (lower) CPU and system clocks, and do not disable PLLs
on entry to LP0, since all clocks and PLLs are stopped in h/w, anyway.
(cherry picked from commit 0142197cf7b1828fa7935c9d8715f37313864db1)
Change-Id: I2f175882d4d3dcfe5aee9c460f873a5e907e4ece
Reviewed-on: http://git-master/r/84714
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
During resume from LP0 on Tegra3 always enable pll secondary dividers
before clocks restoration (to make sure clock sources are enabled).
Restore actual secondary dividers settings after clocks are restored.
Remove pllp secondary dividers restoration from cpu complex restore,
and add them to common clock restoration procedure. These dividers
are not affected by CPU complex suspend, only by LP0 core suspend.
(cherry picked from commit 1f631436717c0602ef30770f7976615150114afe)
Change-Id: I45777ca0535f51a39c35e9d360ac6e97a13ea92c
Reviewed-on: http://git-master/r/84712
This reverts commit a61ef84d7746134aae316fa76867d69fc0753880.
Bug 939415
Change-Id: I7d7c2a69ac7261a221cf69b8f8981d42f575f789
Signed-off-by: Chandrakanth Gorantla <cgorantla@nvidia.com>
Reviewed-on: http://git-master/r/84025
Change-Id: I9862e73f264c757f97aaad03f3373fb1d3e95462
Signed-off-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-on: http://git-master/r/79138
- Completely removed PLLP restoration from CPU complex resume on
Tegra3 platforms (too late: if necessary PLLP is restored by LPx
exit code on Tegra3, and attempt to restore it again does not do
any good).
- Restored PLLX only if it is not already used as CPU source
(it is dangerous to restore PLL in use).
- Restore burst policy on exit from LPx states, but preserve it
after cluster switch, as it maybe different for LP and G clusters.
Reviewed-on: http://git-master/r/72535
Change-Id: Ia5ff24d22a2135494bc3442f92bebcc1953c7f08
Reviewed-on: http://git-master/r/78702
suspend.
Bug 922351
Reviewed-on: http://git-master/r/77444
Change-Id: I68f54a3d981c1cbeac16d58d3beb6e3aa6bf190c
Reviewed-on: http://git-master/r/78031
BUG 922351
Reviewed-on: http://git-master/r/76959
Change-Id: I6a2871d1cc02a19829cf397e9583122e02255f81
Signed-off-by: Wen Yi <wyi@nvidia.com>
Reviewed-on: http://git-master/r/78010
sysfs interface to select suspend mode as TEGRA_SUSPEND_NONE
is disabled. Additionally, if tegra_suspend_dram is called
with suspend mode as TEGRA_SUSPEND_NONE we return error
bug 927937
Reviewed-on: http://git-master/r/77268
Change-Id: Ifdd57cdf27e739a9c093cad4eddefb73a6a2355d
Signed-off-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-on: http://git-master/r/77757
tegra2_cpu_set_resettable_soon() should be called in CPU1 only.
Reviewed-on: http://git-master/r/75517
Change-Id: I0825a2d2ed2935d2b1dac1ff7d134e1f4f37f552
Signed-off-by: Joshua Cha <joshuac@nvidia.com>
Reviewed-on: http://git-master/r/77751
Reviewed-on: http://git-master/r/76686
Change-Id: I88939c92aa1c28f5177010ba2afd524c3a4b713d
Reviewed-on: http://git-master/r/77738
Deleted the tegra debugfs /sys entry. Instead have a unified
/sys/power/suspend/mode sysfs entry to set the suspend state.
Bug 911096
Change-Id: I280eb0ed0f5c8b46c2147d84c27b1cf728078709
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/72419
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
On Tegra3: complete account of in- and out-of-bound rails control.
On Tegra2: out-of-bound vdd_cpu control in LP2 state is not accounted.
Change-Id: Ib68cbbfe3e4f965e758aca17a0ba30277d530347
Reviewed-on: http://git-master/r/67340
Add CONFIG_TRUSTED_FOUNDATIONS build option and calls to issue
SMCs to the TL secure monitor (used when needing to update state
not writable by non-secure code).
Make security/tf_driver an optional part of the build, which is
part of the TL framework to interact with secure services.
Bug 883391
Change-Id: I9c6c14ff457fb3a0c612d558fe731a17c2480750
Signed-off-by: Chris Johnson <cwj@nvidia.com>
Reviewed-on: http://git-master/r/65616
also restore the L2 cache latency values after exit from LP2.
Bug 909628
Change-Id: Ia113d3511255f77ba5f5bfbfafebe43ba247818f
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/67767
The L2 cache RAM is preserved over LP2 so omit the L2 cache flush
in tegra_idle_lp2_last().
Bug 880338
Change-Id: I6aa30c712b6e467bd48e9c1959da2a69453a8f43
Reviewed-on: http://git-master/r/59892
Rebase-Id: R6eee47d009d45d0e20254a97df919bf2fc34e6cd
For platforms where the core & CPU power requests are combined
as a single request to the PMU, we need separate processing to
enable its suspend/resume operation.
Bug 862504
Change-Id: If66282a7b069d35568147e2d64f14371e1692bfd
Reviewed-on: http://git-master/r/64011
Rebase-Id: R21b966a438be03b11b80ce7deb70e3036b80dab2
Restore FCR while resuming debug uart, to enable RX and TX FIFOs with
trigger levels configured during initialisation of debug uart port.
Bug 867063
Change-Id: I9665ff29a53c3e2e6c78a3037e20e7362a642f77
Reviewed-on: http://git-master/r/62411
Tested-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Rebase-Id: Ra3b9858456b952ab539a36019a55863077094054
- Preserve twd periodic load register across suspend and LP2 on main
CPU. Keep timer disabled on resume, since it will be re-configured
later when timekeeping switches from global system timer.
- Generate "load equal zero" warning in twd suspend/resume code only
when timer is in periodic mode.
Change-Id: If7df8be08c0ef4e355f315e3f0b7e3cf1b358f0f
Reviewed-on: http://git-master/r/55068
Rebase-Id: R75f3950a915e0953a098620dea9ea32a7d5e9482
Change-Id: I2f22bf2b416eb7617c2d845b6f7a9f293eb32c1c
Reviewed-on: http://git-master/r/51852
Tested-by: Jin Qian <jqian@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Rebase-Id: R986d6156129b2d62176e68aa01ae3c11e4ef6861
warm boot reads SCRATCH4 to choose wake-up from LP or G
Bug 862504
Change-Id: I5ee4697c6268d379a6708e6a87e3f7df12f2994a
Reviewed-on: http://git-master/r/50610
Reviewed-by: Jin Qian <jqian@nvidia.com>
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Rebase-Id: R7e61acb99f023449c2416054c44b75837c3aff94
move printk as well since they rely on uart resume in syscore
Bug 862504
Change-Id: Iad62c87dbb01d07bf731babb62cb480d62b9402e
Reviewed-on: http://git-master/r/50240
Rebase-Id: R8c5b23f5045260160a4906da425cc297fae5b59b
They're called only when doing cluster switch so move them to
cluster control function.
Change-Id: Ic258dd06ab454aa5eb96673665607b373284a43c
Reviewed-on: http://git-master/r/49952
Rebase-Id: R1b68449702767a8555fff82b5fb8c88e1acbe363
Bug 862504
Change-Id: I910f4f229a2040d13d79e2a4f64fd2558509d9e7
Reviewed-on: http://git-master/r/50241
Rebase-Id: R3c4d055f1c2ebad76ad2a9305d5e02f5a4411400
cluster_switch_prolog is needed to set up car/flow controller registers
for LP1 entry. epilog is needed to clean up some flags in flow controller
after LP1 exit.
Bug 862502
Change-Id: Ib9eeac6fc541cfa644d782071dbd4187255404d8
Reviewed-on: http://git-master/r/47585
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Tested-by: Daniel Willemsen <dwillemsen@nvidia.com>
Rebase-Id: R2c72673ba1b7f04ffa1b760ff54aaf73cf23f09e
Bug 862502
Change-Id: If70e54fb32ce14d5f13dde1d7fb4c1f1499a6722
Reviewed-on: http://git-master/r/47398
Rebase-Id: Ra77a54e6930692bca628a97bf1de10a30408cdef
Change-Id: Ie2bcc74d4a4fb76ee29c4a01e5dae72261da4885
Reviewed-on: http://git-master/r/48623
Rebase-Id: R5ee134042966de7a620f60095169e3aba823cd82
Change-Id: I07c389092132e52e2bdd3deab22c10f8e1e6035c
Reviewed-on: http://git-master/r/48798
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
Rebase-Id: R1e0c9acc87c81f9d0dc394c09d6a7b8b94c48d3f
Use the value calibrated by master cpu.
Bug 843553
Original-Change-Id: I88939f37050873e0633782f6a927ffaf9b8d776d
Reviewed-on: http://git-master/r/47988
Rebase-Id: R6520764a88346d5ab4a180810636b04ce474f4d7
ARMv6+ architecture does not allow ioremap on system memory.
lp0 is relocated using ioremap on DRAM. If lp0 vector start address
is in system memory then use memblock_reserve and do not relocate.
Else if it is overlapping with carveout/fb then first remove the
carveout/fb using memblock_remove and then use ioremap.
Bug 827199
Reviewed-on: http://git-master/r/43685
(cherry picked from commit 1753408edc65ebfc0d4d203f2be960d49ca747a8)
Original-Change-Id: Ic4abfbc98b43aafb2756cb3e69d0ee178204ec7d
Reviewed-on: http://git-master/r/44717
Rebase-Id: Re90d5554c301471fd177632887741109318c2c97
LP0 vector is allocated by BL and address is shared to kernel.
For platform with memory less than 1GB it was allocated in
the overlapping region of carveout memory. Because of it
during AVP operation it gets corrupted, which prevents resume.
Relocate AVP vector to some other location where overlapping will
not occur.
Bug 827199
Reviewed-on: http://git-master/r/42113
(cherry picked from commit 9a3993d39599d1637d7c04218e6a634f914e9f91)
Original-Change-Id: If862f6ff61a316c478806b7dc3deff70a2861410
Reviewed-on: http://git-master/r/44716
Rebase-Id: R085bc615567c70b7ff3b0ba1aee375fb29a72bfd
Change-Id: If06bd6a9030c8b1502c96459eb6657a6bff4b0fa
Reviewed-on: http://git-master/r/47634
Rebase-Id: R2982ec1b130417178376a06bb37f24aaf65ec19f
