SW should explicity add delay between writes to IO_DPD_REQ and
IO_DPD2_REQ registers. This is because we use the same state machine
for both the registers.
The time between writes should be apb clk * (SEL_DPD_TIM + 5).
The worse case of apb clk is 32Khz,
SEL_DPD_TIM is configured as 0x10.
delay = (1/32000) * (16 + 5) which approximately 700us.
Bug 200002717
Change-Id: Icf4efdbc38ccdaca30a9d86da488ac796b657b36
Signed-off-by: Jay Cheng <jacheng@nvidia.com>
Reviewed-on: http://git-master/r/411065
(cherry picked from commit ebba7445ff9a32af6bb1759ac70311f66e2986cb)
Reviewed-on: http://git-master/r/412826
Reviewed-on: http://git-master/r/418379
Reviewed-by: Riham Haidar <rhaidar@nvidia.com>
Tested-by: Riham Haidar <rhaidar@nvidia.com>
The memory block for relocating lp0 vector is referenced by
a physical address (i.e. tegra_lp0_vec_start) which kmemleak
can't detect. Mark it as not a leak to avoid false positive.
Bug 200007297
Change-Id: Ie137f08d77911677d9e76fdb7d0112a1610dd72d
Signed-off-by: Allen Yu <alleny@nvidia.com>
Reviewed-on: http://git-master/r/415032
(cherry picked from commit 60520279ce2d6081a87a1bc1127046223b3839f6)
Reviewed-on: http://git-master/r/416824
Reviewed-by: Mandar Padmawar <mpadmawar@nvidia.com>
Tested-by: Mandar Padmawar <mpadmawar@nvidia.com>
When these changes were integrated, spacing was fixed. Propagate those
fixes back to rel-21.
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Change-Id: I49102bbf7571a6158fe7c0dd2c4d413ef5462334
Reviewed-on: http://git-master/r/409758
Unwanted print, that too with err level is moved
to debug level
Bug 1501662
Change-Id: I0fbfa966ab69ec40dd4a218e4e03226ab197a8da
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-on: http://git-master/r/408038
(cherry picked from commit c01a80c066f97e34f1850c705b9022a9165638bd)
Reviewed-on: http://git-master/r/409205
GVS: Gerrit_Virtual_Submit
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
This reverts commit 193e70e3a74bb167e4a443329dc0bd3cf0fcd7a0.
VDE partition has to be left on before entering LP0, otherwise
secure content playback may be corrupted after resuming from LP0.
So we unpowergate vde in the dependent change. This change turn
off vde partition specifically for LP1 case to save power.
Bug 1502013
Bug 1507043
Change-Id: Ibf1dcb40a33cb52f9366e250452a54ae43fcb67a
Reviewed-on: http://git-master/r/401253
(cherry picked from commit f8b07f13193c1bdd2c76c6dc2520ee66c12b8790)
Reviewed-on: http://git-master/r/401983
Tested-by: Praveen Kumar Reddy M.V. <pkreddy@nvidia.com>
Change-Id: Ife6926d0c00d7e046b2579795f50ef96d633fc8f
Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Reviewed-on: http://git-master/r/395845
Change-Id: I30baee4084399b8078232f31296c4d891a903d47
Reviewed-on: http://git-master/r/395123
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Moving the content of pmc.h to linux/tegra-pmc.h
and deleting it.
Bug 1440573
Change-Id: I54014c58765b99dd99e6aaae22bad8cb9010e79c
Signed-off-by: Sumit Singh <sumsingh@nvidia.com>
Reviewed-on: http://git-master/r/377592
Remove the config variable usage from the kernel and make the secure
firmware check dynamic. This make LP1 resume tricky since we need to
execute out of TZRAM till SDRAM is out of self-refresh. To fix this,
store secure firmware presence bit in TZRAM during boot.
Bug 1475528
Change-Id: Ic18766bbee14626e8cf092363d57f4d98b44b6df
Reviewed-on: http://git-master/r/377616
ARM defines PSCI interfaces to be used for power states. We have
been using the actual semantics for quite some time now and so
can remove our implementation of the SMC issuing code and use the
generic interfaces present in <arm/arm64>/kernel/psci.c.
Bug 1475528
Change-Id: Ieba8a0a54f5ee731626e7d92a767ef044e88f12d
Reviewed-on: http://git-master/r/378354
This reverts commit ff4983e5bf793f1abdd8e325abdbd254256f80e3.
There is no need to powergate VDE specifically in LP1 now since
the dependent change has removed the unpowergating statement in
avp suspend callback. VDE powergating in LP1 will be taken care
of in the common suspend callback.
Bug 1455975
Change-Id: Ibed11846064c1a2cdab6fb311767bcc0f90d4976
Reviewed-on: http://git-master/r/380414
Some devices does not save complete state in runtime suspend and
are supposed to be suspended when IRQs are disabled. Such kind of
devices can register to this notifier which are expected to save
their state before going in LP0 from idle state.
Bug 1254633
Change-Id: Ic134c6036492a0f032b3d2e63d1dc531a40bc3b4
Reviewed-on: http://git-master/r/367580
non-secure mode."
This reverts commit 7f93a0dddf39f372c064f772f9af6903e91aaacf as
the t132ref builds break with the following errors -
<android>/kernel/drivers/platform/tegra/../../../arch/arm/mach-tegra/reset.c:45: undefined reference to `is_secure_mode'
<android>/kernel/drivers/platform/tegra/../../../arch/arm/mach-tegra/reset.c:57: undefined reference to `is_secure_mode'
<android>/kernel/drivers/platform/tegra/../../../arch/arm/mach-tegra/reset.c:58: undefined reference to `tegra_generic_smc'
Change-Id: I4e44c2ffba4e1c013213e543b67f2d49a928b764
Reviewed-on: http://git-master/r/365347
- Remove CONFIG_TEGRA_USE_SECURE_KERNEL config option
- Use DBGDSCR.NS bit to dynamically get secure/non-secure mode
- Replace ifdefs with dynamic code.
- Keep CONFIG_TRUSTED_LITTLE_KERNEL to enable secure os
bug 1411345
Change-Id: I75ddfed7a35fcb30e2772bb43057ae022bcf09b3
Signed-off-by: Nitin Sehgal <nsehgal@nvidia.com>
Reviewed-on: http://git-master/r/353155
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
Change-Id: Ib6beca28f413597f84b3b1a8bebd4f9de4aaf94c
Signed-off-by: Peng Du <pdu@nvidia.com>
Change-Id: I0326b9e22688f236ee961b6c8e6670e322be4d7c
Change-Id: I03dae90251ce6c2cf0c0a237ebe0cf53bda9d57d
Reviewed-on: http://git-master/r/200297
Reviewed-on: http://git-master/r/225393
Fix various warnings to enable -Werror option.
Bug 1211919
Change-Id: I913728fd3f2cbac0243b4e116c53cb035ed17f35
Signed-off-by: Ajay Nandakumar <anandakumarm@nvidia.com>
Reviewed-on: http://git-master/r/354292
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
With multiple Tegra12 platforms support in one kernel image, using
DFLL bypass config option is not sufficient to properly differentiate
platforms with DFLL bypass. Added platform data check to DFLL bypass
detection interface.
Change-Id: I7a20561ef7aa155fb5bcfa310bb8ee7d79711bfb
Signed-off-by: Alex Frid <afrid@nvidia.com>
Reviewed-on: http://git-master/r/353934
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Do not operate on DPD pads and do not TRISTATE
pins before restoring for T124
Bug 1416263
Bug 1429819
Change-Id: I7261c7e5d4341f6d74dadf1ab6af985e7965b860
Signed-off-by: Mohan T <mohant@nvidia.com>
Reviewed-on: http://git-master/r/351369
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Tested-by: Bitan Biswas <bbiswas@nvidia.com>
Move the print for suspend state after changing CPU mode
so that it appears after cluster switch print in case of LP0.
It was confusing for some users if CPU was switching
cluster after entering LP0.
Change-Id: I2b02fa8b70bd110b4386c235c5521730b6cc7536
Reviewed-on: http://git-master/r/350961
Use SIP Service calls (0x82000000x) and Standard Service calls
(0x8400000x) from the DEN0028 spec.
PSCI says that we need to use 0x8400000x in r0 for any power
management features i.e. cpu idle/hotplug/on/off followed by the
actual cpu state (LP2/LP1/LP0) in r1. This translates to Std service
calls space mentioned in the DEN0028 spec.
The SIP service calls can be used by silicon partners for their CPU
specific settings. We use this SMC space for L2 settings and to set
the CPU reset vector.
SMCs that are interrupted return a special status code to the NS world.
Look for that status and send a restart SMC (value = 60 << 24) when
received.
Also removed save/restore of r4-r12 as we rely on the secure OS to
do this for us.
Change-Id: I6fae83cc96d29c23305177df770fa07f7970c383
Signed-off-by: Scott Long <scottl@nvidia.com>
Reviewed-on: http://git-master/r/329998
The tegra_generic_smc is not present in normal OS.
Change-Id: I5d265841cfb6fc1ebe8fe51b9341fab408ef7ddc
Signed-off-by: Antti P Miettinen <amiettinen@nvidia.com>
Reviewed-on: http://git-master/r/326083
Reviewed-by: Hiroshi Doyu <hdoyu@nvidia.com>
Tested-by: Hiroshi Doyu <hdoyu@nvidia.com>
cleanup of unwanted fuse related data as
a part of migration of fuse driver
Bug 1380004
Change-Id: I78ff9f6b1d3a27ae0ba0369ad9692c40e9e24bfd
Signed-off-by: Shardar Shariff Md <smohammed@nvidia.com>
Reviewed-on: http://git-master/r/310037
Reviewed-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Bug 1254633
Change-Id: I8c69d238877615a594bed6542462873f897e0ad4
Reviewed-on: http://git-master/r/309496
Add PM notifier to suspend/resume device for LP0 in idle.
Bug 1254633
Change-Id: I4b6e7e1a00202ab6a4fe6eb12110b82b92589766
Reviewed-on: http://git-master/r/309617
Moving mach-tegra/gic.h and mach-tegra/pm-irq.h to
include/linux/irqchip/tegra-irq.h so that it helps faclitate the
movement of irq drivers from mach-tegra/ to drivers/.
Bug 1379891
Change-Id: Id062ebc16441ac295df78731c1e44b32e75d3286
Reviewed-on: http://git-master/r/302884
Doing prints early in resume can be costly. Let's use
pr_debug instead of pr_info.
Bug 1381343
Change-Id: I5fdc61e7cc95d0864e2e81e36c8b6b2a425fb356
Reviewed-on: http://git-master/r/299970
(cherry picked from commit cf28de40659781154ebdfed922900b160912a3ca)
Reviewed-on: http://git-master/r/301523
Running SCLK from CLKS makes LP1 wakeup latencies horrible.
However, we can utilize IRQ bursting to switch automatically
to CLKM upon LP1 wakeup IRQ. This maintains low power for LP1
but improves wakeup latencies significantly.
Bug 1381343
Change-Id: I9a3fcd81999d1b593bf242bfa7ef8505f9848d43
Reviewed-on: http://git-master/r/298749
Reviewed-by: Bo Yan <byan@nvidia.com>
If DFLL has not initialized, yet, or initialization failed:
- do not change DFLL mode from sysfs callback
- do not resume DFLL bypass mode after CPU rail gating/cluster switch
Change-Id: Ife68679b942e9af30cdc7dddbec1abf15f42dd66
Reviewed-on: http://git-master/r/299264
Moving mach-tegra/clock.h and mach-tegra/timer.h to
include/linux/tegra-cpuidle.h and include/linux/tegra-timer.h so that
it helps faclitate the movement of drivers from mach-tegra/ to
drivers/.
Bug 1379817
Change-Id: Ia0a33c3f726d2f672409c270ac8ca1629f05eff8
Reviewed-on: http://git-master/r/299019
Register syscore ops for modules whose context has to
saved/restore during entry/exit to LP0 state from CPU
Idle.
Bug 1254633
Change-Id: Idf4a67535754db3ccc2fc528469fb17ec198cee0
Reviewed-on: http://git-master/r/299447
Update minimum residency expected for different power
states as derived from analysis done in bug 1347388
Bug 1347388
Change-Id: Ifd3d1e68d58a3c0bf5015b33be5ed8c926dd1e91
Reviewed-on: http://git-master/r/299462
remove unnecesssary typecast in pmc_read/write
remove typecast printk for phys_addr_t
Change-Id: I161ddb3f34ae5bb54845fb9bac507a125f5ebddb
Signed-off-by: Philip Rakity <prakity@nvidia.com>
Reviewed-on: http://git-master/r/270754
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
(cherry picked from commit 246be84a48c706e19e8bcb1c5c4127f89d8761e3)
With DEBUG_RODATA, .text section is set as read-only. This prevents
SMC call from using stack with CONFIG_TEGRA_USE_SECURE_KERNEL. This
patch set SMC stack {read,write}'able exceptionaly for DEBUG_RODATA.
Bug 1365298
Change-Id: I4a18886e5eb0c4f1ca3696d4621bd882dc528e48
Signed-off-by: Hiroshi Doyu <hdoyu@nvidia.com>
Reviewed-on: http://git-master/r/276539
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Change-Id: Ib239cc7ffe37ca5873c2116561bb8d85e70a4fb0
Reviewed-on: http://git-master/r/274749
Change-Id: Icefd90ebe4ae5bcad89e3a61b1c2fc69cded90b5
Reviewed-on: http://git-master/r/272874
Problem:
T12x PMC Wake status gets cleared during
LP0 resume
Cause:
During LP0 resume, T12x APBDEV_PMC_DPD_ENABLE_0
register's TSC_MULT_EN bit needs to be
programmed after DPD_ENABLE is cleared.
Fix:
Cleared the DPD_ENABLE bit along with
TSC_MULT_EN bit clear during LP0 resume
for T12x
bug 1367291
Change-Id: Ifcc25709ffb012b4e6d4d0bb325f12d1ede94413
Signed-off-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-on: http://git-master/r/273646
Added initialization for crail suspend platform data entries missed
by commit 14ddff697632b88f1f89aa2c62f5a053e37c7e27.
Moved CL-DVFS initialization to regulator init call (from fixed
regulator init) to setup dfll bypass call-backs before suspend
initialization.
Bug 1351735
Change-Id: Ia4bbf260873630db40e7fdf0966cd319fe265a4f
Reviewed-on: http://git-master/r/270294
Change-Id: I13f3ff891510d2c868f609d507149b32183d34c5
This moved upstream, do the equivalent change here.
Change-Id: I2de76e5c6487ed4513b6d070e0c515a27a881fff
So that the upstream common clk infrastructure can live side by side.
Change-Id: I0fe0ef8cd207d27b707821eed838c75b8ec04025
Move tracepoints for measuring cluster switch latency
to account for the whole interrupts-disabled time.
Change-Id: Ib49cc54078d2e284c34b55dd6e2dc57431706b78
Reviewed-on: http://git-master/r/264800
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
PMC DT support changes are as follows:
- Downstream code needs local changes in addition
to upstream PMC DT support change to compile fine.
Common clock framework (CCF) is not enabled downstream
today as a result we cannot switch to upstream version
of the function set_power_timers today.
- All PMC platform data from board files is not available
in DT bindings upstream. Using the board passed
values in such cases to ensure that functionality
is intact.
- Further, if DT attribute values do not match
board platform data settings the board setting
is used for the time being.
bug 1173104
Change-Id: Ife63ab84178c5aa4371bfee188ce919a99f651fc
Reviewed-on: http://git-master/r/263727
The CPU power timer set up function was related to PMC register. Now moving
it to PMC driver. And it also help to clean up the PM related code later.
The timer was calculated based on the input clock of PMC. In this patch, we
also get the clock from DT.
Signed-off-by: Joseph Lo <josephl@nvidia.com>
(cherry picked from commit 0337c3e0c3cbbb3a4f411c292f52fcc314abae67)
bug 1173104
Change-Id: I03a80b2c0cfcb5223b1b113f395ef3899eafd06e
Reviewed-on: http://git-master/r/263722
Added an option for cluster switch procedure to turn CPU rail ON
via direct access to PMC registers before disabling interrupts,
and then continue scheduler execution while the rail is ramping up.
RAM repair is executed in s/w as well after rail ramp is done. Only
non-CPU partition is power-gated/un-gated by flow controller in the
atomic section. However, rail ramp in this case is serialized with
CPU save context. Hence the trade-off: early startup option reduces
interrupt disabled time during cluster switch, but increases overall
cluster switch time.
Bug 1351735
Change-Id: I5ff9afb2aa6b27b9aa4b2318ee2740dee4908e2f
Reviewed-on: http://git-master/r/262864
Expanded cluster switch instrumentation with simple timing statistic:
running window average, exponential average, maximum switch time -
aggregated separately for LP/G and G/LP cluster switch. Added
the respective debugfs node. Moved cluster switch start/end timing
samples to exactly match interrupt-disabled section of the switch.
Replaced cluster instrumentation error message with debug print.
The INSTRUMENT_CLUSTER_SWITCH compile option is still disabled, so by
default all changes in this commit are not compiled in.
Change-Id: If7b9c7b1469f6839e20b7c8db3aa9cf2c0592f2d
Reviewed-on: http://git-master/r/262859
Used minimum emc rate required for modem operations in LP1BB/LP0BB to
select emc configuration data block loaded into pmc scratch registers
before entry to LP0 (this commit provides only template for selection:
block 1 is always selected, for now).
Bug 1319638
Change-Id: I0b0322d0d0749356052418d9bf9e3b9f9edf416e
Reviewed-on: http://git-master/r/245672
(cherry picked from commit 21843bddaebf3fc2122ae0943b6a56c4fb02aebc)
Reviewed-on: http://git-master/r/262033
- Set EMC suspend rate to minimum requested by base-band controller
- Specify LP1BB voltage level based on EMC suspend rate (will actually
be set by LP1BB entry code)
Bug 1300939
Change-Id: Ida480539b5a71e13bfd8d00bb19724f4f85927e6
Reviewed-on: http://git-master/r/240305
(cherry picked from commit 4777a040200d582b318ccb247299ddcd4675ac5d)
Reviewed-on: http://git-master/r/262031
Suspended DFLL bypass when LP CPU cluster is powered down always, even
if DFLL will be used as CPU clock source after the switch to G CPU
cluster. This change guarantees safe LP to G cluster switch in case
when DFLL bypass was engaged via sysfs nodes while running on LP CPU.
Bug 1310396
Change-Id: I768f04be2cd9dd5d01be2f9f287c57ff71d5542d
Reviewed-on: http://git-master/r/260865
