When device is idle and display is on, the minimal
cpu frequency can drop to 51mhz. Since it takes several
tens of millisecond to ramp up cpu freq, the delay
impact negatively the performance of low latency CPU bound
tasks.
Given the power savings of several milliwatts running cpu
at 51mhz comparing to 102mhz or 204 mhz at idle, the idle
cpu freq is hence raised to 102mhz for smart panel device
and 204mhz for dump panel devices.
Bug 1036216
Change-Id: Ifb0ed88d4c5fcf5b637d09c587322cec72b8a08d
Signed-off-by: Wen Yi <wyi@nvidia.com>
(cherry picked from commit c8465feffcd0cf2401bbd6c6f535955dd68bda55)
Reviewed-on: http://git-master/r/132479
Reviewed-by: Ujjaval Patel <upatel@nvidia.com>
When the device prepares for LP1, the Core voltage is set to the
highest value(1.2V for Enterprise and Kai, and 1.3V for AP37 and
Cardhu). This is to set for some of the driver suspend along the
sequence need a higher emc frequency and thus a higher Core voltage.
Since the sequence of drivers suspend depends on the sequence of
their registration in the table, which in turn is platform-dependent,
there is no right place in the LP1 entry path where the Core voltage
can be set to a lower voltage. Hence, the Core voltage remains high
in LP1 resulting in higher power.
Thus, the only safe location where the Core voltage can be lowered is
once all the drivers are suspended and the DRAM is set in self-refresh,
at the final point just before the system is suspended in the IRAM code.
This location at the assembly code ensures that no other module will be
running and thus that nothing will require a higher core voltage. The Core
is set to the lowest possible value since nothing requires it. It is then
restored to the highest voltage as soon as the LP1 resume code is started
so that all drivers are resumed safely.
At the execution point in IRAM during LP1 suspend path, even the I2C clocks
are gated. They must be reset first and then the I2C transaction is performed.
An I2C transaction involves 4 bytes of data, to send the slave address,
the Core voltage register address and 2 bytes of data which has the value
to set the voltage(the second byte is not required for this transaction).
Once these registers are set, the I2C transaction is performed by setting
the I2C transaction register to 0xA02. After sending the I2C transaction,
we wait for about 250us to check the status of the transaction and if not
updated, wait for more time to check again. If after 2ms and the transaction
fails to register, the transaction is aborted and the device is allowed
to enter at high voltage. Since the failure rate of I2C transaction is very
low at this point in execution where there will be no conflicts in the bus,
it is okay to have Core high for some of the LP1 cycles.
However, it is unacceptable for the I2C transaction to fail on the way
from LP1 resume since the device cannot come up with a lower Core
voltage. In this case, the transaction is retried again and again till
it is successful. There is no way but to keep trying as the device
would fail to resume with Core at 0.95V.
Each platform(or each PMU) has different values for the I2C transaction
ie. slave address, Core voltage register and the value to set the
voltage. For the device in IRAM, it cannot access anything in SDRAM
memory, these values needs to be pushed to IRAM memory before the device
starts execution in IRAM. This is done during initialization of suspend
code when it picks values from the board files and copies it to IRAM
part of code, before the whole memory is copied to IRAM.
This new feature is controlled by a KConfig variable TEGRA_LP1_950 which
should be enabled once the board file of the device is updated with the
right values. The device hangs when it does not have the right values for
the I2C transaction.
With this change in Core, LP1 power is reduced by 12mW in Enterprise,
20mW in AP37 and about 24mW in Kai.
Bug 1035684
Change-Id: I4318c66fd70ab227ef0786d6a13286e020e4541d
Signed-off-by: Karthik Ramakrishnan <karthikr@nvidia.com>
(cherry picked from commit ab476f287376fd0ae51a9f298659f5eba19f0296)
Reviewed-on: http://git-master/r/124779
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
For the CONFIG_TRUSTED_FOUNDATION code paths, differentiate L2
enable vs. reenable, which are different SMCs (won't trigger an
invalidate in the case of a reenable).
On an L2 disable SMC, optionally pass a 0 for the L2 ways arg,
which skips the full clean/invalidate (and simply just disabled
the L2).
In order to safely skip flushing the L2 on the disable, we have
to be careful what we dirty from the type we flush the L1 and
disable the L2.
Bug 939415
Signed-off-by: Chris Johnson<cwj@nvidia.com>
Change-Id: I756d2ceda83d5d8d6bc5670218e9d874d5e5f62a
Reviewed-on: http://git-master/r/119786
Reviewed-by: Simone Willett <swillett@nvidia.com>
Bootloader io dpd settings are cleared during kernel initialization
bug 758856
Change-Id: Ic6d5250a5ae127bb45ab37b9200ca06c8d1f11a2
Signed-off-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-on: http://git-master/r/115395
This is a WAR solution that allows for the turning on
SD DPD feature.
The original issue is that enabling SD DPD immediately after device comes
out of LP0 causes ULPI disconnect. The root cause of that is
not known.
The WAR is to delay the enabling of SD DPD for 100ms after
device comes out of LP0.
Bug 929628
Change-Id: I3c5e35ace422e5441535c2c0fe18545b53bbddc4
(cherry picked from commit bffb7b917d52a3523af80db21322ec7ba5fd33f9)
Reviewed-on: http://git-master/r/113392
Boost CPU frequency in tegra platform resume finish phase, just
before driver resume. Boost level is specified by platform suspend
data (ignored if 0).
Bug 946301
Signed-off-by: Alex Frid <afrid@nvidia.com>
(cherry picked from commit eaedf228861e4456454ca13f0958ed97e799fc59)
Change-Id: Ica0cff28f9651e38787ec98f54563d95d876d79e
Reviewed-on: http://git-master/r/89353
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
PMC SCRATCH register 0 holds value across warmboot.
Storing values in bit31:30 for recovery and fastboot.
This requires change in bootloader as well to parse these arguments.
Bug 863014
Change-Id: I1d4b752dbc6dd7b065e9d0cc87df189e7caeb201
Signed-off-by: Gaurav Sarode <gsarode@nvidia.com>
Reviewed-on: http://git-master/r/86140
Currently on Tegra3 cpu complex is powered off in idle (enters CPU0
LP2 state) only if all secondary CPUs are off-line. This commit adds
an option for CPU0 to enter LP2 while secondary CPUs are still on-line
but have been power gated and entered LP2 state by themselves.
The critical race: secondary CPU is waking up from LP2, while CPU0 is
turning common CPU rail off, is addressed as follows.
1. When entering LP2 state on CPU0:
a) disable GIC distributor
b) check that CPU1-3 are all power-gated (i.e., either off-lined or
have entered LP2)
c) if (b) passes - set all interrupts affinity to CPU0, then
re-enable distributor and continue with CPU complex powering off
d) if (b) fails - re-enable distributor and enter clock-gated (LP3)
state on CPU0
This procedure prevents waking secondary CPUs by GIC SPIs.
2. We still need to make sure that no CPU1-3 PPIs from legacy IRQ/FIQ
or private timers would happen. This is achieved by disabling timers
and legacy interrupts if CPU1-3 enters LP2 state with external timers
selected as wake sources. Respectively, establish dependency between
turning rail off and LP2 wake timers configuration options.
3. Finally, no IPIs is sent by CPU0 entering LP2.
There are no special changes in wake up procedures - whenever CPU0
is awaken by external interrupt or wake timer, cpu complex is powered
on by h/w, and secondary CPUs that were in LP2 state are ungated by
the same interrupt (off-line CPUs are kept power gated). Hence, there
is no need for CPU1-3 external wake timers to run while the rail is
off, and these timers are stopped. To make sure that none of secondary
CPUs over-sleeps its LP2 time, CPU0 wake timer is set to minimum sleep
interval of all CPUs.
By default configuration option for powering off multiple on-line CPUs
is disabled on Tegra3.
Change-Id: I4920d0df375536b2b8ebd9e6738c5fe4f92b92a0
Reviewed-on: http://git-master/r/83547
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Add an option to use external timer as Tegra3 secondary CPU wake
source from lp2 (power gated) state. This is a follow up to commit
51e6be9ce103fbeb2b73fa2a9d2b6528a6941e81 that disabled wake from
external timer, since its interrupt is registered too late - after
secondary CPU is brought on-line, and already had a chance to enter
lp2. With this commit, secondary CPU is not allowed to enter lp2 in
idle until wake timer is registered (clock-gated lp3 state is entered
instead).
External timer wake up mechanism is enabled on Tegra3 only if option
HAVE_ARM_TWD is not selected. Otherwise, continue to use local CPU
timers as lp2 wake sources.
Change-Id: Ic8c33f55e77174717bfa6525041e1263d3232dd5
Reviewed-on: http://git-master/r/83546
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Defined IO deep power down(DPD) APIs for tegra drivers -
tegra_io_dpd_get - returns dpd handle
tegra_io_dpd_enable - enable driver dpd
tegra_io_dpd_disable - disables driver dpd
bug 919993
Change-Id: I45976b41dca0e3e9266ace86393ef4db8b20c97b
Reviewed-on: http://git-master/r/72737
Bug 915962
Change-Id: Icece8c31a7e31b3871dd836aa79b5f7cc28d0af1
Signed-off-by: Diwakar Tundlam <dtundlam@nvidia.com>
Reviewed-on: http://git-master/r/70121
Add CONFIG_TRUSTED_FOUNDATIONS build option and calls to issue
SMCs to the TL secure monitor (used when needing to update state
not writable by non-secure code).
Make security/tf_driver an optional part of the build, which is
part of the TL framework to interact with secure services.
Bug 883391
Change-Id: I9c6c14ff457fb3a0c612d558fe731a17c2480750
Signed-off-by: Chris Johnson <cwj@nvidia.com>
Reviewed-on: http://git-master/r/65616
For platforms where the core & CPU power requests are combined
as a single request to the PMU, we need separate processing to
enable its suspend/resume operation.
Bug 862504
Change-Id: If66282a7b069d35568147e2d64f14371e1692bfd
Reviewed-on: http://git-master/r/64011
Reviewed-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Tested-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Rebase-Id: R21b966a438be03b11b80ce7deb70e3036b80dab2
Bug 862502
Change-Id: If70e54fb32ce14d5f13dde1d7fb4c1f1499a6722
Reviewed-on: http://git-master/r/47398
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Tested-by: Daniel Willemsen <dwillemsen@nvidia.com>
Rebase-Id: Ra77a54e6930692bca628a97bf1de10a30408cdef
Change-Id: I07c389092132e52e2bdd3deab22c10f8e1e6035c
Signed-off-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-on: http://git-master/r/48798
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
Rebase-Id: R1e0c9acc87c81f9d0dc394c09d6a7b8b94c48d3f
Renamed and moved tegra cpu related function prototypes from power.h
to tegra-cpu.h. No functional changes.
Original-Change-Id: I24c25c9434bf7008e0875d1f74be502cd902c4ba
Reviewed-on: http://git-master/r/40532
Rebase-Id: R3d90799453a86a5a9ed012d2bfe373715de6d5c3
Added the board level suspend/resume and call the console
suspend from board level suspend/resume.
bug 820536
Original-Change-Id: I246265241246dc0682870571c927bd23023e5aca
Reviewed-on: http://git-master/r/41448
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-by: Narendra Damahe <ndamahe@nvidia.com>
Rebase-Id: Re1f3dd4f75ee05456899d9a67f74ae84f9572654
Adding board specific suspend and resume call apis through platform
data.
Added call of these function at appropriate stage of suspend/resume.
Added mechanism to select the uart debug channel base address through
variable so that board file can directly change this.
bug 820536
bug 832273
Original-Change-Id: Ia9ff3b8a8d2faa1071a8ff634960e6a6c8a43d40
Reviewed-on: http://git-master/r/34494
Rebase-Id: R6d7bfb3f8f9152779f5138cbcd1b7a9e9a9545df
Original-Change-Id: If23b48fb414332f5dd25307a098569a5474283c6
Reviewed-on: http://git-master/r/31471
Rebase-Id: R6ba9ce7c7b355da4148ce0ebc9bc357bf5fc0b13
Original-Change-Id: I7f4fb6447c882a54d95ee3fb4c6149f4e0357d69
Reviewed-on: http://git-master/r/31457
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Tested-by: Aleksandr Frid <afrid@nvidia.com>
Tested-by: Diwakar Tundlam <dtundlam@nvidia.com>
Tested-by: Gerrit_Virtual_Submit
Rebase-Id: Rbe2ac5f11065109d34a04793f93c873441e261be
Change-Id: Icc37a1ac4fe1af3d08e579faf35ccb4ab1db1b1c
Rebase-Id: R786d091cccb765acb8d89acd59017ae993b78733
Reduce the complexity of the cluster control compile-time conditionals.
Also disable DEBUG_CLUSTER_SWITCH because it invokes clock code that
takes a mutex when taking of a mutex is disallowed.
Change-Id: I9b614d4b0189fbb01d0b7f8af7053c7586d9515b
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Rebase-Id: R412820dc2fd9f0c9cc7b1e3ad7ead7e2e68a0ff3
Consolidate all of the power management control flags in one
header and adjust the values of the software flags so that they
do not conflict with the values of the hardware flags.
Change-Id: I7971d274946d84dcc50bd9d9e0190091ebbefa2e
Rebase-Id: R29d2420a74f977c16f73b1abd9ca7470695a53f4
Change-Id: I121c8aff9c4cb212ac625ef7751d8cf6b8093068
DW: Split into logical changes, move hotplug notifier to timer-t3.c
Rebase-Id: Rbfbfdb1720960dd9ce2847fb16daa932bebb16d2
Implement extensions to the standard ARM GIC API for Tegra3 power management.
Change-Id: If8b2ce2b366e48bb5ca82d3de2acab1fd0a81bb9
Rebase-Id: Rd7527cd57edf054c871f5d04d7e9185643f79843
- Add a single unified handler for all CPU resets that is copied to
IRAM.
- Add state information to direct the flow of execution through the
reset handler based on the reason a CPU was reset.
- Write the EVP CPU reset vector only once per cold/warm boot session.
- Prevent modification of the EVP CPU reset vector in Tegra3.
Bug 786290
Bug 790458
Change-Id: Ica6707f3514986ee914e73a2d9766a4e06ce2d29
Rebase-Id: R7b9859a83717e76c3c083bdde724bd5fef9ce089
Change-Id: I07ffcffafcf47fd7539b22d4829712e041293bf3
Rebase-Id: R34a7800e24254d54b499411652d59421be703619
Change-Id: If3d4fa59cf6d7cd8692f6e5b59414a923abcfd0d
Rebase-Id: Rec3560499e4c64fd76a873689691cbae59f7602b
Change-Id: I107d301ec8e8cd3b69ea293faab15b8d766e38f4
Rebase-Id: R9f8f016c1850e2c65f30f2f67241a94acf8a7755
Change-Id: If072ef10f02d5be7560fdf42584ab11b2a863481
Rebase-Id: Rf1ace67e281b1581501aaa936cd9137d326f2c4a
Change-Id: I961125e938e72506dc304025b418e80387a5062e
Rebase-Id: R393c5a77803f276467d2974041653eb92026601e
Restore the Tegra2 LP2 timers that were dropped in the port to Linux
2.6.39.
Change-Id: Ie3958fa3c89886d5dc5a5858c694400bd1421741
Rebase-Id: R63ede668965d11ac2b2114ffa817b690a616205a
Move Tegra2 SOC-specific CPU idle functionality to cpuidle-t2.c
Change-Id: I26c94ca74d7a78665c52e23571c5058e3da240a7
Rebase-Id: R1246e3942623458f5121ccdac3e6d4a1d40ad624
Change-Id: Iad4b8a7c73ebe4b23a24b5986807358d481aac55
Rebase-Id: Rb796a9ffc20dd4fbf9c463bc9cf3c175f4b03f88
Change-Id: If50d29696867787b38febd909910dda75475cc30
Rebase-Id: R2275ad736d4dbee0a7b716ee6ea19b1863d8d4f8
Rebase-Id: R03f1fc69f4859a0dc66fbd145eb0df31650de3ac
HALT_CPU and CPU_CSR were backwards. Update with the formulas from
android-tegra-2.6.36, making it hopefully a bit clearer too.
With this fixed, Ventana LP2 works again.
Change-Id: Iebde05904755041ce36d493f8d02507b03dd818a
Reviewed-on: http://git-master/r/41257
Rebase-Id: R4c6d9911e39bb9477ba43827ea73bdea729040d3
Tegra cpu-freq driver will now recognize edp zones
and cap the max cpu freq for that zone. The temperature
monitoring driver will be giving inputs to cpu-freq
on the current temperature which would be interpreted
by the cpu-freq driver appropriately.
Original-Change-Id: I918eb31771aa7e1e1a5f25438edded727de6eb8c
Reviewed-on: http://git-master/r/31339
Rebase-Id: R6d93bf69d0731ce4ae84f80d1e9013378483331c
When current CPU complex frequency is above target range:
- bring new core on-line only if cpufreq governor requests for
all already on-lined CPUs are above 50% of current CPU frequency
- off-line one core (despite high pick request) if cpufreq
governor requests for at least 2 on-lined CPUs are below 25% of
- do nothing if neither of the above conditions is true
Original-Change-Id: I77e1bd543a8fadd51974f7d574f256a6e7e2979a
Reviewed-on: http://git-master/r/29702
Rebase-Id: Rc5c717454d1e09ca97ccc79fff60cb33fcf854e9
- taking CPU core off-line: selected CPU with minimum load
- switching from ULP to G CPU mode: set CPU clock to cpufreq
target rate after the mode switch is completed
Original-Change-Id: I9bf4d0f4b48c262cf678c603aac02043dd602674
Reviewed-on: http://git-master/r/28420
Original-Change-Id: I5a19be79dd8f8fe788637870a22cd34dcfea150e
Rebase-Id: Re264ec676c5c2103f7738c9eab5f4e11a4344975
Added board level tuning parameter to specify minimum LP2 residency
time (previous policy allows down to zero residency targets limited
only by LP2 exit latency).
Original-Change-Id: I4ae7d458fba78f35a40f138cf9489bf938715b22
Reviewed-on: http://git-master/r/28162
Original-Change-Id: I38e798ca6d242d136ea2353d90cc961de14f25b6
Rebase-Id: Rcf9efce3dd037b0a7ca13a9c342f884fac38d654
CPU electrical design point (EDP) limits specify maximum CPU frequency
depending on number of CPU cores on-line, and chip temperature. This
commit added initial edp governor to cpufreq driver. Governor is aware
of CPU departure/arrival, but temperature dependency is yet to be added.
Therefore CPU EDP support is left disabled for now.
Original-Change-Id: Ia875aa6904df7ec25ac98863d59a173703034241
Reviewed-on: http://git-master/r/26982
Original-Change-Id: Iae2e9d47c2d3fd4cb32104adbad4f4b26c46064c
Rebase-Id: Rde24788e86558e1c21b18a1857a8b52220ba8e2a
Use cpufreq (cpu DFS) mutex for auto-hotplug (instead of a separate
one) to serialize cpu frequency scaling, hotplug, and CPU mode switch
operations.
Original-Change-Id: I7ea865894d1676c865294ab31a903248d9437534
Reviewed-on: http://git-master/r/24893
Original-Change-Id: I906a23561c1567079a41590a30b29b3d52fa5de8
Rebase-Id: R5d16154c91b41fd02f2a50af7ec6868a7958dc13
Added second level virtualization (on top of virtual cpu rate control)
to support different Tegra3 CPU power modes: low power (LP) mode and
geared performance (G) mode. Virtual cpu complex (cpu_cmplx) clock is
defined as a child with two parents: virtual cpu_lp and virtual cpu_g
clocks for the respective modes. Mode switch sequence was integrated
into cpu_cmplx set parent implementation. (Before this commit mode
switch was triggered outside the clock framework, which created cpu
clock/mode synchronization problems).
Each mode clock is derived from its own super clock mux (cclk_lp and
cclk_g) to statically match Tegra3 h/w layout. (Before this commit the
code had to dynamically synchronize CPU mode and active mux selection).
This change also allowed to support PLLX output divider for low power
mode as fixed 1:2 divider with bypass control embedded into cclk_lp
parent section.
Updated auto and sysfs CPU mode switch calls to use new clock framework,
and removed clock manipulation from the low level mode switch
implementation.
Original-Change-Id: Ibc3cc495b2ff29e2d3417eff2bfd45535cbd015b
Reviewed-on: http://git-master/r/24734
Tested-by: Jin Qian <jqian@nvidia.com>
Original-Change-Id: I23ae80edbf14fb22727a6fc317cd9e5baf8bd6be
Rebase-Id: Rdcd4a2165ebd92bf4caa35d68ca81d19a3789351
Bug 791803
Original-Change-Id: I25be461cccd6e14618d8b43fd0738e9abfbe4432
Reviewed-on: http://git-master/r/23584
Tested-by: Scott Williams <scwilliams@nvidia.com>
Original-Change-Id: I6bb5dcfbf48323919529c6271ea7696ecc413bb2
Rebase-Id: R3308cf0a852ee2bf0e2adb3de17cebc81e48c71c
Forbid cluster switch to G cluster if the G cluster doesn't exist.
Bug 791057
Original-Change-Id: I215de2581edf5fb3c1feaa00d1c6e0b52b15dc23
Reviewed-on: http://git-master/r/19302
Original-Change-Id: Id0a7e5ad62df4d1638518fe00715aac60e4efea9
Rebase-Id: Re39a0fedb7bb0e2518cfd56d46c6565d4a6c2ef4
Initial implementation of Tegra3 quad core CPU management. Add closed
control loop on top of cpufreq DFS. Target frequency range is bounded
by Fmax(Vnominal) for low power cluster - currently set to 456MHz, and
Fmax(Vminimum) for high power cluster - currently set to 356MHz.
When CPU frequency is scaled below the target range, slave high power
CPUs are gradually brought down and eventually CPU is switched to the
low power cluster.
When CPU frequency is scaled above the target range, CPU is switched
to the high power cluster and slave high power CPUs are gradually
brought up.
The auto hotplug support is disabled on boot. It can be explicitly
enabled via sysfs interface.
Original-Change-Id: Ie0e5cf1f334d9c53932db05950cfcf5addd271d7
Reviewed-on: http://git-master/r/18500
Reviewed-by: Jonathan Mayo <jmayo@nvidia.com>
Original-Change-Id: I86152069aa2bed73e0148a4bcab897811e1a5827
Rebase-Id: R9cf5f5f8868c659db526cb49ddf276a79d93ef1a
Allow run-time control of cluster switch debug messages
so they can be enabled for debuggability and disabled for
performance measurement.
Original-Change-Id: Id2bd85d6a9d3a57430a20d93b51ce5b59fe53c71
Reviewed-on: http://git-master/r/17927
Original-Change-Id: Ia57424eee01276d82af7aab37d2f3d0525acc379
Rebase-Id: Rb7054dcdd910d9f1b82edb485856e868a47c5034
Original-Change-Id: I1526de69a1224f42ce3ff11ba1b6fa949c2f13a5
Reviewed-on: http://git-master/r/17787
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Original-Change-Id: I43caec7348d970dc076f27cc2bb4b6ded234a38c
Rebase-Id: Ra122021184a1c12cc85e08cd3d7abe41345db058
Original-Change-Id: I162c061f8a1851394d6390bc1234910cdf0972b3
Reviewed-on: http://git-master/r/15269
Original-Change-Id: I0dc20ab81db7456c0faf3a81984f2821e7d565ae
Rebase-Id: R880097280de4f9691f689ab8ab25f08020e98e23
