path: root/arch/arm/mach-tegra/pm.h
2011-11-30arm: tegra: Enable Tegra3 cluster controlScott Williams
Original-Change-Id: I162c061f8a1851394d6390bc1234910cdf0972b3 Reviewed-on: http://git-master/r/15269 Reviewed-by: Scott Williams <scwilliams@nvidia.com> Tested-by: Scott Williams <scwilliams@nvidia.com> Original-Change-Id: I0dc20ab81db7456c0faf3a81984f2821e7d565ae Rebase-Id: R880097280de4f9691f689ab8ab25f08020e98e23
2011-11-30ARM: tegra: clock: Update LP-cluster related interfacesAlex Frid
Original-Change-Id: Ifde476a05bd01cdce8c3f4802b268a193a832a1b Reviewed-on: http://git-master/r/14584 Reviewed-by: Aleksandr Frid <afrid@nvidia.com> Tested-by: Aleksandr Frid <afrid@nvidia.com> Reviewed-by: Scott Williams <scwilliams@nvidia.com> Original-Change-Id: I41204d17c5d8092b1a24b3138efe12cfbd16d7e7 Rebase-Id: R9754ff5e07ecabd945edfccdbc0f9d9586be6e23
2011-11-30PARTIAL arm: tegra3: Add CPU idle supportScott Williams
Original-Change-Id: I5464b01ebb454b7fdc6fd316ba31de110a642063 Reviewed-on: http://git-master/r/14167 Tested-by: Scott Williams <scwilliams@nvidia.com> Reviewed-by: Jin Qian <jqian@nvidia.com> Tested-by: Jin Qian <jqian@nvidia.com> Reviewed-by: Krishna Reddy <vdumpa@nvidia.com> Reviewed-by: Aleksandr Frid <afrid@nvidia.com> Reviewed-by: Scott Williams <scwilliams@nvidia.com> Original-Change-Id: I201cdb6dc4e78f762266cb96e48689d4d4f963f6 Rebase-Id: Rb3ac2fff9435330ec65c5541d369b743c9cb898f
2011-11-30[ARM/tegra] Add Tegra3 supportScott Williams
Bug 764354 Original-Change-Id: I8a390eb4dae87dceacb97461f23d13554868b046 Reviewed-on: http://git-master/r/12228 Reviewed-by: Scott Williams <scwilliams@nvidia.com> Tested-by: Scott Williams <scwilliams@nvidia.com> Original-Change-Id: I8e6b8303898796419fb5a759cd16edff9aeac081 Rebase-Id: R2866240384c6c24f46bd7ef54bc3dc9140d9e96b
2011-11-30ARM: tegra: whistler: Power down/up core railPrashant Gaikwad
program pwren signal of max8907c regulator to power down/up core rail on deep sleep enter/exit deep sleep mode. core_timer and core_off_timer changed as per K32. separate_req set to false as whistler pmu has combined power requests. Bug 817378 Original-Change-Id: Ia95a61360079f919a039572cf8fd4597db9efd50 Reviewed-on: http://git-master/r/28435 Tested-by: Prashant Gaikwad <pgaikwad@nvidia.com> Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Rebase-Id: R51bd290332e65f90d7e3013389d1456a99809051
2011-11-30ARM: tegra: Add suspend supportColin Cross
Tegra supports three low power modes that involve powering down the CPU. LP2 powers down both CPU cores and the GICs, but leaves the core peripherals, including the memory controller and the legacy interrupt controller, enabled. The legacy interrupt controller is used as the wakeup source, and any interrupt can wake the device. LP2 can be used in idle. LP1 is the same as LP2, but in addition turns off the memory controller and puts the DDR memory in self-refresh. Any interrupt can wake the device. LP1 could be used in idle if no peripherals are doing DMA. LP0 turns off everything in the SoC except the RTC and a power management controller, both of which run off a 32 kHz clock. The power management controller has 32 wake sources, all other interrupts can not be used to wake from LP0. These low power modes power-gate the main CPU complex, requiring a full processor state save and restore from a reset vector. Platform-specific data (power good times, PMU capabilities, etc.) must be specified when registering the suspend operations to ensure that platform power sequencing restrictions are maintained. In both LP0 and LP1, SDRAM is placed into self-refresh. in order to safely perform this transition, the final shutdown procedure responsible for * turning off the MMU and L1 data cache * putting memory into self-refresh * setting the DDR pads to the lowest power state * and turning off PLLs is copied into IRAM (at the address TEGRA_IRAM_BASE + SZ_4K) at the start of the suspend process. In LP1 mode (like LP2), the CPU is reset and executes the code specified at the EVP reset vector. Since SDRAM is in self-refresh, this code must also be located in IRAM, and it must re-enable DRAM before restoring the full context. In this implementation, it enables the CPU on PLLP, enables PLLC and PLLM, restores the SCLK burst policy, and jumps to the LP2 reset vector to restore the rest of the system (MMU, PLLX, coresite, etc.). The LP2 reset vector is expected to be found in PMC_SCRATCH1, and is initialized during system-bootup. In LP0 mode, the core voltage domain is also shutoff. As a result, all of the volatile state in the core voltage domain (e.g., pinmux registers, clock registers, etc.) must be saved to memory so that it can be restored after the system resumes. A limited set of wakeups are available from LP0, and the correct levels for the wakeups must be programmed into the PMC wakepad configuration register prior to system shutdown. On resume, the system resets into the boot ROM, and the boot ROM restores SDRAM and other system state using values saved during kernel initialization in the PMC scratch registers. Resuming from LP0 requires the boot ROM to supply a signed recovery codeblob to the kernel; the kernel expects that the length and address of this blob is supplied with the lp0_vec= command line argument; if not present, suspend- to-LP0 will be disabled For simplicity, the outer cache is shutdown for both LP0 and LP1; it is possible to optimize the LP1 routine to bypass outer cache shutdown and restart. Includes fixes from: Scott Williams <scwilliams@nvidia.com> Aleksandr Frid <afrid@nvidia.com> Vik Kasivajhula <tkasivajhula@nvidia.com> Bharat Nihalani <Kbnihalani@nvidia.com> James Wylder <james.wylder@motorola.com> Allen Martin <amartin@nvidia.com> Change-Id: I9e4e61c2fbb8c7bb5a29b1832ea38e7ea0524c52 Original-author: Gary King <gking@nvidia.com> Signed-off-by: Gary King <gking@nvidia.com> Signed-off-by: Colin Cross <ccross@android.com>
