Allowed Tegra3 memory PLLM rate change, provided it is disabled.
Since PLLM can deviate from boot configuration now, and on Tegra3 it
is controlled by PMC override registers (not CAR module registers):
- Re-factored PLLM initialization, resume, and set rate operations
accordingly (enable and disable ops already used PMC override).
- Made sure that boot configuration is restored on entry to LP0 to
match memory timing saved in scratch registers.
Bug 1005576
Change-Id: Iac6297455bec709a8e12d71deccab62c18905ea7
Signed-off-by: Alex Frid <afrid@nvidia.com>
Reviewed-on: http://git-master/r/110937
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
(cherry picked from commit b53f88c68543a2b0ddb4545bb3b389b42eeb95d8)
Reviewed-on: http://git-master/r/114759
Reviewed-by: Jihoon Bang <jbang@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
- Adding flag to treat warning as error.
- Handling warnings of unused variable, structures and functions,
wrong return type, wrong type comparision.
Bug 949219
Change-Id: I9d02387ce1073c4e46f69d01669285aa3754f1d9
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/104968
This restores commit 607d5ec8bb46f95473533f611da1ffc97907d16e.
The common ARM CPU state suspend/resume code does not work with
and external L2 cache controller (like a PL310) enabled. This
change fixes corruption of the current PMD by the MMU resume code.
cpu_resume_mmu modifies the currently active page tables to add
a flat (VA==PA) section mapping of cpu_resume_turn_mmu_on to
handle MMU off-to-on transition. It turns off the L1 data cache
but it knows nothing of the L2 cache. Since page table walks are
L2 cacheable, other CPUs in the system can pick up the corrupted
PMD which will eventually result in a kernel panic.
The workaround for this is to modify push_ctx_regs to save the
current TTB0 and CONTEXID registers in the CPU register context
and switch to the private tegra_pgd before saving the rest of the
CPU context. The tegra_pgd already has a flat mapping for the
code in question, so it can't be damaged by the actions of
cpu_resume_mmu. Likewise, pop_ctx_regs is modified to restore
the actual TTB0 and CONTEXTID registers when restoring the CPU
registers.
Bug 967887
Change-Id: Iaf98c46359860531874354e8cddabe299ea90d57
Signed-off-by: Sang-Hun Lee <sanlee@nvidia.com>
Reviewed-on: http://git-master/r/96789
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
This reverts commit e6d0e0ceec7cd1a7b8085eb31d2e70bc4d15684f.
Bug 967887
Change-Id: I60927a93ebdf6ba4da14311f8ffcc1edf4f56391
Reviewed-on: http://git-master/r/96788
This reverts commit f31ca2d9e0580b58dc51fde31fc8ace190dd253b.
Bug 967887
Change-Id: I3fe975f7a6939cace5e208947bcb82e09008c0ac
Reviewed-on: http://git-master/r/96787
The current kernel methodology expects that tegra_cpu_suspend
is actually the last function in the entire suspend sequence.
In order to achieve this, the code needs to be remodelled a
bit so that we actually execute native cpu_suspend at the end
of the suspend sequence. This allows us to leverage all the
cpu_suspend code developed by ARM in the upstream kernels.
Bug 934368
Change-Id: I94172d7adaa54c10043c479a57b270925d85a16b
Reviewed-on: http://git-master/r/84481
Reviewed-by: Simone Willett <swillett@nvidia.com>
Bug 934368
Change-Id: Ic9d75cbb0c324b1858b2e476e33dd4f96349bce3
Reviewed-on: http://git-master/r/86351
This reverts commit 48565a367997c1748c655bc834e06b348d4e5b2c.
Change-Id: I0e1411f1260ae916c510478276d88b41416a0d42
Reviewed-on: http://git-master/r/85670
- current code does not turn off pll-a/p in LP1
irrespective of voice call status
- add a new flag to indicate voice call on-going
- use PMC_SCRATCH37 to hold this flag
- if it is set, do not turn-off pll-a/p during LP1
- save-restore PMC_SCRATCH37 if it was used to hold the
voice call on-going flag
- fix few misc formatting issues in tegra3_cpu_clk32k
Bug 924817
Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Reviewed-on: http://git-master/r/85768
(cherry picked from commit 7853981c987ae329620bb54d869016cb74a6c054)
Change-Id: Id5348d2eb44a4bacaf00f6d17edceedaef819e29
Reviewed-on: http://git-master/r/94395
Tested-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Add CONFIG_TRUSTED_FOUNDATIONS build option and calls to issue
SMCs to the TL secure monitor (used when needing to update state
not writable by non-secure code).
Make security/tf_driver an optional part of the build, which is
part of the TL framework to interact with secure services.
Bug 883391
Change-Id: I9c6c14ff457fb3a0c612d558fe731a17c2480750
Signed-off-by: Chris Johnson <cwj@nvidia.com>
Reviewed-on: http://git-master/r/65616
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
PL310 virtual address was calculated using PPSB virtual/phy address.
It should be done using CPU virtual/phy address. This causes
TEGRA_PL310_VIRT value to get overlapped with virtual kerenl memory map's
Vmalloc region on whistler.
Bug 881831
Bug 867094
Change-Id: Ifaeeb9291553af59453f0041ad7cb1fe9d27979b
Signed-off-by: Puneet Saxena <puneets@nvidia.com>
Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Reviewed-on: http://git-master/r/62097
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Rebase-Id: Ra5a6165c8a02f0ac130bbaac4a477b901ceea62f
Bug 862502
Change-Id: If70e54fb32ce14d5f13dde1d7fb4c1f1499a6722
Reviewed-on: http://git-master/r/47398
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Tested-by: Daniel Willemsen <dwillemsen@nvidia.com>
Rebase-Id: Ra77a54e6930692bca628a97bf1de10a30408cdef
During LP2 for CPU idle on Tegra2, there could be a race condition
between the CPUs. CPU1 cannot autonomously shut itself down (put
itself into reset). CPU1 must be reset by CPU0 but only when it
has no outstanding memory or I/O transactions going on (i.e., it
is in the WFI state). CPU1 indicates its readiness to be reset
by setting status in a PMC scratch register. If CPU1 wakes up
and CPU0 sees CPU1's ready to be reset status before CPU1 can
clear it CPU1 could be reset at inappropriate times resulting
in loss of cache coherency and ultimately a kernel panic.
Eliminate the race condition by ensuring that:
- CPU1's reset ready status is cleared as early as possible
before CPU1 rejoins the coherent world.
- Use writel when updating the IRAM LP2 status flags to ensure
the IRAM and coherent memory views of the flags are consistent.
- If there is not enough time remaining for CPU1 to be in LP2 for
the minimum residency time, clear CPU1's reset status flag
before entering WFI so that CPU0 will not wait for CPU1 to be
ready to reset (since it won't be if there is insufficient time).
Change-Id: I20dc5c6406b1521f20852294d48ce6d67f0926b9
Signed-off-by: Scott Williams <scwilliams@nvidia.com>
Rebase-Id: Rd485f696126d7ca019d15651b839d4f2fc595848
registers.
Change-Id: Ided2b31cbea0b0abb934e64cf056e85e1a3f06ae
Rebase-Id: R3f6ca9c63752430395fdf8375b82794abc9776af
Change-Id: I540d7272d585331da0241e7878dbb35557f0bb99
Rebase-Id: R59fe634cc803ba2c9bb7916046aff5f92120f5c3
The standard cpu_suspend does not work if there is an exernal
L2 cache in the system individual CPUs are suspending without
shutting down the whole CPU complex. As a workaround for this
problem, we must save the CPU context to a non-cacheable region
of memory.
Change-Id: I2fffbc77ed4f17fe9710307aaacda80836bacee8
Rebase-Id: R7328c032c2a13775aa09432e119ea845ded85930
Tag the stack frame created by the CPU register context push
macro with a magic number and validate that magic number in
the register context pop macro to ensure that the stack
remains balanced and uncorrupted.
Change-Id: I6aa876496e30e6e70c0c60800c1b35d217595153
Rebase-Id: R78eba17c256f03bdd6457ca3ebb1ecdba5632e60
Define macros to ensure that the behavior of push/pop of the
context regsiter set is consistent across all callers.
Change-Id: If2e68764e9755979a205a57543b30438e9b7ff96
Rebase-Id: Rb8f4984258e71c318e93fc709b18d1efdf5b2cc4
When exiting SMP coherency, clear cache and TLB operation forwarding.
Change-Id: Id91331b60eb40e47591fb0282820e31b14e027d5
Rebase-Id: R4d7697d029fa1b9d30ff612fad940f1c65b3b376
Define the SMP coherency exit code as a macro to allow it to be
inlined in assembly code that needs to control its register usage.
Change-Id: If5bd01241a92eb471cf59b4fc8445934fd4932b1
Rebase-Id: R921ed4d46431115d164f73bacac16a68a9d32b0a
Change-Id: Ie557f4429d65fb4cf701935b7ea6b1190140a878
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Rebase-Id: Rf03d13e909ff708671ab09077d1de590182b9917
Add support for forced Tegra3 LP2 low power mode on the boot processor
(CPU 0) via the cluster control interface when all others are offline.
Switching to the LP CPU mode is also enabled with this change.
LP2 in idle and LP2 mode on the secondary processors is not yet
supported.
Change-Id: Icb898729f093be5e006c413f701532dd45228687
Rebase-Id: Rd5d8c2b0addfd6853033670b992ae082e4a0d9c8
Change-Id: Ie43f4efdf884a916c6bc9737157091c35dc44501
DW: Split into logical changes
Rebase-Id: R1f023651504a7d336f7e98921f6372bee0aa1341
Consolidate all of the power management control flags in one
header and adjust the values of the software flags so that they
do not conflict with the values of the hardware flags.
Change-Id: I7971d274946d84dcc50bd9d9e0190091ebbefa2e
Rebase-Id: R29d2420a74f977c16f73b1abd9ca7470695a53f4
Rename tegra<n>_sleep_reset to tegra<n>_hotplug_shutdown since that is
more descriptive of their actual function.
Change-Id: I411e2474bd35a799d5367a182809d17933238612
Rebase-Id: R72bf50004ab3fcdde5485b84b7ba008247d1bf4c
- Add a single unified handler for all CPU resets that is copied to
IRAM.
- Add state information to direct the flow of execution through the
reset handler based on the reason a CPU was reset.
- Write the EVP CPU reset vector only once per cold/warm boot session.
- Prevent modification of the EVP CPU reset vector in Tegra3.
Bug 786290
Bug 790458
Change-Id: Ica6707f3514986ee914e73a2d9766a4e06ce2d29
Rebase-Id: R7b9859a83717e76c3c083bdde724bd5fef9ce089
Change-Id: Id45f6be8336370bf011484bea0a90e7e9f49f026
Rebase-Id: R06af455b61cb70a1a7dc18b38ad3f816d4ccba63
Change-Id: I07ffcffafcf47fd7539b22d4829712e041293bf3
Rebase-Id: R34a7800e24254d54b499411652d59421be703619
Change-Id: I2647718dc9c9420e57b24a810738c33ef05bcf61
Rebase-Id: R6d5c6a52a2b0fd1dafd021d4a187528aeca26516
Change-Id: I22bbfe62c6fed753a6852b12246f4a1f2414a96f
Rebase-Id: R2d7985afe7ffafac651d747205e528331f5f993e
Change-Id: I75ec091f9dcd0fa3fa56b1542f58a02006c1a314
Rebase-Id: Ree5fce2632aff6dc59879817ad7ad3f2b1538244
Change-Id: I7e7698ee3a0b51e5d7ea21212806701b34e39064
Rebase-Id: R324cb2c52cc2967be1189ef64ee6ac1bee8f60d0
Restore the code that was dropped in the port to Linux 2.6.39 that
protects against using LP2 mode for idle when the platform suspend
mode has disallowed the use of LP2 mode.
Also cleans up some warning messages.
Change-Id: I357210b8a272c10bf7c1e773342dc864bbddb74e
Reviewed-on: http://git-master/r/40463
Rebase-Id: R6a60e3f0f2ebf06ec9701475af41679c24ef80ab
Tegra supports three low power modes that involve powering down the CPU.
LP2 powers down both CPU cores and the GICs, but leaves the core
peripherals, including the memory controller and the legacy
interrupt controller, enabled. The legacy interrupt controller
is used as the wakeup source, and any interrupt can wake the device.
LP2 can be used in idle.
LP1 is the same as LP2, but in addition turns off the memory
controller and puts the DDR memory in self-refresh. Any interrupt
can wake the device. LP1 could be used in idle if no peripherals
are doing DMA.
LP0 turns off everything in the SoC except the RTC and a power
management controller, both of which run off a 32 kHz clock.
The power management controller has 32 wake sources, all other
interrupts can not be used to wake from LP0.
These low power modes power-gate the main CPU complex, requiring a
full processor state save and restore from a reset vector.
Platform-specific data (power good times, PMU capabilities, etc.) must be
specified when registering the suspend operations to ensure that platform
power sequencing restrictions are maintained.
In both LP0 and LP1, SDRAM is placed into self-refresh. in order to safely
perform this transition, the final shutdown procedure responsible for
* turning off the MMU and L1 data cache
* putting memory into self-refresh
* setting the DDR pads to the lowest power state
* and turning off PLLs
is copied into IRAM (at the address TEGRA_IRAM_BASE + SZ_4K) at the
start of the suspend process.
In LP1 mode (like LP2), the CPU is reset and executes the code specified
at the EVP reset vector. Since SDRAM is in self-refresh, this code must
also be located in IRAM, and it must re-enable DRAM before restoring the
full context. In this implementation, it enables the CPU on PLLP, enables
PLLC and PLLM, restores the SCLK burst policy, and jumps to the LP2 reset
vector to restore the rest of the system (MMU, PLLX, coresite, etc.). The
LP2 reset vector is expected to be found in PMC_SCRATCH1, and is
initialized during system-bootup.
In LP0 mode, the core voltage domain is also shutoff. As a result, all
of the volatile state in the core voltage domain (e.g., pinmux registers,
clock registers, etc.) must be saved to memory so that it can be restored
after the system resumes. A limited set of wakeups are available from LP0,
and the correct levels for the wakeups must be programmed into the PMC
wakepad configuration register prior to system shutdown. On resume, the
system resets into the boot ROM, and the boot ROM restores SDRAM and other
system state using values saved during kernel initialization in the PMC
scratch registers.
Resuming from LP0 requires the boot ROM to supply a signed recovery codeblob
to the kernel; the kernel expects that the length and address of this blob
is supplied with the lp0_vec= command line argument; if not present, suspend-
to-LP0 will be disabled
For simplicity, the outer cache is shutdown for both LP0 and LP1; it
is possible to optimize the LP1 routine to bypass outer cache shutdown
and restart.
Includes fixes from:
Aleksandr Frid <afrid@nvidia.com>
Vik Kasivajhula <tkasivajhula@nvidia.com>
Bharat Nihalani <Kbnihalani@nvidia.com>
James Wylder <james.wylder@motorola.com>
Allen Martin <amartin@nvidia.com>
Change-Id: I9e4e61c2fbb8c7bb5a29b1832ea38e7ea0524c52
Original-author: Gary King <gking@nvidia.com>
Signed-off-by: Gary King <gking@nvidia.com>
Signed-off-by: Colin Cross <ccross@android.com>
