Bug 955718
Reviewed-on: http://git-master/r/94164
(cherry picked from commit 1be4c3a94dd95a9c0fae2317983b0d7e44e39a1f)
Reviewed-on: http://git-master/r/94407
(cherry picked from commit 00799dbe21f5835b729f2fe9fcf95f30aa0b149f)
Change-Id: I909a15ead2d4ecb3dc416b8d3863fa8cb3645501
Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Updated optimized bin0 entries for AP25 CPU dvfs.
Bug 955718
Bug 643434
Reviewed-on: http://git-master/r/57303
(cherry picked from commit 6e5c759fcdfcdf4d1306fe5c9e33bf2dd5458076)
Reviewed-on: http://git-master/r/94406
(cherry picked from commit 61317b2ed1a259d5c0460aec8bc1d9f4e2275922)
Change-Id: I84cccfde1c0fa292c64a9acd2c96643416f00735
Signed-off-by: Bharat Nihalani <bnihalani@nvidia.com>
Reviewed-on: http://git-master/r/90306
Enabled dvfs table for sdmmc clocks
bug 893886
Reviewed-on: http://git-master/r/82687
(cherry picked from commit 45c6c0426fdde8d338d10029cc83b598e7e49e61)
Change-Id: I26e07b45ef6331b99c57dd792ad0cc66a94242fb
Signed-off-by: Shridhar Rasal <srasal@nvidia.com>
Reviewed-on: http://git-master/r/89410
Tested-by: Gerrit_Virtual_Submit
bug 880495
Change-Id: Ic89487c6296b20377ee12a135d06bef5b5c8b6fa
Reviewed-on: http://git-master/r/68983
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
This reverts commit a97ac421395cfb5998a53ccdc07c9a5f9c6777cd.
Fix bug 864254
Change-Id: I61b97e033413f7d61c06da83d9b6f971df9019cc
Reviewed-on: http://git-master/r/49685
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Tested-by: Dan Willemsen <dwillemsen@nvidia.com>
Rebase-Id: Raf5717982cd8768f948f446bfaa48265bfd723f6
Set the working voltage for USB to 1.1 v.
Bug 796594
Reviewed-on: http://git-master/r/30219
(cherry picked from commit af08f51a8c51b7b8d3f25ee7a2372f9d423b78e7)
Original-Change-Id: I71332eaa238c1116bcb2c2555654ea65a648c702
Reviewed-on: http://git-master/r/40305
Reviewed-by: Xin Xie <xxie@nvidia.com>
Tested-by: Xin Xie <xxie@nvidia.com>
Rebase-Id: R17971c5c60e28d8816955cf6d834df4c7d3c272b
Rebase-Id: Rfab78b9c453b9c1f55c780f8c99507a58cbeaece
Original-Change-Id: I2ffeaf6f8dfeb279b40ca6f69f6c9157401a746a
Rebase-Id: Rd8ebde470ad475b826857413018a2da8e1fdea25
Bug 764354
Original-Change-Id: I8a390eb4dae87dceacb97461f23d13554868b046
Reviewed-on: http://git-master/r/12228
Tested-by: Scott Williams <scwilliams@nvidia.com>
Original-Change-Id: I8e6b8303898796419fb5a759cd16edff9aeac081
Rebase-Id: R2866240384c6c24f46bd7ef54bc3dc9140d9e96b
Updated MPE clock dvfs table with recent characterization data.
As a result MPE clock limit is increased to 300MHz across all
tegra 2 SKUs.
Original-Change-Id: Ibe700770c7d109a397cb140b6f217a8d48509ff1
Reviewed-on: http://git-master/r/16662
Reviewed-by: Amit Kamath <akamath@nvidia.com>
Tested-by: Amit Kamath <akamath@nvidia.com>
Rebase-Id: R6e5c6cef46a05527a31d70ed87c6d3f58077c5e7
Updated system bus clock dvfs table with recent characterization
data. As a result nominal core voltage for SKUs with 240MHz SCLK
limit increased from 1.2V to 1.225V.
Original-Change-Id: I42a35f848bb0a410d393d930ddf1a87f86f25280
Reviewed-on: http://git-master/r/16272
Rebase-Id: Rda324012f2f1610da9480023d9fafc00ab9fdbd4
Add per process_id DVFS tables for tegra2 clocks, that are boosted
by the new tegra2 skus. Still use common worst case tables for other
clocks. Updated EMC dvfs table with recent characterization data.
Original-Change-Id: I883ccca54597b87f37c08bc2d7444190f80234f5
Reviewed-on: http://git-master/r/16079
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Tested-by: Aleksandr Frid <afrid@nvidia.com>
Rebase-Id: R47ff0f041def21ee650152224c6b5e654e5d1ab9
Original-Change-Id: Ia651b5c5f6cc0f6811b593bc795e6b7b97eb1741
Reviewed-on: http://git-master/r/16078
Rebase-Id: Re566c05f4e91bc1a0a2c24489edf680722c349fa
Added CPU DVFS tables for new tegra2 revisions/skus. Implemented
table selection based on chip speedo and process corner.
Original-Change-Id: Ic2aa7ff2b487a37a0a97d4f40453ff033a562207
Reviewed-on: http://git-master/r/13397
Rebase-Id: Rd090645567dbff203637e72fef3ead73019b4dcf
Change-Id: I865e52cae592507c642b92dde3a8293db2d0228f
Signed-off-by: Colin Cross <ccross@android.com>
The existing version did not extend well to core dvfs, drop it
for now until the new clk api with clk_prepare and clk_unprepare
is ready and non-atomic clocks are possible.
Acked-by: Olof Johansson <olof@lixom.net>
- Add drivers to clock lookup table
- Add new pll_m entries
- Support I2C U16 divider
- Fix rate reporting on 32.768kHz clock
- Call propagate rate only if set_rate succeeds
- Add support for audio_sync clock
- Add 24MHz to PLLA frequency list
- Correct i2s1/2/spdifout mux
- Add suspend support
- Fix enable/disable parent clocks in set_parent
- Add max_rate parameter to all clocks
- DVFS support
- Add virtual cpu clock with dvfs
- Support clk_round_rate
- Fix requesting very high periph frequencies
- Add quirks for PLLU:
PLLU is slightly different from the rest of the PLLs. The
lock enable bit is at bit 22 instead of 18 in the MISC
register, and the post divider field is a single bit with
reversed values from other PLLs.
- Simplify recalculating clock rates
- Fix UART divider flags
- Remove unused clock ops
