Initialize a variable to avoid a compiler warning and a potential bug.
Bug 999222
Change-Id: I77724b21d20049340943856c8d00af5e067c206a
Signed-off-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-on: http://git-master/r/109552
Tested-by: Stefan Becker <stefanb@nvidia.com>
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
Warnings removed are related to unused variables/labels,
structure/argument type mismatch, copyright update, function return
type mismatch and wrong C coding style.
Bug 949219
Change-Id: Ib748d12d5ab3cfc35118be28c29983081cca6cbb
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/103770
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
EMC state control register is not programmed correctly as the value
is not reset after previous write is done.
Bug 829087
Reviewed-on: http://git-master/r/40230
(cherry picked from commit 51a190b49a347968c22c1ed8187568a7ed1fb1f1)
Original-Change-Id: Ic2c8d33ad241100939eb1d8fa026a1d5849c0fd8
Reviewed-on: http://git-master/r/40687
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Rebase-Id: R6fe4735e67c44d7b3cc26449342de6862aa92b36
- resurrect the support for -group argument from user space. this causes
round robin sampling of client's band-width in a group
- pass current emc frequency to user space so that number of clock ticks
used in band-width calculation is correct
for bug 759918
Original-Change-Id: Ifbfccd3cb761253a1dd3253ce40fb92d9d9bb20c
Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Reviewed-on: http://git-master/r/24929
Rebase-Id: R625be9d46e35ffd77d50a055235469127c443b84
provide a mechanism to perform statistical sampling of the
memory controller usage on a client-by-client basis,
and report the log through sysfs
original work by: gking@nvidia.com
Original-Change-Id: I5d7f357af0353c55e14026b036ccf7e448df643b
Reviewed-on: http://git-master/r/20383
Rebase-Id: R591569f7b618508b34c2abe130700d2668779310
