Added skin prediction algorithm.
bug 1007726
Change-Id: Ia76f73cb818aa02e608e1fc69ab4d8277a5825eb
Signed-off-by: Joshua Primero <jprimero@nvidia.com>
Reviewed-on: http://git-master/r/104814
GVS: Gerrit_Virtual_Submit
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Bug 941960
Removed CONFIG_TEGRA_INTERNAL_TSENSOR_EDP_SUPPORT.
Add internal tsensor on kai.
Change-Id: Iaefa43112fbbaa42d43a428ecb86ad821e683f85
Signed-off-by: Hao Tang <htang@nvidia.com>
Reviewed-on: http://git-master/r/84350
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Removed tsensor initialization if external tdiode is
being used for temperature measurements.
bug 928188
Reviewed-on: http://git-master/r/75995
Change-Id: Ifcfd5b4c2b094dcd4fb5386708b332f2a76c272c
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
Reviewed-on: http://git-master/r/76819
mach-tegra/tegra3_tsensor.h is used for the parameterized initialization
of the tsensor device. mach-tegra/include/mach/tsensor.h is used for the
tsensor device driver.
Really, mach-tegra/tegra3_tsensor.c should go away - probably becoming a
device driver.
Change-Id: I16edae878f1e97d1654252cfee49cd9dd7f77db7
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-on: http://git-master/r/72481
Instead of using 0C as default low temp in thermal
algorithm, query the thermal device driver for
lowest supported temperature.
Change-Id: Id1f70380ba476dec80e36ce79b42ab6f24a5d5ba
Reviewed-on: http://git-master/r/70935
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Added name paramater per therm device so that is
easy to tell which therm device is being used
from sysfs
Change-Id: I58488b4c50ac6dc58dc00e270b613458f61a9fd6
Reviewed-on: http://git-master/r/70929
Hooked up tsensor to thermal framework. Cleaned
up some unnessary tsensor code as well.
Bug 848755
Reviewed-on: http://git-master/r/62021
(cherry picked from commit 307f53a36bd1bdfaabddfdd80f9de5445d805786)
Change-Id: If4156c35f78575bc67b48d1d87fa82a4e32751c5
Reviewed-on: http://git-master/r/63344
Reviewed-on: http://git-master/r/67238
Change-Id: Ie730ad7ec74927ef63722f4038db00e5f5d31154
Signed-off-by: Colin Patrick McCabe <cmccabe@nvidia.com>
Reviewed-on: http://git-master/r/60558
Rebase-Id: Rad06124e61bdf95cb0307dd2204f2bf4bb92e718
tsensor functionality is enabled based on fuse revision.
The fuse revision is to be interpreted as an unsigned integer
while it is interpreted as a decimal number. Corrected this
in platform source file.
bug 863460
Original-Change-Id: Iaf9676d559bb7fb3555c7b731aa018f949441c8e
Reviewed-on: http://git-master/r/46901
Reviewed-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Tested-by: Bitan Biswas <bbiswas@nvidia.com>
Rebase-Id: R8a85e2ce060dd3110c374b30d0018c7512b22113
Add board support needed for PMU switch off when tsensor
detects temperature > TH3 threshold set.
bug 850047
Original-Change-Id: I7a283cedc735264dd8ea52801f7f1a103e9293cb
Reviewed-on: http://git-master/r/41531
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: Rc4bf2206a7207e28434b46baed442cd6f2797fbc
Defined public fuse API to extract tegra3 tsensor configuration
parameters.
bug 851791
Original-Change-Id: Ia14e2d515ee1d695556492464e8ceaf4b0d13477
Reviewed-on: http://git-master/r/42367
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Rebase-Id: R1090e6ad78bcef23670ff647de86e695780f5b76
Tegra internal tsensor driver supported for fuse revision 0.8
and above.
Bug 661228
Original-Change-Id: I820f6b5f20c20bb2d1ba04266148f5969ab84444
Reviewed-on: http://git-master/r/36054
Rebase-Id: R4725524b5e3f83b4cd3dd7d0020ef2d6e09a87d0
