tsensor functionality is enabled based on fuse revision.
The fuse revision is to be interpreted as an unsigned integer
while it is interpreted as a decimal number. Corrected this
in platform source file.
bug 863460
Original-Change-Id: Iaf9676d559bb7fb3555c7b731aa018f949441c8e
Reviewed-on: http://git-master/r/46901
Reviewed-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Tested-by: Bitan Biswas <bbiswas@nvidia.com>
Rebase-Id: R8a85e2ce060dd3110c374b30d0018c7512b22113
Add board support needed for PMU switch off when tsensor
detects temperature > TH3 threshold set.
bug 850047
Original-Change-Id: I7a283cedc735264dd8ea52801f7f1a103e9293cb
Reviewed-on: http://git-master/r/41531
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: Rc4bf2206a7207e28434b46baed442cd6f2797fbc
Defined public fuse API to extract tegra3 tsensor configuration
parameters.
bug 851791
Original-Change-Id: Ia14e2d515ee1d695556492464e8ceaf4b0d13477
Reviewed-on: http://git-master/r/42367
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Rebase-Id: R1090e6ad78bcef23670ff647de86e695780f5b76
Tegra internal tsensor driver supported for fuse revision 0.8
and above.
Bug 661228
Original-Change-Id: I820f6b5f20c20bb2d1ba04266148f5969ab84444
Reviewed-on: http://git-master/r/36054
Rebase-Id: R4725524b5e3f83b4cd3dd7d0020ef2d6e09a87d0
