Fix issues causing the kernel build to fail with CONFIG_SMP not set.
Change-Id: I8c7a49970e55354e38ce41d2d1e0dab00ba78f24
Signed-off-by: Alex Waterman <alexw@nvidia.com>
Reviewed-on: http://git-master/r/114317
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
- Adding flag to treat warning as error.
- Handling warnings of unused variable, structures and functions,
wrong return type, wrong type comparision.
Bug 949219
Change-Id: I9d02387ce1073c4e46f69d01669285aa3754f1d9
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/104968
On entry/exit to suspend state remove/restore Tegra3 LP2 wake timers
interrupts affinity to the respective secondary CPUs.
Change-Id: I9b46c5fa446a8c6e813343f4564abda5313853da
Signed-off-by: Alex Frid <afrid@nvidia.com>
Reviewed-on: http://git-master/r/87541
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Currently on Tegra3 cpu complex is powered off in idle (enters CPU0
LP2 state) only if all secondary CPUs are off-line. This commit adds
an option for CPU0 to enter LP2 while secondary CPUs are still on-line
but have been power gated and entered LP2 state by themselves.
The critical race: secondary CPU is waking up from LP2, while CPU0 is
turning common CPU rail off, is addressed as follows.
1. When entering LP2 state on CPU0:
a) disable GIC distributor
b) check that CPU1-3 are all power-gated (i.e., either off-lined or
have entered LP2)
c) if (b) passes - set all interrupts affinity to CPU0, then
re-enable distributor and continue with CPU complex powering off
d) if (b) fails - re-enable distributor and enter clock-gated (LP3)
state on CPU0
This procedure prevents waking secondary CPUs by GIC SPIs.
2. We still need to make sure that no CPU1-3 PPIs from legacy IRQ/FIQ
or private timers would happen. This is achieved by disabling timers
and legacy interrupts if CPU1-3 enters LP2 state with external timers
selected as wake sources. Respectively, establish dependency between
turning rail off and LP2 wake timers configuration options.
3. Finally, no IPIs is sent by CPU0 entering LP2.
There are no special changes in wake up procedures - whenever CPU0
is awaken by external interrupt or wake timer, cpu complex is powered
on by h/w, and secondary CPUs that were in LP2 state are ungated by
the same interrupt (off-line CPUs are kept power gated). Hence, there
is no need for CPU1-3 external wake timers to run while the rail is
off, and these timers are stopped. To make sure that none of secondary
CPUs over-sleeps its LP2 time, CPU0 wake timer is set to minimum sleep
interval of all CPUs.
By default configuration option for powering off multiple on-line CPUs
is disabled on Tegra3.
Change-Id: I4920d0df375536b2b8ebd9e6738c5fe4f92b92a0
Reviewed-on: http://git-master/r/83547
Add an option to use external timer as Tegra3 secondary CPU wake
source from lp2 (power gated) state. This is a follow up to commit
51e6be9ce103fbeb2b73fa2a9d2b6528a6941e81 that disabled wake from
external timer, since its interrupt is registered too late - after
secondary CPU is brought on-line, and already had a chance to enter
lp2. With this commit, secondary CPU is not allowed to enter lp2 in
idle until wake timer is registered (clock-gated lp3 state is entered
instead).
External timer wake up mechanism is enabled on Tegra3 only if option
HAVE_ARM_TWD is not selected. Otherwise, continue to use local CPU
timers as lp2 wake sources.
Change-Id: Ic8c33f55e77174717bfa6525041e1263d3232dd5
Reviewed-on: http://git-master/r/83546
Consolidate the functions used to measure the input frequency
into a single implementation and perform the measurement only
once.
Change-Id: I3d13e608a7256d154373542ca001cbda9c03c21b
Signed-off-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-on: http://git-master/r/83613
Reviewed-by: Simone Willett <swillett@nvidia.com>
Fix compiler warning when PM_SLEEP and HOTPLUG_CPU are not configured.
Change-Id: I6e9e7aaf9c63752d0c33363b1cced75b4437d82d
Reviewed-on: http://git-master/r/66508
Tested-by: Gerrit_Virtual_Submit
Rebase-Id: R5687b9e034e004907ba01263948bf839544adb1b
Don't call irq_set_affinity() on non-SMP systems.
Change-Id: I728d5163bff3fb2bd4a2ea7946d2e57cb0854589
Reviewed-on: http://git-master/r/49346
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Tested-by: Daniel Willemsen <dwillemsen@nvidia.com>
Rebase-Id: R470db120396c95bdcafc48ba357652a43d63da82
Original-Change-Id: Ibf7a37c0751924f0a8de4932d0d31b6fe6c3c4e8
Reviewed-on: http://git-master/r/49049
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
Rebase-Id: Rfcfb080975c0f844487b91167fc455882f0cb5f4
This change is needed to support three different platforms, silicon,
fpga and simulation.
Change-Id: I407853e1d86accbe3686deb4f34571fe6b10bcce
Reviewed-on: http://git-master/r/36351
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: Rc4b424f1a55ffb71245f3a8330559258124e2a19
Change-Id: I121c8aff9c4cb212ac625ef7751d8cf6b8093068
DW: Split into logical changes, move hotplug notifier to timer-t3.c
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Rebase-Id: Rbfbfdb1720960dd9ce2847fb16daa932bebb16d2
The system timer initialization code for Tegra2 and Tegra3 is
essentially the same except for the actual physical timer used and the
range of possible reference clock frequencies. This change removes the
needless duplication of code and restructures the system timer code into
common and SOC-specific parts.
Change-Id: Icb6e4c0e2b218c67667be9450e10326e1e42945b
Rebase-Id: Rbd3fc10b2a6935dd1ca9272695fd0133e0ca4f15
Rebase-Id: Re2ca6bafa842d114859a40c7ab19097fd86fc635
Rename timer.c to timer-t2.c for consistency with other
chip-specific implementations.
Bug 790458
Bug 790448
Bug 738259
Original-Change-Id: I7e0fceb716590cd92b64ba00c0bebe659e9beb21
Reviewed-on: http://git-master/r/22885
Tested-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Original-Change-Id: I322324c2177d57657a63e9428f8e49d5df2b828e
Rebase-Id: R7312866cdc8044a71cc2f83ad4bc7aa66b07416d
Restructure timer controller usage in order to add Lp2 wake timers
for all cpu's.
Bug 790458
Original-Change-Id: Ie71eb9fb8c1bee0bd059d40b1761718931c9bfe0
Reviewed-on: http://git-master/r/20692
Tested-by: Diwakar Tundlam <dtundlam@nvidia.com>
Tested-by: Krishna Reddy <vdumpa@nvidia.com>
Original-Change-Id: I16ccea6db75ec4fd0d7da264c37b311113e59fd7
Rebase-Id: Rf0292ae426d874ac8c7cd0fa988ba7314c5256a2
