Add silicon aging for VDD_CPU, this recovers some of millivolts based on
the age of the chip.
BUG 1006420
Change-Id: Idddb5861ab039e7ece262dec3697a69c3534ccf2
Signed-off-by: Anshul Jain <anshulj@nvidia.com>
Reviewed-on: http://git-master/r/116911
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
GVS: Gerrit_Virtual_Submit
When Tegra3 secondary CPU is entering LP2, read TWD timer state
into context structure, rather than separate local variables.
Reviewed-on: http://git-master/r/77957
Change-Id: I237eafc50a11d535b94f334631d039ba9c4bf44b
Signed-off-by: Alex Frid <afrid@nvidia.com>
Reviewed-on: http://git-master/r/78899
Change-Id: I629f77041ce444dfff32b563795573174afea3a1
Signed-off-by: Scott Williams <scwilliams@nvidia.com>
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Rebase-Id: R7a21e91127b44461d219a8bfd388f99ba7a72b53
The system timer initialization code for Tegra2 and Tegra3 is
essentially the same except for the actual physical timer used and the
range of possible reference clock frequencies. This change removes the
needless duplication of code and restructures the system timer code into
common and SOC-specific parts.
Change-Id: Icb6e4c0e2b218c67667be9450e10326e1e42945b
DW: Split into logical changes
Rebase-Id: Rbd3fc10b2a6935dd1ca9272695fd0133e0ca4f15
