The wake up time adjustment for per-core CPU power down entry has
a few issues: the logic of checking masking bit is wrong and
unnecessary, the timer function for getting context is not used
elsewhere and seems redundant, the calculating statement itself
is confusing.
This patch aims to fix issues above.
Change-Id: Id717f50005e0c32db80af786d9b1fbbe628c196a
Signed-off-by: Bo Yan <byan@nvidia.com>
Reviewed-on: http://git-master/r/197065
Reviewed-by: Seshendra Gadagottu <sgadagottu@nvidia.com>
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
The sleep length in tick data structure does not reflect how long
timer has been running, thus the expected wake up trigger may be
set to a value which is too late.
Directly accessing timer register to get the next timer event,
which is then used to calculate the expected wake up time.
This implies we are sleeping shorter than before in case of cluster
power down, but will make sure we don't oversleep.
Change-Id: I84598db30b6a739103026d090b130f3adb63147b
Reviewed-on: http://git-master/r/193483
Tegra RTC counter value is added to the suspend trace calls so that
wakeup latency can be measured.
Change-Id: Ibe97b50d89a843c6caffc02587f398ff5d2936a6
Signed-off-by: Sivaram Nair <sivaramn@nvidia.com>
Reviewed-on: http://git-master/r/162302
Reviewed-by: Simone Willett <swillett@nvidia.com>
The TimerValue register in generic timer does not stop after
counting to 0, it will keep counting down. The value is the
time elapsed after event trigger.
Reviewed-on: http://git-master/r/139535
(cherry picked from commit f84b23ed0c37297bf8142b69702cf8f2a1c24058)
Change-Id: I009585819b801b2eb157f9a70a3e9bf75a41ff77
Signed-off-by: Bharat Nihalani <bnihalani@nvidia.com>
Reviewed-on: http://git-master/r/146479
Reviewed-by: Bo Yan <byan@nvidia.com>
Tested-by: Bo Yan <byan@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
GVS: Gerrit_Virtual_Submit
Change-Id: Ib106db20f587e53c95410fcc3d834c257b112a19
Add silicon aging for VDD_CPU, this recovers some of millivolts based on
the age of the chip.
BUG 1006420
Change-Id: Idddb5861ab039e7ece262dec3697a69c3534ccf2
Signed-off-by: Anshul Jain <anshulj@nvidia.com>
Reviewed-on: http://git-master/r/116911
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
There is no new change for T20 and T30. For SoCs with arch timer
support, arch timer is used for LP2 accounting.
Also removed ARM_SMP_TWD option from Kconfig, it's no longer
necessary and deprecated.
Change-Id: I4292e333df97da296318224e0aa1411330f67900
Reviewed-on: http://git-master/r/118365
Save & restore generic timer registers across cluster switch.
Change-Id: I8a7e131dede5b21259868edf4fff2df8a20c93c2
Reviewed-on: http://git-master/r/116859
Change-Id: I94d4ab5c8d53e454bbd09b6ef2586b1baf69d456
Reviewed-on: http://git-master/r/113243
The arch timer suspend/resume functions are somewhat misnamed.
They are more correctly Timer Stamp Counter (TSC) suspend/resume
functions. Rename them accordingly.
Change-Id: I81c3c0385b03a6b0d80613528ce8c8e505391f32
Signed-off-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-on: http://git-master/r/89814
Change-Id: Id52c906149f9c7e72501b50ead3912228aea033a
Reviewed-on: http://git-master/r/84151
Tegra11x will never have ARM TWDs so remove the clock entries
that were propagated from the original Tegra3 tables.
Change-Id: Ic6e551271f373e67e6c541f56e0a392e55ba8b27
Reviewed-on: http://git-master/r/83538
Reviewed-by: Mark Stadler <mastadler@nvidia.com>
Do not initialize the TWD clock if HAVE_ARM_TWD is deselected.
Also moves all TWD initialization out of the common clock file
and into the common timer file.
Change-Id: Ie18594c571bd662c495ae4d786b70eb07b8d1437
Reviewed-on: http://git-master/r/83265
rip out common things from tegra2/3 code and include them
in the common timer init sequence.
Change-Id: Ia6f3dc26b6ddbbc89640a6831b011d69d233338e
When Tegra3 secondary CPU is entering LP2, read TWD timer state
into context structure, rather than separate local variables.
Reviewed-on: http://git-master/r/77957
Change-Id: I237eafc50a11d535b94f334631d039ba9c4bf44b
Signed-off-by: Alex Frid <afrid@nvidia.com>
Reviewed-on: http://git-master/r/78899
Rebase-Id: Ra2fb8f72f23c8aac06757aba504623ea45ae4185
Change-Id: I629f77041ce444dfff32b563795573174afea3a1
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Rebase-Id: R7a21e91127b44461d219a8bfd388f99ba7a72b53
The system timer initialization code for Tegra2 and Tegra3 is
essentially the same except for the actual physical timer used and the
range of possible reference clock frequencies. This change removes the
needless duplication of code and restructures the system timer code into
common and SOC-specific parts.
Change-Id: Icb6e4c0e2b218c67667be9450e10326e1e42945b
DW: Split into logical changes
Rebase-Id: Rbd3fc10b2a6935dd1ca9272695fd0133e0ca4f15
