Integrate MAX9526 video decoder support as found on our analogous
camera module (ACM) connected to a Colibri Evaluation carrier board.
The following kernel configuration options are required to be enabled:
CONFIG_VIDEO_V4L2=y
CONFIG_SOC_CAMERA=y
CONFIG_SOC_CAMERA_MAX9526=y
CONFIG_VIDEO_TEGRA=y
arch/arm/mach-tegra/common.c
drivers/ata/ahci-tegra.c
Move GPIO defines to header file.
While at it get rid of spurious AVDD_DSI_CSI_ENB_GPIO define.
Re-arrange defines in header file.
Get rid of spurious AC_PRESENT_GPIO/INT defines.
Explicitly configure MMC/SD card as 4-bit only by default.
Rename UARTs to be consistent with Colibri FF/BT/STDUART naming.
Rename PWM LEDs to be consistent with Colibri PWM<X> naming.
Migrate from static TEGRA_GPIO_TO_IRQ macro to run-time gpio_to_irq
function.
While at it clean-up some comments and fix some long lines in order to
adhere to Linux kernel coding style.
Clean-up clocks. HDA clocks are of course required on Apalis T30.
Fix naming of fixed regulator initialisation function.
Fix naming of CAN initialisation function.
Move Apalis T30 specific entries for alphabetical consistency. Put
Colibri T30 items in alphabetical order.
Enable back key wake-up source.
Due to missing pull-ups on the gpio-key pins Android unintentionally
entered safe-mode.
Activate 24 bpp RGB output.
Please not that this is just the backend configuration. For true 24 bpp
output the framebuffer as well as driver have to be configured for 24
resp. 32 bpp as well.
The audio_port_id in the audio platform data really has to be the index
of the registered tegra_i2s_device rather than the I2S interface
instance.
Reset PLX PEX 8605 PCIe Switch on Apalis Evaluation Board to enable
X43, X44 and X45.
Add defines for the generic Apalis GPIOs 1 to 8 and the special use
thereof on the Apalis Evaluation Board:
FAN_EN on GPIO8: enable FAN supply on X35
PEX_PERST_N on GPIO7: reset PCIe switch for X43, X44 and X45
TOUCH_WIPER on GPIO6: optional touch wiper GPIO
Fix the following build error using our OpenEmbedded gcc-4.7:
arch/arm/mach-tegra/pcie.c:335:22: error: 'reg_pmc_base' defined but
not used [-Werror=unused-variable]
cc1: all warnings being treated as errors
Add new PCIe driver fixing multi-port operation. Pulled from
Linux_Kernel-src_CARMA_DevKit-ver3.1.10_l4t_Rev545.tgz.
This patch integrates multi-touch for the TouchRevolution Fusion 7 and
10 panels connected to Iris as follows:
Iris X16-5, SODIMM pin 194, I2C SDA
Iris X16-6, SODIMM pin 196, I2C SCL
Iris X16-15, SODIMM pin 103, pen down interrupt
Iris X16-16, SODIMM pin 101, reset
The following kernel configuration needs to be enabled:
Device Drivers -> Input device support -> Touchscreens
-> TouchRevolution Fusion F0710A Touchscreens
Please note that level shifters are required.
Please further note that our current OpenEmbedded BSP does not yet
integrate multi-touch support in the XInput as well as X server layers.
This patch contains updated display timings for the TouchRevolution
Fusion 10 aka Chunghwa Picture Tubes CLAA101NC05 10.1 inch 1024x600@60
single channel LVDS panel.
While at it add a note that the backlight brightness polarity is
display model specific.
This patch adds display timings for the Chunghwa Picture Tubes
CLAA101NC05 10.1 inch 1024x600@60 single channel LVDS panel.
This patch adds display timings for the LG LP156WF1 15.6 inch full HD
dual channel LVDS panel.
The THine THC63LVD827 LVDS transmitter uses 8 GPIOs for configuration.
This patch configures and exports them for easy user-space access.
Configure LG LP156WF1 15.6 inch full HD dual channel LVDS panel:
root@apalis-t30:~# echo out > /sys/class/gpio/gpio216/direction
root@apalis-t30:~# echo 0 > /sys/class/gpio/gpio216/value
root@apalis-t30:~# echo out > /sys/class/gpio/gpio219/direction
root@apalis-t30:~# echo 1 > /sys/class/gpio/gpio219/value
root@apalis-t30:~# echo out > /sys/class/gpio/gpio220/direction
root@apalis-t30:~# echo 1 > /sys/class/gpio/gpio220/value
root@apalis-t30:~# echo out > /sys/class/gpio/gpio221/direction
root@apalis-t30:~# echo 1 > /sys/class/gpio/gpio221/value
root@apalis-t30:~# echo out > /sys/class/gpio/gpio222/direction
root@apalis-t30:~# echo 1 > /sys/class/gpio/gpio222/value
root@apalis-t30:~# echo out > /sys/class/gpio/gpio223/direction
root@apalis-t30:~# echo 1 > /sys/class/gpio/gpio223/value
root@apalis-t30:~# echo out > /sys/class/gpio/gpio225/direction
root@apalis-t30:~# echo 1 > /sys/class/gpio/gpio225/value
root@apalis-t30:~# echo out > /sys/class/gpio/gpio226/direction
root@apalis-t30:~# echo 1 > /sys/class/gpio/gpio226/value
root@apalis-t30:~# cat /sys/kernel/debug/gpio | grep LVDS
gpio-216 (LVDS: Single/Dual Ch) out lo
gpio-219 (LVDS: 18/24 Bit Mode) out hi
gpio-220 (LVDS: Output Enable ) out hi
gpio-221 (LVDS: Power Down ) out hi
gpio-222 (LVDS: Clock Polarity) out hi
gpio-223 (LVDS: Colour Mapping) out hi
gpio-225 (LVDS: Swing Mode ) out hi
gpio-226 (LVDS: DDRclk Disable) out hi
Add battery regulator which is always-on. The rail which is
powered from battery can be added on this rail as consumer.
bug 1218527
Change-Id: I2394e1894649cd4fa736646981374681f603c832
Reviewed-on: http://git-master/r/#change,193052
(cherry picked from commit 4b9cabe87060bf5f252206aba5b62ea1ccb2ff83)
Reviewed-on: http://git-master/r/193777
Tested-by: Preetham Chandru <pchandru@nvidia.com>
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Add support for PM315
Bug 1217569
Change-Id: I230fcec04eb5a96441e2c19b304d608d86eaf996
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-on: http://git-master/r/191555
GVS: Gerrit_Virtual_Submit
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
Looks like this DPD stuff whatever it is fails 8-bit MMC1 slot card
detection on our current Apalis T30 prototypes.
See f4cd0d4448d65a42b65c338f85a3ab8064923c61.
Tested on early prototype Apalis T30 V1.0a module.
Known issues:
- ADC not integrated yet.
- HDA not integrated yet.
- CEC not integrated yet.
- IrDA not integrated yet.
- Keys not integrated yet therefore no way to wake from suspend.
- 8-bit MMC1 slot card detection interrupt not working despite
detection GPIO successfully being tested with GPIOConfig.
Note: even 8-bit cards work fine if already plugged-in during boot.
- PCIe limited to internal Gigabit Ethernet chip for now due to our
proprietary way of resetting other ports which requires further
integration into NVIDIA's driver.
set DD pins to push/pull if not used for I2C in open drain mode
3.3V consumers
PLLE: now supplied by LDO6 - Put the limits of the supplied circuit as constraints - Moved derived rails from 1.8V to 3.3V where applicable
Registration of PWRON key through PMU interrupt
Bug 1218247
Change-Id: I4d5d4a404fff28f2e34b1fd4af5712796eb8806c
Signed-off-by: Ramalingam C <ramalingamc@nvidia.com>
Reviewed-on: http://git-master/r/191574
Reviewed-by: Preetham Chandru <pchandru@nvidia.com>
Reviewed-by: Peer Chen <pchen@nvidia.com>
Looks like we mixed up the low-active buffer enable GPIOs. This fixes
GMI_WR_N on SODIMM pin 93 RDnWR curtsey Tord Andersson from Endian
Technologies AB.
Well commit bfd8d6dc27ccf00bf89b0a7bb3d359bab2142376 got rid of the w1
include a little prematurely.
Add one-wire platform data. Still requires explicitly enabling the
following two kernel configuration options:
CONFIG_W1
CONFIG_W1_MASTER_TEGRA
Make PWM B, C, D accessible from userspace. e.g as
/sys/class/leds/pwm_b.
Can be initiated both by LXDE Logout - Suspend or manually doing
'echo mem > /sys/power/state'. Uses GPIO key power (SODIMM pin 45,
Iris X16-20) as wake-up source. If woken-up LXDE session does not
automatically activate desktop again try manually doing a 'chvt 7'.
Implement the following GPIO keys:
- find (SODIMM pin 77)
- home (SODIMM pin 127)
- back (SODIMM pin 133, Iris X16-14)
- volume up (SODIMM pin 22)
- volume down (SODIMM pin 24)
- power (SODIMM pin 45, Iris X16-20)
- menu (SODIMM pin 135)
Now simply enabling CONFIG_TEGRA_CAMERA resp. not explicitly disabling
it will make L4T's nv_omx_vip Gstreamer plug-in work with analogue video
decoders like the ADV7180 or MAX9526.
Booting with a bare USB hub (e.g. EvalBoard V3.1A) and later plugging
in a USB device completely hang the system. This fixes it.
Shorten GPL license header.
Get rid of obsolete includes.
Get rid of spurious comments.
Fix indentation.
Add some clarifying comments.
Commit 39ca35e4610f1307247815ec5268b5072172d24a mixed up the SCL/SDA
GPIOs. This fixes it again.
Fix indentation.
Rename board level init_machine and reserve functions.
As our hardware only allows triggering an interrupt on over-temperature
shutdown we setup a workqueue to catch leaving it again.
For Tegra 3 NVIDIA relies on the regular Linux thermal subsystem.
As follows some output during a thermal throttling run:
root@colibri-t30:~# cat /sys/bus/i2c/devices/4-004c/temp2_os
45000
RAM 400/980MB (lfb 135x4MB) IRAM 0/255kB(lfb 255kB)
cpu [12%,2%,3%,6%]@475 EMC 533 AVP 81 VDE 400 EDP limit 1300000
Temperatures CPU 42.4 Board 36.4
60000
cpu [14%,5%,4%,4%]@1300 EMC 533 AVP 81 VDE 400 EDP limit 1300000
Temperatures CPU 54.2 Board 47.8
cpu [100%,100%,100%,100%]@1200 EMC 533 AVP 81 VDE 400 EDP limit 1200000
Temperatures CPU 70.4 Board 56.6
75000
cpu [54%,49%,48%,48%]@1200 EMC 533 AVP 81 VDE 400 EDP limit 1200000
Temperatures CPU 70.9 Board 57.1
cpu [100%,100%,100%,100%]@1100 EMC 533 AVP 81 VDE 400 EDP limit 1100000
Temperatures CPU 75.3 Board 60.5
85000
RAM 401/980MB (lfb 135x4MB) IRAM 0/255kB(lfb 255kB)
cpu [65%,61%,61%,61%]@1100 EMC 533 AVP 81 VDE 400 EDP limit 1100000
Temperatures CPU 75.2 Board 61.0
cpu [100%,100%,100%,100%]@1000 EMC 533 AVP 81 VDE 400 EDP limit 1100000
Temperatures CPU 85.1 Board 69.8
cpu [100%,100%,100%,100%]@760 EMC 533 AVP 81 VDE 400 EDP limit 1100000
Temperatures CPU 85.1 Board 69.9
root@colibri-t30:~# cat /sys/class/thermal/cooling_device0/cur_state
0
root@colibri-t30:~# cat /sys/class/thermal/cooling_device0/max_state
10
root@colibri-t30:~# cat /sys/class/thermal/cooling_device0/type
balanced
root@colibri-t30:~# cat /sys/class/thermal/thermal_zone0/cdev0_trip_point
0
root@colibri-t30:~# cat /sys/class/thermal/thermal_zone0/temp
84531
root@colibri-t30:~# cat /sys/class/thermal/thermal_zone0/trip_point_0_temp
85000
root@colibri-t30:~# cat /sys/class/thermal/thermal_zone0/trip_point_0_type
passive
root@colibri-t30:~# cat /sys/class/thermal/thermal_zone0/type
lm95245_remote
Adjust thermal throttling to latest lm95245 evolution and wait with the
interrupt registration until we get the LM95245 drivers probe callback.
While at it add some clarifying comments and wrap RTC stuff with a
define.
