commit d70f7d31a9e2088e8a507194354d41ea10062994 upstream.
There is an unfortunate typo in the code that results in writing to
FLOW_CTLR_HALT instead of FLOW_CTLR_CSR.
Cc: <stable@vger.kernel.org>
Acked-by: Peter De Schrijver <pdeschrijver@nvidia.com>
Signed-off-by: Dmitry Osipenko <digetx@gmail.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Pull ARM SoC driver updates from Olof Johansson:
"This branch contains platform-related driver updates for ARM and ARM64.
Among them:
- Reset driver updates:
+ New API for dealing with arrays of resets
+ Make unimplemented {de,}assert return success on shared resets
+ MSDKv1 driver
+ Removal of obsolete Gemini reset driver
+ Misc updates for sunxi and Uniphier
- SoC drivers:
+ Platform SoC driver registration on Tegra
+ Shuffle of Qualcomm drivers into a submenu
+ Allwinner A64 support for SRAM
+ Renesas R-Car R3 support
+ Power domains for Rockchip RK3366
- Misc updates and smaller fixes for TEE and memory driver
subsystems"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (54 commits)
firmware: arm_scpi: fix endianness of dev_id in struct dev_pstate_set
soc/tegra: fuse: Add missing semi-colon
soc/tegra: Restrict SoC device registration to Tegra
drivers: soc: sunxi: add support for A64 and its SRAM C
drivers: soc: sunxi: add support for remapping func value to reg value
drivers: soc: sunxi: fix error processing on base address when claiming
dt-bindings: add binding for Allwinner A64 SRAM controller and SRAM C
bus: sunxi-rsb: Enable by default for ARM64
soc/tegra: Register SoC device
firmware: tegra: set drvdata earlier
memory: Convert to using %pOF instead of full_name
soc: Convert to using %pOF instead of full_name
bus: Convert to using %pOF instead of full_name
firmware: Convert to using %pOF instead of full_name
soc: mediatek: add SCPSYS power domain driver for MediaTek MT7622 SoC
soc: mediatek: add header files required for MT7622 SCPSYS dt-binding
soc: mediatek: reduce code duplication of scpsys_probe across all SoCs
dt-bindings: soc: update the binding document for SCPSYS on MediaTek MT7622 SoC
reset: uniphier: add analog amplifiers reset control
reset: uniphier: add video input subsystem reset control
Pull ARM/arm64 SoC platform updates from Olof Johansson: "This branch
contains platform updates for 32- and 64-bit ARM, including defconfig
updates to enable new options, drivers and platforms. There are also a
few fixes and cleanups for some existing vendors.
Some of the things worth highlighting here are:
- Enabling new crypt drivers on arm64 defconfig
- QCOM IPQ8074 clocks and pinctrl drivers on arm64 defconfig
- Debug support enabled for Renesas r8a7743
- Various config updates for Renesas platforms (sound, USB, other
drivers)
- Platform support (including SMP) for TI dra762
- OMAP cleanups: Move to use generic 8250 debug_ll, removal of stale
DMA code"
* tag 'armsoc-platforms' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (109 commits)
ARM: multi_v7_defconfig: make eSDHC driver built-in
arm64: defconfig: enable rockchip graphics
MAINTAINERS: Update Cavium ThunderX2 entry
ARM: config: aspeed: Add I2C, VUART, LPC Snoop
ARM: configs: aspeed: Update Aspeed G4 with VMSPLIT_2G
ARM: s3c24xx: Fix NAND ECC mode for mini2440 board
ARM: davinci_all_defconfig: enable tinydrm and ST7586
arm64: defconfig: Enable QCOM IPQ8074 clock and pinctrl
ARM: defconfig: tegra: Enable ChipIdea UDC driver
ARM: configs: Add Tegra I2S interfaces to multi_v7_defconfig
ARM: tegra: Add Tegra I2S interfaces to defconfig
ARM: tegra: Update default configuration for v4.13-rc1
MAINTAINERS: update ARM/ZTE entry
soc: versatile: remove unnecessary static in realview_soc_probe()
ARM: Convert to using %pOF instead of full_name
ARM: hisi: Fix typo in comment
ARM: multi_v7_defconfig: add CONFIG_BRCMSTB_THERMAL
arm64: defconfig: add CONFIG_BRCMSTB_THERMAL
arm64: defconfig: add recently added crypto drivers as modules
arm64: defconfig: enable CONFIG_UNIPHIER_WATCHDOG
Move this code from arch/arm/mach-tegra and make it common among 32-bit
and 64-bit Tegra SoCs. This is slightly complicated by the fact that on
32-bit Tegra, the SoC device is used as the parent for all devices that
are instantiated from device tree.
Rename the ->enter_freeze cpuidle driver callback to ->enter_s2idle
to make it clear that it is used for entering suspend-to-idle and
rename the related functions, variables and so on accordingly.
This automatically selects options for zone DMA and 64 bit DMA addresses
when LPAE is enabled on ARM Tegra platforms. These options are required
for proper operation with LPAE enabled.
The ZONE_DMA option is required to ensure that drivers that allocate DMA
memory get buffers from the first 4 GiB. This is necessary because a lot
of the controllers only support addressing 32 bits.
As for ARCH_DMA_ADDR_T_64BIT, there are situations where devices that do
support addresses of more than 32 bits (such as the display controller
or the GPU) can run without translating addresses through an IOMMU on a
device with more than 4 GiB of system memory.
Note that both of these options are stop-gap solutions required only
until the IOMMU can be properly integrated with the DMA mapping API and
drivers use that properly and consistently.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
[treding@nvidia.com: specify rationale for options]
The flowctrl driver is required for both ARM and ARM64 Tegra devices
and in order to enable support for it for ARM64, move the Tegra flowctrl
driver into drivers/soc/tegra.
By moving the flowctrl driver, tegra_flowctrl_init() is now called by
via an early initcall and to prevent this function from attempting to
mapping IO space for a non-Tegra device, a test for 'soc_is_tegra()'
is also added.
Signed-off-by: Jon Hunter <jonathanh@nvidia.com>
The Tegra flowctrl.h header is included unnecessarily by the Tegra
sleep.S source file. Remove this unnecessary inclusion.
Pull ARM updates from Russell King:
- nommu updates from Afzal Mohammed cleaning up the vectors support
- allow DMA memory "mapping" for nommu Benjamin Gaignard
- fixing a correctness issue with R_ARM_PREL31 relocations in the
module linker
- add strlen() prototype for the decompressor
- support for DEBUG_VIRTUAL from Florian Fainelli
- adjusting memory bounds after memory reservations have been
registered
- unipher cache handling updates from Masahiro Yamada
- initrd and Thumb Kconfig cleanups
* 'for-linus' of git://git.armlinux.org.uk/~rmk/linux-arm: (23 commits)
ARM: mm: round the initrd reservation to page boundaries
ARM: mm: clean up initrd initialisation
ARM: mm: move initrd init code out of arm_memblock_init()
ARM: 8655/1: improve NOMMU definition of pgprot_*()
ARM: 8654/1: decompressor: add strlen prototype
ARM: 8652/1: cache-uniphier: clean up active way setup code
ARM: 8651/1: cache-uniphier: include <linux/errno.h> instead of <linux/types.h>
ARM: 8650/1: module: handle negative R_ARM_PREL31 addends correctly
ARM: 8649/2: nommu: remove Hivecs configuration is asm
ARM: 8648/2: nommu: display vectors base
ARM: 8647/2: nommu: dynamic exception base address setting
ARM: 8646/1: mmu: decouple VECTORS_BASE from Kconfig
ARM: 8644/1: Reduce "CPU: shutdown" message to debug level
ARM: 8641/1: treewide: Replace uses of virt_to_phys with __pa_symbol
ARM: 8640/1: Add support for CONFIG_DEBUG_VIRTUAL
ARM: 8639/1: Define KERNEL_START and KERNEL_END
ARM: 8638/1: mtd: lart: Rename partition defines to be prefixed with PART_
ARM: 8637/1: Adjust memory boundaries after reservations
ARM: 8636/1: Cleanup sanity_check_meminfo
ARM: add CPU_THUMB_CAPABLE to indicate possible Thumb support
All low-level PM/SMP code using virt_to_phys() should actually use
__pa_symbol() against kernel symbols. Update code where relevant to move
away from virt_to_phys().
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
Reviewed-by: Laura Abbott <labbott@redhat.com>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Placement of attributes, such as __initdata, is standardized through the
checkpatch script. Fix up this instance to make checkpatch happy.
Pull ARM SoC cleanups from Olof Johansson:
"The cleanup branch keeps going down in size as we've completed a lot
of the major legacy platform removals and conversions.
A handful of changes this time around, some of the themes or larger
sets are:
- A bunch of i.MX cleanups around platform detection, init call cleanups
- Misc fixes of missing/implicit includes
- Removal of ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIB"
* tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (40 commits)
ARM: mps2: fix typo
ARM: s3c64xx: avoid warning about 'struct device_node'
bus: mvebu-mbus: make mvebu_mbus_syscore_ops static
bus: mvebu-mbus: fix __iomem on register pointers
ARM: tegra: Remove board_init_funcs array
ARM: iop: Fix indentation
ARM: imx: remove cpu_is_mx*()
ARM: imx: remove last call to cpu_is_mx5*
ARM: imx: rework mx27_pm_init() call
ARM: imx: deconstruct mx3_idle
ARM: imx: deconstruct mxc_rnga initialization
ARM: imx: remove cpu_is_mx1 check
ARM: i.MX: Do not explicitly call l2x0_of_init()
ARM: i.MX: system.c: Tweak prefetch settings for performance
ARM: i.MX: system.c: Replace magic numbers
ARM: i.MX: system.c: Remove redundant errata 752271 code
ARM: i.MX: system.c: Convert goto to if statement
ARM: Kirkwood: fix kirkwood_pm_init() declaration/type
ARM: Kirkwood: make kirkwood_disable_mbus_error_propagation() static
ARM: orion5x: make orion5x_legacy_handle_irq static
git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux into next/cleanup
Merge "ARM: tegra: Core SoC changes for v4.8-rc1" into next/cleanup:
Some cleanups to eliminate sparse warnings and a section mismatch.
* tag 'tegra-for-4.8-arm-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux:
ARM: tegra: pm: Add tegra_cpu_do_idle() prototype
ARM: tegra: irq: Add missing irq.h include
ARM: tegra: cpuidle: Add missing cpuidle.h include
ARM: tegra: hotplug: Include missing common.h
In a configuration that enables CONFIG_UBSAN_SANITIZE_ALL, I am getting
a section mismatch warning for tegra20:
WARNING: arch/arm/mach-tegra/built-in.o(.data+0x6e0): Section mismatch in reference from the variable board_init_funcs to the function .init.text:paz00_init()
The array is no longer useful here since there is only one entry,
so we can simply call the function directly after checking
of_machine_is_compatible(). This fixes the section mismatch
and is easier to read.
Use helper of_platform_default_populate() in linux/of_platform
when possible, instead of calling of_platform_populate() with
the default match table.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Krzysztof Halasa <khalasa@piap.pl>
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Shawn Guo <shawnguo@kernel.org>
Cc: Roland Stigge <stigge@antcom.de>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Ray Jui <rjui@broadcom.com>
Cc: Viresh Kumar <vireshk@kernel.org>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Rob Herring <robh@kernel.org>
Cc: Michal Simek <michal.simek@xilinx.com>
Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com>
Signed-off-by: Rob Herring <robh@kernel.org>
When building with W=1 this function is flagged as not having a
prototype defined. Add the prototype to avoid a build warning.
Some of the functions implemented are flagged as not having a prototype
defined when building with W=1. Include the header to avoid these build
warnings.
warnings and add a prototype as well as a dummy implementation for the
tegra_cpuidle_pcie_irqs_in_use() function.
warnings.
This replaces:
- "select ARCH_REQUIRE_GPIOLIB" with "select GPIOLIB" as this can
now be selected directly.
- "select ARCH_WANT_OPTIONAL_GPIOLIB" with no dependency: GPIOLIB
is now selectable by everyone, so we need not declare our
intent to select it.
When ordering the symbols the following rationale was used:
if the selects were in alphabetical order, I moved select GPIOLIB
to be in alphabetical order, but if the selects were not
maintained in alphabetical order, I just replaced
"select ARCH_REQUIRE_GPIOLIB" with "select GPIOLIB".
Cc: Michael Büsch <m@bues.ch>
Cc: arm@kernel.org
Pull ARM SoC driver updates from Arnd Bergmann:
"Driver updates for ARM SoCs, these contain various things that touch
the drivers/ directory but got merged through arm-soc for practical
reasons.
For the most part, this is now related to power management
controllers, which have not yet been abstracted into a separate
subsystem, and typically require some code in drivers/soc or arch/arm
to control the power domains.
Another large chunk here is a rework of the NVIDIA Tegra USB3.0
support, which was surprisingly tricky and took a long time to get
done.
Finally, reset controller handling as always gets merged through here
as well"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (97 commits)
arm-ccn: Enable building as module
soc/tegra: pmc: Add generic PM domain support
usb: xhci: tegra: Add Tegra210 support
usb: xhci: Add NVIDIA Tegra XUSB controller driver
dt-bindings: usb: xhci-tegra: Add Tegra210 XUSB controller support
dt-bindings: usb: Add NVIDIA Tegra XUSB controller binding
PCI: tegra: Support per-lane PHYs
dt-bindings: pci: tegra: Update for per-lane PHYs
phy: tegra: Add Tegra210 support
phy: Add Tegra XUSB pad controller support
dt-bindings: phy: tegra-xusb-padctl: Add Tegra210 support
dt-bindings: phy: Add NVIDIA Tegra XUSB pad controller binding
phy: core: Allow children node to be overridden
clk: tegra: Add interface to enable hardware control of SATA/XUSB PLLs
drivers: firmware: psci: make two helper functions inline
soc: renesas: rcar-sysc: Add support for R-Car H3 power areas
soc: renesas: rcar-sysc: Add support for R-Car E2 power areas
soc: renesas: rcar-sysc: Add support for R-Car M2-N power areas
soc: renesas: rcar-sysc: Add support for R-Car M2-W power areas
soc: renesas: rcar-sysc: Add support for R-Car H2 power areas
Since device_add_property_set() now always takes a copy of
the property_set, and also since the fwnode type is always
hard coded to be FWNODE_PDATA, there is no need for the
drivers to deliver the entire struct property_set. The
function can just create the instance of it on its own and
bind the properties from the drivers to it on the spot.
This renames device_add_property_set() to
device_add_properties(). The function now takes struct
property_entry as its parameter instead of struct
property_set.
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Acked-by: Thierry Reding <treding@nvidia.com>
Acked-by: Lee Jones <lee.jones@linaro.org>
Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com>
Currently, the function tegra_powergate_set() simply sets the desired
powergate state but does not wait for the state to change. In most cases
we should wait for the state to change before proceeding. Currently,
there is a case for Tegra114 and Tegra124 devices where we do not wait
when starting the secondary CPU as this is not necessary. However, this
is only done at boot time and so waiting here will only have a small
impact on boot time. Therefore, update tegra_powergate_set() to wait
when setting the powergate.
By adding this feature, we can also eliminate the polling loop from
tegra30_boot_secondary().
A function has been added for checking the status of the powergate and
so update the tegra_powergate_is_powered() to use this macro as well.
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next
Johannes Berg says:
Here's another round of updates for -next:
* big A-MSDU RX performance improvement (avoid linearize of paged RX)
* rfkill changes: cleanups, documentation, platform properties
* basic PBSS support in cfg80211
* MU-MIMO action frame processing support
* BlockAck reordering & duplicate detection offload support
* various cleanups & little fixes
Pass the rfkill name and type to the device with properties
instead of driver specific platform data.
CC: Alexandre Courbot <gnurou@gmail.com>
CC: Thierry Reding <thierry.reding@gmail.com>
CC: Stephen Warren <swarren@wwwdotorg.org>
Tested-by: Marc Dietrich <marvin24@gmx.de>
git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux into late/tegra
ARM: tegra: Core SoC changes for v4.5-rc1
The big thing here is Tegra210 support, which is really only the Kconfig
symbol. Other than that there's a few miscellaneous fixes.
* tag 'tegra-for-4.5-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux:
ARM: tegra: select USB_ULPI from EHCI rather than platform
ARM: tegra: Ensure entire dcache is flushed on entering LP0/1
amba: Hide TEGRA_AHB symbol
soc/tegra: Add Tegra210 support
soc/tegra: Provide per-SoC Kconfig symbols
Many ARM sub-architectures use prompts followed by "if" conditional,
but it is wrong.
Please notice the difference between
config ARCH_FOO
bool "Foo SoCs" if ARCH_MULTI_V7
and
config ARCH_FOO
bool "Foo SoCs"
depends on ARCH_MULTI_V7
These two are *not* equivalent!
In the former statement, it is not ARCH_FOO, but its prompt that
depends on ARCH_MULTI_V7. So, it is completely valid that ARCH_FOO
is selected by another, but ARCH_MULTI_V7 is still disabled. As it is
not unmet dependency, Kconfig never warns. This is probably not what
you want.
The former should be used only when you need to do so, and you really
understand what you are doing. (In most cases, it should be wrong!)
For enabling/disabling sub-architectures, the latter is always correct.
As a good side effect, this commit fixes some entries over 80 columns
(mach-imx, mach-integrator, mach-mbevu).
[Arnd: I note that there is not really a bug here, according to
the discussion that followed, but I can see value in being consistent
and in making the lines shorter]
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Acked-by: Patrice Chotard <patrice.chotard@st.com>
Acked-by: Liviu Dudau <Liviu.Dudau@arm.com>
Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Jun Nie <jun.nie@linaro.org>
Acked-by: Matthias Brugger <matthias.bgg@gmail.com>
Acked-by: Simon Horman <horms+renesas@verge.net.au>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Krzysztof Halasa <khc@piap.pl>
Acked-by: Maxime Coquelin <maxime.coquelin@st.com>
These smp_operations structures are not over-written, so add "const"
qualifier and replace __initdata with __initconst.
Also, add "static" where it is possible.
Acked-by: Moritz Fischer <moritz.fischer@ettus.com>
Acked-by: Stephen Boyd <sboyd@codeaurora.org> # qcom part
Acked-by: Wei Xu <xuwei5@hisilicon.com>
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
Acked-by: Nicolas Pitre <nico@linaro.org>
For historic reasons, the tegra platform selects USB_ULPI from architecture
code, but that hasn't really made sense for a long time, as the only
user of that code is the Tegra EHCI driver that has its own Kconfig
symbol.
This removes the 'select' statements from mach-tegra and drivers/soc/tegra
and adds them with the device driver that actually needs them.
Tegra support several low-power (LPx) states, which are:
- LP0: CPU + Core voltage off and DRAM in self-refresh
- LP1: CPU voltage off and DRAM in self-refresh
- LP2: CPU voltage off
When entering any of the above states the tegra_disable_clean_inv_dcache()
function is called to flush the dcache. The function
tegra_disable_clean_inv_dcache() will either flush the entire data cache or
up to the Level of Unification Inner Shareable (LoUIS) depending on the
value in r0. When tegra_disable_clean_inv_dcache() is called by
tegra20_sleep_core_finish() or tegra30_sleep_core_finish(), to enter LP0
and LP1 power state, the r0 register contains a physical memory address
which will not be equal to TEGRA_FLUSH_CACHE_ALL (1) and so the data cache
will be only flushed to the LoUIS. However, when
tegra_disable_clean_inv_dcache() called by tegra_sleep_cpu_finish() to
enter to LP2 power state, r0 is set to TEGRA_FLUSH_CACHE_ALL to flush the
entire dcache.
Please note that tegra20_sleep_core_finish(), tegra30_sleep_core_finish()
and tegra_sleep_cpu_finish() are called by the boot CPU once all other CPUs
have been disabled and so it seems appropriate to flush the entire cache at
this stage.
Therefore, ensure that r0 is set to TEGRA_FLUSH_CACHE_ALL when calling
tegra_disable_clean_inv_dcache() from tegra20_sleep_core_finish() and
tegra30_sleep_core_finish().
Reviewed-by: Joseph Lo <josephl@nvidia.com>
Move per-SoC generation Kconfig symbols to drivers/soc/tegra/Kconfig to
gather them all in a single place. This directory is a natural location
for these options since it already contains the drivers that are shared
across 32-bit and 64-bit ARM architectures.
Pull ARM SoC platform updates from Olof Johansson:
"New and/or improved SoC support for this release:
Marvell Berlin:
- Enable standard DT-based cpufreq
- Add CPU hotplug support
Freescale:
- Ethernet init for i.MX7D
- Suspend/resume support for i.MX6UL
Allwinner:
- Support for R8 chipset (used on NTC's $9 C.H.I.P board)
Mediatek:
- SMP support for some platforms
Uniphier:
- L2 support
- Cleaned up SMP support, etc.
plus a handful of other patches around above functionality, and a few
other smaller changes"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (42 commits)
ARM: uniphier: rework SMP operations to use trampoline code
ARM: uniphier: add outer cache support
Documentation: EXYNOS: Update bootloader interface on exynos542x
ARM: mvebu: add broken-idle option
ARM: orion5x: use mac_pton() helper
ARM: at91: pm: at91_pm_suspend_in_sram() must be 8-byte aligned
ARM: sunxi: Add R8 support
ARM: digicolor: select pinctrl/gpio driver
arm: berlin: add CPU hotplug support
arm: berlin: use non-self-cleared reset register to reset cpu
ARM: mediatek: add smp bringup code
ARM: mediatek: enable gpt6 on boot up to make arch timer working
soc: mediatek: Fix random hang up issue while kernel init
soc: ti: qmss: make acc queue support optional in the driver
soc: ti: add firmware file name as part of the driver
Documentation: dt: soc: Add description for knav qmss driver
ARM: S3C64XX: Use PWM lookup table for mach-smartq
ARM: S3C64XX: Use PWM lookup table for mach-hmt
ARM: S3C64XX: Use PWM lookup table for mach-crag6410
ARM: S3C64XX: Use PWM lookup table for smdk6410
Now that __cpuinit has been removed, the __ref markings on these
functions are useless. Remove them. This also reduces the size of
the multi_v7_defconfig image:
$ size before after
12683578 1470996 348904 14503478 dd4e36 before
12683274 1470996 348904 14503174 dd4d06 after
presumably because now we don't have to jump to code in the
.ref.text section and/or the noinline marking is removed.
Cc: Shiraz Hashim <shiraz.linux.kernel@gmail.com>
Cc: Alexandre Courbot <gnurou@gmail.com>
Cc: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Cc: <linux-omap@vger.kernel.org>
Cc: <linux-arm-msm@vger.kernel.org>
Cc: <spear-devel@list.st.com>
Cc: <linux-tegra@vger.kernel.org>
Acked-by: Barry Song <baohua@kernel.org>
Acked-by: Andy Gross <agross@codeaurora.org>
Acked-by: Viresh Kumar <vireshk@kernel.org>
Acked-by: Thierry Reding <thierry.reding@gmail.com>
Acked-by: Sudeep Holla <sudeep.holla@arm.com>
Acked-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Commit 72daceb9a10a ("net: rfkill: gpio: Add default GPIO driver mappings
for ACPI") removed possibility to request GPIO by table index for non-ACPI
platforms without changing its users. As result "shutdown" GPIO request
will fail if request for "reset" GPIO succeeded or "reset" will be
requested instead of "shutdown" if "reset" wasn't defined. Fix it by
making gpiod_lookup_table use con_id's instead of indexes.
Fixes: 72daceb (net: rfkill: gpio: Add default GPIO driver mappings for ACPI)
Cc: <stable@vger.kernel.org> # v3.19+
Acked-by: Alexandre Courbot <acourbot@nvidia.com>
Reviewed-by: Marc Dietrich <marvin24@gmx.de>
"Some releases this branch is nearly empty, others we have more stuff.
It tends to gather drivers that need SoC modification or dependencies
such that they have to (also) go in through our tree.
For this release, we have merged in part of the reset controller tree
(with handshake that the parts we have merged in will remain stable),
as well as dependencies on a few clock branches.
In general, new items here are:
- Qualcomm driver for SMM/SMD, which is how they communicate with the
coprocessors on (some) of their platforms
- memory controller work for ARM's PL172 memory controller
- reset drivers for various platforms
- PMU power domain support for Marvell platforms
- Tegra support for T132/T210 SoCs: PMC, fuse, memory controller
per-SoC support"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (49 commits)
ARM: tegra: cpuidle: implement cpuidle_state.enter_freeze()
ARM: tegra: Disable cpuidle if PSCI is available
soc/tegra: pmc: Use existing pclk reference
soc/tegra: pmc: Remove unnecessary return statement
soc: tegra: Remove redundant $(CONFIG_ARCH_TEGRA) in Makefile
memory: tegra: Add Tegra210 support
memory: tegra: Add support for a variable-size client ID bitfield
clk: shmobile: rz: Add CPG/MSTP Clock Domain support
clk: shmobile: rcar-gen2: Add CPG/MSTP Clock Domain support
clk: shmobile: r8a7779: Add CPG/MSTP Clock Domain support
clk: shmobile: r8a7778: Add CPG/MSTP Clock Domain support
clk: shmobile: Add CPG/MSTP Clock Domain support
ARM: dove: create a proper PMU driver for power domains, PMU IRQs and resets
reset: reset-zynq: Adding support for Xilinx Zynq reset controller.
docs: dts: Added documentation for Xilinx Zynq Reset Controller bindings.
MIPS: ath79: Add the reset controller to the AR9132 dtsi
reset: Add a driver for the reset controller on the AR71XX/AR9XXX
devicetree: Add bindings for the ATH79 reset controller
reset: socfpga: Update reset-socfpga to read the altr,modrst-offset property
doc: dt: add documentation for lpc1850-rgu reset driver
This callback is expected to do the same as enter() but it has to
guarantee that interrupts aren't enabled at any point in its execution,
as the tick is frozen.
It will be called when the system goes to suspend-to-idle and will
reduce power usage because CPUs won't be awaken for unnecessary IRQs.
By setting the CPUIDLE_FLAG_TIMER_STOP flag, we can reuse the same code
for both the enter() and enter_freeze() callbacks.
Signed-off-by: Tomeu Vizoso <tomeu.vizoso@collabora.com>
Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
This is only relevant on Tegra114 and Tegra124, because earlier Tegra
generations used Cortex-A9 without secure extensions.
Unifying the drivers makes it easier to restrict the legacy probing
paths to 32-bit ARM. This in turn will come in handy as support for
new 64-bit ARM SoCs is added.
Tegra CVB tables encode the relationship between operating voltage
and optimal frequency as a function of the so-called speedo value.
The speedo value is written to the on-chip fuses at the factory,
which allows the voltage-frequency operating points to be calculated
on an per-chip basis.
Add utility functions to parse the Tegra-specific tables and export the
voltage-frequency pairs to the generic OPP framework for other drivers
to use.
Signed-off-by: Tuomas Tynkkynen <ttynkkynen@nvidia.com>
Signed-off-by: Mikko Perttunen <mikko.perttunen@kapsi.fi>
Acked-by: Michael Turquette <mturquette@linaro.org>
Pull ARM SoC platform support updates from Kevin Hilman:
"Our SoC branch usually contains expanded support for new SoCs and
other core platform code. Some highlights from this round:
- sunxi: SMP support for A23 SoC
- socpga: big-endian support
- pxa: conversion to common clock framework
- bcm: SMP support for BCM63138
- imx: support new I.MX7D SoC
- zte: basic support for ZX296702 SoC"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (134 commits)
ARM: zx: Add basic defconfig support for ZX296702
ARM: dts: zx: add an initial zx296702 dts and doc
clk: zx: add clock support to zx296702
dt-bindings: Add #defines for ZTE ZX296702 clocks
ARM: socfpga: fix build error due to secondary_startup
MAINTAINERS: ARM64: EXYNOS: Extend entry for ARM64 DTS
ARM: ep93xx: simone: support for SPI-based MMC/SD cards
MAINTAINERS: update Shawn's email to use kernel.org one
ARM: socfpga: support suspend to ram
ARM: socfpga: add CPU_METHOD_OF_DECLARE for Arria 10
ARM: socfpga: use CPU_METHOD_OF_DECLARE for socfpga_cyclone5
ARM: EXYNOS: register power domain driver from core_initcall
ARM: EXYNOS: use PS_HOLD based poweroff for all supported SoCs
ARM: SAMSUNG: Constify platform_device_id
ARM: EXYNOS: Constify irq_domain_ops
ARM: EXYNOS: add coupled cpuidle support for Exynos3250
ARM: EXYNOS: add exynos_get_boot_addr() helper
ARM: EXYNOS: add exynos_set_boot_addr() helper
ARM: EXYNOS: make exynos_core_restart() less verbose
ARM: EXYNOS: fix exynos_boot_secondary() return value on timeout
http://ftp.arm.linux.org.uk/pub/armlinux/kernel/git-cur/linux-2.6-arm into next/cleanup
* 'for-arm-soc' of http://ftp.arm.linux.org.uk/pub/armlinux/kernel/git-cur/linux-2.6-arm:
ARM: fix EFM32 build breakage caused by cpu_resume_arm
ARM: 8389/1: Add cpu_resume_arm() for firmwares that resume in ARM state
ARM: v7 setup function should invalidate L1 cache
All ARMv5 and older CPUs invalidate their caches in the early assembly
setup function, prior to enabling the MMU. This is because the L1
cache should not contain any data relevant to the execution of the
kernel at this point; all data should have been flushed out to memory.
This requirement should also be true for ARMv6 and ARMv7 CPUs - indeed,
these typically do not search their caches when caching is disabled (as
it needs to be when the MMU is disabled) so this change should be safe.
ARMv7 allows there to be CPUs which search their caches while caching is
disabled, and it's permitted that the cache is uninitialised at boot;
for these, the architecture reference manual requires that an
implementation specific code sequence is used immediately after reset
to ensure that the cache is placed into a sane state. Such
functionality is definitely outside the remit of the Linux kernel, and
must be done by the SoC's firmware before _any_ CPU gets to the Linux
kernel.
Changing the data cache clean+invalidate to a mere invalidate allows us
to get rid of a lot of platform specific hacks around this issue for
their secondary CPU bringup paths - some of which were buggy.
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
Tested-by: Florian Fainelli <f.fainelli@gmail.com>
Tested-by: Heiko Stuebner <heiko@sntech.de>
Tested-by: Dinh Nguyen <dinguyen@opensource.altera.com>
Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Tested-by: Thierry Reding <treding@nvidia.com>
Tested-by: Geert Uytterhoeven <geert+renesas@glider.be>
Tested-by: Michal Simek <michal.simek@xilinx.com>
Tested-by: Wei Xu <xuwei5@hisilicon.com>
The pmc driver was previously exporting tegra_pmc_restart, which was
assigned to machine_desc.init_machine, taking precedence over the
restart handlers registered through register_restart_handler().
Signed-off-by: David Riley <davidriley@chromium.org>
[tomeu.vizoso@collabora.com: Rebased]
Reviewed-by: Alexandre Courbot <acourbot@nvidia.com>
[treding@nvidia.com: minor cleanups]
Easy typo to make when you're working in this area of the code.
Commit 7232398abc6a ("ARM: tegra: Convert PMC to a driver") changed tegra_resume()
location storing from late to early and, as a result, broke suspend on Tegra20.
PMC scratch register 41 is used by tegra LP1 resume code for retrieving stored
physical memory address of common resume function and in the same time used by
tegra20_cpu_shutdown() (shared by Tegra20 cpuidle driver and platform SMP code),
which is storing CPU1 "resettable" status. It implies strict order of scratch
register usage, otherwise resume function address is lost on Tegra20 after
disabling non-boot CPU's on suspend. Fix it by storing "resettable" status in
IRAM instead of PMC scratch register.
Fixes: 7232398abc6a (ARM: tegra: Convert PMC to a driver)
Cc: <stable@vger.kernel.org> # v3.17+
Pull power management and ACPI updates from Rafael Wysocki:
"These are mostly fixes and cleanups all over, although there are a few
items that sort of fall into the new feature category.
First off, we have new callbacks for PM domains that should help us to
handle some issues related to device initialization in a better way.
There also is some consolidation in the unified device properties API
area allowing us to use that inferface for accessing data coming from
platform initialization code in addition to firmware-provided data.
We have some new device/CPU IDs in a few drivers, support for new
chips and a new cpufreq driver too.
Specifics:
- Generic PM domains support update including new PM domain callbacks
to handle device initialization better (Russell King, Rafael J
Wysocki, Kevin Hilman)
- Unified device properties API update including a new mechanism for
accessing data provided by platform initialization code (Rafael J
Wysocki, Adrian Hunter)
- ARM cpuidle update including ARM32/ARM64 handling consolidation
(Daniel Lezcano)
- intel_idle update including support for the Silvermont Core in the
Baytrail SOC and for the Airmont Core in the Cherrytrail and
Braswell SOCs (Len Brown, Mathias Krause)
- New cpufreq driver for Hisilicon ACPU (Leo Yan)
- intel_pstate update including support for the Knights Landing chip
(Dasaratharaman Chandramouli, Kristen Carlson Accardi)
- QorIQ cpufreq driver update (Tang Yuantian, Arnd Bergmann)
- powernv cpufreq driver update (Shilpasri G Bhat)
- devfreq update including Tegra support changes (Tomeu Vizoso,
MyungJoo Ham, Chanwoo Choi)
- powercap RAPL (Running-Average Power Limit) driver update including
support for Intel Broadwell server chips (Jacob Pan, Mathias Krause)
- ACPI device enumeration update related to the handling of the
special PRP0001 device ID allowing DT-style 'compatible' property
to be used for ACPI device identification (Rafael J Wysocki)
- ACPI EC driver update including limited _DEP support (Lan Tianyu,
Lv Zheng)
- ACPI backlight driver update including a new mechanism to allow
native backlight handling to be forced on non-Windows 8 systems and
a new quirk for Lenovo Ideapad Z570 (Aaron Lu, Hans de Goede)
- New Windows Vista compatibility quirk for Sony VGN-SR19XN (Chen Yu)
- Assorted ACPI fixes and cleanups (Aaron Lu, Martin Kepplinger,
Masanari Iida, Mika Westerberg, Nan Li, Rafael J Wysocki)
- Fixes related to suspend-to-idle for the iTCO watchdog driver and
the ACPI core system suspend/resume code (Rafael J Wysocki, Chen Yu)
- PM tracing support for the suspend phase of system suspend/resume
transitions (Zhonghui Fu)
- Configurable delay for the system suspend/resume testing facility
(Brian Norris)
- PNP subsystem cleanups (Peter Huewe, Rafael J Wysocki)"
* tag 'pm+acpi-4.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (74 commits)
ACPI / scan: Fix NULL pointer dereference in acpi_companion_match()
ACPI / scan: Rework modalias creation when "compatible" is present
intel_idle: mark cpu id array as __initconst
powercap / RAPL: mark rapl_ids array as __initconst
powercap / RAPL: add ID for Broadwell server
intel_pstate: Knights Landing support
intel_pstate: remove MSR test
cpufreq: fix qoriq uniprocessor build
ACPI / scan: Take the PRP0001 position in the list of IDs into account
ACPI / scan: Simplify acpi_match_device()
ACPI / scan: Generalize of_compatible matching
device property: Introduce firmware node type for platform data
device property: Make it possible to use secondary firmware nodes
PM / watchdog: iTCO: stop watchdog during system suspend
cpufreq: hisilicon: add acpu driver
ACPI / EC: Call acpi_walk_dep_device_list() after installing EC opregion handler
cpufreq: powernv: Report cpu frequency throttling
intel_idle: Add support for the Airmont Core in the Cherrytrail and Braswell SOCs
intel_idle: Update support for Silvermont Core in Baytrail SOC
PM / devfreq: tegra: Register governor on module init
Pull irq core updates from Thomas Gleixner:
"Managerial summary:
Core code:
- final removal of IRQF_DISABLED
- new state save/restore functions for virtualization support
- wakeup support for stacked irqdomains
- new function to solve the netpoll synchronization problem
irqchips:
- new driver for STi based devices
- new driver for Vybrid MSCM
- massive cleanup of the GIC driver by moving the GIC-addons to
stacked irqdomains
- the usual pile of fixes and updates to the various chip drivers"
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (44 commits)
irqchip: GICv3: Add support for irq_[get, set]_irqchip_state()
irqchip: GIC: Add support for irq_[get, set]_irqchip_state()
genirq: Allow the irqchip state of an IRQ to be save/restored
genirq: MSI: Fix freeing of unallocated MSI
irqchip: renesas-irqc: Add wake-up support
irqchip: armada-370-xp: Allow using wakeup source
irqchip: mips-gic: Add new functions to start/stop the GIC counter
irqchip: tegra: Add Tegra210 support
irqchip: digicolor: Move digicolor_set_gc to init section
irqchip: renesas-irqc: Add functional clock to bindings
irqchip: renesas-irqc: Add minimal runtime PM support
irqchip: renesas-irqc: Add more register documentation
DT: exynos: update PMU binding
ARM: exynos4/5: convert pmu wakeup to stacked domains
irqchip: gic: Don't complain in gic_get_cpumask() if UP system
ARM: zynq: switch from gic_arch_extn to gic_set_irqchip_flags
ARM: ux500: switch from gic_arch_extn to gic_set_irqchip_flags
ARM: shmobile: remove use of gic_arch_extn.irq_set_wake
irqchip: gic: Add an entry point to set up irqchip flags
ARM: omap: convert wakeupgen to stacked domains
Replace the clockevents_notify() call with an explicit function call.
Cc: Thierry Reding <thierry.reding@gmail.com>
Link: http://lkml.kernel.org/r/2131111.rjxRLX1eZB@vostro.rjw.lan
The cpu_do_idle() function is always used by the cpuidle drivers.
That led to have each driver including cpuidle.h and proc-fns.h, they are
always paired. That makes a lot of duplicate headers inclusion. Instead of
including both in each .c file, move the proc-fns.h header inclusion in the
cpuidle.h header file directly, so we can save some line of code.
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Acked-by: Kevin Hilman <khilman@linaro.org>
Acked-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Tested-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
