path: root/arch/arm/mach-tegra
2014-08-08Merge tag 'gpio-v3.17-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO update from Linus Walleij: "This is the bulk of GPIO changes for the v3.17 development cycle, and this time we got a lot of action going on and it will continue: - The core GPIO library implementation has been split up in three different files: - gpiolib.c for the latest and greatest and shiny GPIO library code using GPIO descriptors only - gpiolib-legacy.c for the old integer number space API that we are phasing out gradually - gpiolib-sysfs.c for the sysfs interface that we are not entirely happy with, but has to live on for ABI compatibility - Add a flags argument to *gpiod_get* functions, with some backward-compatibility macros to ease transitions. We should have had the flags there from the beginning it seems, now we need to clean up the mess. There is a plan on how to move forward here devised by Alexandre Courbot and Mark Brown - Split off a special <linux/gpio/machine.h> header for the board gpio table registration, as per example from the regulator subsystem - Start to kill off the return value from gpiochip_remove() by removing the __must_check attribute and removing all checks inside the drivers/gpio directory. The rationale is: well what were we supposed to do if there is an error code? Not much: print an error message. And gpiolib already does that. So make this function return void eventually - Some cleanups of hairy gpiolib code, make some functions not to be used outside the library private and make sure they are not exported, remove gpiod_lock/unlock_as_irq() as the existing function is for driver-internal use and fine as it is, delete gpio_ensure_requested() as it is not meaningful anymore - Support the GPIOF_ACTIVE_LOW flag from gpio_request_one() function calls, which is logical since this is already supported when referencing GPIOs from e.g. device trees - Switch STMPE, intel-mid, lynxpoint and ACPI (!) to use the gpiolib irqchip helpers cutting down on GPIO irqchip boilerplate a bit more - New driver for the Zynq GPIO block - The usual incremental improvements around a bunch of drivers - Janitorial syntactic and semantic cleanups by Jingoo Han, and Rickard Strandqvist especially" * tag 'gpio-v3.17-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (37 commits) MAINTAINERS: update GPIO include files gpio: add missing includes in machine.h gpio: add flags argument to gpiod_get*() functions MAINTAINERS: Update Samsung pin control entry gpio / ACPI: Move event handling registration to gpiolib irqchip helpers gpio: lynxpoint: Convert to use gpiolib irqchip gpio: split gpiod board registration into machine header gpio: remove gpio_ensure_requested() gpio: remove useless check in gpiolib_sysfs_init() gpiolib: Export gpiochip_request_own_desc and gpiochip_free_own_desc gpio: move gpio_ensure_requested() into legacy C file gpio: remove gpiod_lock/unlock_as_irq() gpio: make gpiochip_get_desc() gpiolib-private gpio: simplify gpiochip_export() gpio: remove export of private of_get_named_gpio_flags() gpio: Add support for GPIOF_ACTIVE_LOW to gpio_request_one functions gpio: zynq: Clear pending interrupt when enabling a IRQ gpio: drop retval check enforcing from gpiochip_remove() gpio: remove all usage of gpio_remove retval in driver/gpio devicetree: Add Zynq GPIO devicetree bindings documentation ...
2014-08-08Merge tag 'cleanup-for-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Olof Johansson: "This merge window brings a good size of cleanups on various platforms. Among the bigger ones: - Removal of Samsung s5pc100 and s5p64xx platforms. Both of these have lacked active support for quite a while, and after asking around nobody showed interest in keeping them around. If needed, they could be resurrected in the future but it's more likely that we would prefer reintroduction of them as DT and multiplatform-enabled platforms instead. - OMAP4 controller code register define diet. They defined a lot of registers that were never actually used, etc. - Move of some of the Tegra platform code (PMC, APBIO, fuse, powergate) to drivers/soc so it can be shared with 64-bit code. This also converts them over to traditional driver models where possible. - Removal of legacy gpio-samsung driver, since the last users have been removed (moved to pinctrl) Plus a bunch of smaller changes for various platforms that sort of dissapear in the diffstat for the above. clps711x cleanups, shmobile header file refactoring/moves for multiplatform friendliness, some misc cleanups, etc" * tag 'cleanup-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (117 commits) drivers: CCI: Correct use of ! and & video: clcd-versatile: Depend on ARM video: fix up versatile CLCD helper move MAINTAINERS: Add sdhci-st file to ARCH/STI architecture ARM: EXYNOS: Fix build breakge with PM_SLEEP=n MAINTAINERS: Remove Kirkwood ARM: tegra: Convert PMC to a driver soc/tegra: fuse: Set up in early initcall ARM: tegra: Always lock the CPU reset vector ARM: tegra: Setup CPU hotplug in a pure initcall soc/tegra: Implement runtime check for Tegra SoCs soc/tegra: fuse: fix dummy functions soc/tegra: fuse: move APB DMA into Tegra20 fuse driver soc/tegra: Add efuse and apbmisc bindings soc/tegra: Add efuse driver for Tegra ARM: tegra: move fuse exports to soc/tegra/fuse.h ARM: tegra: export apb dma readl/writel ARM: tegra: Use a function to get the chip ID ARM: tegra: Sort includes alphabetically ARM: tegra: Move includes to include/soc/tegra ...
2014-07-28gpio: split gpiod board registration into machine headerLinus Walleij
As per example from the regulator subsystem: put all defines and functions related to registering board info for GPIO descriptors into a separate <linux/gpio/machine.h> header. Cc: Andrew Victor <linux@maxim.org.za> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Thierry Reding <thierry.reding@gmail.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Alexandre Courbot <gnurou@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-07-19Merge tag 'tegra-for-3.17-soc' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux into next/cleanup Merge "ARM: tegra: core code changes for 3.17" from Thierry Reding: Some of the code that's currently called from the Tegra machine setup code is moved to regular initcalls. To catch dependency violations, the various code paths now WARN if they're called to early. Not all of the potential candidates are converted yet, but those that were have been verified to work across all supported Tegra generations. A new function, soc_is_tegra(), is also provided to make sure that the initcalls can abort early if they aren't run on Tegra, which can happen for multi-platform builds. Finally this also moves out the PMC driver to drivers/soc/tegra so that it can be shared with 64-bit ARM. This is based on the for-3.17/fuse-move branch. The split is somewhat arbitrary but allows the dependents of the for-3.17/fuse-move to pull in as little code as necessary. * tag 'tegra-for-3.17-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux: ARM: tegra: Convert PMC to a driver soc/tegra: fuse: Set up in early initcall ARM: tegra: Always lock the CPU reset vector ARM: tegra: Setup CPU hotplug in a pure initcall soc/tegra: Implement runtime check for Tegra SoCs Signed-off-by: Olof Johansson <olof@lixom.net>
2014-07-19Merge tag 'tegra-for-3.17-fuse-move' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux into next/cleanup Merge "ARM: tegra: move fuse code out of arch/arm" from Thierry Reding: This branch moves code related to the Tegra fuses out of arch/arm and into a centralized location which could be shared with ARM64. It also adds support for reading the fuse data through sysfs. Included is also some preparatory work that moves Tegra-related header files from include/linux to include/soc/tegra as suggested by Arnd. Furthermore the Tegra chip ID is now retrieved using a function rather than a variable so that sanity checks can be done. This is convenient in subsequent patches that will move some of the code that's currently called from Tegra machine setup into regular initcalls so that it can be reused on 64-bit ARM. The sanity checks help with verifying that no code tries to obtain the Tegra chip ID before the underlying driver is properly initialized. * tag 'tegra-for-3.17-fuse-move' of git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux: soc/tegra: fuse: fix dummy functions soc/tegra: fuse: move APB DMA into Tegra20 fuse driver soc/tegra: Add efuse and apbmisc bindings soc/tegra: Add efuse driver for Tegra ARM: tegra: move fuse exports to soc/tegra/fuse.h ARM: tegra: export apb dma readl/writel ARM: tegra: Use a function to get the chip ID ARM: tegra: Sort includes alphabetically ARM: tegra: Move includes to include/soc/tegra Signed-off-by: Olof Johansson <olof@lixom.net>
2014-07-18ARM: convert all "mov.* pc, reg" to "bx reg" for ARMv6+Russell King
ARMv6 and greater introduced a new instruction ("bx") which can be used to return from function calls. Recent CPUs perform better when the "bx lr" instruction is used rather than the "mov pc, lr" instruction, and this sequence is strongly recommended to be used by the ARM architecture manual (section A.4.1.1). We provide a new macro "ret" with all its variants for the condition code which will resolve to the appropriate instruction. Rather than doing this piecemeal, and miss some instances, change all the "mov pc" instances to use the new macro, with the exception of the "movs" instruction and the kprobes code. This allows us to detect the "mov pc, lr" case and fix it up - and also gives us the possibility of deploying this for other registers depending on the CPU selection. Reported-by: Will Deacon <will.deacon@arm.com> Tested-by: Stephen Warren <swarren@nvidia.com> # Tegra Jetson TK1 Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> # mioa701_bootresume.S Tested-by: Andrew Lunn <andrew@lunn.ch> # Kirkwood Tested-by: Shawn Guo <shawn.guo@freescale.com> Tested-by: Tony Lindgren <tony@atomide.com> # OMAPs Tested-by: Gregory CLEMENT <gregory.clement@free-electrons.com> # Armada XP, 375, 385 Acked-by: Sekhar Nori <nsekhar@ti.com> # DaVinci Acked-by: Christoffer Dall <christoffer.dall@linaro.org> # kvm/hyp Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> # PXA3xx Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> # Xen Tested-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> # ARMv7M Tested-by: Simon Horman <horms+renesas@verge.net.au> # Shmobile Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-07-17ARM: tegra: Convert PMC to a driverThierry Reding
This commit converts the PMC support code to a platform driver. Because the boot process needs to call into this driver very early, also set up a minimal environment via an early initcall. Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-07-17soc/tegra: fuse: Set up in early initcallThierry Reding
Rather than rely on explicit initialization order called from SoC setup code, use a plain initcall and rely on initcall ordering to take care of dependencies. This driver exposes some functionality (querying the chip ID) needed at very early stages of the boot process. An early initcall is good enough provided that some of the dependencies are deferred to later stages. To make sure any abuses are easily caught, output a warning message if the chip ID is queried while it can't be read yet. Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-07-17ARM: tegra: Always lock the CPU reset vectorThierry Reding
Currently the reset vector is not locked on Tegra20 because the hardware doesn't support it. However in order not to depend on the chip ID, which becomes available only later in the boot process, we set the bit anyway. Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-07-17ARM: tegra: Setup CPU hotplug in a pure initcallThierry Reding
CPU hotplug support doesn't have to be set up until fairly late in the boot process, so it can be done in a regular initcall. To make sure that we don't miss any ordering problems in the future, output a warning if any of the functions are called before initialization has completed. This is part of untangling the boot order dependencies on Tegra so that more code can be shared between 32-bit and 64-bit ARM. Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-07-17soc/tegra: fuse: move APB DMA into Tegra20 fuse driverPeter De Schrijver
The Tegra20 fuse driver is the only user of tegra_apb_readl_using_dma(). Therefore we can simply the code by incorporating the APB DMA handling into the driver directly. tegra_apb_writel_using_dma() is dropped because there are no users. Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-07-17soc/tegra: Add efuse driver for TegraPeter De Schrijver
Implement fuse driver for Tegra20, Tegra30, Tegra114 and Tegra124. This replaces functionality previously provided in arch/arm/mach-tegra, which is removed in this patch. While at it, move the only user of the global tegra_revision variable over to tegra_sku_info.revision and export tegra_fuse_readl() to allow drivers to read calibration fuses. Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-07-17ARM: tegra: move fuse exports to soc/tegra/fuse.hPeter De Schrijver
All fuse related functionality will move to a driver in the following patches. To prepare for this, export all the required functionality in a global header file and move all users of fuse.h to soc/tegra/fuse.h. While we're at it, remove tegra_bct_strapping, as its only user was removed in Commit a7cbe92cef27 ("ARM: tegra: remove tegra EMC scaling driver"). Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-07-17ARM: tegra: export apb dma readl/writelPeter De Schrijver
Export APB DMA readl and writel. These are needed because we can't access the fuses directly on Tegra20 without potentially causing a system hang. Also have the APB DMA readl and writel return an error in case of a read failure instead of just returning zero or ignore write failures. Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-07-17ARM: tegra: Use a function to get the chip IDThierry Reding
Instead of using a simple variable access to get at the Tegra chip ID, use a function so that we can run additional code. This can be used to determine where the chip ID is being accessed without being available. That in turn will be handy for resolving boot sequence dependencies in order to convert more code to regular initcalls rather than a sequence fixed by Tegra SoC setup code. Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-07-17ARM: tegra: Sort includes alphabeticallyThierry Reding
If these aren't sorted alphabetically, then the logical choice is to append new ones, however that creates a lot of potential for conflicts because every change will then add new includes in the same location. Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-07-17ARM: tegra: Move includes to include/soc/tegraThierry Reding
In order to not clutter the include/linux directory with SoC specific headers, move the Tegra-specific headers out into a separate directory. Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-06-19Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Arnd Bergmann: "A first set of bug fixes that didn't make it for the merge window, and two Kconfig cleanups that still make sense at this point. Unfortunately, one of the two cleanups caused an unintended change in the original version, so we had to revert one part of it and do some more testing to ensure the rest is really fine. There was also a last-minute rebase of the patches to remove another bad commit" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: use menuconfig for sub-arch menus ARM: multi_v7_defconfig: re-enable SDHCI drivers ARM: EXYNOS: Fix compilation warning ARM: exynos: move sysram info to exynos.c ARM: dts: Specify the NAND ECC scheme explicitly on Armada 385 DB board ARM: dts: Specify the NAND ECC scheme explicitly on Armada 375 DB board ARM: exynos: cleanup kconfig option display misc: vexpress: fix error handling vexpress_syscfg_regmap_init() ARM: Remove ARCH_HAS_CPUFREQ config option ARM: integrator: fix section mismatch problem ARM: mvebu: DT: fix OpenBlocks AX3-4 RAM size ARM: samsung: make SAMSUNG_DMADEV optional remoteproc: da8xx: don't select CMA on no-MMU bus/arm-cci: add dependency on OF && CPU_V7 ARM: keystone requires ARM_PATCH_PHYS_VIRT ARM: omap2: fix am43xx dependency on l2x0 cache
2014-06-17ARM: use menuconfig for sub-arch menusRob Herring
The System Type menu is getting quite long with platforms and is inconsistent in handling of sub-arch specific options. Tidy up the menu by making platform options a menuconfig entry containing any platform specific config items. [arnd: change OMAP part according to suggestion from Tony Lindgren <tony@atomide.com>] Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-06-17ARM: Remove ARCH_HAS_CPUFREQ config optionStephen Boyd
This config exists entirely to hide the cpufreq menu from the kernel configuration unless a platform has selected it. Nothing is actually built if this config is 'Y' and it just leads to more patches that add a select under a platform Kconfig so that some other CPUfreq option can be chosen. Let's remove the option so that we can always enable CPUfreq drivers on ARM platforms. Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-06-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) Seccomp BPF filters can now be JIT'd, from Alexei Starovoitov. 2) Multiqueue support in xen-netback and xen-netfront, from Andrew J Benniston. 3) Allow tweaking of aggregation settings in cdc_ncm driver, from Bjørn Mork. 4) BPF now has a "random" opcode, from Chema Gonzalez. 5) Add more BPF documentation and improve test framework, from Daniel Borkmann. 6) Support TCP fastopen over ipv6, from Daniel Lee. 7) Add software TSO helper functions and use them to support software TSO in mvneta and mv643xx_eth drivers. From Ezequiel Garcia. 8) Support software TSO in fec driver too, from Nimrod Andy. 9) Add Broadcom SYSTEMPORT driver, from Florian Fainelli. 10) Handle broadcasts more gracefully over macvlan when there are large numbers of interfaces configured, from Herbert Xu. 11) Allow more control over fwmark used for non-socket based responses, from Lorenzo Colitti. 12) Do TCP congestion window limiting based upon measurements, from Neal Cardwell. 13) Support busy polling in SCTP, from Neal Horman. 14) Allow RSS key to be configured via ethtool, from Venkata Duvvuru. 15) Bridge promisc mode handling improvements from Vlad Yasevich. 16) Don't use inetpeer entries to implement ID generation any more, it performs poorly, from Eric Dumazet. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1522 commits) rtnetlink: fix userspace API breakage for iproute2 < v3.9.0 tcp: fixing TLP's FIN recovery net: fec: Add software TSO support net: fec: Add Scatter/gather support net: fec: Increase buffer descriptor entry number net: fec: Factorize feature setting net: fec: Enable IP header hardware checksum net: fec: Factorize the .xmit transmit function bridge: fix compile error when compiling without IPv6 support bridge: fix smatch warning / potential null pointer dereference via-rhine: fix full-duplex with autoneg disable bnx2x: Enlarge the dorq threshold for VFs bnx2x: Check for UNDI in uncommon branch bnx2x: Fix 1G-baseT link bnx2x: Fix link for KR with swapped polarity lane sctp: Fix sk_ack_backlog wrap-around problem net/core: Add VF link state control policy net/fsl: xgmac_mdio is dependent on OF_MDIO net/fsl: Make xgmac_mdio read error message useful net_sched: drr: warn when qdisc is not work conserving ...
2014-06-05Merge branch 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm into nextLinus Torvalds
Pull ARM updates from Russell King: - Major clean-up of the L2 cache support code. The existing mess was becoming rather unmaintainable through all the additions that others have done over time. This turns it into a much nicer structure, and implements a few performance improvements as well. - Clean up some of the CP15 control register tweaks for alignment support, moving some code and data into alignment.c - DMA properties for ARM, from Santosh and reviewed by DT people. This adds DT properties to specify bus translations we can't discover automatically, and to indicate whether devices are coherent. - Hibernation support for ARM - Make ftrace work with read-only text in modules - add suspend support for PJ4B CPUs - rework interrupt masking for undefined instruction handling, which allows us to enable interrupts earlier in the handling of these exceptions. - support for big endian page tables - fix stacktrace support to exclude stacktrace functions from the trace, and add save_stack_trace_regs() implementation so that kprobes can record stack traces. - Add support for the Cortex-A17 CPU. - Remove last vestiges of ARM710 support. - Removal of ARM "meminfo" structure, finally converting us solely to memblock to handle the early memory initialisation. * 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (142 commits) ARM: ensure C page table setup code follows assembly code (part II) ARM: ensure C page table setup code follows assembly code ARM: consolidate last remaining open-coded alignment trap enable ARM: remove global cr_no_alignment ARM: remove CPU_CP15 conditional from alignment.c ARM: remove unused adjust_cr() function ARM: move "noalign" command line option to alignment.c ARM: provide common method to clear bits in CPU control register ARM: 8025/1: Get rid of meminfo ARM: 8060/1: mm: allow sub-architectures to override PCI I/O memory type ARM: 8066/1: correction for ARM patch 8031/2 ARM: 8049/1: ftrace/add save_stack_trace_regs() implementation ARM: 8065/1: remove last use of CONFIG_CPU_ARM710 ARM: 8062/1: Modify ldrt fixup handler to re-execute the userspace instruction ARM: 8047/1: rwsem: use asm-generic rwsem implementation ARM: l2c: trial at enabling some Cortex-A9 optimisations ARM: l2c: add warnings for stuff modifying aux_ctrl register values ARM: l2c: print a warning with L2C-310 caches if the cache size is modified ARM: l2c: remove old .set_debug method ARM: l2c: kill L2X0_AUX_CTRL_MASK before anyone else makes use of this ...
2014-06-02Merge tag 'soc-for-3.16' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc into next Pull part one of ARM SoC updates from Olof Johansson: "A quite large set of SoC updates this cycle. In no particular order: - Multi-cluster power management for Samsung Exynos, adding support for big.LITTLE CPU switching on EXYNOS5 - SMP support for Marvell Armada 375 and 38x - SMP rework on Allwinner A31 - Xilinx Zynq support for SOC_BUS, big endian - Marvell orion5x platform cleanup, modernizing the implementation and moving to DT. - _Finally_ moving Samsung Exynos over to support MULTIPLATFORM, so that their platform can be enabled in the same kernel binary as most of the other v7 platforms in the tree. \o/ The work isn't quite complete, there's some driver fixes still needed, but the basics now work. New SoC support added: - Freescale i.MX6SX - LSI Axxia AXM55xx SoCs - Samsung EXYNOS 3250, 5260, 5410, 5420 and 5800 - STi STIH407 plus a large set of various smaller updates for different platforms. I'm probably missing some important one here" * tag 'soc-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (281 commits) ARM: exynos: don't run exynos4 l2x0 setup on other platforms ARM: exynos: Fix "allmodconfig" build errors in mcpm and hotplug ARM: EXYNOS: mcpm rename the power_down_finish ARM: EXYNOS: Enable mcpm for dual-cluster exynos5800 SoC ARM: EXYNOS: Enable multi-platform build support ARM: EXYNOS: Consolidate Kconfig entries ARM: EXYNOS: Add support for EXYNOS5410 SoC ARM: EXYNOS: Support secondary CPU boot of Exynos3250 ARM: EXYNOS: Add Exynos3250 SoC ID ARM: EXYNOS: Add 5800 SoC support ARM: EXYNOS: initial board support for exynos5260 SoC clk: exynos5410: register clocks using common clock framework ARM: debug: qcom: add UART addresses to Kconfig help for APQ8084 ARM: sunxi: allow building without reset controller Documentation: devicetree: arm: sort enable-method entries ARM: rockchip: convert smp bringup to CPU_METHOD_OF_DECLARE clk: exynos5250: Add missing sysmmu clocks for DISP and ISP blocks ARM: dts: axxia: Add reset controller power: reset: Add Axxia system reset driver ARM: axxia: Adding defconfig for AXM55xx ...
2014-05-30ARM: l2c: tegra: convert to generic l2c OF initialisationRussell King
Remove the explicit call to l2x0_of_init(), converting to the generic infrastructure instead. Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-05-30ARM: l2c: tegra: convert to common l2c310 early resume functionalityRussell King
Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Joseph Lo <josephl@nvidia.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-05-30ARM: l2c: tegra: remove cache size overrideRussell King
The cache size should already be present in the L2 cache auxiliary control register: it is part of the integration process to configure the hardware IP. Most platforms get this right, yet still many cargo-cult program, and assume that they always need specifying to the L2 cache code. Remove them so we can find out which really need this. Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Acked-by: Peter De Schrijver <pdeschrijver@nvidia.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-05-30ARM: l2c: remove platforms/SoCs setting early BRESPRussell King
Since we now automatically enable early BRESP in core L2C-310 code when we detect a Cortex-A9, we don't need platforms/SoCs to set this bit explicitly. Instead, they should seek to preserve the value of bit 30 in the auxiliary control register. Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-05-30ARM: l2c: fix register namingRussell King
We have a mixture of different devices with different register layouts, but we group all the bits together in an opaque mess. Split them out into those which are L2C-310 specific and ones which refer to earlier devices. Provide full auxiliary control register definitions. Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-05-29ARM: kconfig: allow PCI support to be selected with ARCH_MULTIPLATFORMWill Deacon
When targetting ARCH_MULTIPLATFORM, we may include support for SoCs with PCI-capable devices (e.g. mach-virt with virtio-pci). This patch allows PCI support to be selected for these SoCs by selecting CONFIG_MIGHT_HAVE_PCI when CONFIG_ARCH_MULTIPLATFORM=y and removes the individual selections from multi-platform enabled SoCs. Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-05-27Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem
2014-05-21Merge tag 'tegra-for-3.16-soc' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux into next/soc Merge "ARM: tegra: core code changes for 3.16" from Stephen Warren: This branch contains just a single patch this time around. Thierry enhanced Tegra's restart code to allow programming PMC scratch registers to request specific behaviour after reboot. One of the most useful options for mainline software is the ability to reboot directly into USB recovery mode, which e.g. allows the bootloader to be reflashed. * tag 'tegra-for-3.16-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux: ARM: tegra: Support reboot modes Signed-off-by: Olof Johansson <olof@lixom.net>
2014-05-07ARM: tegra: Support reboot modesThierry Reding
The boot ROM on Tegra SoCs supports booting into forced recovery mode (RCM) by setting a bit in the PMC scratch register 0. Similarily, the Android bootloader examines some of the bits in this register to disable autoboot or enter recovery mode. Support these modes by setting the corresponding bits depending on the specified reboot command (forced-recovery, bootloader, recovery). Recent systemd-based distributions allow this to be specified using an optional argument to the reboot command. Signed-off-by: Thierry Reding <treding@nvidia.com> Tested-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-05-06Merge branch 'rfkill-gpio-cleanups' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next
2014-04-24ARM: tegra: remove TEGRA_EMC_SCALING_ENABLEPaul Bolle
Commit a7cbe92cef27 ("ARM: tegra: remove tegra EMC scaling driver") removed the only user of TEGRA_EMC_SCALING_ENABLE. Remove its Kconfig entry too. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-04-11ARM: tegra: remove obsolete gpio entriesHeikki Krogerus
After moving to description based gpio interface in rfkill-gpio, the gpio numbers are not used any more. Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com> Reviewed-by: Marc Dietrich <marvin24@gmx.de> Acked-by: Stephen Warren <swarren@nvidia.com> Acked-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-04-05Merge tag 'soc-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC specific changes from Arnd Bergmann: "Lots of changes specific to one of the SoC families. Some that stick out are: - mach-qcom gains new features, most importantly SMP support for the newer chips (Stephen Boyd, Rohit Vaswani) - mvebu gains support for three new SoCs: Armada 375, 380 and 385 (Thomas Petazzoni and Free-electrons team) - SMP support for Rockchips (Heiko Stübner) - Lots of i.MX changes (Shawn Guo) - Added support for BCM5301x SoC (Hauke Mehrtens) - Multiplatform support for Marvell Kirkwood and Dove (Andrew Lunn and Sebastian Hesselbarth doing the final part of a long journey) - Unify davinci platforms and remove obsolete ones (Sekhar Nori, Arnd Bergmann)" * tag 'soc-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (126 commits) ARM: sunxi: Select HAVE_ARM_ARCH_TIMER ARM: cache-tauros2: remove ARMv6 code ARM: mvebu: don't select CONFIG_NEON ARM: davinci: fix DT booting with default defconfig ARM: configs: bcm_defconfig: enable bcm590xx regulator support ARM: davinci: remove tnetv107x support MAINTAINERS: Update ARM STi maintainers ARM: restrict BCM_KONA_UART to ARCH_BCM_MOBILE ARM: bcm21664: Add board support. ARM: sunxi: Add the new watchog compatibles to the reboot code ARM: enable ARM_HAS_SG_CHAIN for multiplatform ARM: davinci: remove da8xx_omapl_defconfig ARM: davinci: da8xx: fix multiple watchdog device registration ARM: davinci: add da8xx specific configs to davinci_all_defconfig ARM: davinci: enable da8xx build concurrently with older devices ARM: BCM5301X: workaround suppress fault ARM: BCM5301X: add early debugging support ARM: BCM5301X: initial support for the BCM5301X/BCM470X SoCs with ARM CPU ARM: mach-bcm: Remove GENERIC_TIME ARM: shmobile: APMU: Fix warnings due to improper printk formats ...
2014-04-05Merge tag 'cleanup-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Arnd Bergmann: "These cleanup patches are mainly move stuff around and should all be harmless. They are mainly split out so that other branches can be based on top to avoid conflicts. Notable changes are: - We finally remove all mach/timex.h, after CLOCK_TICK_RATE is no longer used (Uwe Kleine-König) - The Qualcomm MSM platform is split out into legacy mach-msm and new-style mach-qcom, to allow easier maintainance of the new hardware support without regressions (Kumar Gala) - A rework of some of the Kconfig logic to simplify multiplatform support (Rob Herring) - Samsung Exynos gets closer to supporting multiplatform (Sachin Kamat and others) - mach-bcm3528 gets merged into mach-bcm (Stephen Warren) - at91 gains some common clock framework support (Alexandre Belloni, Jean-Jacques Hiblot and other French people)" * tag 'cleanup-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (89 commits) ARM: hisi: select HAVE_ARM_SCU only for SMP ARM: efm32: allow uncompress debug output ARM: prima2: build reset code standalone ARM: at91: add PWM clock ARM: at91: move sam9261 SoC to common clk ARM: at91: prepare common clk transition for sam9261 SoC ARM: at91: updated the at91_dt_defconfig with support for the ADS7846 ARM: at91: dt: sam9261: Device Tree support for the at91sam9261ek ARM: at91: dt: defconfig: Added the sam9261 to the list of DT-enabled SOCs ARM: at91: dt: Add at91sam9261 dt SoC support ARM: at91: switch sam9rl to common clock framework ARM: at91/dt: define main clk frequency of at91sam9rlek ARM: at91/dt: define at91sam9rl clocks ARM: at91: prepare common clk transition for sam9rl SoCs ARM: at91: prepare sam9 dt boards transition to common clk ARM: at91: dt: sam9rl: Device Tree for the at91sam9rlek ARM: at91/defconfig: Add the sam9rl to the list of DT-enabled SOCs ARM: at91: Add at91sam9rl DT SoC support ARM: at91: prepare at91sam9rl DT transition ARM: at91/defconfig: refresh at91sam9260_9g20_defconfig ...
2014-03-20Merge tag 'tegra-for-3.15-soc' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux into next/soc Merge "ARM: tegra: core SoC changes for 3.15" from Stephen Warren: A couple of minor fixes, plus the removal of the EMC scaling driver, which hasn't been active since we converted clocks to device tree. * tag 'tegra-for-3.15-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux: ARM: tegra: Export I/O rail functions ARM: tegra: remove tegra EMC scaling driver ARM: tegra: don't timeout if CPU is powergated Signed-off-by: Olof Johansson <olof@lixom.net>
2014-03-20Merge tag 'tegra-for-3.15-tf' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux into next/soc Merge "ARM: tegra: Trusted Foundations work for 3.15" from Stephen Warren: This pull request contains a number of cleanups and enhancements for the Trusted Foundations firmware used on production Tegra SoCs. The changes allow kernels without TF support to run on HW that uses TF, albeit with reduced functionality, and also fix the cpuidle feature. * tag 'tegra-for-3.15-tf' of git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux: ARM: tegra: cpuidle: use firmware for power down ARM: trusted_foundations: implement prepare_idle() ARM: firmware: add prepare_idle() operation ARM: firmware: enable Trusted Foundations by default ARM: trusted_foundations: fallback when TF support is missing ARM: trusted_foundations: fix vendor prefix typos Signed-off-by: Olof Johansson <olof@lixom.net>
2014-03-05Merge tag 'kconfig-cleanup-for-3.15' into imx/socShawn Guo
- Remove common kconfig options required by multi-platform builds out of individual platforms as they are redundant. - Make SMP, CACHE_L2X0 and GPIO config options user visible on multi-platform builds as most platforms enable these options and all platforms can run with them enabled. - Make multi-platform v6 default to more optimal v6k rather than v6 - Remove the last bit of mach-virt and convert it to just a kconfig option. Conflicts: arch/arm/mach-omap2/Kconfig
2014-02-25ARM: tegra: Export I/O rail functionsThierry Reding
The I/O rail functions can be used by drivers that are buildable as modules. Exporting the functions makes sure that they're available. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-02-25ARM: tegra: remove tegra EMC scaling driverStephen Warren
Nothing calls into the Tegra EMC (External Memory Controller) scaling driver any more, so it's dead code. Remove it. Cc: Joseph Lo <josephl@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-02-24Merge 3.14-rc4 into usb-nextGreg Kroah-Hartman
We want the USB fixes in here as well. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-23Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "A collection of fixes for ARM platforms. Most are fixes for DTS files, mostly from DT conversion on OMAP which is still finding a few issues here and there. There's a couple of small stale code removal patches that we usually queue for the next release instead, but they seemed harmless enough to bring in now. Also, a fix for backlight on some PXA platforms, and a cache configuration fix for Tegra, etc" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (25 commits) MAINTAINERS: add additional ARM BCM281xx/BCM11xxx maintainer ARM: tegra: only run PL310 init on systems with one ARM: tegra: Add head numbers to display controllers ARM: imx6: build pm-imx6q.c independently of CONFIG_PM ARM: tegra: fix RTC0 alias for Cardhu ARM: dove: dt: revert PMU interrupt controller node Documentation: dt: OMAP: Update Overo/Tobi ARM: dts: Add support for both OMAP35xx and OMAP36xx Overo/Tobi ARM: dts: omap3-tobi: Use the correct vendor prefix ARM: dts: omap3-tobi: Fix boot with OMAP36xx-based Overo ARM: OMAP2+: Remove legacy macros for zoom platforms ARM: OMAP2+: Remove MACH_NOKIA_N800 ARM: dts: N900: add missing compatible property ARM: dts: N9/N950: fix boot hang with 3.14-rc1 ARM: OMAP1: nokia770: enable tahvo-usb ARM: OMAP2+: gpmc: fix: DT ONENAND child nodes not probed when MTD_ONENAND is built as module ARM: OMAP2+: gpmc: fix: DT NAND child nodes not probed when MTD_NAND is built as module ARM: dts: omap3-gta04: Fix mmc1 properties. ARM: dts: omap3-gta04: Fix 'aux' gpio key flags. ARM: OMAP2+: add missing ARCH_HAS_OPP ...
2014-02-19ARM: select MIGHT_HAVE_CACHE_L2X0 for V6 and V7 multi-platformRob Herring
Many V6 and V7 platforms have an L2x0 cache, so make CONFIG_MIGHT_HAVE_CACHE_L2X0 visible for V6 and V7 multi-platform builds. Signed-off-by: Rob Herring <robh@kernel.org> Acked-by: Stephen Warren <swarren@nvidia.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2014-02-19ARM: select HAVE_SMP for V7 multi-platformRob Herring
All V7 platforms can run SMP kernels, so make CONFIG_SMP visible for V7 multi-platform builds. Signed-off-by: Rob Herring <robh@kernel.org> Acked-by: Stephen Warren <swarren@nvidia.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2014-02-19ARM: centralize common multi-platform kconfig optionsRob Herring
Multi-platform requires various kconfig options to be selected, so platforms don't need to select them individually. Signed-off-by: Rob Herring <robh@kernel.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2014-02-18ARM: tegra: only run PL310 init on systems with oneStephen Warren
Fix tegra_init_cache() to check whether the system has a PL310 cache before touching the PL310 registers. This prevents access to non-existent registers on Tegra114 and later. Note for stable kernels: In <= v3.12, the file to patch is arch/arm/mach-tegra/common.c. Cc: <stable@vger.kernel.org> # v3.9+ Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-02-18ARM: tegra: cpuidle: use firmware for power downAlexandre Courbot
Attempt to invoke the prepare_idle() and do_idle() firmware calls to power down a CPU so an underlying firmware gets informed of the idle operation and performs it by itself if designed in such a way. Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-02-18usb: host: remove selects of USB_ARCH_HAS_?HCIPaul Bolle
USB_ARCH_HAS_EHCI, USB_ARCH_HAS_OHCI, and USB_ARCH_HAS_XHCI were just removed. Selecting them is a nop. The select statements for these symbols can be removed too. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
