path: root/arch/arm/mach-u300
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14clocksource/drivers: Rename clocksource_probe to timer_probeDaniel Lezcano
The function name is now renamed to 'timer_probe' for consistency with the CLOCKSOURCE_OF_DECLARE => TIMER_OF_DECLARE change. Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Heiko Stuebner <heiko@sntech.de> Reviewed-by: Linus Walleij <linus.walleij@linaro.org>
2016-08-01Merge tag 'armsoc-cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Olof Johansson: "The cleanup branch keeps going down in size as we've completed a lot of the major legacy platform removals and conversions. A handful of changes this time around, some of the themes or larger sets are: - A bunch of i.MX cleanups around platform detection, init call cleanups - Misc fixes of missing/implicit includes - Removal of ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIB" * tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (40 commits) ARM: mps2: fix typo ARM: s3c64xx: avoid warning about 'struct device_node' bus: mvebu-mbus: make mvebu_mbus_syscore_ops static bus: mvebu-mbus: fix __iomem on register pointers ARM: tegra: Remove board_init_funcs array ARM: iop: Fix indentation ARM: imx: remove cpu_is_mx*() ARM: imx: remove last call to cpu_is_mx5* ARM: imx: rework mx27_pm_init() call ARM: imx: deconstruct mx3_idle ARM: imx: deconstruct mxc_rnga initialization ARM: imx: remove cpu_is_mx1 check ARM: i.MX: Do not explicitly call l2x0_of_init() ARM: i.MX: system.c: Tweak prefetch settings for performance ARM: i.MX: system.c: Replace magic numbers ARM: i.MX: system.c: Remove redundant errata 752271 code ARM: i.MX: system.c: Convert goto to if statement ARM: Kirkwood: fix kirkwood_pm_init() declaration/type ARM: Kirkwood: make kirkwood_disable_mbus_error_propagation() static ARM: orion5x: make orion5x_legacy_handle_irq static ...
2016-07-30Merge tag 'devicetree-for-4.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull DeviceTree updates from Rob Herring: - remove most of_platform_populate() calls in arch code. Now the DT core code calls it in the default case and platforms only need to call it if they have special needs - use pr_fmt on all the DT core print statements - CoreSight binding doc improvements to block name descriptions - add dt_to_config script which can parse dts files and list corresponding kernel config options - fix memory leak hit with a PowerMac DT - correct a bunch of STMicro compatible strings to use the correct vendor prefix - fix DA9052 PMIC binding doc to match what is actually used in dts files * tag 'devicetree-for-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (35 commits) documentation: da9052: Update regulator bindings names to match DA9052/53 DTS expectations xtensa: Partially Revert "xtensa: Remove unnecessary of_platform_populate with default match table" xtensa: Fix build error due to missing include file MIPS: ath79: Add missing include file Fix spelling errors in Documentation/devicetree ARM: dts: fix STMicroelectronics compatible strings powerpc/dts: fix STMicroelectronics compatible strings Documentation: dt: i2c: use correct STMicroelectronics vendor prefix scripts/dtc: dt_to_config - kernel config options for a devicetree of: fdt: mark unflattened tree as detached of: overlay: add resolver error prints coresight: document binding acronyms Documentation/devicetree: document cavium-pip rx-delay/tx-delay properties of: use pr_fmt prefix for all console printing of/irq: Mark initialised interrupt controllers as populated of: fix memory leak related to safe_name() Revert "of/platform: export of_default_bus_match_table" of: unittest: use of_platform_default_populate() to populate default bus memory: omap-gpmc: use of_platform_default_populate() to populate default bus bus: uniphier-system-bus: use of_platform_default_populate() to populate default bus ...
2016-06-28clocksource/drivers/u300: Add the COMPILE_TEST optionDaniel Lezcano
Change the Kconfig option logic to fullfil with the current approach. A new Kconfig option is added, CONFIG_U300_TIMER and is selected by the platform. Then the clocksource's Kconfig is changed to make this option selectable by the user if the COMPILE_TEST option is set. Otherwise, it is up to the platform's Kconfig to select the timer. Due on the delay specific code, this driver will compile only on the ARM architecture. Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
2016-06-23arm: use of_platform_default_populate() to populateKefeng Wang
Use helper of_platform_default_populate() in linux/of_platform when possible, instead of calling of_platform_populate() with the default match table. Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Krzysztof Halasa <khalasa@piap.pl> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Shawn Guo <shawnguo@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Roland Stigge <stigge@antcom.de> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Ray Jui <rjui@broadcom.com> Cc: Viresh Kumar <vireshk@kernel.org> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Rob Herring <robh@kernel.org> Cc: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com> Signed-off-by: Rob Herring <robh@kernel.org>
2016-06-03ARM: do away with ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIBLinus Walleij
This replaces: - "select ARCH_REQUIRE_GPIOLIB" with "select GPIOLIB" as this can now be selected directly. - "select ARCH_WANT_OPTIONAL_GPIOLIB" with no dependency: GPIOLIB is now selectable by everyone, so we need not declare our intent to select it. When ordering the symbols the following rationale was used: if the selects were in alphabetical order, I moved select GPIOLIB to be in alphabetical order, but if the selects were not maintained in alphabetical order, I just replaced "select ARCH_REQUIRE_GPIOLIB" with "select GPIOLIB". Cc: Michael Büsch <m@bues.ch> Cc: arm@kernel.org Cc: linux-arm-kernel@lists.infradead.org Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2016-02-08ARM: drop unused Makefile.boot of Multiplatform SoCsMasahiro Yamada
The variable "MACHINE" is empty if CONFIG_ARCH_MULTIPLATFORM=y, so these Makefile.boot files are never included. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Michal Simek <michal.simek@xilinx.com> (for Zynq) Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-12-01ARM: use "depends on" for SoC configs instead of "if" after promptMasahiro Yamada
Many ARM sub-architectures use prompts followed by "if" conditional, but it is wrong. Please notice the difference between config ARCH_FOO bool "Foo SoCs" if ARCH_MULTI_V7 and config ARCH_FOO bool "Foo SoCs" depends on ARCH_MULTI_V7 These two are *not* equivalent! In the former statement, it is not ARCH_FOO, but its prompt that depends on ARCH_MULTI_V7. So, it is completely valid that ARCH_FOO is selected by another, but ARCH_MULTI_V7 is still disabled. As it is not unmet dependency, Kconfig never warns. This is probably not what you want. The former should be used only when you need to do so, and you really understand what you are doing. (In most cases, it should be wrong!) For enabling/disabling sub-architectures, the latter is always correct. As a good side effect, this commit fixes some entries over 80 columns (mach-imx, mach-integrator, mach-mbevu). [Arnd: I note that there is not really a bug here, according to the discussion that followed, but I can see value in being consistent and in making the lines shorter] Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Heiko Stuebner <heiko@sntech.de> Acked-by: Patrice Chotard <patrice.chotard@st.com> Acked-by: Liviu Dudau <Liviu.Dudau@arm.com> Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Acked-by: Jun Nie <jun.nie@linaro.org> Acked-by: Matthias Brugger <matthias.bgg@gmail.com> Acked-by: Simon Horman <horms+renesas@verge.net.au> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Acked-by: Shawn Guo <shawnguo@kernel.org> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Thierry Reding <treding@nvidia.com> Acked-by: Krzysztof Halasa <khc@piap.pl> Acked-by: Maxime Coquelin <maxime.coquelin@st.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-11-05Merge tag 'spi-v4.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi Pull spi updates from Mark Brown: "Quite a lot of activity in SPI this cycle, almost all of it in drivers with a few minor improvements and tweaks in the core. - Updates to pxa2xx to support Intel Broxton and multiple chip selects. - Support for big endian in the bcm63xx driver. - Multiple slave support for the mt8173 - New driver for the auxiliary SPI controller in bcm2835 SoCs. - Support for Layerscale SoCs in the Freescale DSPI driver" * tag 'spi-v4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi: (87 commits) spi: pxa2xx: Rework self-initiated platform data creation for non-ACPI spi: pxa2xx: Add support for Intel Broxton spi: pxa2xx: Detect number of enabled Intel LPSS SPI chip select signals spi: pxa2xx: Add output control for multiple Intel LPSS chip selects spi: pxa2xx: Use LPSS prefix for defines that are Intel LPSS specific spi: Add DSPI support for layerscape family spi: ti-qspi: improve ->remove() callback spi/spi-xilinx: Fix race condition on last word read spi: Drop owner assignment from spi_drivers spi: Add THIS_MODULE to spi_driver in SPI core spi: Setup the master controller driver before setting the chipselect spi: dw: replace magic constant by DW_SPI_DR spi: mediatek: mt8173 spi multiple devices support spi: mediatek: handle controller_data in mtk_spi_setup spi: mediatek: remove mtk_spi_config spi: mediatek: Update document devicetree bindings to support multiple devices spi: fix kernel-doc warnings about missing return desc in spi.c spi: fix kernel-doc warnings about missing return desc in spi.h spi: pxa2xx: Align a few defines spi: pxa2xx: Save other reg_cs_ctrl bits when configuring chip select ...
2015-10-28spi: Drop owner assignment from spi_driversAndrew F. Davis
An spi_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Andrew F. Davis <afd@ti.com> Acked-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-10-01clocksource: cosmetic: Drop OF 'dependency' from symbolsMarc Zyngier
Seeing the 'of' characters in a symbol that is being called from ACPI seems to freak out people. So let's do a bit of pointless renaming so that these folks do feel at home. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org> Acked-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Hanjun Guo <hanjun.guo@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-10-28ARM: u300: Convert pr_warning to pr_warnJoe Perches
Use the more common pr_warn. Other miscellanea: o Coalesce formats o Realign arguments o typo fixes of Siple to Simple Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-10-20ARM: mach-u300: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-10-02kbuild: remove unnecessary variable initializaionsMasahiro Yamada
Clearing obj-y, obj-m, obj-n, obj- in each Makefile is a useless habit. They are non-exported variables; therefore they are always empty whenever descending into each subdirectory. (Moreorver, obj-y and obj-m are also set to empty at the beginning of scripts/Makefile.build) Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Peter Foley <pefoley2@pefoley.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-06-17ARM: use menuconfig for sub-arch menusRob Herring
The System Type menu is getting quite long with platforms and is inconsistent in handling of sub-arch specific options. Tidy up the menu by making platform options a menuconfig entry containing any platform specific config items. [arnd: change OMAP part according to suggestion from Tony Lindgren <tony@atomide.com>] Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-04-05Merge tag 'cleanup-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Arnd Bergmann: "These cleanup patches are mainly move stuff around and should all be harmless. They are mainly split out so that other branches can be based on top to avoid conflicts. Notable changes are: - We finally remove all mach/timex.h, after CLOCK_TICK_RATE is no longer used (Uwe Kleine-König) - The Qualcomm MSM platform is split out into legacy mach-msm and new-style mach-qcom, to allow easier maintainance of the new hardware support without regressions (Kumar Gala) - A rework of some of the Kconfig logic to simplify multiplatform support (Rob Herring) - Samsung Exynos gets closer to supporting multiplatform (Sachin Kamat and others) - mach-bcm3528 gets merged into mach-bcm (Stephen Warren) - at91 gains some common clock framework support (Alexandre Belloni, Jean-Jacques Hiblot and other French people)" * tag 'cleanup-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (89 commits) ARM: hisi: select HAVE_ARM_SCU only for SMP ARM: efm32: allow uncompress debug output ARM: prima2: build reset code standalone ARM: at91: add PWM clock ARM: at91: move sam9261 SoC to common clk ARM: at91: prepare common clk transition for sam9261 SoC ARM: at91: updated the at91_dt_defconfig with support for the ADS7846 ARM: at91: dt: sam9261: Device Tree support for the at91sam9261ek ARM: at91: dt: defconfig: Added the sam9261 to the list of DT-enabled SOCs ARM: at91: dt: Add at91sam9261 dt SoC support ARM: at91: switch sam9rl to common clock framework ARM: at91/dt: define main clk frequency of at91sam9rlek ARM: at91/dt: define at91sam9rl clocks ARM: at91: prepare common clk transition for sam9rl SoCs ARM: at91: prepare sam9 dt boards transition to common clk ARM: at91: dt: sam9rl: Device Tree for the at91sam9rlek ARM: at91/defconfig: Add the sam9rl to the list of DT-enabled SOCs ARM: at91: Add at91sam9rl DT SoC support ARM: at91: prepare at91sam9rl DT transition ARM: at91/defconfig: refresh at91sam9260_9g20_defconfig ...
2014-03-11ARM: u300: move timer driver to clocksourceLinus Walleij
Move the U300 timer driver down to the clocksource driver subsystem and keep arch/arm clean. Cc: Daniel Lezcano <daniel.lezcano@linaro.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
2014-02-19ARM: centralize common multi-platform kconfig optionsRob Herring
Multi-platform requires various kconfig options to be selected, so platforms don't need to select them individually. Signed-off-by: Rob Herring <robh@kernel.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2014-01-23Merge tag 'soc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Olof Johansson: "New core SoC-specific changes. New platforms: * Introduction of a vendor, Hisilicon, and one of their SoCs with some random numerical product name. * Introduction of EFM32, embedded platform from Silicon Labs (ARMv7m, i.e. !MMU). * Marvell Berlin series of SoCs, which include the one in Chromecast. * MOXA platform support, ARM9-based platform used mostly in industrial products * Support for Freescale's i.MX50 SoC. Other work: * Renesas work for new platforms and drivers, and conversion over to more multiplatform-friendly device registration schemes. * SMP support for Allwinner sunxi platforms. * ... plus a bunch of other stuff across various platforms" * tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (201 commits) ARM: tegra: fix tegra_powergate_sequence_power_up() inline ARM: msm_defconfig: Update for multi-platform ARM: msm: Move MSM's DT based hardware to multi-platform support ARM: msm: Only build timer.c if required ARM: msm: Only build clock.c on proc_comm based platforms ARM: ux500: Enable system suspend with WFI support ARM: ux500: turn on PRINTK_TIME in u8500_defconfig ARM: shmobile: r8a7790: Fix I2C controller names ARM: msm: Simplify ARCH_MSM_DT config ARM: msm: Add support for MSM8974 SoC ARM: sunxi: select ARM_PSCI MAINTAINERS: Update Allwinner sunXi maintainer files ARM: sunxi: Select RESET_CONTROLLER ARM: imx: improve the comment of CCM lpm SW workaround ARM: imx: improve status check of clock gate ARM: imx: add necessary interface for pfd ARM: imx_v6_v7_defconfig: Select CONFIG_REGULATOR_PFUZE100 ARM: imx_v6_v7_defconfig: Select MX35 and MX50 device tree support ARM: imx: Add cpu frequency scaling support ARM i.MX35: Add devicetree support. ...
2013-12-06Merge branch 'soc/sched_clock' into next/socKevin Hilman
From Stephen Boyd: * soc/sched_clock: ARM: versatile: Switch to sched_clock_register() ARM: orion: Switch to sched_clock_register() ARM: OMAP: Switch to sched_clock_register() ARM: iop: Switch to sched_clock_register() ARM: u300: Switch to sched_clock_register() ARM: sa1100: Switch to sched_clock_register() ARM: pxa: Switch to sched_clock_register() ARM: OMAP2+: Switch to sched_clock_register() ARM: OMAP1: Switch to sched_clock_register() ARM: msm: Switch to sched_clock_register() ARM: mmp: Switch to sched_clock_register() ARM: IXP4xx: Switch to sched_clock_register() ARM: integrator: Switch to sched_clock_register() ARM: imx: Switch to sched_clock_register() ARM: davinci: Switch to sched_clock_register() ARM: clps711x: Switch to sched_clock_register() ARM: timer-sp: Switch to sched_clock_register() Signed-off-by: Kevin Hilman <khilman@linaro.org>
2013-11-26ARM: u300: fix timekeeping when periodic mode is usedUwe Kleine-König
To determine the value to write to the hardware's timer counter register the symbol CLOCK_TICK_RATE is used. This value is a dummy value on u300 though. So instead use the clock rate that is used for oneshot mode. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-11-26ARM: u300: fix return value check in __u300_init_boardpower()Wei Yongjun
In case of error, the function syscon_node_to_regmap() returns ERR_PTR() and never returns NULL. The NULL test in the return value check should be replaced with IS_ERR(). Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
2013-11-21ARM: u300: Switch to sched_clock_register()Stephen Boyd
The 32 bit sched_clock interface now supports 64 bits. Upgrade to the 64 bit function to allow us to remove the 32 bit registration interface. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Kevin Hilman <khilman@linaro.org>
2013-11-12Merge tag 'devicetree-for-3.13' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull devicetree updates from Rob Herring: "DeviceTree updates for 3.13. This is a bit larger pull request than usual for this cycle with lots of clean-up. - Cross arch clean-up and consolidation of early DT scanning code. - Clean-up and removal of arch prom.h headers. Makes arch specific prom.h optional on all but Sparc. - Addition of interrupts-extended property for devices connected to multiple interrupt controllers. - Refactoring of DT interrupt parsing code in preparation for deferred probe of interrupts. - ARM cpu and cpu topology bindings documentation. - Various DT vendor binding documentation updates" * tag 'devicetree-for-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (82 commits) powerpc: add missing explicit OF includes for ppc dt/irq: add empty of_irq_count for !OF_IRQ dt: disable self-tests for !OF_IRQ of: irq: Fix interrupt-map entry matching MIPS: Netlogic: replace early_init_devtree() call of: Add Panasonic Corporation vendor prefix of: Add Chunghwa Picture Tubes Ltd. vendor prefix of: Add AU Optronics Corporation vendor prefix of/irq: Fix potential buffer overflow of/irq: Fix bug in interrupt parsing refactor. of: set dma_mask to point to coherent_dma_mask of: add vendor prefix for PHYTEC Messtechnik GmbH DT: sort vendor-prefixes.txt of: Add vendor prefix for Cadence of: Add empty for_each_available_child_of_node() macro definition arm/versatile: Fix versatile irq specifications. of/irq: create interrupts-extended property microblaze/pci: Drop PowerPC-ism from irq parsing of/irq: Create of_irq_parse_and_map_pci() to consolidate arch code. of/irq: Use irq_of_parse_and_map() ...
2013-10-24of/irq: Use irq_of_parse_and_map()Thierry Reding
Replace some instances of of_irq_map_one()/irq_create_of_mapping() and of_irq_to_resource() by the simpler equivalent irq_of_parse_and_map(). Signed-off-by: Thierry Reding <treding@nvidia.com> Acked-by: Rob Herring <rob.herring@calxeda.com> [grant.likely: resolved conflicts with core code renames] Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-10-07ARM: drop explicit selection of HAVE_CLK and CLKDEV_LOOKUPUwe Kleine-König
CLKDEV_LOOKUP selects HAVE_CLK and COMMON_CLK selects CLKDEV_LOOKUP. So all symbols that select at least two of these symbols can be simplified. For imx, omap2 and ux500 some rearrangements were necessary before the simplification. Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Stephen Boyd <sboyd@codeaurora.org> Acked-by: Dinh Nguyen <dinguyen@altera.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Pawel Moll <pawel.moll@arm.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-09-18ARM: u300: hide submenusLinus Walleij
Right now the U300 submenus are showcased for everyone even if we're not on v5 multiplatforms. Hide this in the multiplatform configuration properly. Cc: arm@kernel.org Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-07-09reboot: arm: change reboot_mode to use enum reboot_modeRobin Holt
Preparing to move the parsing of reboot= to generic kernel code forces the change in reboot_mode handling to use the enum. [akpm@linux-foundation.org: fix arch/arm/mach-socfpga/socfpga.c] Signed-off-by: Robin Holt <holt@sgi.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Russ Anderson <rja@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-06Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer core updates from Thomas Gleixner: "The timer changes contain: - posix timer code consolidation and fixes for odd corner cases - sched_clock implementation moved from ARM to core code to avoid duplication by other architectures - alarm timer updates - clocksource and clockevents unregistration facilities - clocksource/events support for new hardware - precise nanoseconds RTC readout (Xen feature) - generic support for Xen suspend/resume oddities - the usual lot of fixes and cleanups all over the place The parts which touch other areas (ARM/XEN) have been coordinated with the relevant maintainers. Though this results in an handful of trivial to solve merge conflicts, which we preferred over nasty cross tree merge dependencies. The patches which have been committed in the last few days are bug fixes plus the posix timer lot. The latter was in akpms queue and next for quite some time; they just got forgotten and Frederic collected them last minute." * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (59 commits) hrtimer: Remove unused variable hrtimers: Move SMP function call to thread context clocksource: Reselect clocksource when watchdog validated high-res capability posix-cpu-timers: don't account cpu timer after stopped thread runtime accounting posix_timers: fix racy timer delta caching on task exit posix-timers: correctly get dying task time sample in posix_cpu_timer_schedule() selftests: add basic posix timers selftests posix_cpu_timers: consolidate expired timers check posix_cpu_timers: consolidate timer list cleanups posix_cpu_timer: consolidate expiry time type tick: Sanitize broadcast control logic tick: Prevent uncontrolled switch to oneshot mode tick: Make oneshot broadcast robust vs. CPU offlining x86: xen: Sync the CMOS RTC as well as the Xen wallclock x86: xen: Sync the wallclock when the system time is set timekeeping: Indicate that clock was set in the pvclock gtod notifier timekeeping: Pass flags instead of multiple bools to timekeeping_update() xen: Remove clock_was_set() call in the resume path hrtimers: Support resuming with two or more CPUs online (but stopped) timer: Fix jiffies wrap behavior of round_jiffies_common() ...
2013-06-20ARM: u300: only build for ARCH_MULTI_V5Arnd Bergmann
This avoids impossible platform combinations, as we cannot build a combined V5 + V6/V7 kernel. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2013-06-17ARM: u300: switch to using syscon regmap for boardLinus Walleij
This switches the code using a local remapping of the system controller to enable the U300 board to be self-powered over to making the U300-specific syscon compatible with the MFD generic syscon driver, selecting the generic syscon driver, and augmenting the board power code to pick the regmap and manipulate the syscon from the regmap side of things. Cc: Dong Aisheng <dong.aisheng@linaro.org> Suggested-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-06-17pinctrl: get rid of all platform data for coh901Linus Walleij
This deletes the dependency on any platform data for the COH901 pin controller. There is only one user in the kernel, and if we at some point want to support more variants, they shall provide their variant info through the device tree. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-06-17ARM: u300: move the gated system controller clocks to DTLinus Walleij
This moves the slow, fast, AHB bridge and "rest" clocks on the U300 system controller over to registration from the device tree. Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-06-17ARM: u300: remove register definition fileLinus Walleij
Now that the core file is the only one actually using any of the base addresses, we can delete that header and move the base address definitions into the one and only core file. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-06-17ARM: u300: add syscon nodeLinus Walleij
This adds a device tree node for the U300 system controller and remaps this dynamically instead of using hard-coded virtual addresses. The board power set-up code is altered to fetch a reference to the syscon using ampersand <&syscon> notation. This way of passing a pointer to the syscon will also be used by the clocks. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-06-17ARM: u300 use module_spi_driver to register driverPeter Huewe
Removing some boilerplate by using module_spi_driver instead of calling register and unregister in the otherwise empty init/exit functions. Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-06-17ARM: u300: delete remnant machine headersLinus Walleij
Two files remain in <mach/*> for U300: timex.h and uncompress.h. The former is done away with by using defaults, the latter is unused in multiplatform. Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-06-17ARM: u300: convert to multiplatformLinus Walleij
Now that we removed our dependency on <mach/*> the U300 can be converted to mutliplatform. Remove the invalid restriction that U300 would not support AUTO_ZRELADDR (it does) and update the defconfig in the process. Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-06-17ARM: u300: localize <mach/u300-regs.h>Linus Walleij
This register base file is now only used in the machine itself so move it down into mach-u300. Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-06-17ARM: u300: delete <mach/irqs.h>Linus Walleij
All IRQs are now obtained from the device tree, and this file is unused, so delete it. Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-06-17ARM: u300: delete <mach/hardware.h>Linus Walleij
This file is now unused and can be deleted. Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-06-17ARM: u300: push down syscon registersLinus Walleij
Get rid of the <mach/syscon.h> header as a prerequisite for multiplatform support. Do this by pushing the registers down to their respective drivers and deleting the unused remainder. Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-06-17ARM: u300: move debugmacro to debug includesLinus Walleij
This moves the U300 debug macro to the debug headers to make way for multiplatform support. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-06-17ARM: u300: delete all static board dataLinus Walleij
We have now transferred all the U300 peripherals to the device tree, so we just select USE_OF, and delete all static board data, then require that this platform shall be booted using the device tree and nothing else. This gets rid of the MMCI (PL180), PL022, and serial PL011 platform data entries and more. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-06-17ARM: u300: add FSMC flash into the device treeLinus Walleij
This registers the U300 FSMC flash controller from the device tree, and defines the three partitions. Skip the BBT scan as in the current platform data. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-06-17ARM: u300: probe the U300 dummy-spichip from device treeLinus Walleij
This probes the U300 dummy-spichip from the device tree and adds the apropriate node to the tree. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-06-17ARM: u300: add SPI PL022 to the device treeLinus Walleij
This registers the PL022 PrimeCell from the U300 device tree. We make a new copy of the platform data for the device tree boot path, as the old platform data is in an older file which will be going away. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-06-17ARM: u300: add the COH 901 318 DMAC to device treeLinus Walleij
This adds the COH 901 318 DMA controller to the U300 device tree. All devices now converted to device tree so far will start to find their DMA channels. Note that the U300 is not yet using the device tree to obtain DMA channels, but this is a first step. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
