path: root/arch/arm/mach-ux500/board-mop500-pins.c
2011-07-17Merge branches 'cns3xxx/devel', 'davinci/devel', 'imx/devel', ↵Arnd Bergmann
'lpc32xx/devel', 'pxa/devel', 'tegra/devel' and 'stericsson/master' of git+ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc into next/devel
2011-06-23mach-ux500: Add pin configuration for snowball boardRobert Marklund
This sets up a few GPIO pins and some pinmuxing on platform boot for the Snowball board. Based on work from Mathieu J. Poirier <mathieu.poirier@linaro.org>. Signed-off-by: Robert Marklund <robert.marklund@stericsson.com>
2011-06-16amba pl011: platform data for reg lockup and glitch v2Shreshtha Kumar Sahu
This patch provides platform data for following - uart reset function to assist uart register lockup workaround - init/exit function to fix glitch in the tx pin in tty_open when tty port0 is opened a glitch is seen in the tx line of uart0. This happens in pl011_startup() when tx fifo interrupt is provoked into asserting. Now uart0 pins are enabled (alt function) only when init is complete and turned back to gpio when closed. Signed-off-by: Shreshtha Kumar Sahu <shreshthakumar.sahu@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-14mach-ux500: add hrefv60 GPIO pinsBibek Basu
This will centralize all GPIO pin muxing for the different boards in the MOP500 family to a single file. It also kills off the deprecated support for the ED (Early Drop) ASIC, this should never be spotted in the open and ST-Ericsson have internally deprecated this hardware. Signed-off-by: Bibek Basu <bibek.basu@stericsson.com> [Rebasing and kill old ASIC support] Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-03-14mach-ux500: move MOP500 pins to separate fileRabin Vincent
Split off pin definitions for the MOP500 board family to its own file. Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
