path: root/arch/arm/mach-ux500/board-mop500-regulators.c
2011-07-26Merge branch 'next/devel' of ↵Linus Torvalds
ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/devel' of ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (128 commits) ARM: S5P64X0: External Interrupt Support ARM: EXYNOS4: Enable MFC on Samsung NURI ARM: EXYNOS4: Enable MFC on universal_c210 ARM: S5PV210: Enable MFC on Goni ARM: S5P: Add support for MFC device ARM: EXYNOS4: Add support FIMD on SMDKC210 ARM: EXYNOS4: Add platform device and helper functions for FIMD ARM: EXYNOS4: Add resource definition for FIMD ARM: EXYNOS4: Change devname for FIMD clkdev ARM: SAMSUNG: Add IRQ_I2S0 definition ARM: SAMSUNG: Add platform device for idma ARM: EXYNOS4: Add more registers to be saved and restored for PM ARM: EXYNOS4: Add more register addresses of CMU ARM: EXYNOS4: Add platform device for dwmci driver ARM: EXYNOS4: configure rtc-s3c on NURI ARM: EXYNOS4: configure MAX8903 secondary charger on NURI ARM: EXYNOS4: configure ADC on NURI ARM: EXYNOS4: configure MAX17042 fuel gauge on NURI ARM: EXYNOS4: configure regulators and PMIC(MAX8997) on NURI ARM: EXYNOS4: Increase NR_IRQS for devices with more IRQs ... Fix up tons of silly conflicts: - arch/arm/mach-davinci/include/mach/psc.h - arch/arm/mach-exynos4/Kconfig - arch/arm/mach-exynos4/mach-smdkc210.c - arch/arm/mach-exynos4/pm.c - arch/arm/mach-imx/mm-imx1.c - arch/arm/mach-imx/mm-imx21.c - arch/arm/mach-imx/mm-imx25.c - arch/arm/mach-imx/mm-imx27.c - arch/arm/mach-imx/mm-imx31.c - arch/arm/mach-imx/mm-imx35.c - arch/arm/mach-mx5/mm.c - arch/arm/mach-s5pv210/mach-goni.c - arch/arm/mm/Kconfig
2011-06-24treewide: transciever/transceiver spelling fixesJoe Perches
Just tyops. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-06-21mach-ux500: complete regulator constraints for MOP500 boardLinus Walleij
This board now has complete regulation constraints and can turn off unused regulators. For the moment we need to wire VAUX1 (V-DISPLAY rail) always on since it somehow affects the external MMC. Cc: Liam Girdwood <lrg@slimlogic.co.uk> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-03-28mach-ux500: configure board for the TPS61052 regulator v2Linus Walleij
This registers the TPS61052 regulator to the ux500 MOP/HREF boards. Cc: Samuel Ortiz <samuel.ortiz@intel.com> Cc: Liam Girdwood <lrg@slimlogic.co.uk> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Ola Lilja <ola.o.lilja@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-03-28mach-ux500: provide ab8500 init vectorBengt Jonsson
This adds an ab8500 regulator initialization vector for the HREF/MOP500 series of boards. This also sets the display regulator to be on at boot so we don't loose our splash screen when the board comes up. Signed-off-by: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-03-14mach-ux500: add a few AB8500 regulator consumers v3Linus Walleij
Try to make the regulators a little bit more useful by adding some of the most basic consumers we're going to have in the end. Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Rabin Vincent <rabin@rab.in> Cc: Naveen Kumar Gaddipati <naveen.gaddipati@stericsson.com> Cc: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Cc: Lee Jones <lee.jones@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-01-12mach-ux500: Updated and connected ab8500 regulator board configurationBengt Jonsson
The ab8500 regulator board configuration is updated and put in an array which can easily be used in the MFD board configuration. The regulator board configuration is also added to the MFD configuration in this patch. Signed-off-by: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-09-19ARM: 6392/1: ux500: add ab8500-regulators machine specific dataSundar Iyer
From: Sundar R Iyer <sundar.iyer@stericsson.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Bengt JONSSON <bengt.g.jonsson@stericsson.com> Signed-off-by: Sundar R Iyer <sundar.iyer@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
