From: Shreshtha Kumar Sahu <shreshthakumar.sahu@stericsson.com>
platform data for simple backlight driver for LM3530
in the u5500 platform
Signed-off-by: Shreshtha Kumar Sahu <shreshthakumar.sahu@stericsson.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Lee Jones <lee.jones@linaro.org>
This will configure the platform data for the PL011, PL022
and PL180 (derivate) PrimeCells found in the Ux500 to use DMA
with the generic DMA engine for DMA40.
Signed-off-by: Per Forlin <per.forlin@linaro.org>
U5500 now boots from sdi0 (onboard eMMC).
Change machine type to U5500.
Adjust uart and sdi0 clock rates for u5500.
All necessary clocks must be enabled before Linux starts because
there is no clock tree support in u5500 yet.
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
Change the Ux500 devices to be dynamically allocated and added by
calling functions instead of referencing structures, thereby allowing
5500 and other derivatives' support to be added without having to
duplicate structures, use fixup functions, or use compile-time macros.
Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com>
Since we're now using addruart to establish the debug mapping, we can
remove the io_pg_offst and phys_io members of struct machine_desc.
The various declarations were removed using the following script:
grep -rl MACHINE_START arch/arm | xargs \
sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }'
[ Initial patch was from Jeremy Kerr, example script from Russell King ]
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Acked-by: Eric Miao <eric.miao at canonical.com>
Add basic support for the U5500 platform.
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
Acked-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
