path: root/arch/arm/mach-ux500/clock.h
2010-12-20ux500: add debugfs support for powerdebugVincent Guittot
Signed-off-by: Vincent Guittot <vincent.guittot@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
2010-05-27ARM: 6145/1: ux500 MTU clockrate correctionLinus Walleij
This adjusts the clockrate for the MTU timer. On the different UX500 variants this rate is different. The platform can also have been set up at hardware initialization, bootloader or early init for different clock speeds. To have the clock framework available early so the timers can use them, the clock initialization for Nomadik and ux500 is moved to IRQ init time. A custom per-clock callback is added to handle special cases like this. This solves a user-visible bug: without this patch the current UX500 platforms will not be synchronized to wall-clock time and the platform will drift in time. Acked-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-03-19ARM: 5964/1: ux500: support clock gatingRabin Vincent
Implement clock gating support for the u8500 clocks. Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
