path: root/arch/arm/mach-ux500/devices-db8500.c
2011-03-14mach-ux500: config Ux500 PL011 PL022 PL180 for DMALinus Walleij
This will configure the platform data for the PL011, PL022 and PL180 (derivate) PrimeCells found in the Ux500 to use DMA with the generic DMA engine for DMA40. Signed-off-by: Per Forlin <per.forlin@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-03-14mach-ux500: add MUSB to db8500 devicesMian Yousaf Kaukab
- DMA tx and rx maps for usb channels are set to be configured at runtime - GPIO configurations for usb are added - MUSB is enabled with soc specific base address, irq and dma configurations Signed-off-by: Mian Yousaf Kaukab <mian-yousaf.kaukab@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2010-12-19mach-ux500: move keymaps to new fileSundar Iyer
Move keylayouts to a dedicated file and plug these keylayouts for input platform data. This will make addition of new and custom keylayouts localized. Signed-off-by: Sundar Iyer <sundar.iyer@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
2010-12-08ux500: rework gpio registrationRabin Vincent
Rework gpio registration to remove build-time changing macros. Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
2010-12-08ux500: rework device registrationRabin Vincent
Change the Ux500 devices to be dynamically allocated and added by calling functions instead of referencing structures, thereby allowing 5500 and other derivatives' support to be added without having to duplicate structures, use fixup functions, or use compile-time macros. Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
2010-10-27Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (48 commits) DMAENGINE: move COH901318 to arch_initcall dma: imx-dma: fix signedness bug dma/timberdale: simplify conditional ste_dma40: remove channel_type ste_dma40: remove enum for endianess ste_dma40: remove TIM_FOR_LINK option ste_dma40: move mode_opt to separate config ste_dma40: move channel mode to a separate field ste_dma40: move priority to separate field ste_dma40: add variable to indicate valid dma_cfg async_tx: make async_tx channel switching opt-in move async raid6 test to lib/Kconfig.debug dmaengine: Add Freescale i.MX1/21/27 DMA driver intel_mid_dma: change the slave interface intel_mid_dma: fix the WARN_ONs intel_mid_dma: Add sg list support to DMA driver intel_mid_dma: Allow DMAC2 to share interrupt intel_mid_dma: Allow IRQ sharing intel_mid_dma: Add runtime PM support DMAENGINE: define a dummy filter function for ste_dma40 ...
2010-10-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (75 commits) Input: wacom - specify Cinitq supported tools Input: ab8500-ponkey - fix IRQ freeing in error path Input: adp5588-keys - use more obvious i2c_device_id name string Input: ad7877 - switch to using threaded IRQ Input: ad7877 - use attribute group to control visibility of attributes Input: serio - add support for PS2Mult multiplexer protocol Input: wacom - properly enable runtime PM Input: ad7877 - filter events where pressure is beyond the maximum Input: ad7877 - implement EV_KEY:BTN_TOUCH reporting Input: ad7877 - implement specified chip select behavior Input: hp680_ts_input - use cancel_delayed_work_sync() Input: mousedev - correct lockdep annotation Input: ads7846 - switch to using threaded IRQ Input: serio - support multiple child devices per single parent Input: synaptics - simplify pass-through port handling Input: add ROHM BU21013 touch panel controller support Input: omap4-keypad - wake-up on events & long presses Input: omap4-keypad - fix interrupt line configuration Input: omap4-keypad - SYSCONFIG register configuration Input: omap4-keypad - use platform device helpers ...
2010-10-19ste_dma40: remove enum for endianessRabin Vincent
A bool will suffice. The default is little endian. Acked-by: Jonas Aaberg <jonas.aberg@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-10-19ste_dma40: remove TIM_FOR_LINK optionRabin Vincent
This does not seem to be implemented. Acked-by: Jonas Aaberg <jonas.aberg@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-10-19ste_dma40: move mode_opt to separate configRabin Vincent
Defaults are "basic mode" for physical channels, and "logical source logical destination" for logical channels. Acked-by: Jonas Aaberg <jonas.aberg@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-10-19ste_dma40: move channel mode to a separate fieldRabin Vincent
And keep it logical by default. Acked-by: Jonas Aaberg <jonas.aberg@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-10-19ste_dma40: move priority to separate fieldRabin Vincent
And keep it low priority by default. Acked-by: Jonas Aaberg <jonas.aberg@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-10-13ux500 - add platform data for Nomadik SKE keypad controllerSundar Iyer
Signed-off-by: Sundar Iyer <sundar.iyer@stericsson.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-10-04ARM: 6418/1: ux500: rename DB8500 DMA event line macrosRabin Vincent
Change the DMA event line macros to have the name of the SoC. Also, have the event line number encoded in the macro since on DB5500 several event lines are present at multiple alternate numbers. Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-09-22DMAENGINE: ste_dma40: removed non-used variable from structJonas Aaberg
The reqrite of the LCLA code rendered this variable unused. Signed-off-by: Jonas Aaberg <jonas.aberg@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-09-02ARM: 6334/1: ux500: add DB8500 SD/MMC platform devicesHanumath Prasad
Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Hanumath Prasad <hanumath.prasad@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-08-09Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (30 commits) DMAENGINE: at_hdmac: locking fixlet DMAENGINE: pch_dma: kill another usage of __raw_{read|write}l dma: dmatest: fix potential sign bug ioat2: catch and recover from broken vtd configurations v6 DMAENGINE: add runtime slave control to COH 901 318 v3 DMAENGINE: add runtime slave config to DMA40 v3 DMAENGINE: generic slave channel control v3 dmaengine: Driver for Topcliff PCH DMA controller intel_mid: Add Mrst & Mfld DMA Drivers drivers/dma: Eliminate a NULL pointer dereference dma/timb_dma: compile warning on 32 bit DMAENGINE: ste_dma40: support older silicon DMAENGINE: ste_dma40: support disabling physical channels DMAENGINE: ste_dma40: no disabled phy channels on ux500 DMAENGINE: ste_dma40: fix suspend bug DMAENGINE: ste_dma40: add DB8500 memcpy channels DMAENGINE: ste_dma40: no flow control on memcpy DMAENGINE: ste_dma40: arch updates for LCLA and LCPA DMAENGINE: ste_dma40: allocate LCLA dynamically DMAENGINE: ste_dma40: no premature stop ... Fix up trivial conflicts in arch/arm/mach-ux500/devices-db8500.c
2010-07-26ARM: 6266/1: ux500: add separate irq lists for DB8500 and DB5500Rabin Vincent
Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-06-22DMAENGINE: ste_dma40: support older siliconLinus Walleij
This makes sure the DMA40 driver will also work on the oldest silicon revisions that have the on-chip memory on another location in the DB8500 and also requires explicit suspend before starting or resuming a logical channel. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> [added parenthesis to the definition of U8500_DMA_LCPA_BASE_ED] Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-06-22DMAENGINE: ste_dma40: no disabled phy channels on ux500Jonas Aaberg
Make sure we have no disabled physical channels when we start on the ux500 machines. Signed-off-by: Jonas Aaberg <jonas.aberg@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-06-22DMAENGINE: ste_dma40: add DB8500 memcpy channelsJonas Aaberg
This adds all available memcpy channels to the DB8500 in the ux500 platform (and fixes a typo). Signed-off-by: Jonas Aaberg <jonas.aberg@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-06-22DMAENGINE: ste_dma40: no flow control on memcpyJonas Aaberg
On memcpy DMA operations we don't need flow control. Signed-off-by: Jonas Aaberg <jonas.aberg@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-06-22DMAENGINE: ste_dma40: arch updates for LCLA and LCPAJonas Aaberg
This follows on the patch to allocate LCLA dynamically: the on-chip memory is needed for other things so now that that we're using it dynamically we can remove the LCLA resource altogether and free up some ESRAM memory. Signed-off-by: Jonas Aaberg <jonas.aberg@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-05-27DMAENGINE: DMA40 U8500 platform configurationLinus Walleij
This completes the DMA40 support with the platform-specific configuration for U8500/DB8500. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Reviewed-by: Alessandro Rubini <rubini@unipv.it> Cc: STEricsson_nomadik_linux@list.st.com Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> [fixed up dma40_{tx|rx}_map declaration/initialization] Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-05-04ARM: 6086/1: ux500: move gpio devices to devices-db8500.cRabin Vincent
The GPIO layout is different on DB5500, so move the current one to devices-db8500.c. Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-04ARM: 6085/1: ux500: reorganize i2c devicesRabin Vincent
Move common i2c devices to devices.c and DB8500-specific I2C devices to devices-db8500.c. Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-04ARM: 6083/1: ux500: put DB8500-specific devices in devices-db8500.cRabin Vincent
Add devices-db8500.c for DB8500-specific devices, starting with SSP0. Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
