The GIC distributor was mapped statically for the PM code
but the driver already get the base address from the DT.
Augment the PM code to get the base from the device tree
and remove the static map.
The SMP startup/shutdown code relied on a static SCU base
address, let's get this from the device tree instead.
Instead of relying on static maps, remap the BB chip ID
offset dynamically.
This removes the reliance on static maps for SCU and backupram
for the SMP startup of the Ux500 SoC.
Delete the static maps for the Ux500 UARTs and rely
on debug_ll_io_init() to do the trick.
commit f87b95dd2e4a8832b1d6034f15a5324db42608a0
"ARM: ux500: move debugmacro to debug includes"
defined the necessary addruart macro two years ago.
The static mappings of the GPIO blocks, clock/reset controller
and MTU timer are clearly superfluous. These are all probed
exclusively from the device tree. Tested on the U8500.
Instead of directly touching gic_arch_extn, which is about to
be removed, use gic_set_irqchip_flags instead.
Link: https://lkml.kernel.org/r/1426088737-15817-4-git-send-email-marc.zyngier@arm.com
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
of_device_ids (i.e. compatible strings and the respective data) are not
supposed to change at runtime. All functions working with of_device_ids
provided by <linux/of.h> work with const of_device_ids. So mark the
non-const structs in arch/arm as const, too.
While at it also add some __initconst annotations.
Acked-by: Jason Cooper <jason@lakedameon.net>
Since ux500 uses the generic PM domain, let's enable the corresponding
Kconfig as long as CONFIG_PM also is enabled.
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
The ux500 SoC uses the generic PM domain and requires the domains to be
specified through DT.
Currently the genpd callbacks for handling power gating|ungating are
implemented as dummy functions. To be able to enable those to perform
PM domain gating/ungating, each device that resides in the VAPE domain
must be properly handled from a runtime PM perspective.
This cleans out non-DT cache setup (the ux500 is DT only), and
sinks the l2cc base into the unlock function.
The C99 specification states in section 6.11.5:
The placement of a storage-class specifier other than at the beginning
of the declaration specifiers in a declaration is an obsolescent
feature.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
'ab8505_regulators' is used only in this file.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Symbols local to this file are made static.
This variable is not used outside of the file that it's declared in, so
reduce the scope to the local file.
Signed-off-by: Thierry Reding <treding@nvidia.com>
[Also add const marker after suggestion from Lee Jones]
Pull ARM fixes from Russell King:
"A number of low impact fixes, the most noticable one is the thumb2
frame pointer fix. We also fix a regression caused during this merge
window with ARM925 CPUs running with caches disabled, and fix a number
of warnings"
* 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm:
ARM: arm925: ensure assembly sets up writethrough mapping
ARM: perf: fix compiler warning with gcc 4.6.4 (and tidy code)
ARM: l2c: fix dependencies on PL310 errata symbols
ARM: 8069/1: Make thread_save_fp macro aware of THUMB2 mode
ARM: 8068/1: scoop: Remove unused variable
A number of configurations spit out warnings similar to:
warning: (SOC_IMX6 && SOC_VF610 && ARCH_OMAP4) selects PL310_ERRATA_588369 which has unmet direct dependencies (CACHE_L2X0)
warning: (SOC_IMX6 && SOC_VF610 && ARCH_OMAP4) selects PL310_ERRATA_727915 which has unmet direct dependencies (CACHE_L2X0)
Clean up the dependencies here:
* PL310 symbols should only be selected when CACHE_L2X0 is enabled.
* Since the cache-l2x0 code detects PL310 presence at runtime, and we will
eventually get rid of CACHE_PL310, surround these errata options with an
if CACHE_L2X0 conditional rather than repeating the dependency against
each.
The System Type menu is getting quite long with platforms and is
inconsistent in handling of sub-arch specific options. Tidy up the menu
by making platform options a menuconfig entry containing any platform
specific config items.
[arnd: change OMAP part according to suggestion from
Tony Lindgren <tony@atomide.com>]
Signed-off-by: Rob Herring <robh@kernel.org>
This config exists entirely to hide the cpufreq menu from the
kernel configuration unless a platform has selected it. Nothing
is actually built if this config is 'Y' and it just leads to more
patches that add a select under a platform Kconfig so that some
other CPUfreq option can be chosen. Let's remove the option so
that we can always enable CPUfreq drivers on ARM platforms.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Pull ARM updates from Russell King:
- Major clean-up of the L2 cache support code. The existing mess was
becoming rather unmaintainable through all the additions that others
have done over time. This turns it into a much nicer structure, and
implements a few performance improvements as well.
- Clean up some of the CP15 control register tweaks for alignment
support, moving some code and data into alignment.c
- DMA properties for ARM, from Santosh and reviewed by DT people. This
adds DT properties to specify bus translations we can't discover
automatically, and to indicate whether devices are coherent.
- Hibernation support for ARM
- Make ftrace work with read-only text in modules
- add suspend support for PJ4B CPUs
- rework interrupt masking for undefined instruction handling, which
allows us to enable interrupts earlier in the handling of these
exceptions.
- support for big endian page tables
- fix stacktrace support to exclude stacktrace functions from the
trace, and add save_stack_trace_regs() implementation so that kprobes
can record stack traces.
- Add support for the Cortex-A17 CPU.
- Remove last vestiges of ARM710 support.
- Removal of ARM "meminfo" structure, finally converting us solely to
memblock to handle the early memory initialisation.
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (142 commits)
ARM: ensure C page table setup code follows assembly code (part II)
ARM: consolidate last remaining open-coded alignment trap enable
ARM: remove global cr_no_alignment
ARM: remove CPU_CP15 conditional from alignment.c
ARM: remove unused adjust_cr() function
ARM: move "noalign" command line option to alignment.c
ARM: provide common method to clear bits in CPU control register
ARM: 8025/1: Get rid of meminfo
ARM: 8060/1: mm: allow sub-architectures to override PCI I/O memory type
ARM: 8066/1: correction for ARM patch 8031/2
ARM: 8049/1: ftrace/add save_stack_trace_regs() implementation
ARM: 8065/1: remove last use of CONFIG_CPU_ARM710
ARM: 8062/1: Modify ldrt fixup handler to re-execute the userspace instruction
ARM: 8047/1: rwsem: use asm-generic rwsem implementation
ARM: l2c: trial at enabling some Cortex-A9 optimisations
ARM: l2c: add warnings for stuff modifying aux_ctrl register values
ARM: l2c: print a warning with L2C-310 caches if the cache size is modified
ARM: l2c: remove old .set_debug method
ARM: l2c: kill L2X0_AUX_CTRL_MASK before anyone else makes use of this
ux500 can't change the auxiliary control register, so there's no point
passing values to try and modify it to the l2x0 init functions.
The cache size should already be present in the L2 cache auxiliary
control register: it is part of the integration process to configure
the hardware IP. Most platforms get this right, yet still many
cargo-cult program, and assume that they always need specifying to
the L2 cache code. Remove them so we can find out which really need
this.
ux500 can't write to any of the secure registers on the L2C controllers,
so provide a dummy handler which ignores all writes.
We have a mixture of different devices with different register layouts,
but we group all the bits together in an opaque mess. Split them out
into those which are L2C-310 specific and ones which refer to earlier
devices. Provide full auxiliary control register definitions.
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Since all platform data has been transfered to DT, we don't need the
container for the mmci platform data anymore. Remove the file and the
corresponding references to it's data.
Pull ARM SoC device tree changes from Arnd Bergmann:
"A large part of the arm-soc patches are nowadays DT changes, adding
support for new SoCs, boards and devices without changing kernel
source. The plan is still to move the devicetree files out of the
kernel tree and reduce the amount of churn going on here, but we keep
finding reasons to delay doing that.
Changes are really all over the place, with little sticking out
particularly. We have contributions from a total of 116 people in
this branch.
Unfortunately, the size of this branch also causes a significant
number of conflicts at the moment, typically when subsystem
maintainers merge patches that change the driver at the same time as
the dts files. In most cases this could be avoided because the dts
changes are supposed to be compatible in both ways, and we are asking
everyone to send ARM dts changes through our tree only"
* tag 'dt-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (541 commits)
dts: stmmac: Document the clocks property in the stmmac base document
dts: socfpga: Add DTS entry for adding the stmmac glue layer for stmmac.
ARM: STi: stih41x: Add support for the FSM Serial Flash Controller
ARM: STi: stih416: Add support for the FSM Serial Flash Controller
ARM: tegra: fix Dalmore pinctrl configuration
ARM: dts: keystone: use common "ti,keystone" compatible instead of -evm
ARM: dts: k2hk-evm: set ubifs partition size for 512M NAND
ARM: dts: Build all keystone dt blobs
ARM: dts: keystone: Fix control register range for clktsip
ARM: dts: keystone: Fix domain register range for clkfftc1
ARM: dts: bcm28155-ap: leave camldo1 on to fix reboot
ARM: dts: add bcm590xx pmu support and enable for bcm28155-ap
ARM: dts: bcm21664: Add device tree files.
ARM: DT: bcm21664: Device tree bindings
ARM: efm32: properly namespace i2c location property
ARM: efm32: fix unit address part in USART2 device nodes' names
ARM: mvebu: Enable NAND controller in Armada 385-DB
ARM: mvebu: Add support for NAND controller in Armada 38x SoC
ARM: mvebu: Add the Core Divider clock to Armada 38x SoCs
ARM: mvebu: Add a 2 GHz fixed-clock on Armada 38x SoCs
The DBx500 and ABx500 should be getting their IRQs from the
device tree and nowhere else. Get rid of all the static assignments
everywhere, delete it from the driver, platform data and the
board files in one swift strike.
Lots of cross-dependencies in the MFD drivers for PRCMU and
AB8500 makes it necessary to strike everywhere at once to
eradicate IRQs passed as resources and platform data to the left
and right around the platform.
Cc: Mark Brown <broonie@kernel.org>
Cc: Samuel Ortiz <sameo@linux.intel.com>
Acked-by: Lee Jones <lee.jones@linaro.org>
The Ux500 GPIOs are now assigned dynamically from the device tree.
Drop this table of static assignments.
The Ux500 is initializing its IRQs from the device tree and
does not need to figure out any static base addresses anymore,
this is just dead code so delete it.
Cc: Lee Jones <lee.jones@linaro.org>
Supporting device tree on the Ux500 is not optional anymore,
so delete the config option and compile this in at all times.
Many V6 and V7 platforms have an L2x0 cache, so make
CONFIG_MIGHT_HAVE_CACHE_L2X0 visible for V6 and V7 multi-platform
builds.
All V7 platforms can run SMP kernels, so make CONFIG_SMP visible for V7
multi-platform builds.
Multi-platform requires various kconfig options to be selected, so
platforms don't need to select them individually.
Tested-by: Stephen Warren <swarren@wwwdotorg.org>
This moves the set-up of the HREF500 with its AB8505 ASIC to
a device tree include. Since there is not yet any device tree
for this board the DTSI is currently unused. After this delete
the board file for pins for good and migration of pins to the
device tree is complete.
Cc: Patrice Chotard <patrice.chotard@st.com>
This moves the AB8500 pin settings for the clock out pins over
to the device tree. We can delete the special setup calls for the
platforms only using the AB8500 and not AB8505.
This moves the pin setup of the AB8500 modem I2C pins
(SCL/SDA) from the board file to the device tree.
This moves the configuration of the AB8500 EXTCPENA pin
This move the AB8500 DMIC (microphone) pin setup from the board
This moves the set-up of the USB UICC (InteChip USB) from the
This moves the pin muxing and configuration for audio interface
one over to the device tree as a hog configuration.
This moves the muxing and biasing of the AB8500 PWM output pins
over to the device tree for affected platforms.
This moves the pin control settings for the YCBCR connector
on the AB8500 over to the device tree as a hog.
Move the AB8500 muxing and biasing settings over from the board
file to the device tree, include it in the reference designs using
the AB8500: HREF prior to v60, v60plus and Snowball. Set up these
GPIO lines using hogs, just like in the board file.
Pull ARM SoC DT updates from Olof Johansson:
"DT and DT-conversion-related changes for various ARM platforms. Most
of these are to enable various devices on various boards, etc, and not
necessarily worth enumerating.
New boards and systems continue to come in as new devicetree files
that don't require corresponding C changes any more, which is
indicating that the system is starting to work fairly well.
A few things worth pointing out:
* ST Ericsson ux500 platforms have made the major push to move over
to fully support the platform with DT
* Renesas platforms continue their conversion over from legacy
platform devices to DT-based for hardware description"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (327 commits)
ARM: dts: SiRF: add pin group for USP0 with only RX or TX frame sync
ARM: dts: SiRF: add lost usp1_uart_nostreamctrl pin group for atlas6
ARM: dts: sirf: add lost minigpsrtc device node
ARM: dts: sirf: add clock, frequence-voltage table for CPU0
ARM: dts: sirf: add lost bus_width, clock and status for sdhci
ARM: dts: sirf: add lost clocks for cphifbg
ARM: dts: socfpga: add pl330 clock
ARM: dts: socfpga: update L2 tag and data latency
arm: sun7i: cubietruck: Enable the i2c controllers
ARM: dts: add support for EXYNOS4412 based TINY4412 board
ARM: dts: Add initial support for Arndale Octa board
ARM: bcm2835: add USB controller to device tree
ARM: dts: MSM8974: Add MMIO architected timer node
ARM: dts: MSM8974: Add restart node
ARM: dts: sun7i: external clock outputs
ARM: dts: sun7i: Change 32768 Hz oscillator node name to clk@N style
ARM: dts: sun7i: Add pin muxing options for clock outputs
ARM: dts: sun7i: Add rtp controller node
ARM: dts: sun5i: Add rtp controller node
ARM: dts: sun4i: Add rtp controller node
Pull ARM SoC platform changes from Olof Johansson:
"New core SoC-specific changes.
New platforms:
* Introduction of a vendor, Hisilicon, and one of their SoCs with
some random numerical product name.
* Introduction of EFM32, embedded platform from Silicon Labs (ARMv7m,
i.e. !MMU).
* Marvell Berlin series of SoCs, which include the one in Chromecast.
* MOXA platform support, ARM9-based platform used mostly in
industrial products
* Support for Freescale's i.MX50 SoC.
Other work:
* Renesas work for new platforms and drivers, and conversion over to
more multiplatform-friendly device registration schemes.
* SMP support for Allwinner sunxi platforms.
* ... plus a bunch of other stuff across various platforms"
* tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (201 commits)
ARM: tegra: fix tegra_powergate_sequence_power_up() inline
ARM: msm_defconfig: Update for multi-platform
ARM: msm: Move MSM's DT based hardware to multi-platform support
ARM: msm: Only build timer.c if required
ARM: msm: Only build clock.c on proc_comm based platforms
ARM: ux500: Enable system suspend with WFI support
ARM: ux500: turn on PRINTK_TIME in u8500_defconfig
ARM: shmobile: r8a7790: Fix I2C controller names
ARM: msm: Simplify ARCH_MSM_DT config
ARM: msm: Add support for MSM8974 SoC
ARM: sunxi: select ARM_PSCI
MAINTAINERS: Update Allwinner sunXi maintainer files
ARM: sunxi: Select RESET_CONTROLLER
ARM: imx: improve the comment of CCM lpm SW workaround
ARM: imx: improve status check of clock gate
ARM: imx: add necessary interface for pfd
ARM: imx_v6_v7_defconfig: Select CONFIG_REGULATOR_PFUZE100
ARM: imx_v6_v7_defconfig: Select MX35 and MX50 device tree support
ARM: imx: Add cpu frequency scaling support
ARM i.MX35: Add devicetree support.
Pull ARM SoC cleanups from Olof Johansson:
"This is the branch where we usually queue up cleanup efforts, moving
drivers out of the architecture directory, header file restructuring,
etc. Sometimes they tangle with new development so it's hard to keep
it strictly to cleanups.
Some of the things included in this branch are:
* Atmel SAMA5 conversion to common clock
* Reset framework conversion for tegra platforms
- Some of this depends on tegra clock driver reworks that are shared
with Mike Turquette's clk tree.
* Tegra DMA refactoring, which are shared branches with the DMA tree.
* Removal of some header files on exynos to prepare for
multiplatform"
* tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (169 commits)
ARM: mvebu: move Armada 370/XP specific definitions to armada-370-xp.h
ARM: mvebu: remove prototypes of non-existing functions from common.h
ARM: mvebu: move ARMADA_XP_MAX_CPUS to armada-370-xp.h
serial: sh-sci: Rework baud rate calculation
serial: sh-sci: Compute overrun_bit without using baud rate algo
serial: sh-sci: Remove unused GPIO request code
serial: sh-sci: Move overrun_bit and error_mask fields out of pdata
serial: sh-sci: Support resources passed through platform resources
serial: sh-sci: Don't check IRQ in verify port operation
serial: sh-sci: Set the UPF_FIXED_PORT flag
serial: sh-sci: Remove duplicate interrupt check in verify port op
serial: sh-sci: Simplify baud rate calculation algorithms
serial: sh-sci: Remove baud rate calculation algorithm 5
serial: sh-sci: Sort headers alphabetically
ARM: EXYNOS: Kill exynos_pm_late_initcall()
ARM: EXYNOS: Consolidate selection of PM_GENERIC_DOMAINS for Exynos4
ARM: at91: switch Calao QIL-A9260 board to DT
clk: at91: fix pmc_clk_ids data type attriubte
PM / devfreq: use inclusion <mach/map.h> instead of <plat/map-s5p.h>
ARM: EXYNOS: remove <mach/regs-clock.h> for exynos
"In this set, we have:
- Refactoring of some of the old StrongARM-1100 GPIO code to make
things simpler by Dmitry Eremin-Solenikov
- Read-only and non-executable support for modules on ARM from Laura
Abbot
- Removal of unnecessary set_drvdata() calls in AMBA code
- Some non-executable support for kernel lowmem mappings at the 1MB
section granularity, and dumping of kernel page tables via debugfs
- Some improvements for the timer/clock code on Footbridge platforms,
and cleanup some of the LED code there
- Fix fls/ffs() signatures to match x86 to prevent build warnings,
particularly where these are used with min/max() macros
- Avoid using the bootmem allocator on ARM (patches from Santosh
Shilimkar)
- Various asid/unaligned access updates from Will Deacon"
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (51 commits)
ARM: SMP implementations are not supposed to return from smp_ops.cpu_die()
ARM: ignore memory below PHYS_OFFSET
Fix select-induced Kconfig warning for ZBOOT_ROM
ARM: fix ffs/fls implementations to match x86
ARM: 7935/1: sa1100: collie: add gpio-keys configuration
ARM: 7932/1: bcm: Add DEBUG_LL console support
ARM: 7929/1: Remove duplicate SCHED_HRTICK config option
ARM: 7928/1: kconfig: select HAVE_EFFICIENT_UNALIGNED_ACCESS for CPUv6+ && MMU
ARM: 7927/1: dcache: select DCACHE_WORD_ACCESS for big-endian CPUs
ARM: 7926/1: mm: flesh out and fix the comments in the ASID allocator
ARM: 7925/1: mm: keep track of last ASID allocation to improve bitmap searching
ARM: 7924/1: mm: don't bother with reserved ttbr0 when running with LPAE
ARM: PCI: add legacy IDE IRQ implementation
ARM: footbridge: cleanup LEDs code
ARM: pgd allocation: retry on failure
ARM: footbridge: add one-shot mode for DC21285 timer
ARM: footbridge: add sched_clock implementation
ARM: 7922/1: l2x0: add Marvell Tauros3 support
ARM: 7877/1: use built-in byte swap function
ARM: 7921/1: mcpm: remove redundant dsb instructions prior to sev
for-next
'asoc/topic/bcm2835', 'asoc/topic/docs', 'asoc/topic/fsl', 'asoc/topic/generic', 'asoc/topic/kirkwood', 'asoc/topic/mc13783', 'asoc/topic/mxs', 'asoc/topic/nuc900', 'asoc/topic/sai', 'asoc/topic/sh', 'asoc/topic/ssm2602', 'asoc/topic/tlv320aic3x', 'asoc/topic/twl4030', 'asoc/topic/ux500', 'asoc/topic/width' and 'asoc/topic/x86' into for-tiwai
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson into next/soc
From Linus Walleij:
Ux500 core patches for the v3.14 series:
- Enable PRINTK_TIME
- Enable suspend with WFI
* tag 'ux500-core-v3.14' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson:
