set_irq_chipdata -> set_irq_chip_data
get_irq_chipdata -> get_irq_chip_data
do_level_IRQ -> handle_level_irq
do_edge_IRQ -> handle_edge_irq
do_simple_IRQ -> handle_simple_irq
irqdesc -> irq_desc
irqchip -> irq_chip
Untested, but this should fix up the bulk of the totally mechanical
issues, and should make the actual detail fixing easier.
The ARM Versatile board PCI config space read routines are broken for byte
accesses. The access uses a byte read, so masking the bottom two bits of the
address is wrong.
I guess this is a cut/paste error from the the halfword code which uses
aligned word access+shift+mask.
Signed-off-by: Paul Brook <paul@codesourcery.com>
Patch from Yoav Steinberg
Flash resource mapping for versatile machine included one extra byte for the end address. This results in failure to map other resources on physical address directly after the NOR flash.
Signed-off-by: Yoav Steinberg <yoav@monfort.co.il>
Patch from David Brownell
ARM genirq cleanups/updates:
- Start switching platforms to newer APIs
* use "irq_chip" name, not "irqchip"
* providing irq_chip.name
- Show irq_chip.name in /proc/interrupts, like on x86.
This update a bit more than half of the ARM code. The irq_chip.name
values were chosen to match docs (if I have them) or be otherwise
obvious ("FPGA", "CPLD", or matching the code).
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
If a configuration was chosen to support both the Versatile
AB and PB boards, the result would write to registers not
available on the PB version of the board. Resolve this by
using machine_is_xxx().
Also, for the CLCD, despite how the code looks, both the AB
and PB access the same location to control the clock rate -
it's just called something different between the two board
versions. Invent our own name for this location and use it
unconditionally.
The irgflags consolidation did conflict with the ARM to generic IRQ
conversion and was not applied for ARM. Fix it up.
Use the new IRQF_ constants and remove the SA_INTERRUPT define
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Both Integrator and Versatile were using set_irq_handler() and
enable_irq(), and working around the initialisation of the
chained interrupt, instead of the more correct
set_irq_chained_handler() function. Fix Integrator and
Versatile to use the right function, and remove these work-arounds.
Some SoCs have multiple VIC devices. Adapt the generic vic code
to allow multiple implementations to be handled.
Patch from Catalin Marinas
The initial code did not configure the inbound memory windows for direct
master access to the SDRAM. This patch creates a 1:1 mapping between the
Versatile/PB PCI memory windows and its SDRAM. Note that an updated FPGA
image is needed for Versatile/PB since the original windows were 1MB and
not able to cover the whole SDRAM (now extended to 256MB). The patch also
fixes the PCI IRQ mapping for slot #2.
Other machines may wish to make use of the VIC support code, so
move it to arch/arm/common.
The default is already 'n' so there's no need to explicitly state it.
Patch from Nicolas Pitre
This field is redundent since it must be equal to PHYS_OFFSET anyway.
Now that no code uses it anymore, mark it deprecated and remove all
initializations from the tree.
Signed-off-by: Nicolas Pitre <nico@cam.org>
The arm clock semaphores are strict mutexes, convert them to the new
mutex implementation
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
This is needs to be visible to other architectures using the AMBA
bus and peripherals.
Since the ARM AMBA bus is used on MIPS as well as ARM, we need
to make the bus available for other architectures to use. Move
the AMBA include files from include/asm-arm/hardware/ to
include/linux/amba/
It seems that clk_use() and clk_unuse() are additional complexity
which isn't required anymore. Remove them from the clock framework
to avoid the additional confusion which they cause, and update all
ARM machine types except for OMAP.
Manual #include fixups for clashes - there may be some unnecessary
I recently picked up my older work to remove unnecessary #includes of
sched.h, starting from a patch by Dave Jones to not include sched.h
from module.h. This reduces the number of indirect includes of sched.h
by ~300. Another ~400 pointless direct includes can be removed after
this disentangling (patch to follow later).
However, quite a few indirect includes need to be fixed up for this.
In order to feed the patches through -mm with as little disturbance as
possible, I've split out the fixes I accumulated up to now (complete for
i386 and x86_64, more archs to follow later) and post them before the real
patch. This way this large part of the patch is kept simple with only
adding #includes, and all hunks are independent of each other. So if any
hunk rejects or gets in the way of other patches, just drop it. My scripts
will pick it up again in the next round.
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
Convert everyone who uses platform_bus_type to include
linux/platform_device.h.
Patch from Deepak Saxena
Versatile map_desc.pfn conversion
Signed-off-by: Deepak Saxena <dsaxena@plexity.net>
It's pointless to include mach-types.h if you're not going to use
anything from it. These references were removed as a result of:
grep -lr 'asm/mach-types\.h' . | xargs grep -L 'machine_is_\|MACH_TYPE_\|MACHINE_START\|machine_type'
This is part of Thomas Gleixner's generic IRQ patch, which converts
ARM to use the generic IRQ subsystem. Here, we wrap calls to
desc->handler() in an inline function, desc_handle_irq(). This
reduces the size of Thomas' patch since the changes become more
localised.
Remove the pointless machine description macros, favouring C99
initialisers instead.
Convert ARMs timer implementations to use readl/writel instead of accessing
the registers via a struct.
People have recently asked if accessing timers via a structure is the
"right way" and its not the Linux way. So fix this code to conform to
"The Linux Way"(tm).
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
VST needs to know which timer handler is for the timer interrupt.
Mark all timer interrupts with the SA_TIMER flag.
This patch adds PCI support for the Versatile PB926 platform.
Signed-off-by: Colin King
The current red and blue colours on the Versatile CLCD are
reversed when the 5:6:5 mode is used. The patch sets the proper
bit in the SYS_CLCD register value.
infrastructure for it.
Let it rip!
