path: root/arch/arm/mach-versatile
2010-05-02ARM: ICST: move minimum VCO frequency to icst_paramsRussell King
2010-05-02ARM: ICST: use Hz instead of kHzRussell King
This makes the ICST support fit more nicely with the clk API, eliminating the need to *1000 and /1000 in places. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-02ARM: ICST: provide definitions for max/min VCO frequenciesRussell King
2010-05-02ARM: ICST: merge common ICST VCO structuresRussell King
The structures for the ICST307 and ICST525 VCO devices are identical, so merge them together. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-04-29ARM: Fix Versatile&Integrator includes to behave in the same way as RealviewRussell King
Realview doesn't include mach/platform.h in mach/hardware.h, so make versatile behave in the same way. Also, move the definition of __io_address() into mach/hardware.h, just like Realview. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-25Merge branches 'clks' and 'pnx' into develRussell King
2010-02-12ARM: Consolidate clks_register() and similarRussell King
Most machine classes want some way to register a block of clk_lookup structures, and most do it by implementing a clks_register() type function which walks an array, or by open-coding a loop. Consolidate all this into clkdev_add_table(). Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-12ARM: 5910/1: ARM: Add tmp register for addruart and loadspTony Lindgren
Otherwise more complicated uart configuration won't be possible. We can use r1 for tmp register for both head.S and debug.S. NOTE: This patch depends on another patch to add the the tmp register into all debug-macro.S files. That can be done with: $ sed -i -e "s/addruart,rx|addruart, rx/addruart, rx, tmp/" arch/arm/*/include/*/debug-macro.S Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-09-22ARM: 5720/1: Move MMCI header to amba include dirLinus Walleij
This moves the mmci platform data definition struct away from arch/arm/include/asm/mach/mmc.h into the more proper place among the other primecells in include/linux/amba/mmci.h and at the same time renames it to "mmci.h", and also the struct in this file confusingly named mmc_platform_data has been renamed mmci_platform_data for clarity. Cc: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-09-12Merge branch 'devel-stable' into develRussell King
Conflicts: MAINTAINERS arch/arm/mm/fault.c
2009-07-18ARM: Realview & Versatile: Fix i2c_board_info definitionsRussell King
Fix i2c_board_info definitions - we were defining the 'type' field of these structures twice since the first argument of I2C_BOARD_INFO sets this field. Move the second definition into I2C_BOARD_INFO(). Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Jean Delvare <khali@linux-fr.org> Acked-by: Ben Dooks <ben-linux@fluff.org>
2009-07-09MMC: MMCI: allow GPIOs to be passedRussell King
Add and initialize the gpio_wp and gpio_cd members. We need to ensure that all users are covered, because GPIO 0 may be valid. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Linus Walleij <linus.walleij@stericsson.com>
2009-07-06[ARM] versatile: add PL061 gpiolib supportRussell King
2009-06-10Merge branch for-rmk-devel of git://aeryn.fluff.org.uk/bjdooks/linux into develRussell King
2009-05-18[ARM] 5518/1: versatile: don't put clock lookups in __initdataRabin Vincent
Remove the __initdata annotation for the clock lookups, since they will be needed when loading modules which use clk_get(). Signed-off-by: Rabin Vincent <rabin@rab.in> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-05-07[ARM] VIC: Add power management deviceBen Dooks
Add power management support to the VIC by registering each VIC as a system device to get suspend/resume events going. Since the VIC registeration is done early, we need to record the VICs in a static array which is used to add the system devices later once the initcalls are run. This means there is now a configuration value for the number of VICs in the system. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-04-21clocksource: pass clocksource to read() callbackMagnus Damm
Pass clocksource pointer to the read() callback for clocksources. This allows us to share the callback between multiple instances. [hugh@veritas.com: fix powerpc build of clocksource pass clocksource mods] [akpm@linux-foundation.org: cleanup] Signed-off-by: Magnus Damm <damm@igel.co.jp> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-19[ARM] pass reboot command line to arch_reset()Russell King
OMAP wishes to pass state to the boot loader upon reboot in order to instruct it whether to wait for USB-based reflashing or not. There is already a facility to do this via the reboot() syscall, except we ignore the string passed to machine_restart(). This patch fixes things to pass this string to arch_reset(). This means that we keep the reboot mode limited to telling the kernel _how_ to perform the reboot which should be independent of what we request the boot loader to do. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-19[ARM] 5395/1: RealView: Add support for the DS1338 RTC chipCatalin Marinas
This chip is on the I2C bus on the RealView and Versatile boards. The patch adds the i2c_board_info definition for this device and registers it with the I2C subsystem. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-01-06arm: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-02Merge branch 'cpus4096-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'cpus4096-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (66 commits) x86: export vector_used_by_percpu_irq x86: use logical apicid in x2apic_cluster's x2apic_cpu_mask_to_apicid_and() sched: nominate preferred wakeup cpu, fix x86: fix lguest used_vectors breakage, -v2 x86: fix warning in arch/x86/kernel/io_apic.c sched: fix warning in kernel/sched.c sched: move test_sd_parent() to an SMP section of sched.h sched: add SD_BALANCE_NEWIDLE at MC and CPU level for sched_mc>0 sched: activate active load balancing in new idle cpus sched: bias task wakeups to preferred semi-idle packages sched: nominate preferred wakeup cpu sched: favour lower logical cpu number for sched_mc balance sched: framework for sched_mc/smt_power_savings=N sched: convert BALANCE_FOR_xx_POWER to inline functions x86: use possible_cpus=NUM to extend the possible cpus allowed x86: fix cpu_mask_to_apicid_and to include cpu_online_mask x86: update io_apic.c to the new cpumask code x86: Introduce topology_core_cpumask()/topology_thread_cpumask() x86: xen: use smp_call_function_many() x86: use work_on_cpu in x86/kernel/cpu/mcheck/mce_amd_64.c ... Fixed up trivial conflict in kernel/time/tick-sched.c manually
2008-12-13cpumask: convert struct clock_event_device to cpumask pointers.Rusty Russell
Impact: change calling convention of existing clock_event APIs struct clock_event_timer's cpumask field gets changed to take pointer, as does the ->broadcast function. Another single-patch change. For safety, we BUG_ON() in clockevents_register_device() if it's not set. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@elte.hu>
2008-11-30[ARM] Add a common typesafe __io implementationRussell King
As Al did for Versatile in 2ad4f86b60b649fd7428265c08d73a3bd360c81b, add a typesafe __io implementation for platforms to use. Convert platforms to use this new simple typesafe implementation. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-29[ARM] Hide ISA DMA API when ISA_DMA_API is unsetRussell King
When ISA_DMA_API is unset, we're not implementing the ISA DMA API, so there's no point in publishing the prototypes via asm/dma.h, nor including the machine dependent parts of that API. This allows us to remove a lot of mach/dma.h files which don't contain any useful code. Unfortunately though, some platforms put their own private non-ISA definitions into mach/dma.h, so we leave these behind and fix the appropriate #include statments. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-28[ARM] versatile: remove IRQ mask definitionsRussell King
These definitions are unused and serve no purpose with genirq. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-28Merge branch 'highmem' into develRussell King
Conflicts: arch/arm/mach-clps7500/include/mach/memory.h
2008-11-28[ARM] remove a common set of __virt_to_bus definitionsNicolas Pitre
Let's provide an overridable default instead of having every machine class define __virt_to_bus and __bus_to_virt to the same thing. What most platforms are using is bus_addr == phys_addr so such is the default. One exception is ebsa110 which has no DMA what so ever, so the actual definition is not important except only for proper compilation. Also added a comment about the special footbridge bus translation. Let's also remove comments alluding to set_dma_addr which is not (and should not) be commonly used. Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-27Merge branches 'core' and 'clks' into develRussell King
2008-11-27[ARM] versatile: convert to clkdev and lookup clocks by device nameRussell King
People often point to the Integrator/Versatile/Realview implementations to justify using the consumer name as the sole selector for clocks. Eliminate this excuse by changing the Versatile implementation, so it provides a better example of how it should be done. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-27[ARM] Arrange for platforms to select appropriate CPU supportRussell King
Rather than: config CPU_BLAH bool depends on ARCH_FOO || MACH_BAR default y if ARCH_FOO || MACH_BAR arrange for ARCH_FOO and MACH_BAR to select CPU_BLAH directly. Acked-by: Nicolas Pitre <nico@marvell.com> Acked-by: Andrew Victor <linux@maxim.org.za> Acked-by: Brian Swetland <swetland@google.com> Acked-by: Eric Miao <eric.miao@marvell.com> Acked-by: Nicolas Bellido <ml@acolin.be> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-13[ARM] integrator,realview,versatile: remove FLASH_* and EPROM_* constantsRussell King
FLASH_* and EPROM_* constants are unused, and clash with drivers: drivers/atm/ambassador.h:257:1: warning: "FLASH_BASE" redefined drivers/atm/ambassador.h:258:1: warning: "FLASH_SIZE" redefined drivers/atm/iphase.h:332:1: warning: "EPROM_SIZE" redefined so remove them. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-08[ARM] versatile: correct MMC clock rateRussell King
The MMC clock source is actually 24MHz, not 33MHz. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-11Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (236 commits) [ARM] 5300/1: fixup spitz reset during boot [ARM] 5295/1: make ZONE_DMA optional [ARM] 5239/1: Palm Zire 72 power management support [ARM] 5298/1: Drop desc_handle_irq() [ARM] 5297/1: [KS8695] Fix two compile-time warnings [ARM] 5296/1: [KS8695] Replace macro's with trailing underscores. [ARM] pxa: allow multi-machine PCMCIA builds [ARM] pxa: add preliminary CPUFREQ support for PXA3xx [ARM] pxa: add missing ACCR bit definitions to pxa3xx-regs.h [ARM] pxa: rename cpu-pxa.c to cpufreq-pxa2xx.c [ARM] pxa/zylonite: add support for USB OHCI [ARM] ohci-pxa27x: use ioremap() and offset for register access [ARM] ohci-pxa27x: introduce pxa27x_clear_otgph() [ARM] ohci-pxa27x: use platform_get_{irq,resource} for the resource [ARM] ohci-pxa27x: move OHCI controller specific registers into the driver [ARM] ohci-pxa27x: introduce flags to avoid direct access to OHCI registers [ARM] pxa: move I2S register and bit definitions into pxa2xx-i2s.c [ARM] pxa: simplify DMA register definitions [ARM] pxa: make additional DCSR bits valid for PXA3xx [ARM] pxa: move i2c register and bit definitions into i2c-pxa.c ... Fixed up conflicts in arch/arm/mach-versatile/core.c sound/soc/pxa/pxa2xx-ac97.c sound/soc/pxa/pxa2xx-i2s.c manually.
2008-10-09Merge branch 'pxa-all' into develRussell King
Conflicts: arch/arm/mach-pxa/Kconfig arch/arm/mach-pxa/corgi.c arch/arm/mach-pxa/include/mach/hardware.h arch/arm/mach-pxa/spitz.c
2008-10-09[ARM] 5298/1: Drop desc_handle_irq()Dmitry Baryshkov
desc_handle_irq() was declared as obsolete since long ago. Replace it with generic_handle_irq() Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-24MN10300: Move asm-arm/cnt32_to_63.h to include/linux/David Howells
Move asm-arm/cnt32_to_63.h to include/linux/ so that MN10300 can make use of it too. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-18arch: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. It's possible that they rely on it dragging in some unrelated header file, but I can't build all these files, so we'll have fix any build failures as they come up. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2007-07-02[ARM] 4454/1: Use word accesses in Versatile PCI config readsAndrzej Zaborowski
ARM Versatile PCI config reads of one byte width have the lowest two bits of the address cleared and result in reading from a wrong place in the config space. This change is to use word size accesses like it is done for halfword reads. Byte reads are used for retrieving the IRQ number of a PCI device and the problem was not exposed until 2.6.20 because the value read was discarded in drivers/pci/setup-irq.c (recently fixed). Signed-off-by: Andrzej Zaborowski <andrew@openedhand.com> Acked-by: Paul Brook <paul@codesourcery.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-08Add IRQF_IRQPOLL flag on armBernhard Walle
Add IRQF_IRQPOLL for each timer interrupt. Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-21[ARM] 4261/1: clockevent support for Versatile platformKevin Hilman
Update Versatile platform to use new clockevent infrastructure. Signed-off-by: Kevin Hilman <khilman@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-04-21[ARM] 4260/1: clocksource support for Versatile platformKevin Hilman
Update Versatile to use new clocksource infrastructure for basic timekeeping. Signed-off-by: Kevin Hilman <khilman@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-04-21[ARM] Remove needless linux/ptrace.h includesRussell King
Lots of places in arch/arm were needlessly including linux/ptrace.h, resumably because we used to pass a struct pt_regs to interrupt handlers. Now that we don't, all these ptrace.h includes are redundant. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-10i2c: New ARM Versatile/Realview bus driverRussell King
Add support for the I2C bus found on the ARM Versatile and Realview platforms. The I2C bus has a RTC and optionally some EEPROMs attached. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-12-07[ARM] Merge individual ARM sub-treesRussell King
Merge: Atmel AT91RM9200 and AT91SAM9260 changes General ARM developments Disconfiguous memory cleanups 64-bit/32-bit division and sched_clock extension patches EP93xx support changes IOP support changes Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-07[ARM] 3980/1: extend the ARM Versatile sched_clock implementation from 32 to ↵Nicolas Pitre
63 bit period This provides a 63 bit clock counter guaranteed to be monotonic over a period of 35583 days instead of a clock wrap every 179 seconds, as long as sched_clock() is called at least once every 89 seconds. This should not be a problem in practice, although a kernel timer could be scheduled every 80 seconds for example simply to call sched_clock() making sure top bits are always synchronized if need be. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-30[ARM] Fix Versatile PB initialisation to use .init_machineRussell King
There's no point having the Versatile PB initialisation using an arch_initcall() and then checking whether it's running on a Versatile PB board - this is what the .init_machine function pointer in the machine description is for. Use it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
