path: root/arch/arm/mach-versatile
2019-06-17Merge tag 'versatile-v5.3-armsoc' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-integrator into arm/soc Versatile platform updates for the v5.3 kernel cycle: - Drop a slew of unused CLCD platform data - Fix OF reference counts * tag 'versatile-v5.3-armsoc' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-integrator: ARM: versatile: Drop CLCD platform data ARM: versatile: fix a leaked reference by addingmissing of_node_put Signed-off-by: Olof Johansson <olof@lixom.net>
2019-05-30treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 156Thomas Gleixner
Based on 1 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms of the gnu general public license as published by the free software foundation either version 2 of the license or at your option any later version this program is distributed in the hope that it will be useful but without any warranty without even the implied warranty of merchantability or fitness for a particular purpose see the gnu general public license for more details you should have received a copy of the gnu general public license along with this program if not write to the free software foundation inc 59 temple place suite 330 boston ma 02111 1307 usa extracted by the scancode license scanner the SPDX license identifier GPL-2.0-or-later has been chosen to replace the boilerplate/reference in 1334 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Allison Randal <allison@lohutok.net> Reviewed-by: Richard Fontana <rfontana@redhat.com> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190527070033.113240726@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-28ARM: versatile: Drop CLCD platform dataLinus Walleij
The Versatile family no longer makes any use of the CLCD platform data, we have moved over all users to the DRM driver that has built-in handling of the displays. Delete the old auxdata. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2019-05-21treewide: Add SPDX license identifier - Makefile/KconfigThomas Gleixner
Add SPDX license identifiers to all Make/Kconfig files which: - Have no license information of any form These files fall under the project license, GPL v2 only. The resulting SPDX license identifier is: GPL-2.0-only Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-20ARM: versatile: fix a leaked reference by addingmissing of_node_putWen Yang
The call to of_get_next_child returns a node pointer with refcount incremented thus it must be explicitly decremented after the last usage. Detected by coccinelle with the following warnings: ./arch/arm/mach-versatile/versatile_dt.c:315:2-8: ERROR: missing of_node_put; acquired a node pointer with refcount incremented on line 302, but without a corresponding object release within this function. ./arch/arm/mach-versatile/versatile_dt.c:320:2-8: ERROR: missing of_node_put; acquired a node pointer with refcount incremented on line 302, but without a corresponding object release within this function. Signed-off-by: Wen Yang <wen.yang99@zte.com.cn> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Russell King <linux@armlinux.org.uk> Cc: linux-arm-kernel@lists.infradead.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2018-10-08mmc: mmci: Drop support for pdata GPIO numbersLinus Walleij
All the machines using the MMCI are passing GPIOs for the card detect and write protect using the device tree or descriptor table (one single case, Integrator/AP IM-PD1). Drop support for passing global GPIO numbers through platform data, noone is using it. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-21ARM: stop *MIGHT_HAVE_PCI* config from being selected redundantlyKishon Vijay Abraham I
*MIGHT_HAVE_PCI* config is already selected in ARCH_MULTIPLATFORM. Don't select it redundantly in all ARCH_MULTIPLATFORM based machines. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2016-06-23arm: use of_platform_default_populate() to populateKefeng Wang
Use helper of_platform_default_populate() in linux/of_platform when possible, instead of calling of_platform_populate() with the default match table. Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Krzysztof Halasa <khalasa@piap.pl> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Shawn Guo <shawnguo@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Roland Stigge <stigge@antcom.de> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Ray Jui <rjui@broadcom.com> Cc: Viresh Kumar <vireshk@kernel.org> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Rob Herring <robh@kernel.org> Cc: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com> Signed-off-by: Rob Herring <robh@kernel.org>
2016-04-04ARM: versatile: move flash registration to the device treeLinus Walleij
This moves the boardfile definition of the flash memory in the Versatile board into the device tree. The flash was already defined with the property "arm,versatile-flash" which was not handled by the kernel: instead define it as compatible also with "cfi-flash" so it detects properly, and delete the corresponding boardfile code so we get a smooth transition. The old compatible string "arm,versatile-flash" is reused to indicate to the MTD physmap subsystem that this flash requires special VPP handling. (See separate patch.) Cc: Grant Likely <grant.likely@linaro.org> Cc: Rob Herring <robh@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-02-15ARM: versatile: move restart to the device treeLinus Walleij
We have a power/reset driver for the Versatile family in drivers/power/reset so let's just activate that driver and use it and get rid of some non-DT remnants. Cc: Rob Herring <robh@kernel.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-12-15ARM: versatile: convert to multi-platformRob Herring
Now that all the prerequisites are in place, we can enable Versatile boards for multi-platform kernels. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-12-15ARM: versatile: merge mach code into a single fileRob Herring
With DT-only support now in place and most of the legacy code removed, the separation of core.c and versatile_dt.c makes little sense. The headers in mach include directory also have to move for multi-platform support, but with a single .c file the remaining definitions needed can also be moved into the versatile_dt.c. In the move, the system registers and IB2 registers are converted to run-time mappings and all register accesses converted to use readl/writel. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-12-15ARM: versatile: switch to DT only booting and remove legacy codeRob Herring
With DT support for clocks, irqchips, timers, and PCI now in place, DT based booting has feature parity with non-DT legacy boot. The final piece is actually enabling common clock support on Versatile. Enabling full DT support requires either removing the old Versatile clock code, updating the legacy boot to use the common clock code, or making DT and legacy boot mutually exclusive. Given that removing legacy boot code is the goal anyway, I am going with the 1st option. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Mike Turquette <mturquette@linaro.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-12-15ARM: versatile: add DT based PCI detectionRob Herring
Disable the Versatile PCI DT node when no PCI backplane is detected. This will prevent the Versatile PCI driver from probing when PCI is not populated. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-06-02ARM: 8366/1: move Dual-Timer SP804 driver to drivers/clocksourceSudeep Holla
The ARM Dual-Timer SP804 module is peripheral found not only on ARM32 platforms but also on ARM64 platforms. This patch moves the driver out of arch/arm to driver/clocksource so that it can be used on ARM64 platforms also. Cc: Daniel Lezcano <daniel.lezcano@linaro.org> Cc: Rob Herring <robh@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Olof Johansson <olof@lixom.net> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-06-02ARM: 8365/1: introduce sp804_timer_disable and remove arm_timer.h inclusionSudeep Holla
The header asm/hardware/arm_timer.h is included in various machine specific files to access TIMER_CTRL and initialise to a known state. This patch introduces a new function sp804_timer_disable to disable the SP804 timers and uses the same for initialising the timers to known(off) state, thereby removing the dependency on the header asm/hardware/arm_timer.h This change is in prepartion to move sp804 timer support out of arch/arm so that it can be used on ARM64 platforms. Cc: Daniel Lezcano <daniel.lezcano@linaro.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Olof Johansson <olof@lixom.net> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-02-19ARM: make arrays containing machine compatible strings constUwe Kleine-König
The definition static const char *axxia_dt_match[] __initconst = { ... defines a changable array of constant strings. That is you must not do: *axxia_dt_match[0] = 'k'; but axxia_dt_match[0] = "different string"; is fine. So the annotation __initconst is wrong and yields a compiler error when other really const variables are added with __initconst. As the struct machine_desc member dt_compat is declared as const char *const *dt_compat; making the arrays const is the better alternative over changing all annotations to __initdata. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-01-14ARM: versatile: core: Remove unused functionRickard Strandqvist
Remove the function versatile_leds_event() that is not used anywhere. This was partially found by using a static code analysis program called cppcheck. Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-08-08Merge tag 'soc-for-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Olof Johansson: "This is the bulk of new SoC enablement and other platform changes for 3.17: - Samsung S5PV210 has been converted to DT and multiplatform - Clock drivers and bindings for some of the lower-end i.MX 1/2 platforms - Kirkwood, one of the popular Marvell platforms, is folded into the mvebu platform code, removing mach-kirkwood - Hwmod data for TI AM43xx and DRA7 platforms - More additions of Renesas shmobile platform support - Removal of plat-samsung contents that can be removed with S5PV210 being multiplatform/DT-enabled and the other two old platforms being removed New platforms (most with only basic support right now): - Hisilicon X5HD2 settop box chipset is introduced - Mediatek MT6589 (mobile chipset) is introduced - Broadcom BCM7xxx settop box chipset is introduced + as usual a lot other pieces all over the platform code" * tag 'soc-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (240 commits) ARM: hisi: remove smp from machine descriptor power: reset: move hisilicon reboot code ARM: dts: Add hix5hd2-dkb dts file. ARM: debug: Rename Hi3716 to HIX5HD2 ARM: hisi: enable hix5hd2 SoC ARM: hisi: add ARCH_HISI MAINTAINERS: add entry for Broadcom ARM STB architecture ARM: brcmstb: select GISB arbiter and interrupt drivers ARM: brcmstb: add infrastructure for ARM-based Broadcom STB SoCs ARM: configs: enable SMP in bcm_defconfig ARM: add SMP support for Broadcom mobile SoCs Documentation: arm: misc updates to Marvell EBU SoC status Documentation: arm: add URLs to public datasheets for the Marvell Armada XP SoC ARM: mvebu: fix build without platforms selected ARM: mvebu: add cpuidle support for Armada 38x ARM: mvebu: add cpuidle support for Armada 370 cpuidle: mvebu: add Armada 38x support cpuidle: mvebu: add Armada 370 support cpuidle: mvebu: rename the driver from armada-370-xp to mvebu-v7 ARM: mvebu: export the SCU address ...
2014-06-27video: move Versatile CLCD helpersLinus Walleij
This moves the Versatile-specific helper code and panel database down into the drivers/video folder next to the CLCD driver itself, preserving the config symbol but also moving the header to platform data. This is necessary to rid the Integrator of this final <plat/*> inclusion dependency and get us one less user of the plat-versatile folder. Cc: Arnd Bergmann <arnd@arndb.de> Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com> Cc: linux-fbdev@vger.kernel.org Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-06-24ARM: versatile: remove init_irq hook for DT bootRob Herring
Now that versatile's irqchips are initialized from DT, the init_irq hook can be removed. Signed-off-by: Rob Herring <robh@kernel.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-05Merge tag 'kconfig-cleanups' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux into next/cleanup Merge Kconfig cleanups from Rob Herring: Several mach kconfig clean-ups of redundant selects * tag 'kconfig-cleanups' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: ARM: qcom: clean-up unneeded kconfig selects ARM: bcm: clean-up unneeded kconfig selects ARM: mvebu: clean-up unneeded kconfig selects + Linux 3.15-rc2 Signed-off-by: Olof Johansson <olof@lixom.net>
2014-04-05Merge tag 'drivers-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver changes from Arnd Bergmann: "These changes are mostly for ARM specific device drivers that either don't have an upstream maintainer, or that had the maintainer ask us to pick up the changes to avoid conflicts. A large chunk of this are clock drivers (bcm281xx, exynos, versatile, shmobile), aside from that, reset controllers for STi as well as a large rework of the Marvell Orion/EBU watchdog driver are notable" * tag 'drivers-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (99 commits) Revert "dts: socfpga: Add DTS entry for adding the stmmac glue layer for stmmac." Revert "net: stmmac: Add SOCFPGA glue driver" ARM: shmobile: r8a7791: Fix SCIFA3-5 clocks ARM: STi: Add reset controller support to mach-sti Kconfig drivers: reset: stih416: add softreset controller drivers: reset: stih415: add softreset controller drivers: reset: Reset controller driver for STiH416 drivers: reset: Reset controller driver for STiH415 drivers: reset: STi SoC system configuration reset controller support dts: socfpga: Add sysmgr node so the gmac can use to reference dts: socfpga: Add support for SD/MMC on the SOCFPGA platform reset: Add optional resets and stubs ARM: shmobile: r7s72100: fix bus clock calculation Power: Reset: Generalize qnap-poweroff to work on Synology devices. dts: socfpga: Update clock entry to support multiple parents ARM: socfpga: Update socfpga_defconfig dts: socfpga: Add DTS entry for adding the stmmac glue layer for stmmac. net: stmmac: Add SOCFPGA glue driver watchdog: orion_wdt: Use %pa to print 'phys_addr_t' drivers: cci: Export CCI PMU revision ...
2014-02-27ARM: plat-versatile: convert LEDs to platform deviceLinus Walleij
The LEDs were initialized unconditionally with an fs_initcall() which doesn't play well with multiplatform. Convert the driver to a platform device and convert all boards with these LEDs to register a platform device and pass the register as a resource instead. Tested successfully on the Versatile/AB and RealView PB1176. Cc: Bryan Wu <cooloney@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Russell King <linux@arm.linux.org.uk> Cc: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-02-18Merge tag 'dropmachtimexh-v2' of git://git.pengutronix.de/git/ukl/linux into ↵Olof Johansson
next/cleanup This cleanup series gets rid of <mach/timex.h> for platforms not using ARCH_MULTIPLATFORM. (For multi-platform code it's already unused since 387798b (ARM: initial multiplatform support).) To make this work some code out of arch/arm needed to be adapted. The respective changes got acks by their maintainers to be taken via armsoc (with Andrew Morton substituting for Alessandro Zummo as rtc maintainer). Compared to the previous pull request there was another patch added that fixes a (non-critical) regression on ixp4xx. Olof Johansson asked to not squash this fix into the original commit to save him from the need to reverify the series. * tag 'dropmachtimexh-v2' of git://git.pengutronix.de/git/ukl/linux: ARM: ixp4xx: fix timer latch calculation ARM: drop <mach/timex.h> for !ARCH_MULTIPLATFORM, too ARM: rpc: stop using <mach/timex.h> ARM: ixp4xx: stop using <mach/timex.h> input: ixp4xx-beeper: don't use symbols from <mach/timex.h> ARM: at91: don't use <mach/timex.h> ARM: ep93xx: stop using mach/timex.h ARM: mmp: stop using mach/timex.h ARM: netx: stop using mach/timex.h ARM: sa1100: stop using mach/timex.h clocksource: sirf/marco+prima2: drop usage of CLOCK_TICK_RATE rtc: pxa: drop unused #define TIMER_FREQ rtc: at91sam9: include <mach/hardware.h> explicitly ARM/serial: at91: switch atmel serial to use gpiolib Signed-off-by: Olof Johansson <olof@lixom.net>
2014-02-13irqchip: support cascaded VICsLinus Walleij
This adds support for a VIC to be cascaded off another IRQ. On the Integrator/AP logical module IM-PD1 there is a VIC cascaded off the central FPGA IRQ controller so this is needed for that to work out. In order for the plug-in board to be able to register all the devices with their IRQs relative to the offset of the base obtained for the cascaded VIC, the base IRQ number is passed back to the caller. Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-20ARM: versatile: move GPIO2 and GPIO3 to coreLinus Walleij
Move GPIO2 and GPIO3 to be registered from the core as this is certainly available on Versatile AB as well, not just the PB. GPIO2 is used for reading board status and GPIO3 is unused, but it does not hurt to register it anyway. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-20ARM: drop <mach/timex.h> for !ARCH_MULTIPLATFORM, tooUwe Kleine-König
While <mach/timex.h> isn't used for multi-platform builds since long it still is for "normal" builds. As the previous patches fix all sites to not make use of this per-platform file, it can go now for good also for platforms that are not (yet) converted to multi-platform. While at it there are no users of CLOCK_TICK_RATE any more, so also drop the dummy #define. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2013-09-09Merge branch 'versatile/fixes' into fixesOlof Johansson
From Peter Maydell: These patches fix a number of issues with the PCI controller code for mach-versatile: (1) The irq mapping matched neither hardware nor QEMU; we correct it to match the hardware, which means it will also work on recent (1.5 or later) QEMU. (2) The code was confused between the PCI I/O window (at 0x43000000) and the first PCI memory window (at 0x44000000), which meant that PCI devices using PCI PIO rather than MMIO didn't work. This is fixed (and some variables/labels are renamed to avoid further confusion in future). (3) The SMAP register offsets were all off-by-four, though by fluke this didn't actually have any ill effects. All these changes have been tested on real hardware (PB926 plus the PCI backplane), as well as on QEMU. I have confirmed that IRQs and PCI PIO and MMIO work OK. PCI bus-master DMA doesn't seem to work on h/w -- as far as I can tell the device is correctly managing to DMA to the right places in memory, but every other 32 bit word is corrupt (at least judging from rtl8139 debug dumps of the frames it's receiving). I'm not sure what's going on here, but since this is disjoint from the irq and I/O issues I don't think that applying the patches that fix those should be stalled on trying to debug DMA problems. (DMA works fine on QEMU, incidentally.) * versatile/fixes: ARM: PCI: versatile: Fix SMAP register offsets ARM: PCI: versatile: Fix PCI I/O ARM: PCI: versatile: Fix map_irq function to match hardware Signed-off-by: Olof Johansson <olof@lixom.net>
2013-09-04ARM: PCI: versatile: Fix SMAP register offsetsPeter Maydell
The SMAP register offsets in the versatile PCI controller code were all off by four. (This didn't have any observable bad effects because on this board PHYS_OFFSET is zero, and (a) writing zero to the flags register at offset 0x10 has no effect and (b) the reset value of the SMAP register is zero anyway, so failing to write SMAP2 didn't matter.) Signed-off-by: Peter Maydell <peter.maydell@linaro.org> Cc: stable@vger.kernel.org Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Kevin Hilman <khilman@linaro.org>
2013-09-04ARM: PCI: versatile: Fix PCI I/OPeter Maydell
The versatile PCI controller code was confused between the PCI I/O window (at 0x43000000) and the first PCI memory window (at 0x44000000). Pass the correct base address to pci_remap_io() so that PCI I/O accesses work. Since the first PCI memory window isn't used at all (it's an odd size), rename the associated variables and labels so that it's clear that it isn't related to the I/O window. This has been tested and confirmed to fix PCI I/O accesses both on physical PB926+PCI backplane hardware and on QEMU. Signed-off-by: Peter Maydell <peter.maydell@linaro.org> Cc: stable@vger.kernel.org Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Kevin Hilman <khilman@linaro.org>
2013-09-04ARM: PCI: versatile: Fix map_irq function to match hardwarePeter Maydell
The PCI controller code for the Versatile board has never had the correct IRQ mapping for hardware. For many years it had an odd mapping ("all interrupts are int 27") which aligned with the equivalent bug in QEMU. However as of commit 1bc39ac5dab265 the mapping changed and no longer matched either hardware or QEMU, with the result that any PCI card beyond the first in QEMU would not have functioning interrupts; for example a boot with a SCSI controller would time out as follows: ------------ sym0: <895a> rev 0x0 at pci 0000:00:0d.0 irq 92 sym0: SCSI BUS has been reset. scsi0 : sym-2.2.3 [...] scsi 0:0:0:0: ABORT operation started scsi 0:0:0:0: ABORT operation timed-out. scsi 0:0:0:0: DEVICE RESET operation started scsi 0:0:0:0: DEVICE RESET operation timed-out. scsi 0:0:0:0: BUS RESET operation started scsi 0:0:0:0: BUS RESET operation timed-out. scsi 0:0:0:0: HOST RESET operation started sym0: SCSI BUS has been reset ------------ Fix the mapping so that it matches real hardware (checked against the schematics for PB926 and backplane, and tested against the hardware). This allows PCI cards using interrupts to work on hardware for the first time; this change will also work with QEMU 1.5 or later, where the equivalent bugs in the modelling of the hardware have been fixed. Although QEMU will attempt to autodetect whether the kernel is expecting the long-standing "everything is int 27" mapping or the one hardware has, for certainty we force it into "definitely behave like hardware mode"; this will avoid unexpected surprises later if we implement sparse irqs. This is harmless on hardware. Thanks to Paul Gortmaker for bisecting the problem and finding an initial solution, to Russell King for providing the correct interrupt mapping, and to Guenter Roeck for providing an initial version of this patch and prodding me into relocating the hardware and retesting everything. Signed-off-by: Peter Maydell <peter.maydell@linaro.org> Cc: stable@vger.kernel.org Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Kevin Hilman <khilman@linaro.org>
2013-08-25ARM: debug: move PL01X debug include into arch/arm/include/debug/Russell King
Now that the PL01X debug include can mostly stand alone without requiring platforms to provide any macros, move it into the debug directory so it can be directly included. This allows us to get rid of a lot of debug-macros include files. The autodetect case for Versatile Express and the ux500 are left alone; these are more complicated implementations. Acked-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Ryan Mallon <rmallon@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-08-25ARM: debug: provide PL01x debug uart phys/virt address configuration optionsRussell King
Move the definition of the UART register addresses out of the platform specific header files into the Kconfig files. Acked-by: Ryan Mallon <rmallon@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-07-09reboot: arm: change reboot_mode to use enum reboot_modeRobin Holt
Preparing to move the parsing of reboot= to generic kernel code forces the change in reboot_mode handling to use the enum. [akpm@linux-foundation.org: fix arch/arm/mach-socfpga/socfpga.c] Signed-off-by: Robin Holt <holt@sgi.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Russ Anderson <rja@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-11ARM: versatile: use OF init for sp804 timerRob Herring
Enable DT based init for the sp804 timers on versatile DT platform. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-02-21Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC cleanups from Arnd Bergmann: "A large number of cleanups, all over the platforms. This is dominated largely by the Samsung platforms (s3c, s5p, exynos) and a few of the others moving code out of arch/arm into more appropriate subsystems. The clocksource and irqchip drivers are now abstracted to the point where platforms that are already cleaned up do not need to even specify the driver they use, it can all get configured from the device tree as we do for normal device drivers. The clocksource changes basically touch every single platform in the process. We further clean up the use of platform specific header files here, with the goal of turning more of the platforms over to being "multiplatform" enabled, which implies that they cannot expose their headers to architecture independent code any more. It is expected that no functional changes are part of the cleanup. The overall reduction in total code lines is mostly the result of removing broken and obsolete code." * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (133 commits) ARM: mvebu: correct gated clock documentation ARM: kirkwood: add missing include for nsa310 ARM: exynos: move exynos4210-combiner to drivers/irqchip mfd: db8500-prcmu: update resource passing drivers/db8500-cpufreq: delete dangling include ARM: at91: remove NEOCORE 926 board sunxi: Cleanup the reset code and add meaningful registers defines ARM: S3C24XX: header mach/regs-mem.h local ARM: S3C24XX: header mach/regs-power.h local ARM: S3C24XX: header mach/regs-s3c2412-mem.h local ARM: S3C24XX: Remove plat-s3c24xx directory in arch/arm/ ARM: S3C24XX: transform s3c2443 subirqs into new structure ARM: S3C24XX: modify s3c2443 irq init to initialize all irqs ARM: S3C24XX: move s3c2443 irq code to irq.c ARM: S3C24XX: transform s3c2416 irqs into new structure ARM: S3C24XX: modify s3c2416 irq init to initialize all irqs ARM: S3C24XX: move s3c2416 irq init to common irq code ARM: S3C24XX: Modify s3c_irq_wake to use the hwirq property ARM: S3C24XX: Move irq syscore-ops to irq-pm clocksource: always define CLOCKSOURCE_OF_DECLARE ...
2013-02-21Merge tag 'fixes-non-critical' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull non-critical ARM SoC bug fixes from Arnd Bergmann: "Bug fixes that did not make it into v3.8, mostly because they were not considered important enough, and in some cases because bugs only show up in combination with other patches destined for 3.9. This includes a few larger patches for GPIO on the Marvell PXA platform and a lot of Samsung specific bug fixes, as well as a series from Arnd to fix older build warnings." * tag 'fixes-non-critical' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (54 commits) ARM: SPEAr13xx: Enable CONFIG_ARCH_HAS_CPUFREQ ARM: imx: MACH_MX31ADS_WM1133_EV1 needs REGULATOR_WM8350 scripts/sortextable: silence script output ARM: s3c: i2c: add platform_device forward declaration ARM: mvebu: allow selecting mvebu without Armada XP ARM: pick Versatile by default for !MMU ARM: integrator: fix build with INTEGRATOR_AP off ARM: integrator/versatile: fix NOMMU warnings ARM: sa1100: don't warn about mach/ide.h ARM: shmobile: fix defconfig warning on CONFIG_USB ARM: w90x900: fix legacy assembly syntax ARM: samsung: fix assembly syntax for new gas ARM: disable virt_to_bus/virt_to_bus almost everywhere ARM: dts: Correct pin configuration of SD 4 for exynos4x12-pinctrl ARM: SAMSUNG: Silence empty switch warning in fimc-core.h ARM: SAMSUNG: Silence empty switch warning in sdhci.h ARM: msm: proc_comm_boot_wait should not be __init arm: vt8500: Update MAINTAINERS entry for arch-vt8500 ARM: integrator: ensure ap_syscon_base is initialised when !CONFIG_MMU ARM: S5PV210: Fix early uart output in fifo mode ...
2013-02-14ARM: pick Versatile by default for !MMUArnd Bergmann
The introduction of ARCH_MULTIPLATFORM changed the default for nommu kernels from Versatile to Integrator, which is less common, and does not currently build for allnoconfig because that does not select any of the CPUs. This also ensures that at least one of the three board files in versatile are enabled, which lets us successfully build an allnoconfig kernel. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk>
2013-02-14ARM: integrator/versatile: fix NOMMU warningsArnd Bergmann
On NOMMU kernels, the io_desc variables are unused because we don't use the MMU to remap the MMIO areas. Marking these variables as __maybe_unused easily avoids the otherwise harmless warnings like warning: 'versatile_io_desc' defined but not used Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Russell King <linux@arm.linux.org.uk>
2013-02-06ARM: 7635/1: versatile: fix the PCI IRQ regressionLinus Walleij
The PCI IRQs were regressing due to two things: - The PCI glue layer was using an hard-coded IRQ 27 offset. This caused the immediate regression. - The SIC IRQ mask was inverted (i.e. a bit was indeed set to one for each valid IRQ on the SIC, but accidentally inverted in the init call). This has been around forever, but we have been saved by some other forgiving code that would reserve IRQ descriptors in this range, as the versatile is non-sparse. When the IRQs were bumped up 32 steps so as to avoid using IRQ zero and avoid touching the 16 legacy IRQs, things broke. Introduce an explicit valid mask for the IRQs that are active on the PIC/SIC, and pass that. Use the BIT() macro from <linux/bitops.h> to make sure we hit the right bits, readily defined in <mach/platform.h>. Reported-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-02-05Merge tag 'cleanup-decompwdog-3.9' of ↵Olof Johansson
git://git.linaro.org/people/shawnguo/linux-2.6 into next/cleanup From Shawn Guo: The series cleans up ARCH_HAS_DECOMP_WDOG and arch_decomp_wdog which are unused on ARM architecure. Samsung has some code setting up wdog in arch_decomp_wdog(). But since CONFIG_S3C_BOOT_WATCHDOG is defined nowhere, it will not run. Otherwise, system can not boot at all when wdog is set up but no one pats it. * tag 'cleanup-decompwdog-3.9' of git://git.linaro.org/people/shawnguo/linux-2.6: ARM: samsung: remove unused arch_decomp_wdog() code ARM: remove unused arch_decomp_wdog() ARM: decompress: remove unused ARCH_HAS_DECOMP_WDOG Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-14Merge tag 'gic-vic-to-irqchip' of git://sources.calxeda.com/kernel/linux ↵Olof Johansson
into next/cleanup From Rob Herring: Initial irqchip init infrastructure and GIC and VIC clean-ups This creates irqchip initialization infrastructure from Thomas Petazzoni. The VIC and GIC irqchip code is moved to drivers/irqchips and adapted to use the new infrastructure. All DT enabled platforms using GIC and VIC are converted over to use the new irqchip_init. * tag 'gic-vic-to-irqchip' of git://sources.calxeda.com/kernel/linux: irqchip: Move ARM vic.h to include/linux/irqchip/arm-vic.h ARM: picoxcell: use common irqchip_init function ARM: spear: use common irqchip_init function irqchip: Move ARM VIC to drivers/irqchip ARM: samsung: remove unused tick.h ARM: remove unneeded vic.h includes ARM: remove mach .handle_irq for VIC users ARM: VIC: set handle_arch_irq in VIC initialization ARM: VIC: shrink down vic.h irqchip: Move ARM gic.h to include/linux/irqchip/arm-gic.h ARM: use common irqchip_init for GIC init irqchip: Move ARM GIC to drivers/irqchip ARM: remove mach .handle_irq for GIC users ARM: GIC: set handle_arch_irq in GIC initialization ARM: GIC: remove direct use of gic_raise_softirq ARM: GIC: remove assembly ifdefs from gic.h ARM: mach-ux500: use SGI0 to wake up the other core arm: add set_handle_irq() to register the parent IRQ controller handler function irqchip: add basic infrastructure irqchip: add to the directories part of the IRQ subsystem in MAINTAINERS Fixed up massive merge conflicts with the timer cleanup due to adjacent changes: Signed-off-by: Olof Johansson <olof@lixom.net> Conflicts: arch/arm/mach-bcm/board_bcm.c arch/arm/mach-cns3xxx/cns3420vb.c arch/arm/mach-ep93xx/adssphere.c arch/arm/mach-ep93xx/edb93xx.c arch/arm/mach-ep93xx/gesbc9312.c arch/arm/mach-ep93xx/micro9.c arch/arm/mach-ep93xx/simone.c arch/arm/mach-ep93xx/snappercl15.c arch/arm/mach-ep93xx/ts72xx.c arch/arm/mach-ep93xx/vision_ep9307.c arch/arm/mach-highbank/highbank.c arch/arm/mach-imx/mach-imx6q.c arch/arm/mach-msm/board-dt-8960.c arch/arm/mach-netx/nxdb500.c arch/arm/mach-netx/nxdkn.c arch/arm/mach-netx/nxeb500hmi.c arch/arm/mach-nomadik/board-nhk8815.c arch/arm/mach-picoxcell/common.c arch/arm/mach-realview/realview_eb.c arch/arm/mach-realview/realview_pb1176.c arch/arm/mach-realview/realview_pb11mp.c arch/arm/mach-realview/realview_pba8.c arch/arm/mach-realview/realview_pbx.c arch/arm/mach-socfpga/socfpga.c arch/arm/mach-spear13xx/spear1310.c arch/arm/mach-spear13xx/spear1340.c arch/arm/mach-spear13xx/spear13xx.c arch/arm/mach-spear3xx/spear300.c arch/arm/mach-spear3xx/spear310.c arch/arm/mach-spear3xx/spear320.c arch/arm/mach-spear3xx/spear3xx.c arch/arm/mach-spear6xx/spear6xx.c arch/arm/mach-tegra/board-dt-tegra20.c arch/arm/mach-tegra/board-dt-tegra30.c arch/arm/mach-u300/core.c arch/arm/mach-ux500/board-mop500.c arch/arm/mach-ux500/cpu-db8500.c arch/arm/mach-versatile/versatile_ab.c arch/arm/mach-versatile/versatile_dt.c arch/arm/mach-versatile/versatile_pb.c arch/arm/mach-vexpress/v2m.c include/asm-generic/vmlinux.lds.h
2013-01-14Merge branch 'clocksource/cleanup' into next/cleanupOlof Johansson
Clockevent cleanup series from Shawn Guo. Resolved move/change conflict in mach-pxa/time.c due to the sys_timer cleanup. * clocksource/cleanup: clocksource: use clockevents_config_and_register() where possible ARM: use clockevents_config_and_register() where possible clockevents: export clockevents_config_and_register for module use + sync to Linux 3.8-rc3 Signed-off-by: Olof Johansson <olof@lixom.net> Conflicts: arch/arm/mach-pxa/time.c
2013-01-12irqchip: Move ARM vic.h to include/linux/irqchip/arm-vic.hRob Herring
Now that we have VIC moved to drivers/irqchip and all VIC DT init for platforms using irqchip_init, move gic.h and update the remaining includes. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Hartley Sweeten <hsweeten@visionengravers.com> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Alessandro Rubini <rubini@unipv.it> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: STEricsson <STEricsson_nomadik_linux@list.st.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: linux-samsung-soc@vger.kernel.org
2013-01-12ARM: remove unneeded vic.h includesRob Herring
Numerous includes of asm/hardware/vic.h aren't needed, so remove them. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Hubert Feurstein <hubert.feurstein@contec.at> Cc: Alessandro Rubini <rubini@unipv.it> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: STEricsson <STEricsson_nomadik_linux@list.st.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Acked-By: Maxime Ripard <maxime.ripard@free-electrons.com> Cc: linux-samsung-soc@vger.kernel.org Cc: patches@opensource.wolfsonmicro.com Acked-by: Arnd Bergmann <arnd@arndb.de>
2013-01-12ARM: remove mach .handle_irq for VIC usersRob Herring
Now that the VIC initialization sets up the handle_arch_irq pointer, we can remove it for all machines and make it static. Move vic_handle_irq to avoid a forward declaration. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Hubert Feurstein <hubert.feurstein@contec.at> Cc: Alessandro Rubini <rubini@unipv.it> Cc: STEricsson <STEricsson_nomadik_linux@list.st.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Shiraz Hashim <shiraz.hashim@st.com> Cc: Rajeev Kumar <rajeev-dlh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Arnd Bergmann <arnd@arndb.de>
2013-01-11ARM: remove unused arch_decomp_wdog()Shawn Guo
With ARCH_HAS_DECOMP_WDOG removed from arch/arm/boot/compressed/decompress.c, all the arch_decomp_wdog() definition at platform level is unneeded. Remmove it. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Jason Cooper <jason@lakedaemon.net>
2013-01-02ARM: 7610/1: versatile: bump IRQ numbersLinus Walleij
The Versatile starts to register Linux IRQ numbers from offset 0 which is illegal, since this is NO_IRQ. Bump all hard-coded IRQs by 32 to get rid of the problem. Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
