path: root/arch/arm/mach-vexpress
2014-08-31vexpress/spc: fix a build warning on array boundsAlex Shi
With ARCH_VEXPRESS_SPC option, kernel build has the following warning: arch/arm/mach-vexpress/spc.c: In function ‘ve_spc_clk_init’: arch/arm/mach-vexpress/spc.c:431:38: warning: array subscript is below array bounds [-Warray-bounds] struct ve_spc_opp *opps = info->opps[cluster]; ^ since 'cluster' maybe '-1' in UP system. This patch does a active checking to fix this issue. Signed-off-by: Alex Shi <alex.shi@linaro.org> Acked-by: Pawel Moll <pawel.moll@arm.com> Acked-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-08-08Merge tag 'cleanup-for-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Olof Johansson: "This merge window brings a good size of cleanups on various platforms. Among the bigger ones: - Removal of Samsung s5pc100 and s5p64xx platforms. Both of these have lacked active support for quite a while, and after asking around nobody showed interest in keeping them around. If needed, they could be resurrected in the future but it's more likely that we would prefer reintroduction of them as DT and multiplatform-enabled platforms instead. - OMAP4 controller code register define diet. They defined a lot of registers that were never actually used, etc. - Move of some of the Tegra platform code (PMC, APBIO, fuse, powergate) to drivers/soc so it can be shared with 64-bit code. This also converts them over to traditional driver models where possible. - Removal of legacy gpio-samsung driver, since the last users have been removed (moved to pinctrl) Plus a bunch of smaller changes for various platforms that sort of dissapear in the diffstat for the above. clps711x cleanups, shmobile header file refactoring/moves for multiplatform friendliness, some misc cleanups, etc" * tag 'cleanup-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (117 commits) drivers: CCI: Correct use of ! and & video: clcd-versatile: Depend on ARM video: fix up versatile CLCD helper move MAINTAINERS: Add sdhci-st file to ARCH/STI architecture ARM: EXYNOS: Fix build breakge with PM_SLEEP=n MAINTAINERS: Remove Kirkwood ARM: tegra: Convert PMC to a driver soc/tegra: fuse: Set up in early initcall ARM: tegra: Always lock the CPU reset vector ARM: tegra: Setup CPU hotplug in a pure initcall soc/tegra: Implement runtime check for Tegra SoCs soc/tegra: fuse: fix dummy functions soc/tegra: fuse: move APB DMA into Tegra20 fuse driver soc/tegra: Add efuse and apbmisc bindings soc/tegra: Add efuse driver for Tegra ARM: tegra: move fuse exports to soc/tegra/fuse.h ARM: tegra: export apb dma readl/writel ARM: tegra: Use a function to get the chip ID ARM: tegra: Sort includes alphabetically ARM: tegra: Move includes to include/soc/tegra ...
2014-08-06Merge tag 'pm+acpi-3.17-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management updates from Rafael Wysocki: "Again, ACPICA leads the pack (47 commits), followed by cpufreq (18 commits) and system suspend/hibernation (9 commits). From the new code perspective, the ACPICA update brings ACPI 5.1 to the table, including a new device configuration object called _DSD (Device Specific Data) that will hopefully help us to operate device properties like Device Trees do (at least to some extent) and changes related to supporting ACPI on ARM. Apart from that we have hibernation changes making it use radix trees to store memory bitmaps which should speed up some operations carried out by it quite significantly. We also have some power management changes related to suspend-to-idle (the "freeze" sleep state) support and more preliminary changes needed to support ACPI on ARM (outside of ACPICA). The rest is fixes and cleanups pretty much everywhere. Specifics: - ACPICA update to upstream version 20140724. That includes ACPI 5.1 material (support for the _CCA and _DSD predefined names, changes related to the DMAR and PCCT tables and ARM support among other things) and cleanups related to using ACPICA's header files. A major part of it is related to acpidump and the core code used by that utility. Changes from Bob Moore, David E Box, Lv Zheng, Sascha Wildner, Tomasz Nowicki, Hanjun Guo. - Radix trees for memory bitmaps used by the hibernation core from Joerg Roedel. - Support for waking up the system from suspend-to-idle (also known as the "freeze" sleep state) using ACPI-based PCI wakeup signaling (Rafael J Wysocki). - Fixes for issues related to ACPI button events (Rafael J Wysocki). - New device ID for an ACPI-enumerated device included into the Wildcat Point PCH from Jie Yang. - ACPI video updates related to backlight handling from Hans de Goede and Linus Torvalds. - Preliminary changes needed to support ACPI on ARM from Hanjun Guo and Graeme Gregory. - ACPI PNP core cleanups from Arjun Sreedharan and Zhang Rui. - Cleanups related to ACPI_COMPANION() and ACPI_HANDLE() macros (Rafael J Wysocki). - ACPI-based device hotplug cleanups from Wei Yongjun and Rafael J Wysocki. - Cleanups and improvements related to system suspend from Lan Tianyu, Randy Dunlap and Rafael J Wysocki. - ACPI battery cleanup from Wei Yongjun. - cpufreq core fixes from Viresh Kumar. - Elimination of a deadband effect from the cpufreq ondemand governor and intel_pstate driver cleanups from Stratos Karafotis. - 350MHz CPU support for the powernow-k6 cpufreq driver from Mikulas Patocka. - Fix for the imx6 cpufreq driver from Anson Huang. - cpuidle core and governor cleanups from Daniel Lezcano, Sandeep Tripathy and Mohammad Merajul Islam Molla. - Build fix for the big_little cpuidle driver from Sachin Kamat. - Configuration fix for the Operation Performance Points (OPP) framework from Mark Brown. - APM cleanup from Jean Delvare. - cpupower utility fixes and cleanups from Peter Senna Tschudin, Andrey Utkin, Himangi Saraogi, Rickard Strandqvist, Thomas Renninger" * tag 'pm+acpi-3.17-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (118 commits) ACPI / LPSS: add LPSS device for Wildcat Point PCH ACPI / PNP: Replace faulty is_hex_digit() by isxdigit() ACPICA: Update version to 20140724. ACPICA: ACPI 5.1: Update for PCCT table changes. ACPICA/ARM: ACPI 5.1: Update for GTDT table changes. ACPICA/ARM: ACPI 5.1: Update for MADT changes. ACPICA/ARM: ACPI 5.1: Update for FADT changes. ACPICA: ACPI 5.1: Support for the _CCA predifined name. ACPICA: ACPI 5.1: New notify value for System Affinity Update. ACPICA: ACPI 5.1: Support for the _DSD predefined name. ACPICA: Debug object: Add current value of Timer() to debug line prefix. ACPICA: acpihelp: Add UUID support, restructure some existing files. ACPICA: Utilities: Fix local printf issue. ACPICA: Tables: Update for DMAR table changes. ACPICA: Remove some extraneous printf arguments. ACPICA: Update for comments/formatting. No functional changes. ACPICA: Disassembler: Add support for the ToUUID opererator (macro). ACPICA: Remove a redundant cast to acpi_size for ACPI_OFFSET() macro. ACPICA: Work around an ancient GCC bug. ACPI / processor: Make it possible to get local x2apic id via _MAT ...
2014-07-23video: fix up versatile CLCD helper moveArnd Bergmann
commit 11c32d7b6274cb0f ("video: move Versatile CLCD helpers") moved files out of the plat-versatile directory but in the process got a few of the dependencies wrong: - If CONFIG_FB is not set, the file no longer gets built, resulting in a link error - If CONFIG_FB or CONFIG_FB_ARMCLCD are disabled, we also get a Kconfig warning for incorrect dependencies due to the symbol being 'select'ed from the platform Kconfig. - When the file is not built, we also get a link error for missing symbols. This patch should fix all three, by removing the 'select' statements, changing the Kconfig description of the symbol to be enabled in exactly the right configurations, and adding inline stub functions for the case when the framebuffer driver is disabled. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Reviewed-by: Linus Walleij <linus.walleij@linaro.org>
2014-07-23PM / OPP: Remove ARCH_HAS_OPPMark Brown
Since the OPP layer is a kernel library which has been converted to be directly selectable by its callers rather than user selectable and requiring architectures to enable it explicitly the ARCH_HAS_OPP symbol has become redundant and can be removed. Do so. Signed-off-by: Mark Brown <broonie@linaro.org> Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Nishanth Menon <nm@ti.com> Acked-by: Rob Herring <robh@kernel.org> Acked-by: Shawn Guo <shawn.guo@freescale.com> Acked-by: Simon Horman <horms+renesas@verge.net.au> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-07-18ARM: make it easier to check the CPU part number correctlyRussell King
Ensure that platform maintainers check the CPU part number in the right manner: the CPU part number is meaningless without also checking the CPU implement(e|o)r (choose your preferred spelling!) Provide an interface which returns both the implementer and part number together, and update the definitions to include the implementer. Mark the old function as being deprecated... indeed, using the old function with the definitions will now always evaluate as false, so people must update their un-merged code to the new function. While this could be avoided by adding new definitions, we'd also have to create new names for them which would be awkward. Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-07-18ARM: 8082/1: TC2: test the MCPM loopback during bootNicolas Pitre
This is not strictly needed on TC2 but still a good idea to exercise that code. Signed-off-by: nicolas Pitre <nico@linaro.org> Reviewed-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-07-07Merge tag 'versatile-1' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-integrator into next/cleanup Merge "First pull request of Versatile family clean-ups for v3.17" from Linus Walleij: - Remove <mach/memory.h> from the Integrator, paving the road for multiplatform. - Push the CLCD helper code down into the framebuffer subsystem, removing the last hook in plat-versatile for the Integrator, also paving the road for multiplatform. Patches tested on Integrator/AP, Integrator/CP and Versatile AB (all real hardware). * tag 'versatile-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-integrator: video: move Versatile CLCD helpers ARM: integrator: get rid of <mach/memory.h> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-06-27video: move Versatile CLCD helpersLinus Walleij
This moves the Versatile-specific helper code and panel database down into the drivers/video folder next to the CLCD driver itself, preserving the config symbol but also moving the header to platform data. This is necessary to rid the Integrator of this final <plat/*> inclusion dependency and get us one less user of the plat-versatile folder. Cc: Arnd Bergmann <arnd@arndb.de> Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com> Cc: linux-fbdev@vger.kernel.org Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-06-24Merge branch 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "A number of low impact fixes, the most noticable one is the thumb2 frame pointer fix. We also fix a regression caused during this merge window with ARM925 CPUs running with caches disabled, and fix a number of warnings" * 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: ARM: arm925: ensure assembly sets up writethrough mapping ARM: perf: fix compiler warning with gcc 4.6.4 (and tidy code) ARM: l2c: fix dependencies on PL310 errata symbols ARM: 8069/1: Make thread_save_fp macro aware of THUMB2 mode ARM: 8068/1: scoop: Remove unused variable
2014-06-19ARM: l2c: fix dependencies on PL310 errata symbolsRussell King
A number of configurations spit out warnings similar to: warning: (SOC_IMX6 && SOC_VF610 && ARCH_OMAP4) selects PL310_ERRATA_588369 which has unmet direct dependencies (CACHE_L2X0) warning: (SOC_IMX6 && SOC_VF610 && ARCH_OMAP4) selects PL310_ERRATA_727915 which has unmet direct dependencies (CACHE_L2X0) Clean up the dependencies here: * PL310 symbols should only be selected when CACHE_L2X0 is enabled. * Since the cache-l2x0 code detects PL310 presence at runtime, and we will eventually get rid of CACHE_PL310, surround these errata options with an if CACHE_L2X0 conditional rather than repeating the dependency against each. Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-06-17ARM: use menuconfig for sub-arch menusRob Herring
The System Type menu is getting quite long with platforms and is inconsistent in handling of sub-arch specific options. Tidy up the menu by making platform options a menuconfig entry containing any platform specific config items. [arnd: change OMAP part according to suggestion from Tony Lindgren <tony@atomide.com>] Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-06-17ARM: Remove ARCH_HAS_CPUFREQ config optionStephen Boyd
This config exists entirely to hide the cpufreq menu from the kernel configuration unless a platform has selected it. Nothing is actually built if this config is 'Y' and it just leads to more patches that add a select under a platform Kconfig so that some other CPUfreq option can be chosen. Let's remove the option so that we can always enable CPUfreq drivers on ARM platforms. Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-06-05Merge branch 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm into nextLinus Torvalds
Pull ARM updates from Russell King: - Major clean-up of the L2 cache support code. The existing mess was becoming rather unmaintainable through all the additions that others have done over time. This turns it into a much nicer structure, and implements a few performance improvements as well. - Clean up some of the CP15 control register tweaks for alignment support, moving some code and data into alignment.c - DMA properties for ARM, from Santosh and reviewed by DT people. This adds DT properties to specify bus translations we can't discover automatically, and to indicate whether devices are coherent. - Hibernation support for ARM - Make ftrace work with read-only text in modules - add suspend support for PJ4B CPUs - rework interrupt masking for undefined instruction handling, which allows us to enable interrupts earlier in the handling of these exceptions. - support for big endian page tables - fix stacktrace support to exclude stacktrace functions from the trace, and add save_stack_trace_regs() implementation so that kprobes can record stack traces. - Add support for the Cortex-A17 CPU. - Remove last vestiges of ARM710 support. - Removal of ARM "meminfo" structure, finally converting us solely to memblock to handle the early memory initialisation. * 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (142 commits) ARM: ensure C page table setup code follows assembly code (part II) ARM: ensure C page table setup code follows assembly code ARM: consolidate last remaining open-coded alignment trap enable ARM: remove global cr_no_alignment ARM: remove CPU_CP15 conditional from alignment.c ARM: remove unused adjust_cr() function ARM: move "noalign" command line option to alignment.c ARM: provide common method to clear bits in CPU control register ARM: 8025/1: Get rid of meminfo ARM: 8060/1: mm: allow sub-architectures to override PCI I/O memory type ARM: 8066/1: correction for ARM patch 8031/2 ARM: 8049/1: ftrace/add save_stack_trace_regs() implementation ARM: 8065/1: remove last use of CONFIG_CPU_ARM710 ARM: 8062/1: Modify ldrt fixup handler to re-execute the userspace instruction ARM: 8047/1: rwsem: use asm-generic rwsem implementation ARM: l2c: trial at enabling some Cortex-A9 optimisations ARM: l2c: add warnings for stuff modifying aux_ctrl register values ARM: l2c: print a warning with L2C-310 caches if the cache size is modified ARM: l2c: remove old .set_debug method ARM: l2c: kill L2X0_AUX_CTRL_MASK before anyone else makes use of this ...
2014-06-05Merge branches 'alignment', 'fixes', 'l2c' (early part) and 'misc' into for-nextRussell King
2014-06-04Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next Pull timer core updates from Thomas Gleixner: "This time you get nothing really exciting: - A huge update to the sh* clocksource drivers - Support for two more ARM SoCs - Removal of the deprecated setup_sched_clock() API - The usual pile of fixlets all over the place" * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (23 commits) clocksource: Add Freescale FlexTimer Module (FTM) timer support ARM: dts: vf610: Add Freescale FlexTimer Module timer node. clocksource: ftm: Add FlexTimer Module (FTM) Timer devicetree Documentation clocksource: sh_tmu: Remove unnecessary OOM messages clocksource: sh_mtu2: Remove unnecessary OOM messages clocksource: sh_cmt: Remove unnecessary OOM messages clocksource: em_sti: Remove unnecessary OOM messages clocksource: dw_apb_timer_of: Do not trace read_sched_clock clocksource: Fix clocksource_mmio_readX_down clocksource: Fix type confusion for clocksource_mmio_readX_Y clocksource: sh_tmu: Fix channel IRQ retrieval in legacy case clocksource: qcom: Implement read_current_timer for udelay ntp: Make is_error_status() use its argument ntp: Convert simple_strtol to kstrtol timer_stats/doc: Fix /proc/timer_stats documentation sched_clock: Remove deprecated setup_sched_clock() API ARM: sun6i: a31: Add support for the High Speed Timers clocksource: sun5i: Add support for reset controller clocksource: efm32: use $vendor,$device scheme for compatible string KConfig: Vexpress: build the ARM_GLOBAL_TIMER with vexpress platform ...
2014-05-30ARM: l2c: vexpress: convert to generic l2c OF initialisationRussell King
Remove the explicit call to l2x0_of_init(), converting to the generic infrastructure instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-05-30ARM: l2c: vexpress ca9x4: move L2 cache initialisation earlierRussell King
It is beneficial to have the L2 cache up and running earlier in the system boot. Not only will this allow for simpler code when we come to enable some features, but it also means that we get a more accurate bogomips value for the udelay() loop. Calibrating the loop with the L2 cache off, and then running with the L2 cache on is not the best idea. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-05-30ARM: l2c: fix register namingRussell King
We have a mixture of different devices with different register layouts, but we group all the bits together in an opaque mess. Split them out into those which are L2C-310 specific and ones which refer to earlier devices. Provide full auxiliary control register definitions. Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-05-26ARM: vexpress: refine dependencies for new codeArnd Bergmann
The versatile express changes for 3.16 introduced a number of build regressions for randconfig kernels by not tracking dependencies between the components right. This patch tries to rectify that: * the mach-vexpress code cannot link without the syscfg driver, which in turn needs MFD_VEXPRESS_SYSREG * various drivers call devm_regmap_init_vexpress_config(), which has to be exported so it can be used by loadable modules * the configuration bus uses OF DT helper functions that are not available to platforms disable CONFIG_OF * The sysreg driver exports GPIOs through gpiolib, which can be disabled on some platforms. * The clocksource code cannot be built on platforms that don't use modern timekeeping but rely on gettimeoffset. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-05-25ARM: 8029/1: mcpm: Rename the power_down_finish() functions to be less confusingDave Martin
The name "power_down_finish" seems to be causing some confusion, because it suggests that this function is responsible for taking some action to cause the specified CPU to complete its power down. This patch renames the affected functions to "wait_for_powerdown" and similar, since this function's intended purpose is just to wait for the hardware to finish a powerdown initiated by a previous cpu_power_down. Signed-off-by: Dave Martin <Dave.Martin@arm.com> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-05-16Merge remote-tracking branch 'tip/timers/core/timers/core' into clockevents/3.16Daniel Lezcano
2014-05-15ARM: vexpress: move HBI check to sysreg driverPawel Moll
The last reason for static memory mapping is the HBI (board identification number) check early in the machine code. Moving the check to the sysreg driver makes it possible to completely remove the early mapping and init functions. Signed-off-by: Pawel Moll <pawel.moll@arm.com> Acked-by: Lee Jones <lee.jones@linaro.org>
2014-05-15ARM: vexpress: Simplify SMP operations for DT-powered systemPawel Moll
As all cores must be properly described in the Device Tree, there is no point in getting their numbers from SCU on A5/A9 platforms. This significantly simplifies the code, removing the need for flat-tree scanning and early static mapping. Signed-off-by: Pawel Moll <pawel.moll@arm.com>
2014-05-15ARM: vexpress: remove redundant vexpress_dt_cpus_num to get cpu countSudeep KarkadaNagesha
arm_dt_init_cpu_maps parses the device tree, validates and sets the cpu_possible_mask appropriately. It is unnecessary to do another DT parse to get the number of cpus, use num_possible_cpus instead. This patch also removes setting cpu_present_mask as platforms should only re-initialize it in smp_prepare_cpus() if present != possible. Signed-off-by: Sudeep KarkadaNagesha <sudeep.karkadanagesha@arm.com> Signed-off-by: Pawel Moll <pawel.moll@arm.com>
2014-05-15clocksource: Sched clock source for Versatile ExpressPawel Moll
This patch adds a trival sched clock source using free running, 24MHz clocked counter present in the ARM Ltd. reference platforms (Versatile, RealView, Versatile Express) System Registers block. This code replaces the call in the VE machine code. Signed-off-by: Pawel Moll <pawel.moll@arm.com> Reviewed-by: Linus Walleij <linus.walleij@linaro.org>
2014-05-15mfd: vexpress: Define the device as MFD cellsPawel Moll
This patch - finally, after over 6 months! :-( - addresses Samuel's request to split the vexpress-sysreg driver into smaller portions and define the device in a form of MFD cells: * LEDs code has been completely removed and replaced with "gpio-leds" nodes in the tree (referencing dedicated GPIO subnodes in sysreg - bindings documentation updated); this also better fits the reality as some variants of the motherboard don't have all the LEDs populated * syscfg bridge code has been extracted into a separate driver (placed in drivers/misc for no better place) * all the ID & MISC registers are defined as sysconf making them available for other drivers should they need to use them (and also to the user via /sys/kernel/debug/regmap which can be helpful in platform debugging) Signed-off-by: Pawel Moll <pawel.moll@arm.com> Acked-by: Lee Jones <lee.jones@linaro.org>
2014-05-15mfd: vexpress: Convert custom func API to regmapPawel Moll
Components of the Versatile Express platform (configuration microcontrollers on motherboard and daughterboards in particular) talk to each other over a custom configuration bus. They provide miscellaneous functions (from clock generator control to energy sensors) which are represented as platform devices (and Device Tree nodes). The transactions on the bus can be generated by different "bridges" in the system, some of which are universal for the whole platform (for the price of high transfer latencies), others restricted to a subsystem (but much faster). Until now drivers for such functions were using custom "func" API, which is being replaced in this patch by regmap calls. This required: * a rework (and move to drivers/bus directory, as suggested by Samuel and Arnd) of the config bus core, which is much simpler now and uses device model infrastructure (class) to keep track of the bridges; non-DT case (soon to be retired anyway) is simply covered by a special device registration function * the new config-bus driver also takes over device population, so there is no need for special matching table for of_platform_populate nor "simple-bus" hack in the arm64 model dtsi file (relevant bindings documentation has been updated); this allows all the vexpress devices fit into normal device model, making it possible to remove plenty of early inits and other hacks in the near future * adaptation of the syscfg bridge implementation in the sysreg driver, again making it much simpler; there is a special case of the "energy" function spanning two registers, where they should be both defined in the tree now, but backward compatibility is maintained in the code * modification of the relevant drivers: * hwmon - just a straight-forward API change * power/reset driver - API change * regulator - API change plus error handling simplification * osc clock driver - this one required larger rework in order to turn in into a standard platform driver Signed-off-by: Pawel Moll <pawel.moll@arm.com> Acked-by: Mark Brown <broonie@linaro.org> Acked-by: Lee Jones <lee.jones@linaro.org> Acked-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Mike Turquette <mturquette@linaro.org>
2014-04-24ARM: vexpress/TC2: Convert OPP voltage to uV before storingPunit Agrawal
The SPC stores voltage in mV while the code assumes it was returning uV. Convert the returned voltage to uV before storing. Also fix the comment depicting voltage to uV. Signed-off-by: Punit Agrawal <punit.agrawal@arm.com> Reviewed-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Pawel Moll <pawel.moll@arm.com>
2014-04-24arm/mach-vexpress: array accessed out of boundsHeinrich Schuchardt
dcscb_allcpus_mask is an array of size 2. The index variable cluster has to be checked against this limit before accessing the array. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Pawel Moll <pawel.moll@arm.com>
2014-04-22KConfig: Vexpress: build the ARM_GLOBAL_TIMER with vexpress platformMatthew Leach
The Cortex A5 now contains bindings for the global timer driver. Ensure that the driver is built with a vexpress platform. Signed-off-by: Matthew Leach <matthew.leach@arm.com> Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
2014-04-11Merge branch 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull second set of ARM changes from Russell King: "This is the remainder of the ARM changes for this merge window. Included in this request are: - fixes for kprobes for big-endian support - fix tracing in soft_restart - avoid phys address overflow in kdump code - fix reporting of read-only pmd bits in kernel page table dump - remove unnecessary (and possibly buggy) call to outer_flush_all() - fix a three sparse warnings (missing header file for function prototypes) - fix pj4 crashing single zImage (thanks to arm-soc merging changes which enables this with knowledge that the corresponding fix had not even been submitted for my tree before the merge window opened) - vfp macro cleanups - dump register state on undefined instruction userspace faults when debugging" * 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: Dump the registers on undefined instruction userspace faults ARM: 8018/1: Add {inc,dec}_preempt_count asm macros ARM: 8017/1: Move asm macro get_thread_info to asm/assembler.h ARM: 8016/1: Check cpu id in pj4_cp0_init. ARM: 8015/1: Add cpu_is_pj4 to distinguish PJ4 because it has some differences with V7 ARM: add missing system_misc.h include to process.c ARM: 8009/1: dcscb.c: remove call to outer_flush_all() ARM: 8014/1: mm: fix reporting of read-only PMD bits ARM: 8012/1: kdump: Avoid overflow when converting pfn to physaddr ARM: 8010/1: avoid tracers in soft_restart ARM: kprobes-test: Workaround GAS .align bug ARM: kprobes-test: use <asm/opcodes.h> for Thumb instruction building ARM: kprobes-test: use <asm/opcodes.h> for ARM instruction building ARM: kprobes-test: use <asm/opcodes.h> for instruction accesses ARM: probes: fix instruction fetch order with <asm/opcodes.h>
2014-04-11Merge branches 'fixes' and 'misc' into for-nextRussell King
2014-04-07Kconfig: rename HAS_IOPORT to HAS_IOPORT_MAPUwe Kleine-König
If the renamed symbol is defined lib/iomap.c implements ioport_map and ioport_unmap and currently (nearly) all platforms define the port accessor functions outb/inb and friend unconditionally. So HAS_IOPORT_MAP is the better name for this. Consequently NO_IOPORT is renamed to NO_IOPORT_MAP. The motivation for this change is to reintroduce a symbol HAS_IOPORT that signals if outb/int et al are available. I will address that at least one merge window later though to keep surprises to a minimum and catch new introductions of (HAS|NO)_IOPORT. The changes in this commit were done using: $ git grep -l -E '(NO|HAS)_IOPORT' | xargs perl -p -i -e 's/\b((?:CONFIG_)?(?:NO|HAS)_IOPORT)\b/$1_MAP/' Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07ARM: 8009/1: dcscb.c: remove call to outer_flush_all()Nicolas Pitre
Strictly speaking this call is a no-op on the platform where dcscb.c is used since it only has architected caches. The call was there as a hint to people inspired by this code when writing their own backend, but the hint might not always be correct. For example, if a PL310 were to be used it wouldn't be safe to call the regular outer_flush_all() as atomic instructions for locking are involved in that case and those instructions cannot be assumed to still be operational after v7_exit_coherency_flush() has returned. Given no other CPUs (in the cluster) should be running at that point then standard concurrency concerns wouldn't apply. So let's simply kill this call for now and enhance the existing comment. Signed-off-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-04-05Merge tag 'cleanup-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Arnd Bergmann: "These cleanup patches are mainly move stuff around and should all be harmless. They are mainly split out so that other branches can be based on top to avoid conflicts. Notable changes are: - We finally remove all mach/timex.h, after CLOCK_TICK_RATE is no longer used (Uwe Kleine-König) - The Qualcomm MSM platform is split out into legacy mach-msm and new-style mach-qcom, to allow easier maintainance of the new hardware support without regressions (Kumar Gala) - A rework of some of the Kconfig logic to simplify multiplatform support (Rob Herring) - Samsung Exynos gets closer to supporting multiplatform (Sachin Kamat and others) - mach-bcm3528 gets merged into mach-bcm (Stephen Warren) - at91 gains some common clock framework support (Alexandre Belloni, Jean-Jacques Hiblot and other French people)" * tag 'cleanup-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (89 commits) ARM: hisi: select HAVE_ARM_SCU only for SMP ARM: efm32: allow uncompress debug output ARM: prima2: build reset code standalone ARM: at91: add PWM clock ARM: at91: move sam9261 SoC to common clk ARM: at91: prepare common clk transition for sam9261 SoC ARM: at91: updated the at91_dt_defconfig with support for the ADS7846 ARM: at91: dt: sam9261: Device Tree support for the at91sam9261ek ARM: at91: dt: defconfig: Added the sam9261 to the list of DT-enabled SOCs ARM: at91: dt: Add at91sam9261 dt SoC support ARM: at91: switch sam9rl to common clock framework ARM: at91/dt: define main clk frequency of at91sam9rlek ARM: at91/dt: define at91sam9rl clocks ARM: at91: prepare common clk transition for sam9rl SoCs ARM: at91: prepare sam9 dt boards transition to common clk ARM: at91: dt: sam9rl: Device Tree for the at91sam9rlek ARM: at91/defconfig: Add the sam9rl to the list of DT-enabled SOCs ARM: at91: Add at91sam9rl DT SoC support ARM: at91: prepare at91sam9rl DT transition ARM: at91/defconfig: refresh at91sam9260_9g20_defconfig ...
2014-02-19ARM: select MIGHT_HAVE_CACHE_L2X0 for V6 and V7 multi-platformRob Herring
Many V6 and V7 platforms have an L2x0 cache, so make CONFIG_MIGHT_HAVE_CACHE_L2X0 visible for V6 and V7 multi-platform builds. Signed-off-by: Rob Herring <robh@kernel.org> Acked-by: Stephen Warren <swarren@nvidia.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2014-02-19ARM: select HAVE_SMP for V7 multi-platformRob Herring
All V7 platforms can run SMP kernels, so make CONFIG_SMP visible for V7 multi-platform builds. Signed-off-by: Rob Herring <robh@kernel.org> Acked-by: Stephen Warren <swarren@nvidia.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2014-02-19ARM: centralize common multi-platform kconfig optionsRob Herring
Multi-platform requires various kconfig options to be selected, so platforms don't need to select them individually. Signed-off-by: Rob Herring <robh@kernel.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2014-02-18ARM: 7962/2: Make all mcpm functions notraceDave Martin
The functions in mcpm_entry.c are mostly intended for use during scary cache and coherency disabling sequences, or do other things which confuse trace ... like powering a CPU down and not returning. Similarly for the backend code. For simplicity, this patch just makes whole files notrace. There should be more than enough traceable points on the paths to these functions, but we can be more fine-grained later if there is a need for it. Jon Medhurst: Also added spc.o to the list of files as it contains functions used by MCPM code which have comments comments like: "might be used in code paths where normal cacheable locks are not working" Signed-off-by: Dave Martin <dave.martin@linaro.org> Signed-off-by: Jon Medhurst <tixy@linaro.org> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-11-25ARM: vexpress/TC2: Implement MCPM power_down_finish()Dave Martin
This patch implements the power_down_finish() method for TC2, to enable the kernel to confirm when CPUs are safely powered down. The information required for determining when a CPU is parked cannot be obtained from any single place, so a few sources of information must be combined: * mcpm_cpu_power_down() must be pending for the CPU, so that we don't get confused by false STANDBYWFI positives arising from CPUidle. This is detected by waiting for the tc2_pm use count for the target CPU to reach 0. * Either the SPC must report that the CPU has asserted STANDBYWFI, or the TC2 tile's reset control logic must be holding the CPU in reset. Just checking for STANDBYWFI is not sufficient, because this signal is not latched when the the cluster is clamped off and powered down: the relevant status bits just drop to zero. This means that STANDBYWFI status cannot be used for reliable detection of the last CPU in a cluster reaching WFI. This patch is required in order for kexec to work with MCPM on TC2. MCPM code was changed in commit 0de0d6467525 ('ARM: 7848/1: mcpm: Implement cpu_kill() to synchronise on powerdown'), and since then it will hit a WARN_ON_ONCE() due to power_down_finish not being implemented on the TC2 platform. Signed-off-by: Dave Martin <Dave.Martin@arm.com> Acked-by: Pawel Moll <pawel.moll@arm.com> Reviewed-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-11-14Merge tag 'pm+acpi-3.13-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management updates from Rafael J Wysocki: - New power capping framework and the the Intel Running Average Power Limit (RAPL) driver using it from Srinivas Pandruvada and Jacob Pan. - Addition of the in-kernel switching feature to the arm_big_little cpufreq driver from Viresh Kumar and Nicolas Pitre. - cpufreq support for iMac G5 from Aaro Koskinen. - Baytrail processors support for intel_pstate from Dirk Brandewie. - cpufreq support for Midway/ECX-2000 from Mark Langsdorf. - ARM vexpress/TC2 cpufreq support from Sudeep KarkadaNagesha. - ACPI power management support for the I2C and SPI bus types from Mika Westerberg and Lv Zheng. - cpufreq core fixes and cleanups from Viresh Kumar, Srivatsa S Bhat, Stratos Karafotis, Xiaoguang Chen, Lan Tianyu. - cpufreq drivers updates (mostly fixes and cleanups) from Viresh Kumar, Aaro Koskinen, Jungseok Lee, Sudeep KarkadaNagesha, Lukasz Majewski, Manish Badarkhe, Hans-Christian Egtvedt, Evgeny Kapaev. - intel_pstate updates from Dirk Brandewie and Adrian Huang. - ACPICA update to version 20130927 includig fixes and cleanups and some reduction of divergences between the ACPICA code in the kernel and ACPICA upstream in order to improve the automatic ACPICA patch generation process. From Bob Moore, Lv Zheng, Tomasz Nowicki, Naresh Bhat, Bjorn Helgaas, David E Box. - ACPI IPMI driver fixes and cleanups from Lv Zheng. - ACPI hotplug fixes and cleanups from Bjorn Helgaas, Toshi Kani, Zhang Yanfei, Rafael J Wysocki. - Conversion of the ACPI AC driver to the platform bus type and multiple driver fixes and cleanups related to ACPI from Zhang Rui. - ACPI processor driver fixes and cleanups from Hanjun Guo, Jiang Liu, Bartlomiej Zolnierkiewicz, Mathieu Rhéaume, Rafael J Wysocki. - Fixes and cleanups and new blacklist entries related to the ACPI video support from Aaron Lu, Felipe Contreras, Lennart Poettering, Kirill Tkhai. - cpuidle core cleanups from Viresh Kumar and Lorenzo Pieralisi. - cpuidle drivers fixes and cleanups from Daniel Lezcano, Jingoo Han, Bartlomiej Zolnierkiewicz, Prarit Bhargava. - devfreq updates from Sachin Kamat, Dan Carpenter, Manish Badarkhe. - Operation Performance Points (OPP) core updates from Nishanth Menon. - Runtime power management core fix from Rafael J Wysocki and update from Ulf Hansson. - Hibernation fixes from Aaron Lu and Rafael J Wysocki. - Device suspend/resume lockup detection mechanism from Benoit Goby. - Removal of unused proc directories created for various ACPI drivers from Lan Tianyu. - ACPI LPSS driver fix and new device IDs for the ACPI platform scan handler from Heikki Krogerus and Jarkko Nikula. - New ACPI _OSI blacklist entry for Toshiba NB100 from Levente Kurusa. - Assorted fixes and cleanups related to ACPI from Andy Shevchenko, Al Stone, Bartlomiej Zolnierkiewicz, Colin Ian King, Dan Carpenter, Felipe Contreras, Jianguo Wu, Lan Tianyu, Yinghai Lu, Mathias Krause, Liu Chuansheng. - Assorted PM fixes and cleanups from Andy Shevchenko, Thierry Reding, Jean-Christophe Plagniol-Villard. * tag 'pm+acpi-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (386 commits) cpufreq: conservative: fix requested_freq reduction issue ACPI / hotplug: Consolidate deferred execution of ACPI hotplug routines PM / runtime: Use pm_runtime_put_sync() in __device_release_driver() ACPI / event: remove unneeded NULL pointer check Revert "ACPI / video: Ignore BIOS initial backlight value for HP 250 G1" ACPI / video: Quirk initial backlight level 0 ACPI / video: Fix initial level validity test intel_pstate: skip the driver if ACPI has power mgmt option PM / hibernate: Avoid overflow in hibernate_preallocate_memory() ACPI / hotplug: Do not execute "insert in progress" _OST ACPI / hotplug: Carry out PCI root eject directly ACPI / hotplug: Merge device hot-removal routines ACPI / hotplug: Make acpi_bus_hot_remove_device() internal ACPI / hotplug: Simplify device ejection routines ACPI / hotplug: Fix handle_root_bridge_removal() ACPI / hotplug: Refuse to hot-remove all objects with disabled hotplug ACPI / scan: Start matching drivers after trying scan handlers ACPI: Remove acpi_pci_slot_init() headers from internal.h ACPI / blacklist: fix name of ThinkPad Edge E530 PowerCap: Fix build error with option -Werror=format-security ... Conflicts: arch/arm/mach-omap2/opp.c drivers/Kconfig drivers/spi/spi.c
2013-11-14Merge branch 'for-linus' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: "Included in this series are: 1. BE8 (modern big endian) changes for ARM from Ben Dooks 2. big.Little support from Nicolas Pitre and Dave Martin 3. support for LPAE systems with all system memory above 4GB 4. Perf updates from Will Deacon 5. Additional prefetching and other performance improvements from Will. 6. Neon-optimised AES implementation fro Ard. 7. A number of smaller fixes scattered around the place. There is a rather horrid merge conflict in tools/perf - I was never notified of the conflict because it originally occurred between Will's tree and other stuff. Consequently I have a resolution which Will forwarded me, which I'll forward on immediately after sending this mail. The other notable thing is I'm expecting some build breakage in the crypto stuff on ARM only with Ard's AES patches. These were merged into a stable git branch which others had already pulled, so there's little I can do about this. The problem is caused because these patches have a dependency on some code in the crypto git tree - I tried requesting a branch I can pull to resolve these, and all I got each time from the crypto people was "we'll revert our patches then" which would only make things worse since I still don't have the dependent patches. I've no idea what's going on there or how to resolve that, and since I can't split these patches from the rest of this pull request, I'm rather stuck with pushing this as-is or reverting Ard's patches. Since it should "come out in the wash" I've left them in - the only build problems they seem to cause at the moment are with randconfigs, and since it's a new feature anyway. However, if by -rc1 the dependencies aren't in, I think it'd be best to revert Ard's patches" I resolved the perf conflict roughly as per the patch sent by Russell, but there may be some differences. Any errors are likely mine. Let's see how the crypto issues work out.. * 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (110 commits) ARM: 7868/1: arm/arm64: remove atomic_clear_mask() in "include/asm/atomic.h" ARM: 7867/1: include: asm: use 'int' instead of 'unsigned long' for 'oldval' in atomic_cmpxchg(). ARM: 7866/1: include: asm: use 'long long' instead of 'u64' within atomic.h ARM: 7871/1: amba: Extend number of IRQS ARM: 7887/1: Don't smp_cross_call() on UP devices in arch_irq_work_raise() ARM: 7872/1: Support arch_irq_work_raise() via self IPIs ARM: 7880/1: Clear the IT state independent of the Thumb-2 mode ARM: 7878/1: nommu: Implement dummy early_paging_init() ARM: 7876/1: clear Thumb-2 IT state on exception handling ARM: 7874/2: bL_switcher: Remove cpu_hotplug_driver_{lock,unlock}() ARM: footbridge: fix build warnings for netwinder ARM: 7873/1: vfp: clear vfp_current_hw_state for dying cpu ARM: fix misplaced arch_virt_to_idmap() ARM: 7848/1: mcpm: Implement cpu_kill() to synchronise on powerdown ARM: 7847/1: mcpm: Factor out logical-to-physical CPU translation ARM: 7869/1: remove unused XSCALE_PMU Kconfig param ARM: 7864/1: Handle 64-bit memory in case of 32-bit phys_addr_t ARM: 7863/1: Let arm_add_memory() always use 64-bit arguments ARM: 7862/1: pcpu: replace __get_cpu_var_uses ARM: 7861/1: cacheflush: consolidate single-CPU ARMv7 cache disabling code ...
2013-11-12Merge branch 'devel-stable' into for-nextRussell King
Conflicts: arch/arm/include/asm/atomic.h arch/arm/include/asm/hardirq.h arch/arm/kernel/smp.c
2013-10-30ARM: vexpress/TC2: register vexpress-spc cpufreq deviceSudeep KarkadaNagesha
This patch adds vexpress-spc platform device to enables the vexpress SPC cpufreq interface driver. Signed-off-by: Sudeep KarkadaNagesha <sudeep.karkadanagesha@arm.com> Acked-by: Pawel Moll <Pawel.Moll@arm.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-30ARM: vexpress/TC2: add cpu clock supportSudeep KarkadaNagesha
On TC2, the cpu clocks are controlled by the external M3 microcontroller and SPC provides the interface between the CPU and the power controller. The generic cpufreq drivers use the clock APIs to get the cpu clocks. This patch add virtual spc clocks for all the cpus to control the cpu operating frequency via the clock framework. Signed-off-by: Sudeep KarkadaNagesha <sudeep.karkadanagesha@arm.com> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Pawel Moll <Pawel.Moll@arm.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-30ARM: vexpress/TC2: add support for CPU DVFSSudeep KarkadaNagesha
SPC(Serial Power Controller) on TC2 also controls the CPU performance operating points which is essential to provide CPU DVFS. The M3 microcontroller provides two sets of eight performance values, one set for each cluster (CA15 or CA7). Each of this value contains the frequency(kHz) and voltage(mV) at that performance level. It expects these performance level to be passed through the SPC PERF_LVL registers. This patch adds support to populate these performance levels from M3, build the mapping to CPU OPPs at the boot and then use it to get and set the CPU performance level runtime. Signed-off-by: Sudeep KarkadaNagesha <sudeep.karkadanagesha@arm.com> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Pawel Moll <Pawel.Moll@arm.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-29ARM: 7861/1: cacheflush: consolidate single-CPU ARMv7 cache disabling codeNicolas Pitre
This code is becoming duplicated in many places. So let's consolidate it into a handy macro that is known to be right and available for reuse. Signed-off-by: Nicolas Pitre <nico@linaro.org> Acked-by: Dave Martin <Dave.Martin@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-10-28Merge tag 'omap-for-v3.13/cm-scm-cleanup-signed' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/cleanup From Paul Walmsley <paul@pwsan.com> via Tony Lindgren: Move some of the OMAP2+ CM and System Control Module direct register accesses into CM- and System Control Module-specific "drivers" underneath arch/arm/mach-omap2/. This is a prerequisite for moving this code out of arch/arm/mach-omap2/ into drivers/. Basic test logs are available here: http://www.pwsan.com/omap/testlogs/cm_scm_cleanup_a_v3.13/20131019101809/ * tag 'omap-for-v3.13/cm-scm-cleanup-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: ARM: OMAP3: control: add API for setting IVA bootmode ARM: OMAP3: CM/control: move CM scratchpad save to CM driver ARM: OMAP3: McBSP: do not access CM register directly ARM: OMAP3: clock: add API to enable/disable autoidle for a single clock ARM: OMAP2: CM/PM: remove direct register accesses outside CM code + Linux 3.12-rc4 Signed-off-by: Olof Johansson <olof@lixom.net>
2013-10-19ARM: vexpress: add big endian supportBen Dooks
Add support for the versatile express systems to boot big-endian. Signed-off-by: Ben Dooks <ben.dooks@codethink.co.uk>
