path: root/arch/arm/mach-virt
2013-05-07Merge tag '3.9-rc3-smp-6-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sstabellini/xen Pull ARM Xen SMP updates from Stefano Stabellini: "This contains a bunch of Xen/ARM specific changes, including some fixes, SMP support for Xen on ARM, and moving the xenvm machine from mach-vexpress to mach-virt. The non-Xen files that are touched are arch/arm/Kconfig, to select ARM_PSCI on XEN, and arch/arm/boot/dts/Makefile, to build the xenvm DTB if CONFIG_ARCH_VIRT. Highlights: - Move xenvm to mach-virt. - Implement SMP support in Xen on ARM. - Add support for machine reboot and power off via Xen hypercalls" * tag '3.9-rc3-smp-6-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/sstabellini/xen: xen/arm: remove duplicated include from enlighten.c xen/arm: use sched_op hypercalls for machine reboot and power off xenvm: add a simple PSCI node and a second cpu xen/arm: XEN selects ARM_PSCI xen: move the xenvm machine to mach-virt xen/arm: SMP support xen/arm: implement HYPERVISOR_vcpu_op xen/arm: actually pass a non-NULL percpu pointer to request_percpu_irq
2013-05-07Merge tag 'cleanup-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC late cleanups from Arnd Bergmann: "These are cleanups and smaller changes that either depend on earlier feature branches or came in late during the development cycle. We normally try to get all cleanups early, so these are the exceptions: - A follow-up on the clocksource reworks, hopefully the last time we need to merge clocksource subsystem changes through arm-soc. A first set of patches was part of the original 3.10 arm-soc cleanup series because of interdependencies with timer drivers now moved out of arch/arm. - Migrating the SPEAr13xx platform away from using auxdata for DMA channel descriptions towards using information in device tree, based on the earlier SPEAr multiplatform series - A few follow-ups on the Atmel SAMA5 support and other changes for Atmel at91 based on the larger at91 reworks. - Moving the armada irqchip implementation to drivers/irqchip - Several OMAP cleanups following up on the larger series already merged in 3.10." * tag 'cleanup-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (50 commits) ARM: OMAP4: change the device names in usb_bind_phy ARM: OMAP2+: Fix mismerge for timer.c between ff931c82 and da4a686a ARM: SPEAr: conditionalize SMP code ARM: arch_timer: Silence debug preempt warnings ARM: OMAP: remove unused variable serial: amba-pl011: fix !CONFIG_DMA_ENGINE case ata: arasan: remove the need for platform_data ARM: at91/sama5d34ek.dts: remove not needed compatibility string ARM: at91: dts: add MCI DMA support ARM: at91: dts: add i2c dma support ARM: at91: dts: set #dma-cells to the correct value ARM: at91: suspend both memory controllers on at91sam9263 irqchip: armada-370-xp: slightly cleanup irq controller driver irqchip: armada-370-xp: move IRQ handler to avoid forward declaration irqchip: move IRQ driver for Armada 370/XP ARM: mvebu: move L2 cache initialization in init_early() devtree: add binding documentation for sp804 ARM: integrator-cp: convert use CLKSRC_OF for timer init ARM: versatile: use OF init for sp804 timer ARM: versatile: add versatile dtbs to dtbs target ...
2013-04-25xen: move the xenvm machine to mach-virtStefano Stabellini
xenvm is based on mach-vexpress, move it to mach-virt. Changes in v4: - update the dts Makefile too. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> CC: Marc Zyngier <marc.zyngier@arm.com> CC: will.deacon@arm.com CC: arnd@arndb.de CC: rob.herring@calxeda.com
2013-04-11ARM: convert arm/arm64 arch timer to use CLKSRC_OF initRob Herring
This converts arm and arm64 to use CLKSRC_OF DT based initialization for the arch timer. A new function arch_timer_arch_init is added to allow for arch specific setup. This has a side effect of enabling sched_clock on omap5 and exynos5. There should not be any reason not to use the arch timers for sched_clock. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Simon Horman <horms@verge.net.au> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: John Stultz <john.stultz@linaro.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-samsung-soc@vger.kernel.org Cc: linux-omap@vger.kernel.org Cc: linux-sh@vger.kernel.org Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2013-03-26irqchip: gic: Perform the gic_secondary_init() call via CPU notifierCatalin Marinas
All the calls to gic_secondary_init() pass 0 as the first argument. Since this function is called on each CPU when starting, it can be done in a platform-independent way via a CPU notifier registered by the GIC code. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Stephen Warren <swarren@nvidia.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Simon Horman <horms+renesas@verge.net.au> Tested-by: Simon Horman <horms+renesas@verge.net.au> Acked-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Tested-by: Dinh Nguyen <dinguyen@altera.com> Acked-by: Nicolas Pitre <nico@linaro.org> Tested-by: Marc Zyngier <marc.zyngier@arm.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: Sascha Hauer <kernel@pengutronix.de> Cc: David Brown <davidb@codeaurora.org> Cc: Bryan Huntsman <bryanh@codeaurora.org> Cc: Tony Lindgren <tony@atomide.com> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: Shiraz Hashim <shiraz.hashim@st.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Will Deacon <will.deacon@arm.com> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: Barry Song <baohua.song@csr.com>
2013-02-11ARM: mach-virt: fixup machine descriptor after removal of sys_timerWill Deacon
Now that sys_timer has been removed, update the mach-virt machine descriptor to use a direct pointer to its timer_init function. Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-02-02ARM: mach-virt: add SMP support using PSCIWill Deacon
This patch adds support for SMP to mach-virt using the PSCI infrastructure. Acked-by: Arnd Bergmann <arnd@arndb.de> Reviewed-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Will Deacon <will.deacon@arm.com>
2013-02-02ARM: Dummy Virtual Machine platform supportMarc Zyngier
Add support for the smallest, dumbest possible platform, to be used as a guest for KVM or other hypervisors. It only mandates a GIC and architected timers. Fits nicely with a multiplatform zImage. Uses very little silicon area. Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> [will: fixed up conflicts with GIC move to drivers/irqchip/] Signed-off-by: Will Deacon <will.deacon@arm.com>
