Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
This replaces:
- "select ARCH_REQUIRE_GPIOLIB" with "select GPIOLIB" as this can
now be selected directly.
- "select ARCH_WANT_OPTIONAL_GPIOLIB" with no dependency: GPIOLIB
is now selectable by everyone, so we need not declare our
intent to select it.
When ordering the symbols the following rationale was used:
if the selects were in alphabetical order, I moved select GPIOLIB
to be in alphabetical order, but if the selects were not
maintained in alphabetical order, I just replaced
"select ARCH_REQUIRE_GPIOLIB" with "select GPIOLIB".
Cc: Michael Büsch <m@bues.ch>
Cc: arm@kernel.org
This config exists entirely to hide the cpufreq menu from the
kernel configuration unless a platform has selected it. Nothing
is actually built if this config is 'Y' and it just leads to more
patches that add a select under a platform Kconfig so that some
other CPUfreq option can be chosen. Let's remove the option so
that we can always enable CPUfreq drivers on ARM platforms.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
The wm8750 is an ARM1176 which has all the V6K extensions except for SMP,
so V6K should be selected instead. Dropping the select will use the
default for ARCH_MULTI_V6 which is V6K.
Signed-off-by: Rob Herring <robh@kernel.org>
Cc: Tony Prisk <linux@prisktech.co.nz>
Multi-platform requires various kconfig options to be selected, so
platforms don't need to select them individually.
Tested-by: Stephen Warren <swarren@wwwdotorg.org>
CLKDEV_LOOKUP selects HAVE_CLK and COMMON_CLK selects CLKDEV_LOOKUP. So
all symbols that select at least two of these symbols can be simplified.
For imx, omap2 and ux500 some rearrangements were necessary before the
simplification.
Acked-by: Stephen Boyd <sboyd@codeaurora.org>
Acked-by: Dinh Nguyen <dinguyen@altera.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Pawel Moll <pawel.moll@arm.com>
This patch adds support for the GPIO/pinmux controller found on the VIA
VT8500 and Wondermedia WM8xxx-series SoCs.
Each pin within the controller is capable of operating as a GPIO or as
an alternate function. The pins are numbered according to their control
bank/bit so that if new pins are added, the existing numbering is maintained.
All currently supported SoCs are included: VT8500, WM8505, WM8650, WM8750 and
WM8850.
Signed-off-by: Tony Prisk <linux@prisktech.co.nz>
Pull ARM SoC-specific updates from Arnd Bergmann:
"This is a larger set of new functionality for the existing SoC
families, including:
- vt8500 gains support for new CPU cores, notably the Cortex-A9 based
wm8850
- prima2 gains support for the "marco" SoC family, its SMP based
cousin
- tegra gains support for the new Tegra4 (Tegra114) family
- socfpga now supports a newer version of the hardware including SMP
- i.mx31 and bcm2835 are now using DT probing for their clocks
- lots of updates for sh-mobile
- OMAP updates for clocks, power management and USB
- i.mx6q and tegra now support cpuidle
- kirkwood now supports PCIe hot plugging
- tegra clock support is updated
- tegra USB PHY probing gets implemented diffently"
* tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (148 commits)
ARM: prima2: remove duplicate v7_invalidate_l1
ARM: shmobile: r8a7779: Correct TMU clock support again
ARM: prima2: fix __init section for cpu hotplug
ARM: OMAP: Consolidate OMAP USB-HS platform data (part 3/3)
ARM: OMAP: Consolidate OMAP USB-HS platform data (part 1/3)
arm: socfpga: Add SMP support for actual socfpga harware
arm: Add v7_invalidate_l1 to cache-v7.S
arm: socfpga: Add entries to enable make dtbs socfpga
arm: socfpga: Add new device tree source for actual socfpga HW
ARM: tegra: sort Kconfig selects for Tegra114
ARM: tegra: enable ARCH_REQUIRE_GPIOLIB for Tegra114
ARM: tegra: Fix build error w/ ARCH_TEGRA_114_SOC w/o ARCH_TEGRA_3x_SOC
ARM: tegra: Fix build error for gic update
ARM: tegra: remove empty tegra_smp_init_cpus()
ARM: shmobile: Register ARM architected timer
ARM: MARCO: fix the build issue due to gic-vic-to-irqchip move
ARM: mxs_defconfig: Select CONFIG_DEVTMPFS_MOUNT
ARM: mxs: decrease mxs_clockevent_device.min_delta_ns to 2 clock cycles
ARM: mxs: use apbx bus clock to drive the timers on timrotv2
Pull ARM SoC multiplatform support from Arnd Bergmann:
"Converting more ARM platforms to multiplatform support. This time,
OMAP gets converted, which is a major step since this is by far the
largest platform in terms of code size. The same thing happens to the
vt8500 platform."
* tag 'multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
net: cwdavinci_cpdma: export symbols for cpsw
remoteproc: omap: depend on OMAP_MBOX_FWK
[media] davinci: do not include mach/hardware.h
ARM: OMAP2+: Make sure files with omap initcalls include soc.h
ARM: OMAP2+: Include soc.h to drm.c to fix compiling
ARM: OMAP2+: Fix warning for hwspinlock omap_postcore_initcall
ARM: multi_v7_defconfig: add ARCH_ZYNQ
ARM: multi_v7_defconfig: remove unnecessary CONFIG_GPIOLIB
arm: vt8500: Remove remaining mach includes
arm: vt8500: Convert debug-macro.S to be multiplatform friendly
arm: vt8500: Remove single platform Kconfig options
ARM: OMAP2+: Remove now obsolete uncompress.h and debug-macro.S
ARM: OMAP2+: Add minimal support for booting vexpress
ARM: OMAP2+: Enable ARCH_MULTIPLATFORM support
ARM: OMAP2+: Disable code that currently does not work with multiplaform
ARM: OMAP2+: Add multiplatform debug_ll support
ARM: OMAP: Fix dmaengine init for multiplatform
ARM: OMAP: Fix i2c cmdline initcall for multiplatform
ARM: OMAP2+: Use omap initcalls
ARM: OMAP2+: Limit omap initcalls to omap only on multiplatform kernels
In drivers/gpio/Kcong, ARCH_REQUIRE_GPIOLIB selects GPIOLIB which in
turn selects GENERIC_GPIO. So GENERIC_GPIO will be selected
automatically for those platforms that select ARCH_REQUIRE_GPIOLIB.
Remove the redundant 'select GENERIC_GPIO' for platforms that already
select ARCH_REQUIRE_GPIOLIB at either mach or plat level.
This patch converts arch-vt8500 to make use of CLKSRC_OF. Doing so
removes the need for include/linux/vt8500_timer.h as vt8500_timer_init
no longer needs to be visible outside vt8500_timer.c
This patch moves arch-vt8500/timer.c into drivers/clocksource and
updates the necessary Kconfig/Makefile options.
This patch adds support for the WM8750 (ARMv6) and WM8850 (ARMv7).
Devicetree documentation is updated for new SoCs.
Single-platform Kconfig options are removed, making arch-vt8500
multiplatform only.
This patch almosts completes the conversion to ARCH_MULTI_V5
for arch-vt8500.
Both single platform and multiplatform configurations are supported
until earlyprintk support is available for multiplatform.
Merged existing board files to a single dt-capable file.
Converted irq and timer code to devicetree.
Removed existing device files that are no longer required with
devicetree support.
All existing platform devices are converted to devicetree nodes
except PWM.
Removed restart.c and moved code into vt8500.c to remove
duplicate PMC code.
This adds support for the family of Systems-on-Chip produced initially
by VIA and now its subsidiary WonderMedia that have recently become
widespread in lower-end Chinese ARM-based tablets and netbooks.
Support is included for both VT8500 and WM8505, selectable by a
configuration switch at kernel build time.
Included are basic machine initialization files, register and
interrupt definitions, support for the on-chip interrupt controller,
high-precision OS timer, GPIO lines, necessary macros for early debug,
pulse-width-modulated outputs control, as well as platform device
configurations for the specific drivers implemented elsewhere.
Signed-off-by: Alexey Charkov <alchark@gmail.com>
