path: root/arch/arm/mach-vt8500
2019-05-30treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 156Thomas Gleixner
Based on 1 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms of the gnu general public license as published by the free software foundation either version 2 of the license or at your option any later version this program is distributed in the hope that it will be useful but without any warranty without even the implied warranty of merchantability or fitness for a particular purpose see the gnu general public license for more details you should have received a copy of the gnu general public license along with this program if not write to the free software foundation inc 59 temple place suite 330 boston ma 02111 1307 usa extracted by the scancode license scanner the SPDX license identifier GPL-2.0-or-later has been chosen to replace the boilerplate/reference in 1334 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Allison Randal <allison@lohutok.net> Reviewed-by: Richard Fontana <rfontana@redhat.com> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190527070033.113240726@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-21treewide: Add SPDX license identifier - Makefile/KconfigThomas Gleixner
Add SPDX license identifiers to all Make/Kconfig files which: - Have no license information of any form These files fall under the project license, GPL v2 only. The resulting SPDX license identifier is: GPL-2.0-only Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-02arm: vt8500: kconfig: Remove blank help textUlf Magnusson
Blank help texts are probably either a typo, a Kconfig misunderstanding, or some kind of half-committing to adding a help text (in which case a TODO comment would be clearer, if the help text really can't be added right away). Best to remove them, IMO. Signed-off-by: Ulf Magnusson <ulfalizer@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-01Merge tag 'armsoc-cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Olof Johansson: "The cleanup branch keeps going down in size as we've completed a lot of the major legacy platform removals and conversions. A handful of changes this time around, some of the themes or larger sets are: - A bunch of i.MX cleanups around platform detection, init call cleanups - Misc fixes of missing/implicit includes - Removal of ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIB" * tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (40 commits) ARM: mps2: fix typo ARM: s3c64xx: avoid warning about 'struct device_node' bus: mvebu-mbus: make mvebu_mbus_syscore_ops static bus: mvebu-mbus: fix __iomem on register pointers ARM: tegra: Remove board_init_funcs array ARM: iop: Fix indentation ARM: imx: remove cpu_is_mx*() ARM: imx: remove last call to cpu_is_mx5* ARM: imx: rework mx27_pm_init() call ARM: imx: deconstruct mx3_idle ARM: imx: deconstruct mxc_rnga initialization ARM: imx: remove cpu_is_mx1 check ARM: i.MX: Do not explicitly call l2x0_of_init() ARM: i.MX: system.c: Tweak prefetch settings for performance ARM: i.MX: system.c: Replace magic numbers ARM: i.MX: system.c: Remove redundant errata 752271 code ARM: i.MX: system.c: Convert goto to if statement ARM: Kirkwood: fix kirkwood_pm_init() declaration/type ARM: Kirkwood: make kirkwood_disable_mbus_error_propagation() static ARM: orion5x: make orion5x_legacy_handle_irq static ...
2016-06-23arm: Remove unnecessary of_platform_populate with default match tableKefeng Wang
After patch "of/platform: Add common method to populate default bus", it is possible for arch code to remove unnecessary callers of of_platform_populate with default match table. Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Ray Jui <rjui@broadcom.com> Cc: Lee Jones <lee@kernel.org> Cc: Krzysztof Halasa <khalasa@piap.pl> Cc: Kukjin Kim <kgene@kernel.org> Cc: Rob Herring <robh@kernel.org> Cc: Shawn Guo <shawnguo@kernel.org> Cc: Santosh Shilimkar <ssantosh@kernel.org> Cc: Roland Stigge <stigge@antcom.de> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: Heiko Stuebner <heiko@sntech.de> Cc: Viresh Kumar <vireshk@kernel.org> Cc: Shiraz Hashim <shiraz.linux.kernel@gmail.com> Cc: Tony Prisk <linux@prisktech.co.nz> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com> Signed-off-by: Rob Herring <robh@kernel.org>
2016-06-03ARM: do away with ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIBLinus Walleij
This replaces: - "select ARCH_REQUIRE_GPIOLIB" with "select GPIOLIB" as this can now be selected directly. - "select ARCH_WANT_OPTIONAL_GPIOLIB" with no dependency: GPIOLIB is now selectable by everyone, so we need not declare our intent to select it. When ordering the symbols the following rationale was used: if the selects were in alphabetical order, I moved select GPIOLIB to be in alphabetical order, but if the selects were not maintained in alphabetical order, I just replaced "select ARCH_REQUIRE_GPIOLIB" with "select GPIOLIB". Cc: Michael Büsch <m@bues.ch> Cc: arm@kernel.org Cc: linux-arm-kernel@lists.infradead.org Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-09-26arm, vt8500, LLVMLlinux: Use mcr instead of mcr% for mach-vt8500Behan Webster
The ASM below does not compile with clang and is not the way that the mcr command is used in other parts of the kernel. arch/arm/mach-vt8500/vt8500.c:72:11: error: invalid % escape in inline assembly string asm("mcr%? p15, 0, %0, c7, c0, 4" : : "r" (0)); ~~~~~^~~~~~~~~~~~~~~~~~~~~~~~ 1 error generated. There are other forms that are supported on different ARM instruction sets but generally the kernel just uses mcr as it is supported in all ARM instruction sets. Signed-off-by: Behan Webster <behanw@converseincode.com> Reviewed-by: Mark Charlebois <charlebm@gmail.com> Acked-by: Will Deacon <will.deacon@arm.com> Acked-by: Tony Prisk <linux@prisktech.co.nz> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-07-06ARM: vt8500: Staticize local symbolsSachin Kamat
Variables local to this file are made static. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Sachin Kamat <sachin.kamat@samsung.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Tony Prisk <linux@prisktech.co.nz> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-06-17ARM: Remove ARCH_HAS_CPUFREQ config optionStephen Boyd
This config exists entirely to hide the cpufreq menu from the kernel configuration unless a platform has selected it. Nothing is actually built if this config is 'Y' and it just leads to more patches that add a select under a platform Kconfig so that some other CPUfreq option can be chosen. Let's remove the option so that we can always enable CPUfreq drivers on ARM platforms. Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-02-19ARM: vt8500: enable V6K instead of plain V6Rob Herring
The wm8750 is an ARM1176 which has all the V6K extensions except for SMP, so V6K should be selected instead. Dropping the select will use the default for ARCH_MULTI_V6 which is V6K. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Tony Prisk <linux@prisktech.co.nz>
2014-02-19ARM: centralize common multi-platform kconfig optionsRob Herring
Multi-platform requires various kconfig options to be selected, so platforms don't need to select them individually. Signed-off-by: Rob Herring <robh@kernel.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2013-10-07ARM: drop explicit selection of HAVE_CLK and CLKDEV_LOOKUPUwe Kleine-König
CLKDEV_LOOKUP selects HAVE_CLK and COMMON_CLK selects CLKDEV_LOOKUP. So all symbols that select at least two of these symbols can be simplified. For imx, omap2 and ux500 some rearrangements were necessary before the simplification. Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Stephen Boyd <sboyd@codeaurora.org> Acked-by: Dinh Nguyen <dinguyen@altera.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Pawel Moll <pawel.moll@arm.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-09-29ARM: vt8500: remove custom .init_time hookSebastian Hesselbarth
With arch/arm calling of_clk_init(NULL) from time_init(), we can now remove custom .init_time hooks. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Tony Prisk <linux@prisktech.co.nz>
2013-09-29ARM: vt8500: prepare for arch-wide .init_time callbackSebastian Hesselbarth
Current vt8500 board init calls of_clk_init() from vtwm_clk_init. To allow consolidation of DT driven .time_init, move of_clock_init() to a temporary .time_init callback that will be removed when arch-wide callback is available. With previous pmc_base parsing helper for vt8500 clock providers, we can also safely remove the call to vtwm_clk_init() and get rid of some includes. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Tony Prisk <linux@prisktech.co.nz> Acked-by: Mike Turquette <mturquette@linaro.org>
2013-07-09reboot: arm: change reboot_mode to use enum reboot_modeRobin Holt
Preparing to move the parsing of reboot= to generic kernel code forces the change in reboot_mode handling to use the enum. [akpm@linux-foundation.org: fix arch/arm/mach-socfpga/socfpga.c] Signed-off-by: Robin Holt <holt@sgi.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Russ Anderson <rja@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-31Merge tag 'arm-soc-cleanups-for-3.11' of git://github.com/mripard/linux into ↵Olof Johansson
next/cleanup From Maxime Ripard: Cleanups in various machine definitions - Patches to remove the .init_irq definition when using irqchip_init - Make the ARM core code call debug_ll_io_init when no map_io callback is declared - Remove the .map_io definition in the various machines using it (Some of these go through the platform maintainers, these are the ones who got explicitly acked and not picked up by anyone else) Signed-off-by: Olof Johansson <olof@lixom.net> * tag 'arm-soc-cleanups-for-3.11' of git://github.com/mripard/linux: ARM: sunxi: Remove the .map_io function declaration ARM: mxs: remove the .map_io declaration ARM: highbank: remove the .map_io declaration ARM: mmu: Call debug_ll_io_init if no map_io function is specified ARM: vt8500: Remove init_irq declaration in machine description ARM: virt: Remove init_irq declaration in machine description ARM: vexpress: Remove init_irq declaration in machine description ARM: sirf: Remove init_irq declaration in machine description ARM: spear: Remove init_irq declaration in machine description ARM: nomadik: Remove init_irq declaration in machine description
2013-05-24ARM: vt8500: Remove init_irq declaration in machine descriptionMaxime Ripard
Commit ebafed7a ("ARM: irq: Call irqchip_init if no init_irq function is specified") removed the need to explictly setup the init_irq field in the machine description when using only irqchip_init. Remove that declaration for vt8500 as well. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Tony Prisk <linux@prisktech.co.nz>
2013-05-20ARM: vt8500: Add missing NULL terminator in dt_compatSrinivas Kandagatla
When I tried booting a stih415 Dual core A9 with multi_v7_defconfig, it failed to boot. The issues seems to be changing by enabling or disabling VT8550 platform. Having a quick look at dt_compat list, it seems to miss a NULL terminator, which means of_flat_dt_match will compat check will cross the boundary of dt_compat and fault at some point , which is what was happening in my case. Without this patch if we try to boot multi_v7_defconfig you might notice that some of the platforms might fault if they fall after vt8500 in machine-desc list. Other platforms which fall before vt8500 in mdesc list will not fault. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com> Acked-by: Tony Prisk <linux@prisktech.co.nz> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-04-12irqchip: vt8500: Convert arch-vt8500 to new irqchip infrastructureTony Prisk
This patch moves the arch-vt8500 irq code to drivers/irqchip and converts it to use the new IRQCHIP_DECLARE and irqchip_init. This allows the removal of some more functions from common.h Signed-off-by: Tony Prisk <linux@prisktech.co.nz> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-04-04pinctrl: gpio: vt8500: Add pincontrol driver for arch-vt8500Tony Prisk
This patch adds support for the GPIO/pinmux controller found on the VIA VT8500 and Wondermedia WM8xxx-series SoCs. Each pin within the controller is capable of operating as a GPIO or as an alternate function. The pins are numbered according to their control bank/bit so that if new pins are added, the existing numbering is maintained. All currently supported SoCs are included: VT8500, WM8505, WM8650, WM8750 and WM8850. Signed-off-by: Tony Prisk <linux@prisktech.co.nz> Reviewed-by: Stephen Warren <swarren@nvidia.com> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2013-02-21Merge tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC-specific updates from Arnd Bergmann: "This is a larger set of new functionality for the existing SoC families, including: - vt8500 gains support for new CPU cores, notably the Cortex-A9 based wm8850 - prima2 gains support for the "marco" SoC family, its SMP based cousin - tegra gains support for the new Tegra4 (Tegra114) family - socfpga now supports a newer version of the hardware including SMP - i.mx31 and bcm2835 are now using DT probing for their clocks - lots of updates for sh-mobile - OMAP updates for clocks, power management and USB - i.mx6q and tegra now support cpuidle - kirkwood now supports PCIe hot plugging - tegra clock support is updated - tegra USB PHY probing gets implemented diffently" * tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (148 commits) ARM: prima2: remove duplicate v7_invalidate_l1 ARM: shmobile: r8a7779: Correct TMU clock support again ARM: prima2: fix __init section for cpu hotplug ARM: OMAP: Consolidate OMAP USB-HS platform data (part 3/3) ARM: OMAP: Consolidate OMAP USB-HS platform data (part 1/3) arm: socfpga: Add SMP support for actual socfpga harware arm: Add v7_invalidate_l1 to cache-v7.S arm: socfpga: Add entries to enable make dtbs socfpga arm: socfpga: Add new device tree source for actual socfpga HW ARM: tegra: sort Kconfig selects for Tegra114 ARM: tegra: enable ARCH_REQUIRE_GPIOLIB for Tegra114 ARM: tegra: Fix build error w/ ARCH_TEGRA_114_SOC w/o ARCH_TEGRA_3x_SOC ARM: tegra: Fix build error for gic update ARM: tegra: remove empty tegra_smp_init_cpus() ARM: shmobile: Register ARM architected timer ARM: MARCO: fix the build issue due to gic-vic-to-irqchip move ARM: shmobile: r8a7779: Correct TMU clock support ARM: mxs_defconfig: Select CONFIG_DEVTMPFS_MOUNT ARM: mxs: decrease mxs_clockevent_device.min_delta_ns to 2 clock cycles ARM: mxs: use apbx bus clock to drive the timers on timrotv2 ...
2013-02-21Merge tag 'multiplatform' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC multiplatform support from Arnd Bergmann: "Converting more ARM platforms to multiplatform support. This time, OMAP gets converted, which is a major step since this is by far the largest platform in terms of code size. The same thing happens to the vt8500 platform." * tag 'multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: net: cwdavinci_cpdma: export symbols for cpsw remoteproc: omap: depend on OMAP_MBOX_FWK [media] davinci: do not include mach/hardware.h ARM: OMAP2+: Make sure files with omap initcalls include soc.h ARM: OMAP2+: Include soc.h to drm.c to fix compiling ARM: OMAP2+: Fix warning for hwspinlock omap_postcore_initcall ARM: multi_v7_defconfig: add ARCH_ZYNQ ARM: multi_v7_defconfig: remove unnecessary CONFIG_GPIOLIB arm: vt8500: Remove remaining mach includes arm: vt8500: Convert debug-macro.S to be multiplatform friendly arm: vt8500: Remove single platform Kconfig options ARM: OMAP2+: Remove now obsolete uncompress.h and debug-macro.S ARM: OMAP2+: Add minimal support for booting vexpress ARM: OMAP2+: Enable ARCH_MULTIPLATFORM support ARM: OMAP2+: Disable code that currently does not work with multiplaform ARM: OMAP2+: Add multiplatform debug_ll support ARM: OMAP: Fix dmaengine init for multiplatform ARM: OMAP: Fix i2c cmdline initcall for multiplatform ARM: OMAP2+: Use omap initcalls ARM: OMAP2+: Limit omap initcalls to omap only on multiplatform kernels
2013-02-05Merge tag 'cleanup-decompwdog-3.9' of ↵Olof Johansson
git://git.linaro.org/people/shawnguo/linux-2.6 into next/cleanup From Shawn Guo: The series cleans up ARCH_HAS_DECOMP_WDOG and arch_decomp_wdog which are unused on ARM architecure. Samsung has some code setting up wdog in arch_decomp_wdog(). But since CONFIG_S3C_BOOT_WATCHDOG is defined nowhere, it will not run. Otherwise, system can not boot at all when wdog is set up but no one pats it. * tag 'cleanup-decompwdog-3.9' of git://git.linaro.org/people/shawnguo/linux-2.6: ARM: samsung: remove unused arch_decomp_wdog() code ARM: remove unused arch_decomp_wdog() ARM: decompress: remove unused ARCH_HAS_DECOMP_WDOG Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-27Merge branch 'depends/cleanup' into next/socOlof Johansson
2013-01-22ARM: remove redundant 'select GENERIC_GPIO'Shawn Guo
In drivers/gpio/Kcong, ARCH_REQUIRE_GPIOLIB selects GPIOLIB which in turn selects GENERIC_GPIO. So GENERIC_GPIO will be selected automatically for those platforms that select ARCH_REQUIRE_GPIOLIB. Remove the redundant 'select GENERIC_GPIO' for platforms that already select ARCH_REQUIRE_GPIOLIB at either mach or plat level. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-15timer: vt8500: Convert vt8500 to use CLKSRC_OFTony Prisk
This patch converts arch-vt8500 to make use of CLKSRC_OF. Doing so removes the need for include/linux/vt8500_timer.h as vt8500_timer_init no longer needs to be visible outside vt8500_timer.c Signed-off-by: Tony Prisk <linux@prisktech.co.nz> Reviewed-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-14timer: vt8500: Move timer code to drivers/clocksourceTony Prisk
This patch moves arch-vt8500/timer.c into drivers/clocksource and updates the necessary Kconfig/Makefile options. Signed-off-by: Tony Prisk <linux@prisktech.co.nz>
2013-01-12arm: vt8500: Add support for Wondermedia WM8750/WM8850Tony Prisk
This patch adds support for the WM8750 (ARMv6) and WM8850 (ARMv7). Devicetree documentation is updated for new SoCs. Signed-off-by: Tony Prisk <linux@prisktech.co.nz>
2013-01-12arm: vt8500: Remove remaining mach includesTony Prisk
Remove the last two mach-vt8500/include/mach headers as they are no longer required with multiplatform-only configuration. Signed-off-by: Tony Prisk <linux@prisktech.co.nz>
2013-01-12arm: vt8500: Convert debug-macro.S to be multiplatform friendlyTony Prisk
This patch moves debug-macro.S from arm/mach-vt8500/include/mach to arm/include/debug/vt8500.S to provide multiplatform support. Minor style changes in code for readability. Signed-off-by: Tony Prisk <linux@prisktech.co.nz>
2013-01-12arm: vt8500: Remove single platform Kconfig optionsTony Prisk
Single-platform Kconfig options are removed, making arch-vt8500 multiplatform only. Signed-off-by: Tony Prisk <linux@prisktech.co.nz>
2013-01-11ARM: remove unused arch_decomp_wdog()Shawn Guo
With ARCH_HAS_DECOMP_WDOG removed from arch/arm/boot/compressed/decompress.c, all the arch_decomp_wdog() definition at platform level is unneeded. Remmove it. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Jason Cooper <jason@lakedaemon.net>
2012-12-24ARM: delete struct sys_timerStephen Warren
Now that the only field in struct sys_timer is .init, delete the struct, and replace the machine descriptor .timer field with the initialization function itself. This will enable moving timer drivers into drivers/clocksource without having to place a public prototype of each struct sys_timer object into include/linux; the intent is to create a single of_clocksource_init() function that determines which timer driver to initialize by scanning the device dtree, much like the proposed irqchip_init() at: http://www.spinics.net/lists/arm-kernel/msg203686.html Includes mach-omap2 fixes from Igor Grinberg. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-12-13Merge tag 'multiplatform' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC multiplatform conversion patches from Olof Johansson: "Here are more patches in the progression towards multiplatform, sparse irq conversions in particular. Tegra has a handful of cleanups and general groundwork, but is not quite there yet on full enablement. Platforms that are enabled through this branch are VT8500 and Zynq. Note that i.MX was converted in one of the earlier cleanup branches as well (before we started a separate topic for multiplatform). And both new platforms for this merge window, sunxi and bcm, were merged with multiplatform support enabled." Fix up conflicts mostly as per Olof. * tag 'multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (29 commits) ARM: zynq: Remove all unused mach headers ARM: zynq: add support for ARCH_MULTIPLATFORM ARM: zynq: make use of debug_ll_io_init() ARM: zynq: remove TTC early mapping ARM: tegra: move debug-macro.S to include/debug ARM: tegra: don't include iomap.h from debug-macro.S ARM: tegra: decouple uncompress.h and debug-macro.S ARM: tegra: simplify DEBUG_LL UART selection options ARM: tegra: select SPARSE_IRQ ARM: tegra: enhance timer.c to get IO address from device tree ARM: tegra: enhance timer.c to get IRQ info from device tree ARM: timer: fix checkpatch warnings ARM: tegra: add TWD to device tree ARM: tegra: define DT bindings for and instantiate RTC ARM: tegra: define DT bindings for and instantiate timer clocksource/mtu-nomadik: use apb_pclk clk: ux500: Register mtu apb_pclocks ARM: plat-nomadik: convert platforms to SPARSE_IRQ mfd/db8500-prcmu: use the irq_domain_add_simple() mfd/ab8500-core: use irq_domain_add_simple() ...
2012-10-26ARM: vt8500: Convert arch-vt8500 to multiplatformTony Prisk
This patch almosts completes the conversion to ARCH_MULTI_V5 for arch-vt8500. Both single platform and multiplatform configurations are supported until earlyprintk support is available for multiplatform. Signed-off-by: Tony Prisk <linux@prisktech.co.nz> Acked-by: Arnd Bergmann <arnd@arndb.de>
2012-10-26arm: vt8500: Convert irq.c for multiplatform integrationTony Prisk
This patch converts arch-vt8500/irq.c to MULTI_IRQ_HANDLER and SPARSE_IRQ. IRQ domain is changed from legacy to linear. Also, remove legacy code in include/mach/entry-macro.S and include/mach/irq.h to prepare for multiplatform. Signed-off-by: Tony Prisk <linux@prisktech.co.nz> Acked-by: Arnd Bergmann <arnd@arndb.de>
2012-10-15vt8500: Fix header in mach-vt8500/timer.cTony Prisk
Correct filename reference in file header. Signed-off-by: Tony Prisk <linux@prisktech.co.nz>
2012-10-15vt8500: Remove unused headers from include/mach/Tony Prisk
Remove restart.h and reference in vt8500.c - unused. Remove hardware.h - empty and now optional. Remove i8042.h - not supported now that devicetree-only. Signed-off-by: Tony Prisk <linux@prisktech.co.nz>
2012-10-07arm: vt8500: Fix build warning in uncompress.hTony Prisk
This removes a build-time warning in uncompress.h due to incorrectly cast values being passed to readb/writeb. Removed arm/io.h and readb/writeb. Read/write directly to the serial port with a volatile pointer. Signed-off-by: Tony Prisk <linux@prisktech.co.nz> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-10-07vt8500: Fix build warning when no framebuffer selectedTony Prisk
Check for framebuffer defines before declaring variables in vt8500.c Removes a compile-time warning about unused variables. Signed-off-by: Tony Prisk <linux@prisktech.co.nz> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-10-01Merge tag 'multiplatform' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM soc multiplatform enablement from Olof Johansson: "This is a pretty significant branch. It's the introduction of the first multiplatform support on ARM, and with this (and the later branch) merged, it is now possible to build one kernel that contains support for highbank, vexpress, mvebu, socfpga, and picoxcell. More platforms will be convered over in the next few releases. Two critical last things had to be done for this to be practical and possible: * Today each platform has its own include directory under mach-<mach>/include/mach/*, and traditionally that is where a lot of driver/platform shared definitions have gone, such as platform data structures. They now need to move out to a common location instead, and this branch moves a large number of those out to include/linux/platform_data. * Each platform used to list the device trees to compile for its boards in mach-<mach>/Makefile.boot. Both of the above changes will mean that there are some merge conflicts to come (and some to resolve here). It's a one-time move and once it settles in, we should be good for quite a while. Sorry for the overhead." Fix conflicts as per Olof. * tag 'multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (51 commits) ARM: add v7 multi-platform defconfig ARM: msm: Move core.h contents into common.h ARM: highbank: call highbank_pm_init from .init_machine ARM: dtb: move all dtb targets to common Makefile ARM: spear: move platform_data definitions ARM: samsung: move platform_data definitions ARM: orion: move platform_data definitions ARM: vexpress: convert to multi-platform ARM: initial multiplatform support ARM: mvebu: move armada-370-xp.h in mach dir ARM: vexpress: remove dependency on mach/* headers ARM: picoxcell: remove dependency on mach/* headers ARM: move all dtb targets out of Makefile.boot ARM: picoxcell: move debug macros to include/debug ARM: socfpga: move debug macros to include/debug ARM: mvebu: move debug macros to include/debug ARM: vexpress: move debug macros to include/debug ARM: highbank: move debug macros to include/debug ARM: move debug macros to common location ARM: make mach/gpio.h headers optional ...
2012-09-29arm: vt8500: Fixup for missing gpio.hTony Prisk
mach/include/gpio.h was removed as part of the multiplatform-3.7 update. This patch removes the include from arch-vt8500/vt8500.c Signed-off-by: Tony Prisk <linux@prisktech.co.nz> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-22Merge branch 'multiplatform/platform-data' into next/multiplatformOlof Johansson
* multiplatform/platform-data: ARM: spear: move platform_data definitions ARM: samsung: move platform_data definitions ARM: orion: move platform_data definitions ARM: nomadik: move platform_data definitions ARM: w90x900: move platform_data definitions ARM: vt8500: move platform_data definitions ARM: tegra: move sdhci platform_data definition ARM: sa1100: move platform_data definitions ARM: pxa: move platform_data definitions ARM: netx: move platform_data definitions ARM: msm: move platform_data definitions ARM: imx: move platform_data definitions ARM: ep93xx: move platform_data definitions ARM: davinci: move platform_data definitions ARM: at91: move platform_data definitions Conflicts due to removed files: arch/arm/mach-tegra/board-harmony.c arch/arm/mach-tegra/board-trimslice.c Conflicts due to code removal: arch/arm/mach-tegra/board-paz00.c Context conflicts in: drivers/mmc/host/sdhci-tegra.c drivers/net/irda/pxaficp_ir.c Signed-off-by: Olof Johansson <olof@lixom.net>
2012-09-21arm: vt8500: Update arch-vt8500 to devicetree support.Tony Prisk
Merged existing board files to a single dt-capable file. Converted irq and timer code to devicetree. Removed existing device files that are no longer required with devicetree support. All existing platform devices are converted to devicetree nodes except PWM. Removed restart.c and moved code into vt8500.c to remove duplicate PMC code. Signed-off-by: Tony Prisk <linux@prisktech.co.nz> Acked-by: Arnd Bergmann <arnd@arndb.de>
2012-09-14ARM: make mach/gpio.h headers optionalRob Herring
Most platforms don't need mach/gpio.h and it prevents multi-platform kernel images. Add CONFIG_NEED_MACH_GPIO_H and make platforns select it if they need gpio.h. This is platforms that define __GPIOLIB_COMPLEX or have lots of implicit includes pulled in by mach/gpio.h. at91 and omap have gpio clean-up pending and can drop CONFIG_NEED_MACH_GPIO_H once that is in. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Jason Cooper <jason@lakedaemon.net> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2012-09-14ARM: vt8500: move platform_data definitionsArnd Bergmann
Platform data for device drivers should be defined in include/linux/platform_data/*.h, not in the architecture and platform specific directories. This moves such data out of the vt8500 include directories Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Tony Prisk <linux@prisktech.co.nz> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
2012-07-30Merge branch 'for-3.6' of git://gitorious.org/linux-pwm/linux-pwmLinus Torvalds
Pull PWM subsystem from Thierry Reding: "The new PWM subsystem aims at collecting all implementations of the legacy PWM API and to eventually replace it completely. The subsystem has been in development for over half a year now and many drivers have already been converted. It has been in linux-next for a couple of weeks and there have been no major issues so I think it is ready for inclusion in your tree." Arnd Bergmann <arnd@arndb.de>: "Very much Ack on the new subsystem. It uses the interface declarations as the previously separate pwm drivers, so nothing changes for now in the drivers using it, although it enables us to change those more easily in the future if we want to. This work is also one of the missing pieces that are required to eventually build ARM kernels for multiple platforms, which is currently prohibited (amongs other things) by the fact that you cannot have more than one driver exporting the pwm functions." Tested-and-acked-by: Alexandre Courbot <acourbot@nvidia.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Philip, Avinash <avinashphilip@ti.com> # TI's AM33xx platforms Acked-By: Alexandre Pereira da Silva <aletes.xgr@gmail.com> # LPC32XX Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Sachin Kamat <sachin.kamat@linaro.org> Fix up trivial conflicts with other cleanups and DT updates. * 'for-3.6' of git://gitorious.org/linux-pwm/linux-pwm: (36 commits) pwm: pwm-tiehrpwm: PWM driver support for EHRPWM pwm: pwm-tiecap: PWM driver support for ECAP APWM pwm: fix used-uninitialized warning in pwm_get() pwm: add lpc32xx PWM support pwm_backlight: pass correct brightness to callback pwm: Use pr_* functions in pwm-samsung.c file pwm: Convert pwm-samsung to use devm_* APIs pwm: Convert pwm-tegra to use devm_clk_get() pwm: pwm-mxs: Return proper error if pwmchip_remove() fails pwm: pwm-bfin: Return proper error if pwmchip_remove() fails pwm: pxa: Propagate pwmchip_remove() error pwm: Convert pwm-pxa to use devm_* APIs pwm: Convert pwm-vt8500 to use devm_* APIs pwm: Convert pwm-imx to use devm_* APIs pwm: Conflict with legacy PWM API pwm: pwm-mxs: add pinctrl support pwm: pwm-mxs: use devm_* managed functions pwm: pwm-mxs: use global reset function stmp_reset_block pwm: pwm-mxs: encode soc name in compatible string pwm: Take over maintainership of the PWM subsystem ...
2012-07-18ARM:vt8500: Convert to use .restart and remove arch_reset()Tony Prisk
Removed system.h as it only contained an inline for arch_reset() Changed the existing board files to use .restart in there machine descriptions. Added device tree support for the restart controller. Device tree support for mach-vt8500 is still a work-in-progress. Signed-off-by: Tony Prisk <linux@prisktech.co.nz> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-07-02ARM vt8500: Move vt8500 pwm driver to pwm frameworkSascha Hauer
Move the driver to drivers/pwm/ and convert it to use the framework. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Cc: Alexey Charkov <alchark@gmail.com> Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
