path: root/arch/arm/mach-w90x900
2011-07-19ARM: Consolidate the clkdev header filesKyungmin Park
Now most of ARM machines has the alsmot same __clk_get/put() macro So place it at the arch/arm/include/asm/clkdev.h and remove the reduntant header files But some machines don't have the same form as above. It can use the machince specific clkdev file by HAVE_MACH_CLKDEV config Now there are only 3 caese. 1) define the clk structure with clkdev macro => Need to move clk structure to proper header file arch/arm/mach-versatile/include/mach/clkdev.h arch/arm/mach-realview/include/mach/clkdev.h arch/arm/mach-vexpress/include/mach/clkdev.h arch/arm/mach-integrator/include/mach/clkdev.h 2) export the __clk_get/put function at clock.c arch/arm/mach-shmobile/include/mach/clkdev.h 3) demuxing the clk source arch/arm/mach-u300/include/mach/clkdev.h Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2011-05-23Merge branch 'devel-stable' into for-linusRussell King
Conflicts: arch/arm/Kconfig arch/arm/mach-ns9xxx/include/mach/uncompress.h
2011-05-23clocksource: convert W90x900 24-bit down counting clocksourceRussell King
Convert the W90x900 24-bit down-counting clocksource to the generic mmio clocksource infrastructure Acked-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-07ARM: zImage: remove the static qualifier from global data variablesNicolas Pitre
To be able to relocate the .bss section at run time independently from the rest of the code, we must make sure that no GOTOFF relocations are used with .bss symbols. This usually means that no global variables can be marked static unless they're also const. Let's remove the static qualifier from current offenders, or turn them into const variables when possible. Next commit will ensure the build fails if one of those is reintroduced due to otherwise enforced coding standards for the kernel. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Tested-by: Tony Lindgren <tony@atomide.com>
2011-03-29arm: Fold irq_set_chip/irq_set_handlerThomas Gleixner
Use irq_set_chip_and_handler() instead. Converted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: Cleanup the irq namespaceThomas Gleixner
Convert to the new function names. Automated with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-17ARM: P2V: separate PHYS_OFFSET from platform definitionsRussell King
This uncouple PHYS_OFFSET from the platform definitions, thereby facilitating run-time computation of the physical memory offset. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Magnus Damm <damm@opensource.se> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-13ARM: w90x900: irq_data conversion.Lennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca> Acked-by: Wan ZongShun <mcuos.com@gmail.com>
2011-01-06Merge branch 'misc' into develRussell King
Conflicts: arch/arm/Kconfig arch/arm/common/Makefile arch/arm/kernel/Makefile arch/arm/kernel/smp.c
2010-12-22ARM: nuc: update clock source registrationRussell King
In d7e81c2 (clocksource: Add clocksource_register_hz/khz interface) new interfaces were added which simplify (and optimize) the selection of the divisor shift/mult constants. Switch over to using this new interface. Acked-by: Wan zongshun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-11-26ARM: 6483/1: arm & sh: factorised duplicated clkdev.cJean-Christop PLAGNIOL-VILLARD
factorise some generic infrastructure to assist looking up struct clks for the ARM & SH architecture. as the code is identical at 99% put the arch specific code for allocation as example in asm/clkdev.h Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-08-11i2c/nuc900: add i2c driver support for nuc900Wan ZongShun
This patch is to add i2c driver support for nuc900. Signed-off-by: Wan ZongShun <mcuos.com@gmail.org> Reviewed-by: Marek Vasut <marek.vasut@gmail.com> Reviewed-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-07-31Merge branches 'at91', 'ep93xx', 'kexec', 'iop', 'lmb', 'nomadik', 'nuc', ↵Russell King
'pl', 'spear' and 'versatile' into devel
2010-07-29ARM: 6274/1: add global control registers definition header file for nuc900wanzongshun
add global control registers definition header file for nuc900 Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-22ARM: 6250/1: patch for modifying spi flash configurationwanzongshun
This patch is to modify spi flash configuration, the previous one can make spi driver work failed. Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-22ARM: 6249/1: add nuc900 kpi platform_device structure to nuc910_devwanzongshun
Add nuc900 kpi platform_device structure to nuc910_dev Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-22ARM: 6232/1: add nuc900 keypad arch platform datawanzongshun
This patch is to add nuc900 keypad arch platform data. Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-22ARM: 6231/1: re-organize the nuc900 lcd arch platform data settingwanzongshun
The patch re-organizes the nuc900 lcd arch platform data, remove the lcd platform data setting from nuc950.c to dev.c It can maximize the share codes between nuc900 series MCUs. Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-22ARM: 6230/1: fix nuc900 touchscreen clk definition bugwanzongshun
This patch is to fix nuc900 touchscreen clk definition bug,the .dev_id's name should be 'nuc900-ts', it should be the same to pdev.name. or else, the touchscreen driver will be not working well due to clock engine disabled. Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-24ARM: 6141/1: Add audio support part in arch/arm/mach-w90x900wanzongshun
Add audio support part in arch/arm/mach-w90x900 Signed-off-by: Wan ZongShun<mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-12NUC900 LCD Controller DriverWang Qiang
An LCD controller driver for nuc900s. The Linux LOGO is just fine and the FB-Test application was ok, too. Signed-off-by: Wang Qiang <rurality.linux@gmail.com> Cc: Wang Zongshun <mcuos.com@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-25Merge branches 'clks' and 'pnx' into develRussell King
2010-02-25Merge branch 'misc2' into develRussell King
2010-02-25Merge branches 'at91', 'cache', 'cup', 'ep93xx', 'ixp4xx', 'nuc', ↵Russell King
'pending-dma-streaming', 'u300' and 'umc' into devel
2010-02-21ARM: 5949/1: NUC900 add gpio virtual memory mapwanzongshun
NUC900 add gpio virtual memory map Signed-off-by: Wang Qiang <rurality.linux@gmail.com> Signed-off-by: Wang Zongshun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-21ARM: 5948/1: Enable timer0 to time4 clock support for nuc910wanzongshun
Enable timer0 to time4 clock support for nuc910 Signed-off-by: Wang Qiang <rurality.linux@gmail.com> Signed-off-by: Wang Zongshun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-15ARM: 5928/1: Change type of VMALLOC_END to unsigned long.Fenkart/Bostandzhyan
Makes it consistent with VMALLOC_START Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Andreas Fenkart <andreas.fenkart@streamunlimited.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-12ARM: Consolidate clks_register() and similarRussell King
Most machine classes want some way to register a block of clk_lookup structures, and most do it by implementing a clks_register() type function which walks an array, or by open-coding a loop. Consolidate all this into clkdev_add_table(). Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-01-05ARM: 5864/1: Implement arch_reset() in NUC900Li Jie
Implement arch_reset(), reboot from shell become possible. Signed-off-by: lijie <eltshanli@gmail.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-01-05ARM: 5863/1: fix bugs of clock source of NUC900Li Jie
This patch fix following bugs: 1. typo error, CLOCK_EVT_MODE_PERIODIC -> CLOCK_EVT_FEAT_PERIODIC 2. TCSR register of timer1 missed PRESCALE 3. timer1 should be enabled before register it to clock source. Signed-off-by: lijie <eltshanli@gmail.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-22ARM: 5856/1: Fix bug of uart0 platfrom data for nuc900wanzongshun
Fix bug of uart0 platfrom data for nuc900 Signed-off-by: lijie <eltshanli@gmail.com> Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-22ARM: 5855/1: putc support for nuc900wanzongshun
putc support for nuc900 Signed-off-by: lijie <eltshanli@gmail.com> Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-22ARM: 5854/1: fix compiling error for NUC900wanzongshun
fix compiling error for NUC900 Signed-off-by: lijie <eltshanli@gmail.com> Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-14Merge branch 'next-spi' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-spi' of git://git.secretlab.ca/git/linux-2.6: (23 commits) spi: fix probe/remove section markings Add OMAP spi100k driver spi-imx: don't access struct device directly but use dev_get_platdata spi-imx: Add mx25 support spi-imx: use positive logic to distinguish cpu variants spi-imx: correct check for platform_get_irq failing ARM: NUC900: Add spi driver support for nuc900 spi: SuperH MSIOF SPI Master driver V2 spi: fix spidev compilation failure when VERBOSE is defined spi/au1550_spi: fix setupxfer not to override cfg with zeros spi/mpc8xxx: don't use __exit_p to wrap plat_mpc8xxx_spi_remove spi/i.MX: fix broken error handling for gpio_request spi/i.mx: drain MXC SPI transfer buffer when probing device MAINTAINERS: add SPI co-maintainer. spi/xilinx_spi: fix incorrect casting spi/mpc52xx-spi: minor cleanups xilinx_spi: add a platform driver using the xilinx_spi common module. xilinx_spi: add support for the DS570 IP. xilinx_spi: Switch to iomem functions and support little endian. xilinx_spi: Split into of driver and generic part. ...
2009-12-13ARM: NUC900: Add spi driver support for nuc900Wan ZongShun
Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2009-12-01ARM: 5842/1: add spi resource support for nuc900wanzongshun
add spi resource support Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-09-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (52 commits) Input: bcm5974 - silence uninitialized variables warnings Input: wistron_btns - add keymap for AOpen 1557 Input: psmouse - use boolean type Input: i8042 - use platform_driver_probe Input: i8042 - use boolean type where it makes sense Input: i8042 - try disabling and re-enabling AUX port at close Input: pxa27x_keypad - allow modifying keymap from userspace Input: sunkbd - fix formatting Input: i8042 - bypass AUX IRQ delivery test on laptops Input: wacom_w8001 - simplify querying logic Input: atkbd - allow setting force-release bitmap via sysfs Input: w90p910_keypad - move a dereference below a NULL test Input: add twl4030_keypad driver Input: matrix-keypad - add function to build device keymap Input: tosakbd - fix cleaning up KEY_STROBEs after error Input: joydev - validate axis/button maps before clobbering current ones Input: xpad - add USB ID for the drumkit controller from Rock Band Input: w90p910_keypad - rename driver name to match platform Input: add new driver for Sentelic Finger Sensing Pad Input: psmouse - allow defining read-only attributes ...
2009-09-02ARM: 5684/1: Add nuc960 platform to w90x900wanzongshun
Add nuc960 platform to w90x900. Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-09-02ARM: 5683/1: Add nuc950 platform to w90x900wanzongshun
Add nuc950 platform to w90x900. Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-09-02ARM: 5682/1: Add cpu.c and dev.c and modify some files of w90p910 platformwanzongshun
Add the cpu.c and dev.c and modify w90p910 platform to apply to use the common API(provided by cpu.c and dev.c) at the same time, I renamed all w90x900 to nuc900 in every c file of w90x900 platform and touchscreen's driver name. Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-08-15ARM: 5675/1: The semaphore is used as mutex so make it a mutexwanzongshun
The semaphore is used as mutex so make it a mutex. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-08-15ARM: 5674/1: Add clocksource/clockevent support for w90p910 platformwanzongshun
Add clocksource/clockevent support for w90p910 platform. Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-08-09Input: w90p910_keypad - adjust to use definitions from matrix_keypad.hDmitry Torokhov
Also have the driver send MSC_SCAN events as most keyboards do to aid in updating keymap from userspace. Tested-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-08-09Input: add keypad driver for w90p910Wan ZongShun
Add keypad driver for the 4x4 keypad on an evaluation board based on w90p910. Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Reviewed-by: Trilok Soni <soni.trilok@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-08-01ARM: 5634/1: Add static setting cpu frequence for w90p910 platformwanzongshun
Add static setting cpu frequence for w90p910 platform. Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-08-01ARM: 5633/1: Add wdt resource for w90p910 platformwanzongshun
Add wdt resource for w90p910 platform. Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-07-23[ARM] 5619/1: Add spi mfp api for w90p910 spi driverwanzongshun
Add spi mfp api for w90p910 spi driver. Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-07-23[ARM] 5618/1: Add spi resource define for w90p910 spi driverwanzongshun
Add spi resource define for w90p910 spi driver. Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
