In many of clk_disable() implementations, it is a no-op for a NULL
pointer input, but this is one of the exceptions.
Making it treewide consistent will allow clock consumers to call
clk_disable() without NULL pointer check.
Acked-by: Wan Zongshun <mcuos.com@gmail.com>
Pull ARM updates from Russell King:
"Another mixture of changes this time around:
- Split XIP linker file from main linker file to make it more
maintainable, and various XIP fixes, and clean up a resulting
macro.
- Decompressor cleanups from Masahiro Yamada
- Avoid printing an error for a missing L2 cache
- Remove some duplicated symbols in System.map, and move
vectors/stubs back into kernel VMA
- Various low priority fixes from Arnd
- Updates to allow bus match functions to return negative errno
values, touching some drivers and the driver core. Greg has acked
these changes.
- Virtualisation platform udpates form Jean-Philippe Brucker.
- Security enhancements from Kees Cook
- Rework some Kconfig dependencies and move PSCI idle management code
out of arch/arm into drivers/firmware/psci.c
- ARM DMA mapping updates, touching media, acked by Mauro.
- Fix places in ARM code which should be using virt_to_idmap() so
that Keystone2 can work.
- Fix Marvell Tauros2 to work again with non-DT boots.
- Provide a delay timer for ARM Orion platforms"
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (45 commits)
ARM: 8546/1: dma-mapping: refactor to fix coherent+cma+gfp=0
ARM: 8547/1: dma-mapping: store buffer information
ARM: 8543/1: decompressor: rename suffix_y to compress-y
ARM: 8542/1: decompressor: merge piggy.*.S and simplify Makefile
ARM: 8541/1: decompressor: drop redundant FORCE in Makefile
ARM: 8540/1: decompressor: use clean-files instead of extra-y to clean files
ARM: 8539/1: decompressor: drop more unneeded assignments to "targets"
ARM: 8538/1: decompressor: drop unneeded assignments to "targets"
ARM: 8532/1: uncompress: mark putc as inline
ARM: 8531/1: turn init_new_context into an inline function
ARM: 8530/1: remove VIRT_TO_BUS
ARM: 8537/1: drop unused DEBUG_RODATA from XIP_KERNEL
ARM: 8536/1: mm: hide __start_rodata_section_aligned for non-debug builds
ARM: 8535/1: mm: DEBUG_RODATA makes no sense with XIP_KERNEL
ARM: 8534/1: virt: fix hyp-stub build for pre-ARMv7 CPUs
ARM: make the physical-relative calculation more obvious
ARM: 8512/1: proc-v7.S: Adjust stack address when XIP_KERNEL
ARM: 8411/1: Add default SPARSEMEM settings
ARM: 8503/1: clk_register_clkdev: remove format string interface
ARM: 8529/1: remove 'i' and 'zi' targets
When CONFIG_DEBUG_ICEDCC is set, we don't use the platform
specific putc() function, but use icedcc_putc() instead, so
putc is unused and causes a compile time warning:
In file included from ../arch/arm/boot/compressed/misc.c:28:0:
arch/arm/mach-rpc/include/mach/uncompress.h:79:13: warning: 'putc' defined but not used [-Wunused-function]
arch/arm/mach-w90x900/include/mach/uncompress.h:30:13: warning: 'putc' defined but not used [-Wunused-function]
On most platforms, this does not happen, because putc is defined
as 'static inline' so the compiler will automatically drop it
when it's unused.
This changes the remaining seven platforms to behave the same way.
This makes the driver use the data pointer added to the gpio_chip
to store a pointer to the state container instead of relying on
container_of().
Cc: arm@kernel.org
Acked-by: Olof Johansson <olof@lixom.net>
Some header files are never included outside of a mach-w90x900
directory and do not need to be made visible in include/mach,
so let's just move them all down one level.
set_irq_flags is ARM specific with custom flags which have genirq
equivalents. Convert drivers to use the genirq interfaces directly, so we
can kill off set_irq_flags. The translation of flags is as follows:
IRQF_VALID -> !IRQ_NOREQUEST
IRQF_PROBE -> !IRQ_NOPROBE
IRQF_NOAUTOEN -> IRQ_NOAUTOEN
For IRQs managed by an irqdomain, the irqdomain core code handles clearing
and setting IRQ_NOREQUEST already, so there is no need to do this in
.map() functions and we can simply remove the set_irq_flags calls. Some
users also modify IRQ_NOPROBE and this has been maintained although it
is not clear that is really needed. There appears to be a great deal of
blind copy and paste of this code.
Signed-off-by: Rob Herring <robh@kernel.org>
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Cc: Gregory Clement <gregory.clement@free-electrons.com>
Acked-by: Hans Ulli Kroll <ulli.kroll@googlemail.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Imre Kaloz <kaloz@openwrt.org>
Acked-by: Krzysztof Halasa <khalasa@piap.pl>
Cc: Greg Ungerer <gerg@uclinux.org>
Cc: Roland Stigge <stigge@antcom.de>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Daniel Mack <daniel@zonque.org>
Cc: Haojian Zhuang <haojian.zhuang@gmail.com>
Cc: Robert Jarzmik <robert.jarzmik@free.fr>
Cc: Simtec Linux Team <linux@simtec.co.uk>
Cc: Kukjin Kim <kgene@kernel.org>
Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Cc: linux-omap@vger.kernel.org
Cc: linux-samsung-soc@vger.kernel.org
Tested-by: Kevin Hilman <khilman@linaro.org>
Migrate w90x900 driver to the new 'set-state' interface provided by
clockevents core, the earlier 'set-mode' interface is marked obsolete
now.
This also enables us to implement callbacks for new states of clockevent
devices, for example: ONESHOT_STOPPED.
Cc: Wan ZongShun <mcuos.com@gmail.com>
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Replace obsolete strict_strto with kstrto calls
Signed-off-by: Daniel Walter <dwalter@google.com>
Pull ARM SoC cleanups from Arnd Bergmann:
"These cleanup patches are mainly move stuff around and should all be
harmless. They are mainly split out so that other branches can be
based on top to avoid conflicts.
Notable changes are:
- We finally remove all mach/timex.h, after CLOCK_TICK_RATE is no
longer used (Uwe Kleine-König)
- The Qualcomm MSM platform is split out into legacy mach-msm and
new-style mach-qcom, to allow easier maintainance of the new
hardware support without regressions (Kumar Gala)
- A rework of some of the Kconfig logic to simplify multiplatform
support (Rob Herring)
- Samsung Exynos gets closer to supporting multiplatform (Sachin
Kamat and others)
- mach-bcm3528 gets merged into mach-bcm (Stephen Warren)
- at91 gains some common clock framework support (Alexandre Belloni,
Jean-Jacques Hiblot and other French people)"
* tag 'cleanup-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (89 commits)
ARM: hisi: select HAVE_ARM_SCU only for SMP
ARM: efm32: allow uncompress debug output
ARM: prima2: build reset code standalone
ARM: at91: add PWM clock
ARM: at91: move sam9261 SoC to common clk
ARM: at91: prepare common clk transition for sam9261 SoC
ARM: at91: updated the at91_dt_defconfig with support for the ADS7846
ARM: at91: dt: sam9261: Device Tree support for the at91sam9261ek
ARM: at91: dt: defconfig: Added the sam9261 to the list of DT-enabled SOCs
ARM: at91: dt: Add at91sam9261 dt SoC support
ARM: at91: switch sam9rl to common clock framework
ARM: at91/dt: define main clk frequency of at91sam9rlek
ARM: at91/dt: define at91sam9rl clocks
ARM: at91: prepare common clk transition for sam9rl SoCs
ARM: at91: prepare sam9 dt boards transition to common clk
ARM: at91: dt: sam9rl: Device Tree for the at91sam9rlek
ARM: at91/defconfig: Add the sam9rl to the list of DT-enabled SOCs
ARM: at91: Add at91sam9rl DT SoC support
ARM: at91: prepare at91sam9rl DT transition
ARM: at91/defconfig: refresh at91sam9260_9g20_defconfig
This patch removes the use of the IRQF_DISABLED flag
from arch/arm/mach-w90x900/time.c
It's a NOOP since 2.6.35 and it will be removed one day.
Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com>
Acked-by: Wan zongshun <mcuos.com@gmail.com>
While <mach/timex.h> isn't used for multi-platform builds since long it
still is for "normal" builds. As the previous patches fix all sites to
not make use of this per-platform file, it can go now for good also for
platforms that are not (yet) converted to multi-platform.
While at it there are no users of CLOCK_TICK_RATE any more, so also drop
the dummy #define.
The local <mach/gpio.h> file on the w90x900 is completely unused
and the platform does not define NEED_MACH_GPIO_H.
Preparing to move the parsing of reboot= to generic kernel code forces
the change in reboot_mode handling to use the enum.
[akpm@linux-foundation.org: fix arch/arm/mach-socfpga/socfpga.c]
Signed-off-by: Robin Holt <holt@sgi.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Russ Anderson <rja@sgi.com>
Cc: Robin Holt <holt@sgi.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Use the generic idle loop and replace enable/disable_hlt with the
respective core functions.
Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
Reviewed-by: Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Cc: Magnus Damm <magnus.damm@gmail.com>
Tested-by: Kevin Hilman <khilman@linaro.org> # OMAP
Link: http://lkml.kernel.org/r/20130321215233.826238797@linutronix.de
"A large number of cleanups, all over the platforms. This is dominated
largely by the Samsung platforms (s3c, s5p, exynos) and a few of the
others moving code out of arch/arm into more appropriate subsystems.
The clocksource and irqchip drivers are now abstracted to the point
where platforms that are already cleaned up do not need to even
specify the driver they use, it can all get configured from the device
tree as we do for normal device drivers. The clocksource changes
basically touch every single platform in the process.
We further clean up the use of platform specific header files here,
with the goal of turning more of the platforms over to being
"multiplatform" enabled, which implies that they cannot expose their
headers to architecture independent code any more.
It is expected that no functional changes are part of the cleanup.
The overall reduction in total code lines is mostly the result of
removing broken and obsolete code."
* tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (133 commits)
ARM: mvebu: correct gated clock documentation
ARM: kirkwood: add missing include for nsa310
ARM: exynos: move exynos4210-combiner to drivers/irqchip
mfd: db8500-prcmu: update resource passing
drivers/db8500-cpufreq: delete dangling include
ARM: at91: remove NEOCORE 926 board
sunxi: Cleanup the reset code and add meaningful registers defines
ARM: S3C24XX: header mach/regs-mem.h local
ARM: S3C24XX: header mach/regs-power.h local
ARM: S3C24XX: header mach/regs-s3c2412-mem.h local
ARM: S3C24XX: Remove plat-s3c24xx directory in arch/arm/
ARM: S3C24XX: transform s3c2443 subirqs into new structure
ARM: S3C24XX: modify s3c2443 irq init to initialize all irqs
ARM: S3C24XX: move s3c2443 irq code to irq.c
ARM: S3C24XX: transform s3c2416 irqs into new structure
ARM: S3C24XX: modify s3c2416 irq init to initialize all irqs
ARM: S3C24XX: move s3c2416 irq init to common irq code
ARM: S3C24XX: Modify s3c_irq_wake to use the hwirq property
ARM: S3C24XX: Move irq syscore-ops to irq-pm
clocksource: always define CLOCKSOURCE_OF_DECLARE
New ARM binutils don't allow extraneous whitespace inside
of brackets, which causes this error on all mach-w90x900
defconfigs:
arch/arm/kernel/entry-armv.S: Assembler messages:
arch/arm/kernel/entry-armv.S:214: Error: ARM register expected -- `ldr r0,[ r6,#(0x10C)]'
arch/arm/kernel/entry-armv.S:214: Error: ARM register expected -- `ldr r0,[ r6,#(0x110)]'
arch/arm/kernel/entry-armv.S:430: Error: ARM register expected -- `ldr r0,[ r6,#(0x10C)]'
arch/arm/kernel/entry-armv.S:430: Error: ARM register expected -- `ldr r0,[ r6,#(0x110)]'
This removes the whitespace in order to build the kernel
again.
git://git.linaro.org/people/shawnguo/linux-2.6 into next/cleanup
From Shawn Guo:
The series cleans up ARCH_HAS_DECOMP_WDOG and arch_decomp_wdog which
are unused on ARM architecure. Samsung has some code setting up wdog
in arch_decomp_wdog(). But since CONFIG_S3C_BOOT_WATCHDOG is defined
nowhere, it will not run. Otherwise, system can not boot at all when
wdog is set up but no one pats it.
* tag 'cleanup-decompwdog-3.9' of git://git.linaro.org/people/shawnguo/linux-2.6:
ARM: samsung: remove unused arch_decomp_wdog() code
ARM: remove unused arch_decomp_wdog()
ARM: decompress: remove unused ARCH_HAS_DECOMP_WDOG
Clockevent cleanup series from Shawn Guo.
Resolved move/change conflict in mach-pxa/time.c due to the sys_timer
cleanup.
* clocksource/cleanup:
clocksource: use clockevents_config_and_register() where possible
ARM: use clockevents_config_and_register() where possible
clockevents: export clockevents_config_and_register for module use
+ sync to Linux 3.8-rc3
arch/arm/mach-pxa/time.c
The clockevent core is able to figure out the best mult and shift,
calculate min_delta_ns and max_delta_ns, with the necessary info passed
into clockevents_config_and_register(). Use this combined configure
and register function where possible to make the codes less error prone
and gain some positive diff stat.
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Reviewed-by: Anton Vorontsov <cbouatmailru@gmail.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Tested-by: Roland Stigge <stigge@antcom.de>
Acked-by: Eric Miao <eric.y.miao@gmail.com>
Cc: David Brown <davidb@codeaurora.org>
Tested-by: Tony Lindgren <tony@atomide.com>
Acked-by: Barry Song <baohua.song@csr.com>
Acked-by: Tony Prisk <linux@prisktech.co.nz>
Cc: Lennert Buytenhek <buytenh@wantstofly.org>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Jason Cooper <jason@lakedaemon.net>
With ARCH_HAS_DECOMP_WDOG removed from arch/arm/boot/compressed/decompress.c,
all the arch_decomp_wdog() definition at platform level is unneeded.
Remmove it.
Acked-by: Nicolas Pitre <nico@linaro.org>
Now that the only field in struct sys_timer is .init, delete the struct,
and replace the machine descriptor .timer field with the initialization
function itself.
This will enable moving timer drivers into drivers/clocksource without
having to place a public prototype of each struct sys_timer object into
include/linux; the intent is to create a single of_clocksource_init()
function that determines which timer driver to initialize by scanning
the device dtree, much like the proposed irqchip_init() at:
http://www.spinics.net/lists/arm-kernel/msg203686.html
Includes mach-omap2 fixes from Igor Grinberg.
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
Platform data for device drivers should be defined in
include/linux/platform_data/*.h, not in the architecture
and platform specific directories.
This moves such data out of the w90x900 include directories
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Cc: "Ben Dooks (embedded platforms)" <ben-linux@fluff.org>
Cc: "Wolfram Sang (embedded platforms)" <w.sang@pengutronix.de>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Pull a few more ARM platform fixes from Olof Johansson:
"Apologies for back-to-back fixes pull requests, but one of the patches
below are the kind we'll see posted over and over if we don't send it
in. I hadn't done the full sanity-check of defconfig builds by the
time I sent up the other fixes yesterday or I would have included it
then.
Two patches, one dealing with the system.h fallout, the other is a
missing linux/bug.h in a place where ARRAY_SIZE() is used."
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: clps711x: fix missing include file
ARM: fix builds due to missing <asm/system_misc.h> includes
This does a sweeping change fixing up all the missing system_misc.h and
system_info.h includes from the system.h split-up change. These were the
ones I came across when building all defconfigs in arch/arm/configs, there
might be more but they lack adequate build coverage to be easily caught.
I'm expecting to get a lot of these piecemeal by each maintainer, so we
might just as well do one sweeping change to get them all at once.
Cc: Krzysztof Halasa <khc@pm.waw.pl>
Cc: Eric Miao <eric.y.miao@gmail.com>
Pull "ARM: cleanups of io includes" from Olof Johansson:
"Rob Herring has done a sweeping change cleaning up all of the
mach/io.h includes, moving some of the oft-repeated macros to a common
location and removing a bunch of boiler plate. This is another step
closer to a common zImage for multiple platforms."
Fix up various fairly trivial conflicts (<mach/io.h> removal vs changes
around it, tegra localtimer.o is *still* gone, yadda-yadda).
* tag 'cleanup2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (29 commits)
ARM: tegra: Include assembler.h in sleep.S to fix build break
ARM: pxa: use common IOMEM definition
ARM: dma-mapping: convert ARCH_HAS_DMA_SET_COHERENT_MASK to kconfig symbol
ARM: __io abuse cleanup
ARM: create a common IOMEM definition
ARM: iop13xx: fix missing declaration of iop13xx_init_early
ARM: fix ioremap/iounmap for !CONFIG_MMU
ARM: kill off __mem_pci
ARM: remove bunch of now unused mach/io.h files
ARM: make mach/io.h include optional
ARM: clps711x: remove unneeded include of mach/io.h
ARM: dove: add explicit include of dove.h to addr-map.c
ARM: at91: add explicit include of hardware.h to uncompressor
ARM: ep93xx: clean-up mach/io.h
ARM: tegra: clean-up mach/io.h
ARM: orion5x: clean-up mach/io.h
ARM: davinci: remove unneeded mach/io.h include
[media] davinci: remove includes of mach/io.h
ARM: OMAP: Remove remaining includes for mach/io.h
ARM: msm: clean-up mach/io.h
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system
Pull "Disintegrate and delete asm/system.h" from David Howells:
"Here are a bunch of patches to disintegrate asm/system.h into a set of
separate bits to relieve the problem of circular inclusion
dependencies.
I've built all the working defconfigs from all the arches that I can
and made sure that they don't break.
The reason for these patches is that I recently encountered a circular
dependency problem that came about when I produced some patches to
optimise get_order() by rewriting it to use ilog2().
This uses bitops - and on the SH arch asm/bitops.h drags in
asm-generic/get_order.h by a circuituous route involving asm/system.h.
The main difficulty seems to be asm/system.h. It holds a number of
low level bits with no/few dependencies that are commonly used (eg.
memory barriers) and a number of bits with more dependencies that
aren't used in many places (eg. switch_to()).
These patches break asm/system.h up into the following core pieces:
(1) asm/barrier.h
Move memory barriers here. This already done for MIPS and Alpha.
(2) asm/switch_to.h
Move switch_to() and related stuff here.
(3) asm/exec.h
Move arch_align_stack() here. Other process execution related bits
could perhaps go here from asm/processor.h.
(4) asm/cmpxchg.h
Move xchg() and cmpxchg() here as they're full word atomic ops and
frequently used by atomic_xchg() and atomic_cmpxchg().
(5) asm/bug.h
Move die() and related bits.
(6) asm/auxvec.h
Move AT_VECTOR_SIZE_ARCH here.
Other arch headers are created as needed on a per-arch basis."
Fixed up some conflicts from other header file cleanups and moving code
around that has happened in the meantime, so David's testing is somewhat
weakened by that. We'll find out anything that got broken and fix it..
* tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits)
Delete all instances of asm/system.h
Remove all #inclusions of asm/system.h
Add #includes needed to permit the removal of asm/system.h
Move all declarations of free_initmem() to linux/mm.h
Disintegrate asm/system.h for OpenRISC
Split arch_align_stack() out from asm-generic/system.h
Split the switch_to() wrapper out of asm-generic/system.h
Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h
Create asm-generic/barrier.h
Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h
Disintegrate asm/system.h for Xtensa
Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt]
Disintegrate asm/system.h for Tile
Disintegrate asm/system.h for Sparc
Disintegrate asm/system.h for SH
Disintegrate asm/system.h for Score
Disintegrate asm/system.h for S390
Disintegrate asm/system.h for PowerPC
Disintegrate asm/system.h for PA-RISC
Disintegrate asm/system.h for MN10300
Disintegrate asm/system.h for ARM.
cc: Russell King <linux@arm.linux.org.uk>
cc: linux-arm-kernel@lists.infradead.org
Now that many platforms don't need mach/io.h, remove the unused ones.
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Acked-by: Jamie Iles <jamie@jamieiles.com>
Acked-by: Pawel Moll <pawel.moll@arm.com>
into for-armsoc
Now that most platforms don't need disable_fiq and arch_ret_to_user
macros, we can remove the empty macros or empty entry-macro.S files.
Acked-by: Ryan Mallon <rmallon@gmail.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
When this is the only content remaining in mach/system.h then the
whole file is removed.
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Acked-and-tested-by: Jamie Iles <jamie@jamieiles.com>
Acked-by: David Brown <davidb@codeaurora.org>
Signed-off-by: nicolas Pitre <nicolas.pitre@linaro.org>
This change ensures the platform device name matches nuc900-ac97 platform
driver name.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
* 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (73 commits)
arm: fix up some samsung merge sysdev conversion problems
firmware: Fix an oops on reading fw_priv->fw in sysfs loading file
Drivers:hv: Fix a bug in vmbus_driver_unregister()
driver core: remove __must_check from device_create_file
debugfs: add missing #ifdef HAS_IOMEM
arm: time.h: remove device.h #include
driver-core: remove sysdev.h usage.
clockevents: remove sysdev.h
arm: convert sysdev_class to a regular subsystem
arm: leds: convert sysdev_class to a regular subsystem
kobject: remove kset_find_obj_hinted()
m86k: gpio - convert sysdev_class to a regular subsystem
mips: txx9_sram - convert sysdev_class to a regular subsystem
mips: 7segled - convert sysdev_class to a regular subsystem
sh: dma - convert sysdev_class to a regular subsystem
sh: intc - convert sysdev_class to a regular subsystem
power: suspend - convert sysdev_class to a regular subsystem
power: qe_ic - convert sysdev_class to a regular subsystem
power: cmm - convert sysdev_class to a regular subsystem
s390: time - convert sysdev_class to a regular subsystem
Fix up conflicts with 'struct sysdev' removal from various platform
drivers that got changed:
- arch/arm/mach-exynos/cpu.c
- arch/arm/mach-exynos/irq-eint.c
- arch/arm/mach-s3c64xx/common.c
- arch/arm/mach-s3c64xx/cpu.c
- arch/arm/mach-s5p64x0/cpu.c
- arch/arm/mach-s5pv210/common.c
- arch/arm/plat-samsung/include/plat/cpu.h
- arch/powerpc/kernel/sysfs.c
and fix up cpu_is_hotpluggable() as per Greg in include/linux/cpu.h
This resolves the conflict in the arch/arm/mach-s3c64xx/s3c6400.c file,
and it fixes the build error in the arch/x86/kernel/microcode_core.c
file, that the merge did not catch.
The microcode_core.c patch was provided by Stephen Rothwell
<sfr@canb.auug.org.au> who was invaluable in the merge issues involved
with the large sysdev removal process in the driver-core tree.
The changes to arch/arm/mach-exynos/cpu.c were moved to
mach-exynos/common.c.
Remove the now empty arch_reset() from all the mach/system.h includes,
and remove its callsite. Remove arm_machine_restart() as this function
no longer does anything useful.
For samsung platforms, remove the include of mach/system-reset.h and
plat/system-reset.h from their respective mach/system.h headers as these
just define their arch_reset functions. As a result, the s3c2410 and
plat-samsung system-reset.h files are no longer referenced, so remove
these files entirely.
Hook these platforms restart code into the new restart hook rather
than using arch_reset().
arch/arm/kernel/setup.c
arch/arm/plat-omap/include/plat/common.h
The sysdev.h file should not be needed by any in-kernel code, so remove
the .h file from these random files that seem to still want to include
it.
The sysdev code will be going away soon, so this include needs to be
removed no matter what.
Cc: Jiandong Zheng <jdzheng@broadcom.com>
Cc: Scott Branden <sbranden@broadcom.com>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: Daniel Walker <dwalker@fifo99.com>
Cc: Bryan Huntsman <bryanh@codeaurora.org>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: "Venkatesh Pallipadi
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Matthew Garrett <mjg@redhat.com>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
devel-stable
git://git.kernel.org/pub/scm/linux/kernel/git/will/linux into devel-stable
arch/arm/common/gic.c
Rather than having separate extern declarations in nuc9*.h, provide
a common header file containing these definitions.
Tested-by: Wan Zongshun <mcuos.com@gmail.com>
We only need to set the system up for a soft-restart if we're going to
be doing a soft-restart. Provide a new function (soft_restart()) which
does the setup and final call for this, and make platforms use it.
Eliminate the call to setup_restart() from the default handler.
This means that platforms arch_reset() function is no longer called with
the page tables prepared for a soft-restart, and caches will still be
enabled.
Acked-by: Will Deacon <will.deacon@arm.com>
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Acked-by: Viresh Kumar <viresh.kumar@st.com>
Acked-by: Krzysztof Ha■asa <khc@pm.waw.pl>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Acked-by: Richard Purdie <richard.purdie@linuxfoundation.org>
This patch is to add new MFP implement in mfp.c,since nuc900 mmc driver
needs this function support.
Signed-off-by: Wan ZongShun <mcuos.com@gmail.com>
This patch is to fix a WARNING which is the "modpost: Found 1 section
mismatch(es)" for nuc900 platform.
