commit b7005d4ef4f3aa2dc24019ffba03a322557ac43d upstream.
This fixes a kernel panic on memcpy when
FORTIFY_SOURCE is enabled.
The initial smp implementation on commit aa7eb2bb4e4a
("arm: zynq: Add smp support")
used memcpy, which worked fine until commit ee333554fed5
("ARM: 8749/1: Kconfig: Add ARCH_HAS_FORTIFY_SOURCE")
enabled overflow checks at runtime, producing a read
overflow panic.
The computed size of memcpy args are:
- p_size (dst): 4294967295 = (size_t) -1
- q_size (src): 1
- size (len): 8
Additionally, the memory is marked as __iomem, so one of
the memcpy_* functions should be used for read/write.
Fixes: aa7eb2bb4e4a ("arm: zynq: Add smp support")
Signed-off-by: Luis Araneda <luaraneda@gmail.com>
Cc: stable@vger.kernel.org
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
The function name is now renamed to 'timer_probe' for consistency with
the CLOCKSOURCE_OF_DECLARE => TIMER_OF_DECLARE change.
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Heiko Stuebner <heiko@sntech.de>
All low-level PM/SMP code using virt_to_phys() should actually use
__pa_symbol() against kernel symbols. Update code where relevant to move
away from virt_to_phys().
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
Reviewed-by: Laura Abbott <labbott@redhat.com>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
On Zynq, we haven't been reserving the correct amount of DMA-incapable
RAM to keep DMA away from it (per the Zynq TRM Section 4.1, it should be
the first 512k). In older kernels, this was masked by the
memblock_reserve call in arm_memblock_init(). Now, reserve the correct
amount excplicitly rather than relying on swapper_pg_dir, which is an
address and not a size anyway.
Fixes: 46f5b96 ("ARM: zynq: Reserve not DMAable space in front of the
kernel")
Signed-off-by: Kyle Roeschley <kyle.roeschley@ni.com>
Tested-by: Nathan Rossi <nathan@nathanrossi.com>
Use helper of_platform_default_populate() in linux/of_platform
when possible, instead of calling of_platform_populate() with
the default match table.
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Krzysztof Halasa <khalasa@piap.pl>
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Shawn Guo <shawnguo@kernel.org>
Cc: Roland Stigge <stigge@antcom.de>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Ray Jui <rjui@broadcom.com>
Cc: Viresh Kumar <vireshk@kernel.org>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Rob Herring <robh@kernel.org>
Cc: Michal Simek <michal.simek@xilinx.com>
Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com>
Signed-off-by: Rob Herring <robh@kernel.org>
The cpufreq-dt-platdev driver supports creation of cpufreq-dt platform
device now, reuse that and remove similar code from platform code.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Pull ARM SoC platform updates from Arnd Bergmann:
"Newly added support for additional SoCs:
- Axis Artpec-6 SoC family
- Allwinner A83T SoC
- Mediatek MT7623
- NXP i.MX6QP SoC
- ST Microelectronics stm32f469 microcontroller
New features:
- SMP support for Mediatek mt2701
- Big-endian support for NXP i.MX
- DaVinci now uses the new DMA engine dma_slave_map
- OMAP now uses the new DMA engine dma_slave_map
- earlyprintk support for palmchip uart on mach-tango
- delay timer support for orion
Other:
- Exynos PMU driver moved out to drivers/soc/
- Various smaller updates for Renesas, Xilinx, PXA, AT91, OMAP,
uniphier"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (83 commits)
ARM: uniphier: rework SMP code to support new System Bus binding
ARM: uniphier: add missing of_node_put()
ARM: at91: avoid defining CONFIG_* symbols in source code
ARM: DRA7: hwmod: Add data for eDMA tpcc, tptc0, tptc1
ARM: imx: Make reset_control_ops const
ARM: imx: Do L2 errata only if the L2 cache isn't enabled
ARM: imx: select ARM_CPU_SUSPEND only for imx6
dmaengine: pxa_dma: fix the maximum requestor line
ARM: alpine: select the Alpine MSI controller driver
ARM: pxa: add the number of DMA requestor lines
dmaengine: mmp-pdma: add number of requestors
dma: mmp_pdma: Add the #dma-requests DT property documentation
ARM: OMAP2+: Add rtc hwmod configuration for ti81xx
ARM: s3c24xx: Avoid warning for inb/outb
ARM: zynq: Move early printk virtual address to vmalloc area
ARM: DRA7: hwmod: Add custom reset handler for PCIeSS
ARM: SAMSUNG: Remove unused register offset definition
ARM: EXYNOS: Cleanup header files inclusion
drivers: soc: samsung: Enable COMPILE_TEST
MAINTAINERS: Add maintainers entry for drivers/soc/samsung
The Zynq has a bug where the L2 cache will return invalid data in some
circumstances unless the L2C_RAM register is set to 0x00020202 before the first
enabling of the L2 cache.
The Xilinx-recommended solution to this problem is to ensure that early one of
the earlier bootstages correctly initialize L2C_RAM, however, this issue wasn't
discovered and fixed until after their EDK/SDK 14.4 release. For systems built
prior to that, and which lack field-upgradable bootloaders, this issue still
exists and silent data corruption can be seen in the wild.
Fix these systems by ensuring L2C_RAM is properly initialized at the
earliest convenient moment prior to the L2 being brought up, which is
when the SLCR is first mapped.
The Zynq bug is described in more detail by Xilinx AR# 54190 as quoted
below.
Xilinx AR# 54190
http://www.xilinx.com/support/answers/54190.htm
Captured on 2014-09-24 14:43 -0500
= Description =
For proper L2 cache operation, the user code must program the
slcr.L2C_RAM register (address 0xF800_0A1C) to the value of
0x0002_0202 before enabling the L2 cache. The reset value
(0x0001_0101) might cause, very infrequently, the L2 cache to return
invalid data.
= Solution =
It is up to the user code (FSBL or other user code) to set the
slcr.L2C_RAM register to the value 0x0002_0202 before enabling the L2
cache.
Note: The L2 cache is disabled after reset and is not enabled by the
BootROM.
Note: The slcr.l2C_RAM register was previously reserved. It is added
in the Zynq-7000 AP SoC Technical Reference Manual (TRM) v1.5 as
"Reserved".
Thanks to Jaeden Amero for initial debugging and triage efforts.
Signed-off-by: Josh Cartwright <joshc@ni.com>
In preparation for performing additional configuration prior to bringing
up L2, move the slcr initialization earlier in the boot process.
The variable "MACHINE" is empty if CONFIG_ARCH_MULTIPLATFORM=y,
so these Makefile.boot files are never included.
Acked-by: Michal Simek <michal.simek@xilinx.com> (for Zynq)
Merge in cleanup to avoid internal conflicts with newly added code.
* treewide/cleanup:
ARM: use "depends on" for SoC configs instead of "if" after prompt
ARM/clocksource: use automatic DT probing for ux500 PRCMU
ARM: use const and __initconst for smp_operations
ARM: hisi: do not export smp_operations structures
Signed-off-by: Moritz Fischer <moritz.fischer@ettus.com>
Many ARM sub-architectures use prompts followed by "if" conditional,
but it is wrong.
Please notice the difference between
config ARCH_FOO
bool "Foo SoCs" if ARCH_MULTI_V7
and
config ARCH_FOO
bool "Foo SoCs"
depends on ARCH_MULTI_V7
These two are *not* equivalent!
In the former statement, it is not ARCH_FOO, but its prompt that
depends on ARCH_MULTI_V7. So, it is completely valid that ARCH_FOO
is selected by another, but ARCH_MULTI_V7 is still disabled. As it is
not unmet dependency, Kconfig never warns. This is probably not what
you want.
The former should be used only when you need to do so, and you really
understand what you are doing. (In most cases, it should be wrong!)
For enabling/disabling sub-architectures, the latter is always correct.
As a good side effect, this commit fixes some entries over 80 columns
(mach-imx, mach-integrator, mach-mbevu).
[Arnd: I note that there is not really a bug here, according to
the discussion that followed, but I can see value in being consistent
and in making the lines shorter]
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Acked-by: Patrice Chotard <patrice.chotard@st.com>
Acked-by: Liviu Dudau <Liviu.Dudau@arm.com>
Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Jun Nie <jun.nie@linaro.org>
Acked-by: Matthias Brugger <matthias.bgg@gmail.com>
Acked-by: Simon Horman <horms+renesas@verge.net.au>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Thierry Reding <treding@nvidia.com>
Acked-by: Krzysztof Halasa <khc@piap.pl>
Acked-by: Maxime Coquelin <maxime.coquelin@st.com>
These smp_operations structures are not over-written, so add "const"
qualifier and replace __initdata with __initconst.
Also, add "static" where it is possible.
Acked-by: Moritz Fischer <moritz.fischer@ettus.com>
Acked-by: Stephen Boyd <sboyd@codeaurora.org> # qcom part
Acked-by: Wei Xu <xuwei5@hisilicon.com>
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
Acked-by: Nicolas Pitre <nico@linaro.org>
Seeing the 'of' characters in a symbol that is being called from
ACPI seems to freak out people. So let's do a bit of pointless
renaming so that these folks do feel at home.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org>
Tested-by: Hanjun Guo <hanjun.guo@linaro.org>
Pull irq updates from Thomas Gleixner:
"This updated pull request does not contain the last few GIC related
patches which were reported to cause a regression. There is a fix
available, but I let it breed for a couple of days first.
The irq departement provides:
- new infrastructure to support non PCI based MSI interrupts
- a couple of new irq chip drivers
- the usual pile of fixlets and updates to irq chip drivers
- preparatory changes for removal of the irq argument from interrupt
flow handlers
- preparatory changes to remove IRQF_VALID"
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (129 commits)
irqchip/imx-gpcv2: IMX GPCv2 driver for wakeup sources
irqchip: Add bcm2836 interrupt controller for Raspberry Pi 2
irqchip: Add documentation for the bcm2836 interrupt controller
irqchip/bcm2835: Add support for being used as a second level controller
irqchip/bcm2835: Refactor handle_IRQ() calls out of MAKE_HWIRQ
PCI: xilinx: Fix typo in function name
irqchip/gic: Ensure gic_cpu_if_up/down() programs correct GIC instance
irqchip/gic: Only allow the primary GIC to set the CPU map
PCI/MSI: pci-xgene-msi: Consolidate chained IRQ handler install/remove
unicore32/irq: Prepare puv3_gpio_handler for irq argument removal
tile/pci_gx: Prepare trio_handle_level_irq for irq argument removal
m68k/irq: Prepare irq handlers for irq argument removal
C6X/megamode-pic: Prepare megamod_irq_cascade for irq argument removal
blackfin: Prepare irq handlers for irq argument removal
arc/irq: Prepare idu_cascade_isr for irq argument removal
sparc/irq: Use access helper irq_data_get_affinity_mask()
sparc/irq: Use helper irq_data_get_irq_handler_data()
parisc/irq: Use access helper irq_data_get_affinity_mask()
mn10300/irq: Use access helper irq_data_get_affinity_mask()
irqchip/i8259: Prepare i8259_irq_dispatch for irq argument removal
Add a zero argument to the .word directive in
zynq_secondary_trampoline. Without an expression the assembler emits
nothing for the .word directive.
This makes it so that the intended range is communicated to ioremap
and outer_flush_range in zynq_cpun_start; e.g. for LE
trampoline_code_size evaluates to 12 now instead of 8.
Found by inspection. I'm not aware of any real problem this fixes.
Tested by doing on online/offline loop on ZC702.
Signed-off-by: Nathan Lynch <nathan_lynch@mentor.com>
Now that the GIC chip implementation enables IRQCHIP_SKIP_SET_WAKE and
IRQCHIP_MASK_ON_SUSPEND by default, the platforms requiring them need
not override the irqchip flags as before.
This patch removes all the users of gic_set_irqchip_flags and the
function itself.
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Simon Horman <horms@verge.net.au>
Cc: Magnus Damm <magnus.damm@gmail.com>
Cc: Gregory CLEMENT <gregory.clement@free-electrons.com>
Cc: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Link: http://lkml.kernel.org/r/1436971109-20189-2-git-send-email-sudeep.holla@arm.com
This patch is based on the
commit 1a8e41cd672f ("ARM: 6395/1: VExpress: Set bit 22 in the PL310
(cache controller) AuxCtlr register")
Clearing bit 22 in the PL310 Auxiliary Control register (shared
attribute override enable) has the side effect of transforming Normal
Shared Non-cacheable reads into Cacheable no-allocate reads.
Coherent DMA buffers in Linux always have a cacheable alias via the
kernel linear mapping and the processor can speculatively load cache
lines into the PL310 controller. With bit 22 cleared, Non-cacheable
reads would unexpectedly hit such cache lines leading to buffer
corruption.
For Zynq, this fix avoids memory inconsistencies between Gigabit
Ethernet controller (GEM) and CPU when DMA_CMA is disabled.
Suggested-by: Punnaiah Choudary Kalluri <punnaia@xilinx.com>
Signed-off-by: Thomas Betker <thomas.betker@rohde-schwarz.com>
Pull ARM SoC platform support updates from Kevin Hilman:
"Our SoC branch usually contains expanded support for new SoCs and
other core platform code. Some highlights from this round:
- sunxi: SMP support for A23 SoC
- socpga: big-endian support
- pxa: conversion to common clock framework
- bcm: SMP support for BCM63138
- imx: support new I.MX7D SoC
- zte: basic support for ZX296702 SoC"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (134 commits)
ARM: zx: Add basic defconfig support for ZX296702
ARM: dts: zx: add an initial zx296702 dts and doc
clk: zx: add clock support to zx296702
dt-bindings: Add #defines for ZTE ZX296702 clocks
ARM: socfpga: fix build error due to secondary_startup
MAINTAINERS: ARM64: EXYNOS: Extend entry for ARM64 DTS
ARM: ep93xx: simone: support for SPI-based MMC/SD cards
MAINTAINERS: update Shawn's email to use kernel.org one
ARM: socfpga: support suspend to ram
ARM: socfpga: add CPU_METHOD_OF_DECLARE for Arria 10
ARM: socfpga: use CPU_METHOD_OF_DECLARE for socfpga_cyclone5
ARM: EXYNOS: register power domain driver from core_initcall
ARM: EXYNOS: use PS_HOLD based poweroff for all supported SoCs
ARM: SAMSUNG: Constify platform_device_id
ARM: EXYNOS: Constify irq_domain_ops
ARM: EXYNOS: add coupled cpuidle support for Exynos3250
ARM: EXYNOS: add exynos_get_boot_addr() helper
ARM: EXYNOS: add exynos_set_boot_addr() helper
ARM: EXYNOS: make exynos_core_restart() less verbose
ARM: EXYNOS: fix exynos_boot_secondary() return value on timeout
All ARMv5 and older CPUs invalidate their caches in the early assembly
setup function, prior to enabling the MMU. This is because the L1
cache should not contain any data relevant to the execution of the
kernel at this point; all data should have been flushed out to memory.
This requirement should also be true for ARMv6 and ARMv7 CPUs - indeed,
these typically do not search their caches when caching is disabled (as
it needs to be when the MMU is disabled) so this change should be safe.
ARMv7 allows there to be CPUs which search their caches while caching is
disabled, and it's permitted that the cache is uninitialised at boot;
for these, the architecture reference manual requires that an
implementation specific code sequence is used immediately after reset
to ensure that the cache is placed into a sane state. Such
functionality is definitely outside the remit of the Linux kernel, and
must be done by the SoC's firmware before _any_ CPU gets to the Linux
kernel.
Changing the data cache clean+invalidate to a mere invalidate allows us
to get rid of a lot of platform specific hacks around this issue for
their secondary CPU bringup paths - some of which were buggy.
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
Tested-by: Florian Fainelli <f.fainelli@gmail.com>
Tested-by: Heiko Stuebner <heiko@sntech.de>
Tested-by: Dinh Nguyen <dinguyen@opensource.altera.com>
Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Tested-by: Thierry Reding <treding@nvidia.com>
Tested-by: Geert Uytterhoeven <geert+renesas@glider.be>
Tested-by: Michal Simek <michal.simek@xilinx.com>
Tested-by: Wei Xu <xuwei5@hisilicon.com>
The SLCR is unconditionally unlocked early on boot in zynq_slcr_init()
and not ever re-locked. As such, it is not necessary to explicitly unlock in
the restart codepath.
By making use of the restart_handler chain mechanism, the SLCR-based
reset mechanism can be prioritized amongst other mechanisms available on
a particular board.
Choose a default high-ish priority of 192 for this restart mechanism.
Instead of directly touching gic_arch_extn, which is about to
be removed, use gic_set_irqchip_flags instead.
Link: https://lkml.kernel.org/r/1426088737-15817-5-git-send-email-marc.zyngier@arm.com
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
Based on
"mfd: syscon: Decouple syscon interface from platform devices"
(sha1: bdb0066df96e74a4002125467ebe459feff1ebef)
SLCR driver can use syscon/regmap drivers directly.
Select pinctrl and the Zynq pinctrl driver.
Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com>
Tested-by: Andreas Färber <afaerber@suse.de>
secondary_startup() in the header is not needed at all.
Commit 'ARM: zynq: Remove hotplug.c'
(caf86a73eab4132f870e883216850d9eee40b04b) was supposed to remove
hotplug.c - but it didn't. It moved all content from
hotplug.c elsewhere and removed its entry from the Makefile, but missed
to actually remove the whole file. Remove it now.
Pull ACPI and power management updates from Rafael Wysocki:
"Features-wise, to me the most important this time is a rework of
wakeup interrupts handling in the core that makes them work
consistently across all of the available sleep states, including
suspend-to-idle. Many thanks to Thomas Gleixner for his help with
this work.
Second is an update of the generic PM domains code that has been in
need of some care for quite a while. Unused code is being removed, DT
support is being added and domains are now going to be attached to
devices in bus type code in analogy with the ACPI PM domain. The
majority of work here was done by Ulf Hansson who also has been the
most active developer this time.
Apart from this we have a traditional ACPICA update, this time to
upstream version 20140828 and a few ACPI wakeup interrupts handling
patches on top of the general rework mentioned above. There also are
several cpufreq commits including renaming the cpufreq-cpu0 driver to
cpufreq-dt, as this is what implements generic DT-based cpufreq
support, and a new DT-based idle states infrastructure for cpuidle.
In addition to that, the ACPI LPSS driver is updated, ACPI support for
Apple machines is improved, a few bugs are fixed and a few cleanups
are made all over.
Finally, the Adaptive Voltage Scaling (AVS) subsystem now has a tree
maintained by Kevin Hilman that will be merged through the PM tree.
Numbers-wise, the generic PM domains update takes the lead this time
with 32 non-merge commits, second is cpufreq (15 commits) and the 3rd
place goes to the wakeup interrupts handling rework (13 commits).
Specifics:
- Rework the handling of wakeup IRQs by the IRQ core such that all of
them will be switched over to "wakeup" mode in suspend_device_irqs()
and in that mode the first interrupt will abort system suspend in
progress or wake up the system if already in suspend-to-idle (or
equivalent) without executing any interrupt handlers. Among other
things that eliminates the wakeup-related motivation to use the
IRQF_NO_SUSPEND interrupt flag with interrupts which don't really
need it and should not use it (Thomas Gleixner and Rafael Wysocki)
- Switch over ACPI to handling wakeup interrupts with the help of the
new mechanism introduced by the above IRQ core rework (Rafael Wysocki)
- Rework the core generic PM domains code to eliminate code that's
not used, add DT support and add a generic mechanism by which
devices can be added to PM domains automatically during enumeration
(Ulf Hansson, Geert Uytterhoeven and Tomasz Figa).
- Add debugfs-based mechanics for debugging generic PM domains
(Maciej Matraszek).
- ACPICA update to upstream version 20140828. Included are updates
related to the SRAT and GTDT tables and the _PSx methods are in the
METHOD_NAME list now (Bob Moore and Hanjun Guo).
- Add _OSI("Darwin") support to the ACPI core (unfortunately, that
can't really be done in a straightforward way) to prevent
Thunderbolt from being turned off on Apple systems after boot (or
after resume from system suspend) and rework the ACPI Smart Battery
Subsystem (SBS) driver to work correctly with Apple platforms
(Matthew Garrett and Andreas Noever).
- ACPI LPSS (Low-Power Subsystem) driver update cleaning up the code,
adding support for 133MHz I2C source clock on Intel Baytrail to it
and making it avoid using UART RTS override with Auto Flow Control
(Heikki Krogerus).
- ACPI backlight updates removing the video_set_use_native_backlight
quirk which is not necessary any more, making the code check the
list of output devices returned by the _DOD method to avoid
creating acpi_video interfaces that won't work and adding a quirk
for Lenovo Ideapad Z570 (Hans de Goede, Aaron Lu and Stepan Bujnak)
- New Win8 ACPI OSI quirks for some Dell laptops (Edward Lin)
- Assorted ACPI code cleanups (Fabian Frederick, Rasmus Villemoes,
Sudip Mukherjee, Yijing Wang, and Zhang Rui)
- cpufreq core updates and cleanups (Viresh Kumar, Preeti U Murthy,
Rasmus Villemoes)
- cpufreq driver updates: cpufreq-cpu0/cpufreq-dt (driver name change
among other things), ppc-corenet, powernv (Viresh Kumar, Preeti U
Murthy, Shilpasri G Bhat, Lucas Stach)
- cpuidle support for DT-based idle states infrastructure, new ARM64
cpuidle driver, cpuidle core cleanups (Lorenzo Pieralisi, Rasmus
Villemoes)
- ARM big.LITTLE cpuidle driver updates: support for DT-based
initialization and Exynos5800 compatible string (Lorenzo Pieralisi,
Kevin Hilman)
- Rework of the test_suspend kernel command line argument and a new
trace event for console resume (Srinivas Pandruvada, Todd E Brandt)
- Second attempt to optimize swsusp_free() (hibernation core) to make
it avoid going through all PFNs which may be way too slow on some
systems (Joerg Roedel)
- devfreq updates (Paul Bolle, Punit Agrawal, Ãrjan Eide).
- rockchip-io Adaptive Voltage Scaling (AVS) driver and AVS entry
update in MAINTAINERS (Heiko Stübner, Kevin Hilman)
- PM core fix related to clock management (Geert Uytterhoeven)
- PM core's sysfs code cleanup (Johannes Berg)"
* tag 'pm+acpi-3.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (105 commits)
ACPI / fan: printk replacement
PM / clk: Fix crash in clocks management code if !CONFIG_PM_RUNTIME
PM / Domains: Rename cpu_data to cpuidle_data
cpufreq: cpufreq-dt: fix potential double put of cpu OF node
cpufreq: cpu0: rename driver and internals to 'cpufreq_dt'
PM / hibernate: Iterate over set bits instead of PFNs in swsusp_free()
cpufreq: ppc-corenet: remove duplicate update of cpu_data
ACPI / sleep: Rework the handling of ACPI GPE wakeup from suspend-to-idle
PM / sleep: Rename platform suspend/resume functions in suspend.c
PM / sleep: Export dpm_suspend_late/noirq() and dpm_resume_early/noirq()
ACPICA: Introduce acpi_enable_all_wakeup_gpes()
ACPICA: Clear all non-wakeup GPEs in acpi_hw_enable_wakeup_gpe_block()
ACPI / video: check _DOD list when creating backlight devices
PM / Domains: Move dev_pm_domain_attach|detach() to pm_domain.h
cpufreq: Replace strnicmp with strncasecmp
cpufreq: powernv: Set the cpus to nominal frequency during reboot/kexec
cpufreq: powernv: Set the pstate of the last hotplugged out cpu in policy->cpus to minimum
cpufreq: Allow stop CPU callback to be used by all cpufreq drivers
PM / devfreq: exynos: Enable building exynos PPMU as module
PM / devfreq: Export helper functions for drivers
The naming convention of this driver was always under the scanner, people
complained that it should have a more generic name than cpu0, as it manages all
CPUs that are sharing clock lines.
Also, in future it will be modified to support any number of clusters with
separate clock/voltage lines.
Lets rename it to 'cpufreq_dt' from 'cpufreq_cpu0'.
Tested-by: Stephen Boyd <sboyd@codeaurora.org>
AUX setting has no effect that's why remove it.
Warning log:
L2C: platform provided aux values match the hardware, so
have no effect. Please remove them.
Match the naming pattern of all other SMP ops and rename
zynq_platform_cpu_die --> zynq_cpu_die.
The hotplug code contains only a single function, which is an SMP
function. Move that to platsmp.c where all other SMP runctions reside.
That allows removing hotplug.c and declaring the cpu_die function
static.
Avoid races and add synchronisation between the arch specific
kill and die routines.
The same synchronisation issue was fixed on IMX platform
by this commit:
"ARM: imx: fix sync issue between imx_cpu_die and imx_cpu_kill"
(sha1: 2f3edfd7e27ad4206acbc2ae99c9df5f46353024)
As there is no Power management unit on this board, it is not possible to power
down a core, just WFI is allowed. There is no point to invalidate the cache and
exit coherency.
Reviewed-and-tested-by: Soren Brinkmann <soren.brinkmann@xilinx.com>
The DDR controller can detect idle periods and leverage low power
features clock stop. When new requests occur, the DDRC resumes
normal operation.
Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Since the OPP layer is a kernel library which has been converted to be
directly selectable by its callers rather than user selectable and
requiring architectures to enable it explicitly the ARCH_HAS_OPP symbol
has become redundant and can be removed. Do so.
Signed-off-by: Mark Brown <broonie@linaro.org>
Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Nishanth Menon <nm@ti.com>
Acked-by: Rob Herring <robh@kernel.org>
Acked-by: Shawn Guo <shawn.guo@freescale.com>
This config exists entirely to hide the cpufreq menu from the
kernel configuration unless a platform has selected it. Nothing
is actually built if this config is 'Y' and it just leads to more
patches that add a select under a platform Kconfig so that some
other CPUfreq option can be chosen. Let's remove the option so
that we can always enable CPUfreq drivers on ARM platforms.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Pull ARM updates from Russell King:
- Major clean-up of the L2 cache support code. The existing mess was
becoming rather unmaintainable through all the additions that others
have done over time. This turns it into a much nicer structure, and
implements a few performance improvements as well.
- Clean up some of the CP15 control register tweaks for alignment
support, moving some code and data into alignment.c
- DMA properties for ARM, from Santosh and reviewed by DT people. This
adds DT properties to specify bus translations we can't discover
automatically, and to indicate whether devices are coherent.
- Hibernation support for ARM
- Make ftrace work with read-only text in modules
- add suspend support for PJ4B CPUs
- rework interrupt masking for undefined instruction handling, which
allows us to enable interrupts earlier in the handling of these
exceptions.
- support for big endian page tables
- fix stacktrace support to exclude stacktrace functions from the
trace, and add save_stack_trace_regs() implementation so that kprobes
can record stack traces.
- Add support for the Cortex-A17 CPU.
- Remove last vestiges of ARM710 support.
- Removal of ARM "meminfo" structure, finally converting us solely to
memblock to handle the early memory initialisation.
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (142 commits)
ARM: ensure C page table setup code follows assembly code (part II)
ARM: consolidate last remaining open-coded alignment trap enable
ARM: remove global cr_no_alignment
ARM: remove CPU_CP15 conditional from alignment.c
ARM: remove unused adjust_cr() function
ARM: move "noalign" command line option to alignment.c
ARM: provide common method to clear bits in CPU control register
ARM: 8025/1: Get rid of meminfo
ARM: 8060/1: mm: allow sub-architectures to override PCI I/O memory type
ARM: 8066/1: correction for ARM patch 8031/2
ARM: 8049/1: ftrace/add save_stack_trace_regs() implementation
ARM: 8065/1: remove last use of CONFIG_CPU_ARM710
ARM: 8062/1: Modify ldrt fixup handler to re-execute the userspace instruction
ARM: 8047/1: rwsem: use asm-generic rwsem implementation
ARM: l2c: trial at enabling some Cortex-A9 optimisations
ARM: l2c: add warnings for stuff modifying aux_ctrl register values
ARM: l2c: print a warning with L2C-310 caches if the cache size is modified
ARM: l2c: remove old .set_debug method
ARM: l2c: kill L2X0_AUX_CTRL_MASK before anyone else makes use of this
Remove the explicit call to l2x0_of_init(), converting to the generic
infrastructure instead.
The cache size should already be present in the L2 cache auxiliary
control register: it is part of the integration process to configure
the hardware IP. Most platforms get this right, yet still many
cargo-cult program, and assume that they always need specifying to
the L2 cache code. Remove them so we can find out which really need
this.
Enable ARCH_SUPPORTS_BIG_ENDIAN in Kconfig.
zynq_secondary_trampoline is the first function
that is called on secondary CPU.
Reference:
"ARM: mcpm: fix big endian issue in mcpm startup code"
(sha1: 519ceb9fd10cd7e836d0aa97b2068cc9e97f463b)
Fix early printk support. Based on:
"ARM: pl01x debug code endian fix"
(sha1: 76e3faf156fa95b6465e747d702b94faf67117fc)
Keep options sorted.
Provide information through SOC_BUS to user space.
Silicon revision is provided through devcfg device.
Pull ARM SoC late cleanups from Arnd Bergmann:
"These could not be part of the first cleanup branch, because they
either came too late in the cycle, or they have dependencies on other
branches. Important changes are:
- The integrator platform is almost multiplatform capable after some
reorganization (Linus Walleij)
- Minor cleanups on Zynq (Michal Simek)
- Lots of changes for Exynos and other Samsung platforms, including
further preparations for multiplatform support and the clocks
bindings are rearranged"
* tag 'tags/cleanup2-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (54 commits)
devicetree: fix newly added exynos sata bindings
ARM: EXYNOS: Fix compilation error in cpuidle.c
ARM: S5P64X0: Explicitly include linux/serial_s3c.h in mach/pm-core.h
ARM: EXYNOS: Remove hardware.h file
ARM: SAMSUNG: Remove hardware.h inclusion
ARM: S3C24XX: Remove invalid code from hardware.h
dt-bindings: clock: Move exynos-audss-clk.h to dt-bindings/clock
ARM: dts: Keep some essential LDOs enabled for arndale-octa board
ARM: dts: Disable MDMA1 node for arndale-octa board
ARM: S3C64XX: Fix build for implicit serial_s3c.h inclusion
serial: s3c: Fix build of header without serial_core.h preinclusion
ARM: EXYNOS: Allow wake-up using GIC interrupts
ARM: EXYNOS: Stop using legacy Samsung PM code
ARM: EXYNOS: Remove PM initcalls and useless indirection
ARM: EXYNOS: Fix abuse of CONFIG_PM
ARM: SAMSUNG: Move s3c_pm_check_* prototypes to plat/pm-common.h
ARM: SAMSUNG: Move common save/restore helpers to separate file
ARM: SAMSUNG: Move Samsung PM debug code into separate file
ARM: SAMSUNG: Consolidate PM debug functions
ARM: SAMSUNG: Use debug_ll_addr() to get UART base address
Pull ARM SoC cleanups from Arnd Bergmann:
"These cleanup patches are mainly move stuff around and should all be
harmless. They are mainly split out so that other branches can be
based on top to avoid conflicts.
Notable changes are:
- We finally remove all mach/timex.h, after CLOCK_TICK_RATE is no
longer used (Uwe Kleine-König)
- The Qualcomm MSM platform is split out into legacy mach-msm and
new-style mach-qcom, to allow easier maintainance of the new
hardware support without regressions (Kumar Gala)
- A rework of some of the Kconfig logic to simplify multiplatform
support (Rob Herring)
- Samsung Exynos gets closer to supporting multiplatform (Sachin
Kamat and others)
- mach-bcm3528 gets merged into mach-bcm (Stephen Warren)
- at91 gains some common clock framework support (Alexandre Belloni,
Jean-Jacques Hiblot and other French people)"
* tag 'cleanup-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (89 commits)
ARM: hisi: select HAVE_ARM_SCU only for SMP
ARM: efm32: allow uncompress debug output
ARM: prima2: build reset code standalone
ARM: at91: add PWM clock
ARM: at91: move sam9261 SoC to common clk
ARM: at91: prepare common clk transition for sam9261 SoC
ARM: at91: updated the at91_dt_defconfig with support for the ADS7846
ARM: at91: dt: sam9261: Device Tree support for the at91sam9261ek
ARM: at91: dt: defconfig: Added the sam9261 to the list of DT-enabled SOCs
ARM: at91: dt: Add at91sam9261 dt SoC support
ARM: at91: switch sam9rl to common clock framework
ARM: at91/dt: define main clk frequency of at91sam9rlek
ARM: at91/dt: define at91sam9rl clocks
ARM: at91: prepare common clk transition for sam9rl SoCs
ARM: at91: prepare sam9 dt boards transition to common clk
ARM: at91: dt: sam9rl: Device Tree for the at91sam9rlek
ARM: at91/defconfig: Add the sam9rl to the list of DT-enabled SOCs
ARM: at91: Add at91sam9rl DT SoC support
ARM: at91: prepare at91sam9rl DT transition
ARM: at91/defconfig: refresh at91sam9260_9g20_defconfig
Pull timer changes from Thomas Gleixner:
"This assorted collection provides:
- A new timer based timer broadcast feature for systems which do not
provide a global accessible timer device. That allows those
systems to put CPUs into deep idle states where the per cpu timer
device stops.
- A few NOHZ_FULL related improvements to the timer wheel
- The usual updates to timer devices found in ARM SoCs
- Small improvements and updates all over the place"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (44 commits)
tick: Remove code duplication in tick_handle_periodic()
tick: Fix spelling mistake in tick_handle_periodic()
x86: hpet: Use proper destructor for delayed work
workqueue: Provide destroy_delayed_work_on_stack()
clocksource: CMT, MTU2, TMU and STI should depend on GENERIC_CLOCKEVENTS
timer: Remove code redundancy while calling get_nohz_timer_target()
hrtimer: Rearrange comments in the order struct members are declared
timer: Use variable head instead of &work_list in __run_timers()
clocksource: exynos_mct: silence a static checker warning
arm: zynq: Add support for cpufreq
arm: zynq: Don't use arm_global_timer with cpufreq
clocksource/cadence_ttc: Overhaul clocksource frequency adjustment
clocksource/cadence_ttc: Call clockevents_update_freq() with IRQs enabled
clocksource: Add Kconfig entries for CMT, MTU2, TMU and STI
sh: Remove Kconfig entries for TMU, CMT and MTU2
ARM: shmobile: Remove CMT, TMU and STI Kconfig entries
clocksource: armada-370-xp: Use atomic access for shared registers
clocksource: orion: Use atomic access for shared registers
clocksource: timer-keystone: Delete unnecessary variable
clocksource: timer-keystone: introduce clocksource driver for Keystone
