path: root/arch/arm/mm/abort-ev4.S
2015-08-26ARM: entry: provide uaccess assembly macro hooksRussell King
Provide hooks into the kernel entry and exit paths to permit control of userspace visibility to the kernel. The intended use is: - on entry to kernel from user, uaccess_disable will be called to disable userspace visibility - on exit from kernel to user, uaccess_enable will be called to enable userspace visibility - on entry from a kernel exception, uaccess_save_and_disable will be called to save the current userspace visibility setting, and disable access - on exit from a kernel exception, uaccess_restore will be called to restore the userspace visibility as it was before the exception occurred. These hooks allows us to keep userspace visibility disabled for the vast majority of the kernel, except for localised regions where we want to explicitly access userspace. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-02ARM: entry: data abort: tail-call the main data abort handlerRussell King
Tail-call the main C data abort handler code from the per-CPU helper code. Update the comments in the code wrt the new calling and return register state. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-02ARM: entry: data abort: arrange for CPU abort helpers to take pc/psr in r4/r5Russell King
Re-jig the CPU abort helpers to take the PC/PSR in r4/r5 rather than r2/r3. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
