path: root/arch/arm/mm/cache-v4wb.S
2014-07-18ARM: convert all "mov.* pc, reg" to "bx reg" for ARMv6+Russell King
ARMv6 and greater introduced a new instruction ("bx") which can be used to return from function calls. Recent CPUs perform better when the "bx lr" instruction is used rather than the "mov pc, lr" instruction, and this sequence is strongly recommended to be used by the ARM architecture manual (section A.4.1.1). We provide a new macro "ret" with all its variants for the condition code which will resolve to the appropriate instruction. Rather than doing this piecemeal, and miss some instances, change all the "mov pc" instances to use the new macro, with the exception of the "movs" instruction and the kprobes code. This allows us to detect the "mov pc, lr" case and fix it up - and also gives us the possibility of deploying this for other registers depending on the CPU selection. Reported-by: Will Deacon <will.deacon@arm.com> Tested-by: Stephen Warren <swarren@nvidia.com> # Tegra Jetson TK1 Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> # mioa701_bootresume.S Tested-by: Andrew Lunn <andrew@lunn.ch> # Kirkwood Tested-by: Shawn Guo <shawn.guo@freescale.com> Tested-by: Tony Lindgren <tony@atomide.com> # OMAPs Tested-by: Gregory CLEMENT <gregory.clement@free-electrons.com> # Armada XP, 375, 385 Acked-by: Sekhar Nori <nsekhar@ti.com> # DaVinci Acked-by: Christoffer Dall <christoffer.dall@linaro.org> # kvm/hyp Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> # PXA3xx Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> # Xen Tested-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> # ARMv7M Tested-by: Simon Horman <horms+renesas@verge.net.au> # Shmobile Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-09-25ARM: mm: implement LoUIS API for cache maintenance opsLorenzo Pieralisi
ARM v7 architecture introduced the concept of cache levels and related control registers. New processors like A7 and A15 embed an L2 unified cache controller that becomes part of the cache level hierarchy. Some operations in the kernel like cpu_suspend and __cpu_disable do not require a flush of the entire cache hierarchy to DRAM but just the cache levels belonging to the Level of Unification Inner Shareable (LoUIS), which in most of ARM v7 systems correspond to L1. The current cache flushing API used in cpu_suspend and __cpu_disable, flush_cache_all(), ends up flushing the whole cache hierarchy since for v7 it cleans and invalidates all cache levels up to Level of Coherency (LoC) which cripples system performance when used in hot paths like hotplug and cpuidle. Therefore a new kernel cache maintenance API must be added to cope with latest ARM system requirements. This patch adds flush_cache_louis() to the ARM kernel cache maintenance API. This function cleans and invalidates all data cache levels up to the Level of Unification Inner Shareable (LoUIS) and invalidates the instruction cache for processors that support it (> v7). This patch also creates an alias of the cache LoUIS function to flush_kern_all for all processor versions prior to v7, so that the current cache flushing behaviour is unchanged for those processors. v7 cache maintenance code implements a cache LoUIS function that cleans and invalidates the D-cache up to LoUIS and invalidates the I-cache, according to the new API. Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Tested-by: Shawn Guo <shawn.guo@linaro.org>
2012-05-02ARM: 7408/1: cacheflush: return error to userspace when flushing syscall failsWill Deacon
The cacheflush syscall can fail for two reasons: (1) The arguments are invalid (nonsensical address range or no VMA) (2) The region generates a translation fault on a VIPT or PIPT cache This patch allows do_cache_op to return an error code to userspace in the case of the above. The various coherent_user_range implementations are modified to return 0 in the case of VIVT caches or -EFAULT in the case of an abort on v6/v7 cores. Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-07ARM: mm: cache-v4wb: Use the new processor struct macrosDave Martin
Signed-off-by: Dave Martin <dave.martin@linaro.org>
2010-10-28ARM: 6466/1: implement flush_icache_all for the rest of the CPUsMika Westerberg
Commit 81d11955bf0 ("ARM: 6405/1: Handle __flush_icache_all for CONFIG_SMP_ON_UP") added a new function to struct cpu_cache_fns: flush_icache_all(). It also implemented this for v6 and v7 but not for v5 and backwards. Without the function pointer in place, we will be calling wrong cache functions. For example with ep93xx we get following: Unable to handle kernel paging request at virtual address ee070f38 pgd = c0004000 [ee070f38] *pgd=00000000 Internal error: Oops: 80000005 [#1] PREEMPT last sysfs file: Modules linked in: CPU: 0 Not tainted (2.6.36+ #1) PC is at 0xee070f38 LR is at __dma_alloc+0x11c/0x2d0 pc : [<ee070f38>] lr : [<c0032c8c>] psr: 60000013 sp : c581bde0 ip : 00000000 fp : c0472000 r10: c0472000 r9 : 000000d0 r8 : 00020000 r7 : 0001ffff r6 : 00000000 r5 : c0472400 r4 : c5980000 r3 : c03ab7e0 r2 : 00000000 r1 : c59a0000 r0 : c5980000 Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel Control: c000717f Table: c0004000 DAC: 00000017 Process swapper (pid: 1, stack limit = 0xc581a270) [<c0032c8c>] (__dma_alloc+0x11c/0x2d0) [<c0032e5c>] (dma_alloc_writecombine+0x1c/0x24) [<c0204148>] (ep93xx_pcm_preallocate_dma_buffer+0x44/0x60) [<c02041c0>] (ep93xx_pcm_new+0x5c/0x88) [<c01ff188>] (snd_soc_instantiate_cards+0x8a8/0xbc0) [<c01ff59c>] (soc_probe+0xfc/0x134) [<c01adafc>] (platform_drv_probe+0x18/0x1c) [<c01acca4>] (driver_probe_device+0xb0/0x16c) [<c01ac284>] (bus_for_each_drv+0x48/0x84) [<c01ace90>] (device_attach+0x50/0x68) [<c01ac0f8>] (bus_probe_device+0x24/0x44) [<c01aad7c>] (device_add+0x2fc/0x44c) [<c01adfa8>] (platform_device_add+0x104/0x15c) [<c0015eb8>] (simone_init+0x60/0x94) [<c0021410>] (do_one_initcall+0xd0/0x1a4) __dma_alloc() calls (inlined) __dma_alloc_buffer() which ends up calling dmac_flush_range(). Now since the entries in the arm920_cache_fns are shifted by one, we jump into address 0xee070f38 which is actually next instruction after the arm920_cache_fns structure. So implement flush_icache_all() for the rest of the supported CPUs using a generic 'invalidate I cache' instruction. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-15ARM: dma-mapping: remove dmac_clean_range and dmac_inv_rangeRussell King
These are now unused, and so can be removed. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Tested-By: Santosh Shilimkar <santosh.shilimkar@ti.com>
2010-02-15ARM: dma-mapping: provide per-cpu type map/unmap functionsRussell King
2009-12-14ARM: add size argument to __cpuc_flush_dcache_pageRussell King
... and rename the function since it no longer operates on just pages. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-04-07[ARM] Fix SA110/SA1100 cache flushingRussell King
We had two implementations for flushing the cache, which meant StrongARM caches weren't being correctly flushed. Fix this by always using the v4wb_flush_kern_cache_all method, rather than duplicating it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
